PXV1220S-10DBN1-T
PXV1220S-10DBN1-T
    SUSUMU
    热敏芯片衰减器
PXV1220S-10DBN1-T 数据手册
Components Temperature compensated chip attenuators ■ P*V series Features ● For simplifying temperature drift compensation of GaAs high frequency amplifiers ● Excellent high frequency characteristics Applications ● Base station and others ※ Except for  Chinese RoHS Specifications *All made to order. ▪ Dimensions 0.65 0.70 0.65 ±0.35 ±0.2 ±0.35 ▪ Equivalent circuits 0.9±0.2 0.35±0.2 PXV1220S 0.55±0.2 1.25±0.2 0.35±0.2 2.0±0.2 1.5max 1.0±0.2 0.55±0.25 0.4±0.2 PBV1632S 1.60±0.2 0.4±0.2 0.4±0.2 3.2±0.2 0.4±0.1 3.2±0.2 Front side Back side (unit:mm) Series name PXV1220S (0805) Attenuation 1, 2, 3, 4, 5, 6, 7, 8, 9, 10dB PBV1632S (1206) Attenuation tolerance 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 16dB ±0.5dB(@25 ℃, no load) Impedance * P V series 50Ω VSWR 1.3max. Temperature coefficient of attenuation ex : N1 N2 N3 N4 N1 〜 N8 (1 〜 3dB : N1 〜 N9) 6dB 0.0119dB/dB*℃ 0.0088dB/dB*℃ 0.0062dB/dB*℃ 0.0047dB/dB*℃ Operating frequency N5 N6 N7 N8 0.0041dB/dB*℃ 0.0035dB/dB*℃ 0.0026dB/dB*℃ 0.0019dB/dB*℃ DC〜 3GHz Rated power 63mW Operating temperature Packaging High frequency surface mount components ▪ Electrical characteristics 100mW −40 ℃〜+100 ℃ 100pcs/bag 200pcs/reel 1,000pcs/reel min.20pcs/bag 1,000pcs/reel ・Refer to the data book for details. Part numbering system PXV 1220S - 6dB N1 - T Packaging(T02=200, T1=1,000, B=Bulk) Temperature coefficient of attenuation Attenuation Size Product code 26
PXV1220S-10DBN1-T
1. 物料型号:文档中提到了两种型号,PXV1220S和PBV1632S,分别对应0805和1206尺寸。
2. 器件简介:这些芯片衰减器用于简化GaAs高频放大器的温度漂移补偿,具有出色的高频特性,并且符合RoHS标准(除中国RoHS外)。
3. 引脚分配:文档中没有提供具体的引脚分配图,但通常这类表面贴装组件会有明确的引脚定义。
4. 参数特性: - 衰减值:PXV1220S提供1至10dB的衰减,而PBV1632S提供1至10dB和16dB的衰减。 - 衰减容差:±0.5dB(在25°C,无负载条件下)。 - 阻抗:500欧姆。 - 电压驻波比(VSWR):最大1.3。 - 衰减的温度系数:例如,6dB衰减的温度系数从N1到N8为1~3dB,N10为0.0119dB/dB°C等。
5. 功能详解:文档中提到了这些衰减器在直流至3GHz的频率范围内工作,额定功率分别为63mW和100mW,并在-40°C至+100°C的温度范围内操作。
6. 应用信息:这些衰减器适用于基站等应用。
7. 封装信息:PXV1220S的封装尺寸为0.70 x 0.65 x 0.65mm,PBV1632S的尺寸为3.2 x 1.0 x 0.4mm。封装方式包括每袋100个、每卷200个、每卷1000个等。
PXV1220S-10DBN1-T 价格&库存
很抱歉,暂时无法提供与“PXV1220S-10DBN1-T”相匹配的价格&库存,您可以联系我们找货
