410-279
410-279
    DIGILENT(迪芝伦)
    BOARD DEV ZYBO ZYNQ-7000
410-279 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com ZYBO™ FPGA Board Reference Manual Revised April 11, 2016 This manual applies to the ZYBO rev. B Overview The ZYBO (ZYnq BOard) is a feature-rich, ready-to-use, entry-level embedded software and digital circuit development platform built around the smallest member of the Xilinx Zynq-7000 family, the Z-7010. The Z-7010 is based on the Xilinx All Programmable System-on-Chip (AP SoC) architecture, which tightly integrates a dual-core ARM Cortex-A9 processor with Xilinx 7-series Field Programmable Gate Array (FPGA) logic. When coupled with the rich set of multimedia and connectivity peripherals available on the ZYBO, the Zynq Z-7010 can host a whole system design. The on-board memories, video and audio I/O, dual-role USB, Ethernet, and SD slot will have your design up-and-ready with no additional hardware needed. Additionally, six Pmod ports are available to put any design on an easy growth path. The Zynq 7010 AP SoC offers the following features:      650Mhz dual-core Cortex-A9 processor DDR3 memory controller with 8 DMA channels High-bandwidth peripheral controllers: 1G Ethernet, USB 2.0, SDIO Low-bandwidth peripheral controller: SPI, UART, CAN, I2C Reprogrammable logic equivalent to Artix-7 FPGA o 4,400 logic slices, each with four 6-input LUTs and 8 flip-flops o 240 KB of fast block RAM o Two clock management tiles, each with a phase-locked loop (PLL) and mixed-mode clock manager (MMCM) o 80 DSP slices o Internal clock speeds exceeding 450MHz o On-chip analog-to-digital converter (XADC) DOC#: 502-279 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 26 ZYBO™ FPGA Board Reference Manual              The ZYBO Zynq-7000 development board. ZYNQ XC7Z010-1CLG400C 512MB x32 DDR3 w/ 1050Mbps bandwidth Dual-role (Source/Sink) HDMI port 16-bits per pixel VGA source port Trimode (1Gbit/100Mbit/10Mbit) Ethernet PHY MicroSD slot (supports Linux file system) OTG USB 2.0 PHY (supports host and device) External EEPROM (programmed with 48-bit globally unique EUI-48/64™ compatible identifier) Audio codec with headphone out, microphone and line in jacks 128Mb Serial Flash w/ QSPI interface On-board JTAG programming and UART to USB converter GPIO: 6 pushbuttons, 4 slide switches, 5 LEDs Six Pmod ports (1 processor-dedicated, 1 dual analog/digital, 3 high-speed differential, 1 logicdedicated) The ZYBO is compatible with Xilinx's new high-performance Vivado Design Suite as well as the ISE/EDK toolset. These toolsets meld FPGA logic design with embedded ARM software development into an easy to use, intuitive design flow. They can be used for designing systems of any complexity, from a complete operating system running multiple server applications in tandem, down to a simple bare-metal program that controls some LEDs. An accessory kit that contains a 5V/2.5A power adapter, a USB A to Micro B cable, an 8GB speed class 10 microSD card, and a Xilinx voucher for a Vivado Design Suite license will be available to purchase separately off of the Digilent website in the near future. The Vivado Design Suite license enables use of the Logic Analyzer tools, which accelerate debug and testing. This license is a 1 year, device-locked license, and will only work with the Z-7010 Zynq part on the ZYBO. After the license expires, any version of Vivado Design Suite that was released during this 1 year period can continue to be used indefinitely. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 26 ZYBO™ FPGA Board Reference Manual 27 28 26 25 24 23 22 21 20 1 2 19 3 4 18 5 17 6 16 7 15 8 9 10 11 13 12 14 Callout Component Description Callout Component Description 1 Power Switch 15 Processor Reset Pushbutton 2 Power Select Jumper and battery header 16 Logic configuration reset Pushbutton 3 Shared UART/JTAG USB port 17 Audio Codec Connectors 4 MIO LED 18 Logic Configuration Done LED 5 MIO Pushbuttons (2) 19 Board Power Good LED 6 MIO Pmod 20 JTAG Port for optional external cable 7 USB OTG Connectors 21 Programming Mode Jumper 8 Logic LEDs (4) 22 Independent JTAG Mode Enable Jumper 9 Logic Slide switches (4) 23 PLL Bypass Jumper 10 USB OTG Host/Device Select Jumpers 24 VGA connector 11 Standard Pmod 25 microSD connector (Reverse side) 12 High-speed Pmods (3) 26 HDMI Sink/Source Connector 13 Logic Pushbuttons (4) 27 Ethernet RJ45 Connector 14 XADC Pmod 28 Power Jack Table 1. ZYBO Device Diagram. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 26 ZYBO™ FPGA Board Reference Manual 1 Power Supplies The ZYBO can be powered from the Digilent USB-JTAG-UART port (J11), or from an external power supply. Jumper JP7 (near the power switch) determines which power source is used. There are three valid configurations for this jumper corresponding to the three powering options: USB, wall wart with barrel jack, and battery pack. There is a diagram on the board silkscreen indicating all three. All on-board power supplies are enabled or disabled by the power switch SW4. The power indicator LED (LD11) is on when all the supply rails reach their nominal voltage. An overview of the power circuit is shown in Fig.2 Power Jack (J15) VU5V0 Power Switch (SW4) JP7 J14 VIN R281 PVIN5 1.5A 3.3V (III) PVIN1-4 2.1A 1.0V (I) EN 1.2A 0.6A 1.5V (III) 1.8V (II) 0.1A 1.8V (III, analog) D13 Micro-USB Port (J11) IC27: ADR127 Power-on Reset PGOOD IC26: ADP5052 Power Source Select 1.25V (III) REF Power On LED (LD11) JP7 J14 USB WALL BATTERY VIN 0.1A 3.3V (IV, analog) EN IC6: ADP150 Figure 2. Power circuit overview. A USB 2.0 port can deliver maximum 0.5A of current according to the specifications. This should provide enough power for lower complexity designs. An idling blank board consumes around 0.2A from the 5V input supply. As an example, the standalone lwIP echo server sample project replying to ping requests consumes 0.38A on average. More demanding applications, including any that drive multiple peripheral boards or other USB devices, might require more power than the USB port can provide. In this case, power consumption will increase until it’s limited by the USB host. This limit varies a lot between manufacturers and depends on many factors. When in current limit, once the voltage rails dip below their nominal value, the Zynq is reset by the Power-on Reset signal and power consumption returns to its idle value. Also, some applications may need to run without being connected to a PC’s USB port. In these instances an external power supply or battery pack can be used. An external power supply (wall wart) can be used by plugging into to the power jack (J15) and setting jumper JP7 to "wall". The supply must use a coax, center-positive 2.1mm internal-diameter plug, and deliver 4.5VDC to 5.5VDC and at least 2.5A of current (i.e., at least 12.5W of power). Suitable supplies can be purchased from the Digilent website or through catalog vendors like DigiKey. Power supply voltages above 6VDC might cause permanent damage. An external battery pack can be used by connecting the battery’s positive terminal to the center pin of JP7 and the negative terminal to the pin labeled J14 next to JP7. The external battery pack must be limited to 5.5VDC. The minimum voltage of the battery pack depends on the application: if the USB Host (J10) or HDMI Source (J8) function is used, at least 4.6V need to be provided. In other cases the minimum voltage is 3.6V. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 26 ZYBO™ FPGA Board Reference Manual Voltage regulator circuits from Analog Devices create the required 3.3V, 1.8V, 1.5V, and 1.0V supplies from the main power input. Table 2 provides additional information (typical currents depend strongly on FPGA configuration and the values provided are typical of medium size/speed designs). Supply Circuits Device Current (max/typical) 3.3V FPGA I/O, USB ports, Clocks, Ethernet, SD slot, Flash, HDMI IC26#1: ADP5052 2.5A/0.1A to 1.5A 1.0V FPGA, Ethernet Core IC26#2: ADP5052 2.5A/0.2A to 2.1A 1.5V DDR3 IC26#3: ADP5052 1.2A/0.1A to 1.2A 1.8V FPGA Auxiliary, Ethernet I/O, USB OTG IC26#4: ADP5052 1.2A/0.1A to 0.6A 1.8V XADC Analog IC26#5: ADP5052 200mA/20mA 3.3V Audio Analog IC6: ADP150 150mA/50mA 1.25V XADC Precision Reference IC27: ADR127 5mA/50uA Table 2. ZYBO power supplies. The supply rails are daisy-chained to follow the Xilinx-recommended start-up sequence. Flicking the power switch (SW4) will enable the 1.0V rail, which enables the 1.8V digital supply rail, which in turn enables the I/O supply rails 3.3V and 1.5V. The 1.25V reference and 1.8V analog supply ramp together with the 3.3V rail. Once all the channels of the ADP5052 (IC26) supply reach regulation, the PGOOD signal will assert, enabling the 3.3V audio supply, lighting up the power LED (LD11), and de-asserting the Power-On Reset signal (PS_POR_B) of the Zynq. Each power supply uses a soft-start ramp of 1-10ms to limit in-rush current. There is an additional delay of at least 130ms after the power rails reach regulation and before the Power-On Reset signal de-assert to allow for the PS_CLK (IC22) to stabilize. 2 Zynq AP SoC Architecture The Zynq AP SoC is divided into two distinct subsystems: The Processing System (PS), and the Programmable Logic (PL). Figure 3 shows an overview of the Zynq AP SoC architecture, with the PS colored light green and the PL in yellow. Note that the PCIe Gen2 controller and Multi-gigabit transceivers are not available on the Zynq-7010 device. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 5 of 26 ZYBO™ FPGA Board Reference Manual Figure 3. Zynq AP SoC architecture. The PL is nearly identical to a Xilinx 7-series Artix FPGA, except that it contains several dedicated ports and buses that tightly couple it to the PS. The PL also does not contain the same configuration hardware as a typical 7-series FPGA, and it must be configured either directly by the processor or via the JTAG port. The PS consists of many components, including the Application Processing Unit (APU, which includes 2 Cortex-A9 processors), Advanced Microcontroller Bus Architecture (AMBA) Interconnect, DDR3 Memory controller, and various peripheral controllers with their inputs and outputs multiplexed to 54 dedicated pins (called MultiplexedI/O, or MIO pins). Peripheral controllers that do not have their inputs and outputs connected to MIO pins can instead route their I/O through the PL, via the Extended-MIO (EMIO) interface. The peripheral controllers are connected to the processors as slaves via the AMBA interconnect, and contain readable/writable control registers that are addressable in the processors’ memory space. The programmable logic is also connected to the interconnect as a slave, and designs can implement multiple cores in the FPGA fabric that each also contain addressable control registers. Furthermore, cores implemented in the PL can trigger interrupts to the processors (connections not shown in Fig. 3) and perform DMA accesses to DDR3 memory. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 6 of 26 ZYBO™ FPGA Board Reference Manual There are many aspects of the Zynq AP SoC architecture that are beyond the scope of this document. For a complete and thorough description, refer to the Zynq Technical Reference Manual, available at www.xilinx.com. Figure 3 depicts the external components connected to the MIO pins of the ZYBO. The Zynq Board Definition File found on the Digilent ZYBO product page can be imported into EDK and Vivado Designs to properly configure the PS to work with these peripherals. MIO 500 3.3 V Peripherals Peripherals Peripherals Pin Pmod SPI Flash GPIO 0 JF7 1 CS 2 DQ0 3 DQ1 4 DQ2 5 DQ3 6 SCLK 7 LED4 8 SLCK FB 9 JF8 10 JF2 11 JF3 12 JF4 13 JF1 14 JF9 15 JF10 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 7 of 26 ZYBO™ FPGA Board Reference Manual MIO 501 1.8V Pin Peripherals ENET 0 16 TXCK 17 TXD0 18 TXD1 19 TXD2 20 TXD3 21 TXCTL 22 RXCK 23 RXD0 24 RXD1 25 RXD2 26 RXD3 27 RXCTL USB 0 28 DATA4 29 DIR 30 STP 31 NXT 32 DATA0 33 DATA1 34 DATA2 35 DATA3 36 CLK 37 DATA5 38 DATA6 39 DATA7 SDIO 0 40 CCLK 41 CMD 42 D0 43 D1 44 D2 45 D3 46 UART 1 GPIO RESETN 47 CD 48 RXD 49 TXD 50 BTN4 51 BTN5 52 MDC 53 MDIO Table 3. MIO Pinout. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 8 of 26 ZYBO™ FPGA Board Reference Manual 3 Zynq Configuration Unlike Xilinx FPGA devices, AP SoC devices such as the Zynq-7010 are designed around the processor, which acts as a master to the programmable logic fabric and all other on-chip peripherals in the processing system. This causes the Zynq boot process to be more similar to that of a microcontroller than an FPGA. This process involves the processor loading and executing a Zynq Boot Image, which includes a First Stage Bootloader (FSBL), a bitstream for configuring the programmable logic (optional), and a user application. The boot process is broken into three stages: Stage 0 After the ZYBO is powered on or the Zynq is reset (in software or by pressing PS-SRST), one of the processors (CPU0) begins executing an internal piece of read-only code called the BootROM. If and only if the Zynq was just powered on, the BootROM will first latch the state of the mode pins into the mode register (the mode pins are attached to JP5 on the ZYBO). If the BootROM is being executed due to a reset event, then the mode pins are not latched, and the previous state of the mode register is used. This means that the ZYBO needs a power cycle to register any change in the programming mode jumper (JP5). Next, the BootROM copies an FSBL from the form of non-volatile memory specified by the mode register to the 256 KB of internal RAM within the APU (called On-Chip Memory, or OCM). The FSBL must be wrapped up in a Zynq Boot Image in order for the BootROM to properly copy it. The last thing the BootROM does is hand off execution to the FSBL in OCM. Stage 1 During this stage, the FSBL first finishes configuring the PS components, such as the DDR memory controller. Then, if a bitstream is present in the Zynq Boot Image, it is read and used to configure the PL. Finally, the user application is loaded into memory from the Zynq Boot Image, and execution is handed off to it. Stage 2 The last stage is the execution of the user application that was loaded by the FSBL. This can be any sort of program, from a simple “Hello World” design, to a Second Stage Boot loader used to boot an operating system like Linux. For a more thorough explanation of the boot process, refer to Chapter 6 of the Zynq Technical Reference Manual. The Zynq Boot Image is created using Vivado and Xilinx Software Development Kit (Xilinx SDK). For a tutorial on how to build an image using these tools that properly targets the ZYBO, download the ZYBO Base System Design from the Digilent ZYBO product page and follow the included documentation. The ZYBO supports three different boot modes: microSD, QSPI Flash, and JTAG. The boot mode is selected using the Mode jumper (JP5), which affects the state of the Zynq configuration pins after power-on. Figure 4 depicts how the Zynq configuration pins are connected on the ZYBO. Note that MIO2-MIO8 are shared with the QSPI Flash and MIO LED, but not pictured in Fig. 4. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 9 of 26 ZYBO™ FPGA Board Reference Manual USB-JTAG/UART Port Micro-AB USB Connector (J11) 6-pin JTAG Header (J12) Zynq USB Controller 1x6 JTAG Header JP6 MIO2/M3 JTAG Port Mode (JP5) MIO3/M1 MIO4/M2 MIO5/M0 MIO6/M4 MIO7/VCFG0 JP4 JP5 MIO8/VCFG1 MicroSD PROGRAM_B DONE PS_SRST_B QSPI Flash JTAG Programming Mode Figure 4. ZYBO configuration pins. The three boot modes are described in the following sections. 3.1 MicroSD Boot Mode The ZYBO supports booting from a microSD card inserted into connector J4. The following procedure will allow you to boot the Zynq from microSD: 1) 2) 3) 4) 5) 6) 7) 3.2 Format the microSD card with a FAT32 file system. Copy the Zynq Boot Image created with Xilinx SDK to the microSD card. Rename the Zynq Boot Image on the microSD card to BOOT.bin. Eject the microSD card from your computer and insert it into connector J4 on the ZYBO. Attach a power source to the ZYBO and select it using JP7. Place a single jumper on JP5, shorting the two leftmost pins (labeled “SD”). Turn the board on. The board will now boot the image on the microSD card. QSPI Boot Mode The ZYBO has an onboard 128-Mbit Quad-SPI (QSPI) serial Flash that the Zynq can boot from. The ZYBO Base System Design includes a tutorial for how to configure the QSPI Flash with a Zynq Boot Image using the iMPACT tool included with Xilinx ISE and Vivado. Once the QSPI Flash has been loaded with a Zynq Boot Image, the following steps can be followed to boot from it: 1) Attach a power source to the ZYBO and select it using JP7. 2) Place a single jumper on JP5, shorting the two center pins (labeled “QSPI”). 3) Turn the board on. The board will now boot the image stored in the QSPI flash. The ZYBO ships with a demonstration application pre-loaded into QSPI. For information on this image and how to restore it if erased, download the Factory Loaded Demo project from the ZYBO page at www.digilentinc.com. 3.3 JTAG Boot Mode When placed in JTAG boot mode, the processor will wait until software is loaded by a host computer using the Xilinx tools. After software has been loaded, it is possible to either let the software begin executing, or step Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 10 of 26 ZYBO™ FPGA Board Reference Manual through it line by line using Xilinx SDK. The ZYBO Base System Design includes a tutorial for debugging software over JTAG in Xilinx SDK. It is also possible to directly configure the PL over JTAG, independent of the processor. This can be done using iMPACT or the Vivado Hardware Server. The ZYBO is configured to boot in Cascaded JTAG mode, which allows the PS to be accessed via the same JTAG port as the PL. It is also possible to boot the ZYBO in Independent JTAG mode by loading a jumper in JP6 and shorting it. This will cause the PS to not be accessible from the onboard JTAG circuitry, and only the PL will be visible in the scan chain. To access the PS over JTAG while in independent JTAG mode, users will have to route the signals for the PJTAG peripheral over EMIO, and use an external device to communicate with it. 4 SPI Flash The ZYBO features a 4-bit SPI (quad-SPI) serial NOR flash. The Spansion S25FL128S is used on this board. The MultiI/O SPI Flash memory is used to provide non-volatile code and data storage. It can be used to initialize the PS subsystem as well as configure the PL subsystem (bitstream). Spansion provides Spansion Flash File System (FFS) for use after booting the Zynq-7000 AP SoC. The relevant device attributes are:     128Mbit x1, x2, and x4 support Speeds up to 104 MHz, supporting Zynq configuration rates @ 100 MHz. In Quad-SPI mode, this translates to 400Mbs Powered from 3.3V The SPI Flash connects to the Zynq-7000 AP SoC supporting up to Quad-I/O SPI interface. This requires connection to specific pins in MIO Bank 0/500, specifically MIO[1:6,8] as outlined in the Zynq datasheet. Quad-SPI feedback mode is used, thus qspi_sclk_fb_out/MIO[8] is left to freely toggle and is connected only to a 20K pull-up resistor to 3.3V. This allows a QSPI clock frequency greater than FQSPICLK2. 5 DDR Memory The ZYBO includes two Micron MT41J128M16JT-125 or MT41K128M16JT-125 DDR3 memory components creating a single rank, 32-bit wide interface and a total of 512MiB of capacity. The DDR3 is connected to the hard memory controller in the Processor Subsystem (PS), as outlined in the Zynq documentation. The PS incorporates an AXI memory port interface, a DDR controller, the associated PHY, and a dedicated I/O bank. DDR3 memory interface speeds up to 533 MHz/1066 Mbps are supported1. The DDR3 uses 1.5V SSTL-compatible inputs. The two components are organized in a tree topology with a series termination scheme while keeping traces as short as possible and matched. ZYBO was routed with 40 ohm (+/-10%) trace impedance for single-ended signals, and differential clock and strobes set to 80 ohms (+/-10%). A feature called DCI (Digitally Controlled Impedance) is used to match the drive 1 Maximum actual clock frequency is 525 MHz due to PLL limitation. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 11 of 26 ZYBO™ FPGA Board Reference Manual strength and termination impedance of the PS pins to the trace impedance. On the memory side, each chip calibrates its on-die termination and drive strength using a 240 ohm resistor on the ZQ pin. Due to layout reasons, the two lower data byte groups (DQ[0-7], DQ[8-15]) were swapped. To the same effect, the data bits inside byte groups were swapped as well. These changes are transparent to the user. During the whole design process the Xilinx PCB guidelines were followed. Both the memory chips and the PS DDR bank are powered from the 1.5V supply. The mid-point reference of 0.75V is created with a simple resistor divider and is available to the Zynq as external reference. For proper operation it is essential that the PS memory controller is configured properly. Settings range from the actual memory flavor to the board trace delays. For your convenience the board definition file provided on our website will automatically configure the correct parameters. For best DDR3 performance, DRAM training is enabled for write leveling, read gate, and read data eye options in the PS Configuration Tool in Xilinx tools. Training is done dynamically by the controller to account for board delays, process variations and thermal drift. Optimum starting values for the training process are the board delays (propagation delays) for certain memory signals. Board delays are specified for each of the byte groups. These parameters are board-specific and were calculated from the PCB trace length reports. The DQS to CLK Delay and Board Delay values are calculated specific to the ZYBO memory interface PCB design. For more details on memory controller operation, refer to the Xilinx Zynq TRM (ug585). 6 USB UART Bridge (Serial Port) The ZYBO includes an FTDI FT2232HQ USB-UART bridge (attached to connector J11) that lets you use PC applications to communicate with the board using standard Windows COM port commands. Free USB-COM port drivers, available from www.ftdichip.com under the "Virtual Com Port" or VCP heading, convert USB packets to UART/serial port data. Serial port data is exchanged with the Zynq using a two-wire serial port (TXD/RXD). After the drivers are installed, I/O commands can be used from the PC directed to the COM port to produce serial data traffic on the Zynq pins. The port is tied to PS (MIO) pins and can be used in combination with the UART 1 controller. A 3.3V->1.8V voltage level translation interfaces the FT2232 with MIO Bank 501, a process transparent to the user. The board definition file takes care of mapping the correct MIO pins to the UART 1 controller and uses the following default protocol parameters: 115200 baud rate, 1 stop bit, no parity, 8-bit character length. 2 Micro-USB (J11) 4 JTAG JTAG TXD RXD MIO48 MIO49 Zynq-7 TX LED RX LED LD9 LD8 FT2232 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 12 of 26 ZYBO™ FPGA Board Reference Manual Figure 5. USB-UART bridge. Two on-board status LEDs provide visual feedback on traffic flowing through the port: the transmit LED (LD9) and the receive LED (LD8). Signal names that imply direction are from the point-of-view of the DTE (Data Terminal Equipment), in this case the PC. The FT2232HQ is also used as the controller for the Digilent USB-JTAG circuitry, but the USB-UART and USB-JTAG functions behave entirely independent of one another. Programmers interested in using the UART functionality of the FT2232 within their design do not need to worry about the JTAG circuitry interfering with the UART data transfers, and vice-versa. The combination of these two features into a single device allows the ZYBO to be programmed, communicated with via UART, and powered from a computer attached with a single Micro USB cable. 7 MicroSD Slot The ZYBO provides a microSD slot (J4) for non-volatile external memory storage as well as booting the Zynq. The slot is wired to Bank 1/501 MIO[40-47], including Card Detect. On the PS side peripheral SDIO 0 is mapped out to these pins and controls communication with the SD card. The pinout can be seen in Table 4Error! Reference ource not found.. The peripheral controller supports 1-bit and 4-bit SD transfer modes, but does not support SPI mode. Based on the Zynq TRM, SDIO host mode is the only mode supported. Signal Name Description Zynq Pin SD Slot Pin SD_D0 Data[0] MIO42 7 SD_D1 Data[1] MIO43 8 SD_D2 Data[2] MIO44 1 SD_D3 Data[3] MIO45 2 SD_CCLK Clock MIO40 5 SD_CMD Command MIO41 3 SD_CD Card Detect MIO47 9 Table 4. MicroSD pinout. The SD slot is a powered from 3.3V, but is connected through MIO Bank 1/501 (1.8V). Therefore, a TI TXS02612 level shifter performs this translation. The TXS02612 is actually 2-port SDIO port expander, but only its level shifter function is used. The connection diagram can be seen on Figure 6. Mapping out the correct pins and configuring the interface is handled by the ZYBO board definition file. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 13 of 26 ZYBO™ FPGA Board Reference Manual 1.8V CD DAT2 DAT3 CMD VDD CLK GND DAT0 DAT1 SD MICRO 3.3V SD_D2 SD_D3 SD_CMD MIO47 MIO44 MIO45 MIO41 SD_CCLK MIO40 SD_D0 SD_D1 MIO42 MIO43 TXS02612RTWR Zynq-7 Voltage Level Translator Figure 6. MicroSD slot signals. Both low speed and high speed cards are supported, the maximum clock frequency being 50 MHz. A Class 4 card or better is recommended. Refer to section 3.1 for information on how to boot from an SD card. For more information, consult the Xilinx Zynq TRM (ug585). 8 USB OTG The ZYBO implements one of the two available PS USB OTG interfaces on the Zynq device. A Microchip USB3320 USB 2.0 Transceiver Chip with an 8-bit ULPI interface is used as the PHY. The PHY features a complete HS-USB Physical Front-End supporting speeds of up to 480Mbs. The PHY is connected to MIO Bank 1/501, which is powered at 1.8V. The usb0 peripheral is used on the PS, connected through MIO[28-39]. The USB OTG interface can act as an embedded host or a peripheral device. The USB mode is controlled from software by manipulating the USB0 peripheral controller in the Zynq. When acting as a peripheral, the USB Micro AB connector (J9) should be used to connect to a USB host device, and JP1 should not be shorted. When acting as an embedded host, the USB A connector (J10) should be used to connect to a USB peripheral device, and JP1 should be shorted. The ZYBO should never have a peripheral device and a host device connected to these two connectors at the same time. While in host mode, the ZYBO is technically an "embedded host", because it does not provide the required 150 µF of capacitance on VBUS required to qualify as a general purpose host. It is possible to modify the ZYBO so that it complies with the general purpose USB host requirements by loading C64 with a 150 µF capacitor and shorting JP2. Only those experienced at soldering small components on PCBs should attempt this rework. Many USB peripheral devices will work just fine without loading C64. Whether the ZYBO is configured as an embedded host or a general purpose host, it can provide 500 mA on the 5V VBUS line. Note that if your design uses the USB OTG feature in host mode (embedded or general purpose), then the ZYBO should not be powered via USB (J11), but instead by a battery or wall adapter capable of providing more power. 9 Ethernet PHY The ZYBO uses a Realtek RTL8211E-VL PHY to implement a 10/100/1000 Ethernet port for network connection. The PHY connects to MIO Bank 501 (1.8V) and interfaces to the Zynq-7000 AP SoC via RGMII for data and MDIO for management. The auxiliary interrupt (INTB) and reset (PHYRSTB) signals connect to PL pins to be accessed via EMIO. The connection diagram can be seen on Fig. 7. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 14 of 26 ZYBO™ FPGA Board Reference Manual After power-up the PHY starts with Auto Negotiation enabled, advertising 10/100/1000 link speeds and full duplex. If there is an Ethernet-capable partner connected, the PHY automatically establishes a link with it, even with the Zynq not configured. MIO53 MIO52 MDIO MDC MIO23 MIO24 MIO25 MIO26 MIO27 MIO22 RXD0/SELRGV RXD1/TXDLY RXD2/AN0 RXD3/AN1 RXCTL/PHY_AD2 RXC MIO17 MIO18 MIO19 MIO20 MIO21 MIO16 TXD0 TXD1 TXD2 TXD3 TXCTL TXC F16 E17 L16 RJ-45 with magnetics 8 INTB PHYRSTB CLK125 LED0/PHY_AD0 PS_CLK Zynq-7 CKXTAL1 50 MHz Oscillator DSC1121CE5 ACT LED (LD7) LINK LED (LD6) LED1/PHY_AD1 Realtek RTL8211E Figure 7. Ethernet PHY signals. Two status indicator LEDs are on-board near the RJ-45 connector that indicate traffic (LD7) and valid link state (LD6). Table 5 shows the default behavior. Function Designator LINK LD6 ACT LD7 State Description On Link 10/100/1000 Blinking 0.4s ON, 2s OFF Link, Energy Efficient Ethernet (EEE) mode Blinking Transmitting or Receiving Table 5. Ethernet status LEDs. The Zynq incorporates two independent Gigabit Ethernet Controllers. They implement a 10/100/1000 half/full duplex Ethernet MAC. Of these two, GEM 0 can be mapped to the MIO pins where the PHY interfaces. Since the MIO bank is powered from 1.8V, the RGMII interface uses 1.8V HSTL Class 1 drivers. For this I/O standard an external reference of 0.9V is provided in bank 501 (PS_MIO_VREF). Mapping out the correct pins and configuring the interface is handled by the ZYBO board definition file. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 15 of 26 ZYBO™ FPGA Board Reference Manual Although the default power-up configuration of the PHY might be enough in most applications, the MDIO bus is available for management. The RTL8211E-VL is assigned address 00001b. With simple register read and write commands, status information can be read out or configuration changed. The Realtek PHY follows industrystandard register map for basic configuration. The RGMII specification calls for the receive (RXC) and transmit clock (TXC) to be delayed relative to the data signals (RXD[0:3], RXCTL and TXD[0:3], TXCTL). Xilinx PCB guidelines also require this delay to be added. The RTL8211E-VL is capable of inserting a 2ns delay on both the TXC and RXC so that board traces do not need to be made longer. The PHY is clocked from the same 50 MHz oscillator (IC22) that clocks the PS too. The parasitic capacitance of the two loads is low enough to be driven from a single source. On an Ethernet network each node needs a unique MAC address. To this end, a Microchip 24AA02E48 EEPROM is provided on the ZYBO. On one hand it is a read-writeable EEPROM that can be accessed via I2C. On the other hand it features a read-only memory section that comes pre-programmed with a unique identifier. This unique identifier can be read and used as a MAC address, avoiding a possible address conflict on the network. The I2C interface connects to the PL side and can be accessed from the PS over EMIO as well. The device address of the EEPROM is 1010000b. For more information on using the Gigabit Ethernet MAC, refer to the Xilinx Zynq TRM (ug585). 10 HDMI Source/Sink Port An input and output-capable HDMI Port connects to the programmable logic pins. Over this connector an HDMI or DVI-compatible video stream can be driven in or out of the ZYBO. Encoding or decoding the HDMI/DVI video stream needs to be implemented in logic, as well as auxiliary functions, like DDC or CEC. Depending on the actual design, it can take the Source role driving a monitor/TV display, or behave as a Sink accepting a video stream from any HDMI/DVI Source, like a laptop or smartphone. On-board auxiliary buffers and electronic switches control the direction of signals that differ between Source and Sink. These signals are summarized Table 6. Signal HPD 5V0 Role Description Direction (Zynq POW) How to control Source Hot-plug detect; signals the presence of a Sink to a Source Input HDMI_OUT_EN = 1 Output HDMI_OUT_EN = 0 Output Input HDMI_OUT_EN = 1 HDMI_OUT_EN = 0 Sink Source Sink Auxiliary power for Sink Table 6. HDMI signal direction in Source and Sink roles. The CEC function is bi-directional by definition, so it is treated the same no matter what role the port takes. If the CEC function is not used, declare it as input and constrain it to the correct PL pin to leave other devices on the CEC bus unaffected. When operating as Sink, the DDC function is required to be implemented so that a connected Source can read out important characteristics of the device. This can be done by emulating an I 2C-capable EEPROM in programmable logic. Likewise, in Source mode DDC can be used to find out the capabilities of the connected display. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 16 of 26 ZYBO™ FPGA Board Reference Manual The HDMI/DVI protocol uses TMDS (Transition-minimized differential signaling) as I/O standard. It is supported on Zynq by the I/O buffers on the programmable logic side. 50 ohm external parallel termination resistors are provided on-board. HDMI specifications only require terminations on the Sink side, but optional Source-side terminations reduce reflections, resulting in improved signal quality. Do not connect powered HDMI/DVI devices to an unpowered ZYBO, as it might result in back-powering the board through the termination resistors. Resolutions up to 720p (1280x720) have been tested. HDMI and DVI are high-speed source-synchronous serial protocols. Implementations on FPGA are required to use certain built-in primitives to properly synthesize the correct clock frequency, serialize the transmission, and keep a lock on the signal. The actual implementation of the HDMI/DVI protocols is outside the scope of this manual. Check for upcoming reference projects on our website or consult relevant specifications and Xilinx documentation. 11 VGA Port The ZYBO board uses 18 programmable logic pins to create an analog VGA output port. This translates to 16-bit color depth and two standard sync signals (HS – Horizontal Sync, and VS – Vertical Sync). The digital-to-analog conversion is done using a simple R-2R resistor ladder2. The ladder works in conjunction with the 75-ohm termination resistance of the VGA display to create 32 and 64 analog signal levels red, blue, and green VGA signals. This circuit, shown in Fig. 8, produces video color signals that proceed in equal increments between 0V (fully off) and 0.7V (fully on). With 5 bits each for red and blue and 6 bits for green, 65,536 (32×32×64) different colors can be displayed, one for each unique 16-bit pattern. A video controller circuit must be created in programmable logic to drive the sync and color signals with the correct timing in order to produce a working display system. 5 Pin 1: Red Pin 2: Grn Pin 3: Blue Pin 13: HS Pin 14: VS 1 10 6 15 11 Pin 5: GND Pin 6: Red GND Pin 7: Grn GND Pin 8: Blu GND Pin 10: Sync GND F19 RED5 536W G20 RED4 536W 270W 536W 270W J20 RED3 RED2 270W L20 536W 536W 270W M19 RED1 HS 536W VS RED BLU HD-DB15F F20 GRN5 536W GRN4 536W 270W H20 J19 GRN3 536W 270W L19 GRN2 536W 270W N20 GRN1 536W 270W GRN0 536W 270W H18 GRN 536W G19 BLU5 536W BLU4 536W 270W J18 BLU3 536W 270W K19 M20 BLU2 536W 270W P20 BLU1 536W 270W 536W P19 R19 HSYNC 100W VSYNC 100W Zynq- 7 Figure 8. ZYBO VGA circuit. 2 http://en.wikipedia.org/wiki/Resistor_ladder Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 17 of 26 ZYBO™ FPGA Board Reference Manual 11.1 VGA System Timing VGA signal timings are specified, published, copyrighted, and sold by the VESA organization (www.vesa.org). The following VGA system timing information is provided as an example of how a VGA monitor might be driven in 640 by 480 mode. NOTE: For more precise information, or for information on other VGA frequencies, refer to documentation available at the VESA website. CRT-based VGA displays use amplitude-modulated moving electron beams (or cathode rays) to display information on a phosphor-coated screen. LCD displays use an array of switches that can impose a voltage across a small amount of liquid crystal, thereby changing light permittivity through the crystal on a pixel-by-pixel basis. Although the following description is limited to CRT displays, LCD displays have evolved to use the same signal timings as CRT displays (so the “signals” discussion below pertains to both CRTs and LCDs). Color CRT displays use three electron beams (one for red, one for blue, and one for green) to energize the phosphor that coats the inner side of the display end of a cathode ray tube (see Fig. 9). Anode (entire screen) Cathode ray tube Deflection coils Grid Electron guns (Red, Blue, Green) Cathode ray R,G,B signals (to guns) VGA cable High voltage deflection grid supply (>20kV) control control gun control Figure 9. Color CRT display. Electron beams emanate from “electron guns” which are finely-pointed heated cathodes placed in close proximity to a positively charged annular plate called a “grid.” The electrostatic force imposed by the grid pulls rays of energized electrons from the cathodes, and those rays are fed by the current that flows into the cathodes. These particle rays are initially accelerated towards the grid, but they soon fall under the influence of the much larger electrostatic force that results from the entire phosphor-coated display surface of the CRT being charged to 20kV (or more). The rays are focused to a fine beam as they pass through the center of the grids, and then they accelerate to impact on the phosphor-coated display surface. The phosphor surface glows brightly at the impact point, and it continues to glow for several hundred microseconds after the beam is removed. The larger the current fed into the cathode, the brighter the phosphor will glow. Between the grid and the display surface, the beam passes through the neck of the CRT where two coils of wire produce orthogonal electromagnetic fields. Because cathode rays are composed of charged particles (electrons), they can be deflected by these magnetic fields. Current waveforms are passed through the coils to produce magnetic fields that interact with the cathode rays and cause them to transverse the display surface in a “raster” pattern, horizontally from left to right and vertically from top to bottom, as shown in Fig. 10. As the cathode ray Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 18 of 26 ZYBO™ FPGA Board Reference Manual moves over the surface of the display, the current sent to the electron guns can be increased or decreased to change the brightness of the display at the cathode ray impact point. Information is only displayed when the beam is moving in the “forward” direction (left to right and top to bottom), and not during the time the beam is reset back to the left or top edge of the display. Much of the potential display time is therefore lost in “blanking” periods when the beam is reset and stabilized to begin a new horizontal or vertical display pass. The size of the beams, the frequency at which the beam can be traced across the display, and the frequency at which the electron beam can be modulated determine the display resolution. Modern VGA displays can accommodate different resolutions, and a VGA controller circuit dictates the resolution by producing timing signals to control the raster patterns. The controller must produce synchronizing pulses at 3.3V (or 5V) to set the frequency at which current flows through the deflection coils, and it must ensure that video data is applied to the electron guns at the correct time. Raster video displays define a number of “rows” that corresponds to the number of horizontal passes the cathode makes over the display area, and a number of “columns” that corresponds to an area on each row that is assigned to one “picture element”, or pixel. Typical displays use from 240 to 1200 rows and from 320 to 1600 columns. The overall size of a display and the number of rows and columns determines the size of each pixel. pixel 0,0 pixel 0,639 640 pixels per row are displayed during forward beam trace Display Surface pixel 479,0 Retrace - no information displayed during this time pixel 479,639 Stable current ramp - information is displayed during this time Current waveform through horizontal defletion coil Total horizontal time Horizontal display time retrace time time HS "front porch" Horizontal sync signal sets retrace frequency "back porch" Figure 10. VGA horizontal synchronization. Video data typically comes from a video refresh memory; with one or more bytes assigned to each pixel location (the ZYBO uses 16 bits per pixel). The controller must index into video memory as the beams move across the display, and retrieve and apply video data to the display at precisely the time the electron beam is moving across a given pixel. A VGA controller circuit must generate the HS and VS timings signals and coordinate the delivery of video data based on the pixel clock. The pixel clock defines the time available to display one pixel of information. The VS signal defines the “refresh” frequency of the display, or the frequency at which all information on the display is redrawn. The minimum refresh frequency is a function of the display’s phosphor and electron beam intensity, with practical Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 19 of 26 ZYBO™ FPGA Board Reference Manual refresh frequencies falling in the 50Hz to 120Hz range. The number of lines to be displayed at a given refresh frequency defines the horizontal “retrace” frequency. For a 640-pixel by 480-row display using a 25MHz pixel clock and 60 +/-1Hz refresh, the signal timings shown in Fig. 11 can be derived. Timings for sync pulse width and front and back porch intervals (porch intervals are the pre- and post-sync pulse times during which information cannot be displayed) are based on observations taken from actual VGA displays. TS Tfp Tdisp T pw Symbol Parameter TS Sync pulse T disp Display time Tbp Horiz. Sync Vertical Sync Time Clocks Lines Time Clks 16.7ms 416,800 521 32 us 800 15.36ms 384,000 480 25.6 us 640 T pw Pulse width 64 us 1,600 2 3.84 us 96 T fp Front porch 320 us 8,000 10 640 ns 16 T bp Back porch 928 us 23,200 29 1.92 us 48 Figure 11. Signal timings for a 640-pixel by 480 row display using a 25MHz pixel clock and 60Hz vertical refresh. A VGA controller circuit, such as the one diagramed in Fig. 12, decodes the output of a horizontal-sync counter driven by the pixel clock to generate HS signal timings. You can use this counter to locate any pixel location on a given row. Likewise, the output of a vertical-sync counter that increments with each HS pulse can be used to generate VS signal timings, and you can use this counter to locate any given row. These two continually running counters can be used to form an address into video RAM. No time relationship between the onset of the HS pulse and the onset of the VS pulse is specified, so you can arrange the counters to easily form video RAM addresses, or to minimize decoding logic for sync pulse generation. HS Pixel CLK Horizontal Counter Zero Detect Set 3.84us Detect Reset Horizontal Synch CE Vertical Counter Zero Detect Set Vertical Synch 64us Detect VS Reset Figure 12. VGA display controller block diagram. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 20 of 26 ZYBO™ FPGA Board Reference Manual 12 Clock Sources The ZYBO provides a 50 MHz clock to the Zynq PS_CLK input, which is used to generate the clocks for each of the PS subsystems. The 50 MHz input allows the processor to operate at a maximum frequency of 650 MHz and the DDR3 memory controller to operate at a maximum of 525 MHz (1050 Mbps). The ZYBO Base System Design configures the PS to work properly with this input clock, and should be used as a reference when creating custom designs. The PS has a dedicated PLL capable of generating up to four reference clocks, each with settable frequencies, that can be used to clock custom logic implemented in the PL. Additionally, The ZYBO provides an external 125 MHz reference clock directly to pin L16 of the PL. The external reference clock allows the PL to be used completely independently of the PS, which can be useful for simple applications that do not require the processor. The PL of the Zynq-Z7010 also includes two MMCM’s and two PLL’s that can be used to generate clocks with precise frequencies and phase relationships. Any of the four PS reference clocks or the 125 MHz external reference clock can be used as an input to the MMCMs and PLLs. For a full description of the capabilities of the Zynq PL clocking resources, refer to the “7 Series FPGAs Clocking Resources User Guide” available from Xilinx. Figure 13 outlines the clocking scheme used on the ZYBO. Note that the reference clock output from the Ethernet PHY is used as the 125 MHz reference clock to the PL, in order to cut the cost of including a dedicated oscillator for this purpose. Keep in mind that CLK125 will be disabled when the Ethernet PHY (IC1) is held in hardware reset by driving the PHYRSTB signal low. 50 MHz Oscillator (IC22) OUT 3.3V PS_CLK CKXTAL1 CLK125 PHYRSTB Ethernet PHY (IC1) PS PLL FCLK_CLK[0:3] L16 PL E17 Zynq Figure 13. ZYBO clocking. 13 Basic I/O The ZYBO board includes four slide switches, four push buttons, and four individual LEDs connected to the Zynq PL, as shown in Fig. 14. There are also two additional pushbuttons and one LED connected directly to the PS via MIO pins, also shown in Fig. 14. The pushbuttons and slide switches are connected to the Zynq via series resistors to prevent damage from inadvertent short circuits (a short circuit could occur if a pin assigned to a pushbutton or slide switch was inadvertently defined as an output). The pushbuttons are "momentary" switches that normally generate a low output when they are at rest, and a high output only when they are pressed. Slide switches generate constant high or low inputs depending on their position. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 21 of 26 ZYBO™ FPGA Board Reference Manual PS 3.3V MIO Buttons MIO51 BTN5 MIO7 MIO LED LD12 MIO50 BTN4 3.3V Buttons PL Y16 BTN3 V16 BTN2 P16 BTN1 LEDs R18 BTN0 D18 G14 M15 M14 3.3V Slide Switches SW3 T16 SW2 W13 SW1 P15 SW0 G15 LD3 LD2 LD1 LD0 Zynq Figure 14. ZYBO GPIO. The high-efficiency LEDs are anode-connected to the Zynq via 330-ohm resistors, so they will turn on when a logic high voltage is applied to their respective I/O pin. Additional LEDs that are not user-accessible indicate power-on, FPGA programming status, and USB and Ethernet port status. The LED and two pushbuttons attached directly to the PS are accessed using the Zynq GPIO controller. This core is described in full in Chapter 14 of the Zynq Technical Reference Manual. 14 Audio An Analog Devices SSM2603 Audio Codec provides integrated digital audio processing to the Zynq-7000 AP SoC. It allows for stereo record and playback at sample rates from 8 kHz to 96 kHz. On the analog side, the codec connects to three 3.5 mm standard audio jacks. There are two inputs: a mono microphone and a stereo line in. There is one stereo output, the headphone jack. Analog power is provided by a dedicated linear power supply (IC6). Audio Jack Description Channels Color SSM2603 pin J5 Headphone Out Stereo Black L/RHPOUT J6 Microphone In Mono Pink MICIN, MICBIAS J7 Line In Stereo Light Blue L/RLINEIN Table 7. Analog audio signals. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 22 of 26 ZYBO™ FPGA Board Reference Manual The digital interface of the SSM2603 is wired to the programmable logic side of the Zynq. Audio data is transferred via the I2S protocol. Configuration is done over an I2C bus. The device address of the SSM2603 is 0011010b. All digital I/O are 3.3V level and connect to a 3.3V-powered FPGA bank. SSM2603 pin Protocol Direction (Zynq POW) Zynq pin BCLK I2S (Serial Clock) Output K18 2 PBDAT I S (Playback Data) Output M17 PBLRC I2S (Playback Channel Clock) Output L17 RECDAT I2S (Record Data) Input K17 2 RECLRC I S (Record Channel Clock) Output M18 SDIN I2C (Data) Input/Output N17 SCLK I2C (Clock) Output N18 MUTE Digital Enable (Active Low) Output P18 MCLK Master Clock Output T19 Table 8. Digital audio signals, with the SSM2603 in default slave mode. The audio codec needs to be clocked from the Zynq on the MCLK pin. This master clock will be used by the audio codec to establish the audio sampling frequency. This clock is required to be an integer multiple of the desired sampling rate. The default settings require a master clock of 12.288 Mhz, resulting in a 48 kHz sampling rate. For other frequencies and their respective configuration parameters, consult the SSM2603 datasheet. The codec has two modes: master and slave, with the slave being default. In this mode, the direction of the signals is specified in Table 8. When configured as master, the direction of BCLK, PBLRC and RECLRC is inverted. In this mode, the codec generates the proper frequencies for these clocks. No matter where are the clocks are generated, PBDAT needs to be driven out and RECDAT sampled in sync with them. The master clock is always driven out of the Zynq. The timing diagram of an I2S stream can be seen on Figure 15. Note the one-cycle delay of the data stream with respect to the left/right clock changing state. Audio samples are transmitted MSB first, noted as 1 in the diagram. 1/fs BCLK PB/RECLRC PB/RECDAT N 1 2 3 N 1 2 3 N Figure 15. I2S timing diagram. The digital mute signal (MUTE) is active-low, with a pull-down resistor. This means that when not used in the design, it will stay low and the analog outputs of the codec will stay muted. To enable the analog outputs, drive this signal high. To use the audio codec in a design with non-default settings, it needs to be configured over I2C. The audio path needs to be established by configuring the (de)multiplexers and amplifiers in the codec. Some digital processing Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 23 of 26 ZYBO™ FPGA Board Reference Manual can also be done in the codec. Configuration is read out and written by accessing the register map via I2C transfers. The register map is described in the SSM2603 datasheet. 15 Reset Sources 15.1 Power-on Reset The Zynq PS supports external power-on reset signals. The power-on reset is the master reset of the entire chip. This signal resets every register in the device capable of being reset. The ZYBO drives this signal from a comparator that holds the system in reset until all power supplies are valid. Several other IC’s on the ZYBO are reset by this signal as well. 15.2 Program Push-button Switch A PROG push switch, BTN6, toggles Zynq PROG_B. This resets the PL and causes DONE to be de-asserted. The PL will remain unconfigured until it is reprogrammed by the processor or via JTAG. 15.3 Processor Subsystem Reset The external system reset, labeled PS_SRST/BTN7, resets the Zynq device without disturbing the debug environment. For example, the previous break points set by the user remain valid after system reset. Due to security concerns, system reset erases all memory content within the PS, including the OCM. The PL is also cleared during a system reset. System reset does not cause the boot mode strapping pins to be re-sampled. 16 Pmod Ports Pmod ports are 2x6, right-angle, 100-mil spaced female connectors that mate with standard 2x6 pin headers. Each 12-pin Pmod port provides two 3.3V VCC signals (pins 6 and 12), two Ground signals (pins 5 and 11), and eight logic signals, as shown in Fig. 16. The VCC and Ground pins can deliver up to 1A of current, but care must be taken not to exceed any of the power budgets of the onboard regulators or the external power supply. VCC GND 8 signals Pin 1 Pin 6 Pin 12 Figure 16. Pmod diagram. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 24 of 26 ZYBO™ FPGA Board Reference Manual Pmod JA (XADC) Pmod JB (Hi-Speed) Pmod JC (Hi-Speed) Pmod JD (Hi-Speed) Pmod JE (Std.) Pmod JF (MIO) JA1: N15 JB1: T20 JC1: V15 JD1: T14 JE1: V12 JF1: MIO-13 JA2: L14 JB2: U20 JC2: W15 JD2: T15 JE2: W16 JF2: MIO-10 JA3: K16 JB3: V20 JC3: T11 JD3: P14 JE3: J15 JF3: MIO-11 JA4: K14 JB4: W20 JC4: T10 JD4: R14 JE4: H15 JF4: MIO-12 JA7: N16 JB7: Y18 JC7: W14 JD7: U14 JE7: V13 JF7: MIO-0 JA8: L15 JB8: Y19 JC8: Y14 JD8: U15 JE8: U17 JF8: MIO-9 JA9: J16 JB9: W18 JC9: T12 JD9: V17 JE9: T17 JF9: MIO-14 JA10: J14 JB10: W19 JC10: U12 JD10: V18 JE10: Y17 JF10: MIO-15 Table 9. Pmod pinout. Digilent produces a large collection of Pmod accessory boards that can attach to the Pmod expansion connectors to add ready-made functions like A/D’s, D/A’s, motor drivers, sensors, and other functions. See www.digilentinc.com for more information. The ZYBO has six Pmod ports, some of which behave differently than others. Each Pmod port falls into one of four categories: standard, MIO connected, XADC, or high-speed Table 9 specifies which category each Pmod falls into, and also lists the Zynq pins they are connected to. The following sections describe the different types of Pmods. 16.1 Standard Pmod The standard Pmod port is connected to the PL of the Zynq via 200 Ohm series resistors. The series resistors prevent short circuits that can occur if the user accidently drives a signal that is supposed to be used as an input. The downside to this added protection is that these resistors can limit the maximum switching speed of the data signals. If the Pmod being used does not require high-speed access, then the standard Pmod port should be used to help prevent damage to the devices. 16.2 MIO Pmod The MIO Pmod port is connected to the MIO bus in the PS of the Zynq via 200 Ohm series resistors. Like the standard Pmod port, these series resistors add protection at the cost of maximum switching speed. Since these data signals are connected to the MIO interface, they can only be accessed by the PS peripheral controller cores. The GPIO, UART, I2C, and SPI cores can all be used to drive devices connected to this Pmod. Note that the pin layout of the UART and I2C cores will not align perfectly with the typical Pmod pinouts for these interfaces. This means that UART or I2C devices connected to this Pmod may require some of the pins to be swapped around externally using individual wires between the ZYBO and the Pmod. 16.3 Dual Analog/Digital Pmod (XADC Pmod) The on-board Pmod expansion connector labeled “JA” is wired to the auxiliary analog input pins of the PL. Depending on the configuration, this connector can be used to input differential analog signals to the analog-todigital converter inside the Zynq (XADC). Any or all pairs in the connector can be configured either as analog input or digital input-output. In analog input mode, the voltage on these pins must be limited to 1V peak-to-peak. In digital mode, the regular VCCO-dependent limits apply. See Xilinx datasheets for more information. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 25 of 26 ZYBO™ FPGA Board Reference Manual The Dual Analog/Digital Pmod on the ZYBO differs from the rest in the routing of its traces. The eight data signals are grouped into four pairs, with the pairs routed closely coupled for better analog noise immunity. Pins 1 and 7, pins 2 and 8, pins 3 and 9, and pins 4 and 10 are paired up. Furthermore, each pair has a partially loaded anti-alias filter laid out on the PCB. The filter does not have capacitors C94-C97. In designs where such filters are desired, the capacitors can be manually loaded by the user. NOTE: The coupled routing and the anti-alias filters might limit the data speeds when used for digital signals. The XADC core within the Zynq is a dual channel 12-bit analog-to-digital converter capable of operating at 1 MSPS. Either channel can be driven by any of the auxiliary analog input pairs connected to the JXADC header. The XADC core is controlled and accessed from the PL via the Dynamic Reconfiguration Port (DRP). The DRP also provides access to voltage monitors that are present on each of the FPGA’s power rails, and a temperature sensor that is internal to the FPGA. For more information on using the XADC core, refer to the Xilinx document titled “7 Series FPGAs and Zynq-7000 All Programmable SoC XADC Dual 12-Bit 1 MSPS Analog-to-Digital Converter.” It is also possible to access the XADC core directly using the PS, via the “PS-XADC” interface. This interface is described in full in chapter 30 of the Zynq Technical Reference Manual. 16.4 High-Speed Pmod The High-speed Pmods use the standard Pmod port, but have their data signals routed as impedance matched differential pairs for maximum switching speeds. They have pads for loading resistors for added protection, but the ZYBO ships with these loaded as 0-Ohm shunts. With the series resistors shunted, these Pmods offer no protection against short circuits, but allow for much faster switching speeds. The signals are paired to the adjacent signals in the same row: pins 1 and 2, pins 3 and 4, pins 7 and 8, and pins 9 and 10. Traces are routed 100 ohm (+/- 10%) differential. These connectors should be used only when high speed differential signaling is required or the other Pmods are all occupied. If used as single-ended, coupled pairs will have significant crosstalk. In applications where this is a concern, the standard Pmod port shall be used. Another option would be to ground one of the signals (drive it low from the FPGA) and use its pair for the signal-ended signal. Since the High-Speed Pmods have 0-ohm shunts instead of protection resistors, the operator must take precaution to ensure that they do not cause any shorts. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 26 of 26
410-279 价格&库存
很抱歉,暂时无法提供与“410-279”相匹配的价格&库存,您可以联系我们找货
