AT0603T06ECAC7
AT0603T06ECAC7
    ATC
    ATTENUATOR6DB50OHM0603SMT
AT0603T06ECAC7 数据手册
ATC AT Series 0603 RF/Microwave Attenuator • Thin Film Design • EIA 0603 SMT • Power Rating: 1 watt • Highest Power in Class • Frequency Response +/- 0.5 dB • ALN construction • Characterized to 20 GHz • Non-Magnetic • CPW and Microstrip Applications • RoHs compliant •B  alanced PI design ATC’s new RF / Microwave SMT Attenuator Series (AT) is manufactured with the highest quality materials for reliable and repeatable performance. These devices are constructed with Aluminum Nitride (AlN) and are available in a standard EIA 0603 case size. The AT Series exhibits excellent performance characteristics for the most demanding RF / Microwave applications. The AT provides virtually flat loss over a broad frequency spectrum and is ideal where low noise, low inductance and low parasitic capacitance is required. Thin film metallization provides for very stable characteristics over temperature and time. Its balanced PI design provides even current distribution and accurate attenuation characteristics from DC to 20 GHz. It is designed to meet a wide range of RF and microwave large and small signal level applications. The AT is ideal for impedance matching, input padding, signal level tuning, and many other critical RF / Microwave applications. The AT is rated highest power in class and is suitable for microstrip and CPW applications. The non-magnetic termination is available providing a range of attachment options such as eutectic die-bonding, conductive epoxies, and soldering. The AT is fully compatible with high speed automated pick-and-place processing. Typical applications: Telecommunications, Satellite Communications, Cellular Base Stations, Microwave Radio, ISM, RF / Microwave Power, Military / Aerospace, Test and Measurement. ENVIRONMENTAL SPECIFICATIONS OPERATING TEMPERATURE: -55°C to +150°C 100% inspection Per MIL-STD-883 ELECTRICAL AND MECHANICAL SPECIFICATIONS NOMINAL IMPEDANCE: 50 ohms FREQUENCY RANGE: DC to 20 GHz VALUES AVAILABLE: 3dB, 6dB, 10dB INPUT POWER CW: 1W VSWR: 1.25:1 typical ATTENUATION ACCURACY (dB): 1 to 9 dB: ±0.50 10 dB: ±0.75 SUBSTRATE MATERIAL: AlN RESISTORS: Tantalum Nitride TERMINAL: Thin Film metal stack, Ni/Au Functional applications: Impedance Matching, Input Padding, Signal Level Tuning, Signal Conditioning. Note: Consult Factory for other attenuation values, termination styles and case sizes. THE ENGINEERS’ CHOICE ® www. a tc e ra mi c s . c o m ATC # 001-1149 Rev. A; 4/16 Mechanical Configurations 0.004 0.016 0.005 ø0.003 0.015 ø0.003 0.008 0.024 0.024 0.031 0.031 0.003 0.014 0.010 0.010 0.063 0.063 B FACE A FACE ATC PART NUMBER CODE ATC AT 0603 T 03 E Product Designation Case Size) CA T D Quantity D = 1000 B = 500 7 = 100 3 = 25 Power Rating T=1W Attenuation: 3 dB, 6 dB, 10 dB Packaging T = Tape & Reel: 7’’ reel, 1000 pcs. C = Cap Pack, 100 pcs. S= Snippet Configuration E = All Terminations wrapped and patterned ground plane Termination CA = Non-Mag Gold The above part number refers to an ATC AT 0603 Case Size with an attenuation of 3dB, 1W Power Rating, wrapped and patterned ground plane configuration with Non-Mag Gold Termination and tape and reel packaging, 1000 pcs. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. For additional information and catalogs contact your ATC representative or call direct at (+1-631) 622-4700. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992 Rev. B; 12/05). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC’s website at www.atceramics.com/ productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product without prior notice. © 2016 American Technical Ceramics Corp. All Rights Reserved A M E R I C A N ATC North America sales@atceramics.com 2 ATC # 001-1149 Rev. A; 4/16 T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com www.at c er am ic s .c om
AT0603T06ECAC7 价格&库存
很抱歉,暂时无法提供与“AT0603T06ECAC7”相匹配的价格&库存,您可以联系我们找货
