Midwest Microwave
Attenuator
kwiQMAte™
QMA Attenuator
Emerson Network Power Connectivity Solutions offers the
Midwest Microwave line of QMA attenuators featuring a pushon style SMA interface. This line of attenuators integrates the
kwiQMAte™ interface into its industry leading high quality and
performance line of microwave attenuators. These attenuators
are offered as an alternative to standard SMA versions for new
generation Telecom Base Stations and Mil-Aero applications
with requirements for quick and secure low force mating in
higher density configurations with space constraints.
Replacing standard threaded SMA designs with the
kwiQMAte™ snap-lock mechanism allow for increased
packaging density as torque wrench clearance space is no
longer required.
Our unique snap-lock mating design provides excellent
electrical performance and low VSWR. The kwiQMAte™
interface meets or exceeds the performance requirements of
MIL-PRF-39012. These attenuators are 50 ohm devices which
operate to 6.0 GHz. The attenuator bodies are constructed of
brass with Tri-Alloy plating as a standard finish. All contacts are
plated with 50 micro-inches of gold for excellent durability and
performance in high frequency mating environments.
Key Features & Benefits
Excellent VSWR and attenuation accuracy
Compact, high quality design
Ideal for high density packaging applications
High performance kwiQMAte™ interface
Offered from stock in 1, 2, 3, 6 & 10 dB
values with other dB values(1-30dB)
available upon request
Materials
Rugged Brass Tri-Alloy Construction
BeCu spring construction
All dimensions are inches
Technical Drawing
Technical Specifications
Performance
Impedance:
50 Ohms
Frequency Range:
0-6 GHz
Attenuation Values:
1, 2, 3, 6, and 10 dB Nominal*
Attenuation Accuracy:
+/-0.5
VSWR Max:
1.30
Average Input Power:
2 W Max @ +25°C, Derated Linearly to 0.5W at +125°C
Temperature range
-55 to +125C
Shock
MIL-STD-202, Method 213, Condition I
Thermal Shock
MIL-STD-202, Method 107, Condition B ( except +85°C high temperature)
Vibration Sinusoidal
MIL-STD-202, Method 204, Condition D
Midwest Microwave
299 Johnson Ave.
Waseca, MN 56093
1-800-247-8256
Whilst due care has been taken to ensure the contents of this data sheet are
accurate, Emerson Network Power Connectivity Solutions cannot accept
liability for any errors or omissions that may occur. We reserve the right to
alter specifications of products without prior notice.
Emerson Network Power and the Emerson
Network Power logo are trademarks and
service marks of Emerson Electric Co.
©2013 Emerson Electric Co.
pi-QMAAttenuator.pdf
很抱歉,暂时无法提供与“ATT-0106-06-QMA-32”相匹配的价格&库存,您可以联系我们找货
