ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
DATE
APPROVED
E
DCN 41727
10/15
DAL
F
DCN 43286
04/17
STW
REV
PRODUCT DATA DRAWING
1.210 30.73 MAX
2X .250
ACROSS FLATS
MATERIAL:
.370 9.40
BODY &
COUPLING NUT:
LOCK RING &
CONTACTS
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1, OR ASTM A582,
TYPE 303
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
SLEEVE:
BRASS PER ASTM B16, ALLOY UNS No. C36000
BELLOWS SPRING:
ELECTRO DEPOSITED NICKEL: GOLD PLATED
INSULATORS:
PTFE PER ASTM D1710, TYPE I, GRADE 1,
CLASS B
GASKET:
SILICONE RUBBER PER A-A-59588,
CLASS 2B, GRADE 60/70
RESISTOR ELEMENT:
.312 HEX.
1/4-36 UNS-2A
ELECTRICAL CHARACTERISTICS
VSWR
ALUMINUM NITRIDE SUBSTRATE WITH
TANTALUM NITRIDE RESISTOR: GOLD PLATED
TERMINATIONS
ATTENUATOR ATTENUATION
INCREMENT
ACCURACY DC TO 4 GHz 4 TO 12.4 GHz
(dB)
(dB)
NOTES:
FINISH:
BODY &
COUPLING NUT:
CONTACTS
& SLEEVE:
0 TO .5
1. REPLACE "XX" IN PART NUMBER WITH
DESIRED dB VALUE.
PASSIVATED PER AMS-2700
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
PERFORMANCE:
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
IMPEDANCE:
FREQ. RANGE:
1 TO 6
7 TO 15
16 TO 20
30 TO 40
50 OHMS
DC TO 18.0 GHz
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
+0.00
-0.30
+/-.3
+/-.5
+/-.7
+/-1.00
1.15
1.25
12.4 TO 18.0
GHz
1.35
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
GPF 10/02/15
CHECKED:
APPROVED:
DAL 10/02/15
JM 03/18/96
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMA JACK TO PLUG DC-18.0
GHz ATTENUATOR
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 4:1
SF0930-6200-XX
SHEET 1 OF 1
很抱歉,暂时无法提供与“SF0930-6200-03”相匹配的价格&库存,您可以联系我们找货
