ATT-0313-10-BNC-10
ATT-0313-10-BNC-10
    CINCH
    BNC单排模块
    ATTENUATOR 10 DB DC 4GHZ
ATT-0313-10-BNC-10 数据手册
Attenuators BNC Type DC - 4 GHz Performance Frequency: DC - 4.0 GHz and DC - 2.0 units available Attenuation Values: 1 - 40 dB as noted Attenuation Accuracy: 1 - 6 dB + 0.3 dB 7 - 10 dB 11 - 20 dB 21 - 40 dB 41-60 dB + 0.5 dB + 0.75 dB + 1.0 dB ± 1.5 dB Impedance: 50 Ohms VSWR: 1.25 max Power: 2 Watts average @ +25 oC derated linearly to 0.5 Watts @ +125 oC U.O.S. Peak Power: 200 Watts for 2Watt units and 100 Watts Peak for 5 & 10 Watt Operating Temperature Range: -54C to +125C Finish: Nickel Plated Brass and Black Anodized Aluminum DC - 4.0 GHz Male / Female ATT-0313-XX-BNC-10 313 Series Female / Female ATT-313F-XX-BNC-10 Model Number Male / Male ATT-313M-XX-BNC-10 Attenuation Value = XX, Select 1 - 60 dB in 1 dB increments DC - 2.0 GHz Male/Female ATT-0314-XX-BNC-10 314 Series Female/Female ATT-314F-XX-BNC-10 Attenuation Value 1 - 20 dB 21 - 60 dB Length A 1.36 1.65 Attenuation Value 1 - 20 dB 21 - 60 dB Length A 1.43 1.72 Attenuation Value 1 - 20 dB 21 - 60 dB Length A 1.55 1.84 Model Number Male/Male ATT-314M-XX-BNC-10 Attenuation Value = XX, Select 1 - 60 dB in 1 dB increments DC - 4.0 GHz 581 Series Male/Female Female/Female ATT-0581-XX-BNC-07 ATT-581F-XX-BNC-07 Model Number Male/Male ATT-581M-XX-BNC-07 Attenuation Value = XX, Select 1 - 60 dB in 1 dB increments 5 Watts DC - 4.0 GHz 582 Series Male/Female Female/Female ATT-0582-XX-BNC-07 ATT-582F-XX-BNC-07 Model Number Male/Male ATT-582M-XX-BNC-07 Attenuation Value = XX, Select 1 - 60 dB in 1 dB increments 10 Watts 31
ATT-0313-10-BNC-10
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:适用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
ATT-0313-10-BNC-10 价格&库存
很抱歉,暂时无法提供与“ATT-0313-10-BNC-10”相匹配的价格&库存,您可以联系我们找货
