ATT-0550-20-35M-02
ATT-0550-20-35M-02
    CINCH
    3.5mm单排模块
    ATTENUATOR 20 DB DC 26.5GHZ
ATT-0550-20-35M-02 数据手册
Attenuators DC - 4.0 GHz Male/Female ATT-0278-XX-SMA-02 SMA Ultraminiature Type 278 Series Model Numbers Female/Female ATT-278F-XX-SMA-02 Male/Male ATT-278M-XX-SMA-02 XX = Attenuation Value: Select 01-30dB in 1dB increments (.5 dB increments available) DC - 2.0 GHz 279 Series Male/Female Female/Female ATT-0279-XX-SMA-02 ATT-279F-XX-SMA-02 Model Numbers Male/Male ATT-279M-XX-SMA-02 XX = Attenuation Value: Select 01-30dB in 1dB increments (.5 dB increments available) DC - 26.5 GHz 3.5mm High Performance • • • • • • Extended Frequency Performance 0 - 20 dB Attenuation Values 3.5 mm Precision Connectors (mates with SMA) Small Size - Light Weight Any Male/Female Connector Configuration Rugged Stainless Steel Construction Midwest Microwave's 3.5 mm subminiature series of precision fixed coaxial attenuators provide extended frequency operation of up to 26.5 GHz when mated with connector interfaces of the same family. These temperature stable, ruggedly built, precision attenuators allow high performance in a very small light weight package size. Attenuation values up through 20 dB in 1 dB increments are available with any combination of female or male 3.5mm connectors. SPECIFICATIONS - HIGH PERFORMANCE VSWR: 1.07 + 0.015 f (GHz) Frequency: DC - 18.0, DC - 26.5 GHz Power: 2 Watts Average @ +25 oC derated linearly to .5 watts @ +125 oC Attenuation Accuracy: 1-6 dB + 0.5 dB Peak Power: 200 Watts 7-20 dB + 0.7 dB Operating Temp Range: - 65 to + 125C Finish: Passivated Stainless Steel DC - 26.5 GHz 550 Series Male/Female Female/Female ATT-0550-XX-35M-02 ATT-550F-XX-35M-02 Model Numbers Male/Male 1.36 ATT-550M-XX-35M-02 XX = Attenuation Value: Select 01-20dB in 1dB increments (.5 dB increments available) 26.5 GHz Extended Frequency Performance Note: dimensions shown above are for the Male/Female version. The length for the Female/Female version is 1.33 and for the Male/Male version is 1.39. Note: For DC - 18.0 GHz Model, subsitute "551" for "550" in Model No. 17
ATT-0550-20-35M-02 价格&库存
很抱歉,暂时无法提供与“ATT-0550-20-35M-02”相匹配的价格&库存,您可以联系我们找货
