M3933/16-51N
M3933/16-51N
    CINCH
    SMA单排模块
    ATTENUATORSMAQPL
M3933/16-51N 数据手册
REV J K L ECO 23703 25016 25125 DATE 7/15/2011 1/31/2014 7/18/2014 O .385 MAX #### YYWW S IV MFR 340 3933/16-AAA SMA FEMALE PER MIL-STD-348 FIG. 310-2 18.0 GHz 2 W 2X TORQUE STRIP 2X EPOXY SEAL SMA MALE PER MIL-STD-348 FIG. 310-1 "A" NOTES: UNLESS OTHERWISE SPECIFIED. 1. MATERIAL & FINISH: 1.1 BODY: PASSIVATED STAINLESS STEEL 1.2 DIELECTRIC: PTFE (TEFLON) 1.3 CENTER CONTACT: GOLD PLATED BERYLLIUM COPPER 1.5 GASKET: SILICONE RUBBER 2. SPECIFICATIONS: 2.1 FREQUENCY RANGE: DC - 18 GHz 2.2 INPEDANCE: 50 OHMS NOMINAL 2.3 VSWR (MAX) BOTH ENDS: DC - 4.0 GHz: 1.15:1 4.0 - 8.0 GHz: 1.20:1 8.0 - 12.4 GHz: 1.25:1 12.4 - 18 GHz: 1.35:1 2.4 ATTENUATION ACCURACY: 0 - 2.5 dB: u0.4 dB 3 - 6.5 dB: u0.3 dB 7 - 15.5 dB: u0.5 dB 16 - 28 dB: u0.7 dB 30 - 40 dB: u1.0 dB 2.5 MAXIMUM INPUT POWER 2.5.1 AVERAGE: 2 WATTS AT 25vC DERATED LINEARLY TO 0.5 WATTS AT 125vC 2.5.2 PEAK: 500 WATTS FOR A DUTY CYCLE OF 5x10^-4, MAX PULSE DURATION OF 5 MICROSECONDS 2.6 OPERATING TEMP RANGE: -55vC TO 125vC 2.7 WEIGHT (MAX): 2.7.1 0 - 25 dB: 0.5 oz 2.7.2 28 dB: 0.7 oz 2.7.3 34 - 40 dB: 0.8 oz 3. TORQUE STRIP (SCREENED MODELS ONLY): 3.1 ENTHONE M-9-N WHITE/CATALYST B-3, TML = 0.51%, CVCM = 0.4% MODEL NO. (N OR S) M3933/16-01 M3933/16-02 M3933/16-03 M3933/16-04 M3933/16-05 M3933/16-06 M3933/16-07 M3933/16-08 M3933/16-09 M3933/16-10 M3933/16-11 M3933/16-12 M3933/16-13 M3933/16-16 M3933/16-17 M3933/16-18 M3933/16-19 M3933/16-20 M3933/16-21 dB VALUE 3 6 10 20 1 2 4 5 7 8 9 30 40 0 0.5 1.5 2.5 3.5 4.5 MODEL NO. (N OR S) M3933/16-22 M3933/16-23 M3933/16-24 M3933/16-25 M3933/16-26 M3933/16-27 M3933/16-28 M3933/16-29 M3933/16-30 M3933/16-31 M3933/16-32 M3933/16-33 M3933/16-34 M3933/16-35 M3933/16-36 M3933/16-37 M3933/16-38 M3933/16-39 M3933/16-40 dB VALUE 5.5 6.5 7.5 8.5 9.5 10.5 11 11.5 12 12.5 13 13.5 14 14.5 15 15.5 16 16.5 17 MODEL NO. (N OR S) M3933/16-41 M3933/16-42 M3933/16-43 M3933/16-44 M3933/16-45 M3933/16-46 M3933/16-47 M3933/16-48 M3933/16-49 M3933/16-50 M3933/16-51 M3933/16-52 M3933/16-53 M3933/16-54 M3933/16-55 M3933/16-56 M3933/16-57 M3933/16-58 dB VALUE 17.5 18 18.5 19 19.5 20.5 21 21.5 22 22.5 23 23.5 24 24.5 25 28 32 36 dB VALUE 0 - 25 30 -40 "A" MAX 1.24 1.85 Model No. M3933/16-XX(N OR S) Cage Code RoHS2 This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permissi on and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 2011/65/EU 34078 QPL ATTENUATOR 3RD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED: UNITS: INCH .XX u.02 .XXX u.005 ANGLES u2v MIDWEST MICROWAVE Title: Drawing No. Drawn by: C. WALLACE Size Date: 7/22/2014 Rev. M3933/16-XX(N OR S)-01 B DO NOT SCALE DRAWING Workmanship Std: NONE L Sheet 1 of 1
M3933/16-51N
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款用于红外遥控系统的接收器,具有高灵敏度和低功耗的特点。
3. 引脚分配:EL817共有3个引脚,分别为Vcc、GND和Out。
4. 参数特性:工作电压范围为3-6V,工作电流为1.5mA,接收频率为38kHz。
5. 功能详解:EL817能够接收红外信号并输出相应的电信号。
6. 应用信息:广泛应用于电视、空调等家用电器的遥控系统中。
7. 封装信息:EL817采用SOP-8封装。
M3933/16-51N 价格&库存
很抱歉,暂时无法提供与“M3933/16-51N”相匹配的价格&库存,您可以联系我们找货
