120084
120084
    TPI(TPI 公司)
    BNC单排模块
120084 数据手册
BNC ATTENUATORS PART NUMBER AND DESCRIPTION Part No. 120082 120083 120084 120085 120086 Attenuation Impedance Frequency Power APPLICATIONS Increase the input range of an oscilloscope. (dB) (Ohm) (GHz) (Watt) 3 50 0 to 1 1 6 50 0 to 1 1 10 50 0 to 1 1 20 50 0 to 1 1 Attenuator kit containing one each of the above attenuators in a hard case. Reduce the output level of fixed amplitude signal sources. Connect low impedance sources to instruments with high-impedance inputs. SPECIFICATIONS Material: Tin-Zinc-Copper Plating Nominal Impedance: 50Ω Operating Temperature: -50 to 80°C VSWR Deviation: 0.1% over operating temperature range Power Rating: 1W over operating temperature range Peak Power Rating: 100W for 25 microseconds Power Coefficient: 0.001dB/W change in attenuation with power increase Temperature Coefficient: 0.001dB/°C maximum, 0.0003dB/°C typical MECHANICAL Attenuator Dimensions (mm) 120086 Attenuator Kit Case Dimensions (mm)
120084 价格&库存
很抱歉,暂时无法提供与“120084”相匹配的价格&库存,您可以联系我们找货
