SF0929-6200-2X
SF0929-6200-2X
    AMPHENOLSVMICROWAVE(安费诺MAO)
    SMA单排模块
    ATTENUATOR18GHZ50OHMSMA
SF0929-6200-2X 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 38051 DATE APPROVED 03/11 PJS "A" MAX. .312 7.92 HEX MATERIAL: BODIES, COUPLING NUT: LOCK RINGS, CONTACTS: .330 8.38 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 .298 7.56 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 SLEEVE: BRASS PER ASTM B16, ALLOY UNS No. C36000 BELLOWS: ELECTRO-DEPOSITED GOLD OVER NICKEL INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B GASKETS: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 RESISTOR ELEMENTS: ALUMINA SUBSTRATE WITH TANTALUM NITRIDE RESISTOR 1/4-36 UNS-2A .250 [6.35] ACROSS 2 FLATS FINISH: BODIES, COUPLING NUT: CONTACTS, SLEEVE: TABLE 1 dB VALUE PASSIVATED PER AMS-2700, TYPE 2 0 dB 0.5-6.5 dB 7-8.5 dB 9-14.5 dB 15-20 dB 21-29 dB 30-39 dB 40 dB 50 dB GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: OPERATING TEMP.: AVG. POWER: PEAK POWER: ENGAGEMENT/ DISENGAGEMENT: 50 OHMS DC TO 18.0 GHz SEE TABLE 1 -55 C TO +125 C 2 WATT (POWER INPUT DERATED LINEARLY FROM 25 C TO 0.5 WATTS AT 125 C) 500 WATTS (PEAK POWER FOR A DUTY CYCLE OF 5X10-4 MAXIMUM PULSE DURATION OF 5 MICROSECONDS) FINISH: 2 IN-LBS SURFACE AREA: MATERIAL: VSWR ATTENUATION ACCURACY DC-2 GHz 2-4 GHz 4-8 GHz 8-12.4 GHz 12.4-18 GHz +0 /-0.3 dB 0.3 dB 0.4 dB 0.5 dB 0.6 dB 1.10:1 1.15:1 1.20:1 1.25:1 1.35:1 1.0 dB 1.0 dB 1.0 dB 2.0 dB SEE NOTES SEE NOTES N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 03/07/11 CHECKED: APPROVED: PJS 03/07/11 PJS 03/07/11 "A" DIM. .870 .870 .870 .870 .870 1.040 1.040 1.040 1.350 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA PLUG TO JACK MICRO ATTENUATOR DC TO 18 GHz SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF0929-6200-XXX SHEET 1 OF 2 ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 38051 DATE APPROVED 03/11 PJS MAY VARY FROM 1 CHARACTER TO 3 CHARACTERS dB VALUE TO "XXX" NUMBER CHART MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 03/07/11 CHECKED: APPROVED: PJS 03/07/11 PJS 03/07/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA PLUG TO JACK MICRO ATTENUATOR DC TO 18 GHz SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF0929-6200-XXX SHEET 2 OF 2
SF0929-6200-2X 价格&库存
很抱歉,暂时无法提供与“SF0929-6200-2X”相匹配的价格&库存,您可以联系我们找货
