VL-EBXE-41SLK
VL-EBXE-41SLK
    VERSALOGIC
    SBC COPPERHEAD CELERON
VL-EBXE-41SLK 数据手册
Product Data Sheet Copperhead EBX Single Board Computer Overview Highlights The Copperhead is a high-performance embedded computer powered by the 3rd Generation Intel “Ivy Bridge” family of processors. Its performance level and extensive I/O allows for the integration of multiple high-bandwidth functions, such as digital signal processing and real-time video processing, onto a single board. This can drastically reduce system cost and size when used to replace multi-board chassis-based systems or custom hardware. ƒƒ Industrial temp (-40° to +85°C) operating temperature versions For systems that require video processing or intense computation, the Copperhead features a high-speed memory interface, up to 16 GB on-board RAM capacity, and up to three independent display outputs. The PCIe/104 expansion site with a PCIe x16 lane is ideal for add-on cards, such as frame grabbers. Based on the industry-standard EBX format, the Copperhead provides a choice of Intel core i7, core i3, and Celeron processor options to meet a variety of price/performance application requirements. It features several heat management configurations and offers options for I/O interfaces and interface connectors. The Copperhead enables scalability, simplifies design, and lowers overall system cost. ƒƒ Shock & vibration per MIL-STD-202G ƒƒ Gigabit Ethernet ƒƒ VGA, LVDS, and mini DisplayPort video ƒƒ EBX™ form factor ƒƒ Mini PCIe socket / with mSATA support ƒƒ Very high performance! ƒƒ USB 3.0 and USB 2.0 ports ƒƒ 3rd Generation Intel processor (“Ivy Bridge”) ƒƒ Serial I/O (4 RS-232/422) - Core i7-3615QE (quad core) or ƒƒ Digital I/O (32 lines) - Core i7-3517UE (dual core) or ƒƒ Fanless versions - Core i3-3217UE (dual core) or ƒƒ Trusted Platform Module (TPM) security chip (optional) - Celeron 1047UE (dual core) ƒƒ Up to 16 GB SO-DIMM RAM system memory ƒƒ Wide input voltage (9V–15V) ƒƒ SATA (6 Gb/s and 3 Gb/s) ƒƒ VersaAPI programming support ƒƒ Customization available in quantities as low as 100 pcs. ƒƒ PCIe/104 or SUMIT expansion C O R P O R A T I O N Product Data Sheet Features 1 Intel® 3rd Generation Core™ Processor Core i7, Core i3, and Celeron CPU options allow selecting best price/performance for the application. Copperhead provides high performance with advanced technology features: Intel Turbo Boost 2.0*, Intel vPro*, Hyper-threading* (two threads per core), and Advanced Vector Extensions* (AVX). 2 High-performance Video Integrated Intel HD graphics core with GPU Turbo Boost*. DirectX 11, MPEG-2, H.264, OGL 3.1 compliant and MPEG-2 video encoding and decoding. Supports up to three independent displays. Standard video outputs include LVDS (3a – on back side) for flat panel displays, dual mini DisplayPort™ (3b), and an analog VGA output (3c). All outputs support multiple display modes including Extended Desktop and Clone. 4 Industrial Temperature Versions On-board security option defends against attacks from unauthorized hardware and software for applications that require enhanced hardware-level security functions. -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock and vibration environments. Software Support 13 SPX Expansion Compatible with a variety of popular x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks. Supports VersaAPI programming support for onboard I/O devices. Add low cost analog, digital, and CANbus modules. SPX interface supports up to four external SPX devices. Intel QM77 Platform Controller Hub The PCH provides extensive I/O support to the CPU 3 12 Trusted Platform Module (optional) 14 EBX™ Format Industry-standard format with SUMIT™(14a) or PCIe/104 Type 1 (14b) expansion. 5 6a 6b 7a 11 7b 3c 9 Network Support 4 Dual Ethernet interfaces, autodetect 10BaseT / 100BaseTX / 1000BaseT with network boot capability. 5 RAM 14a Up to 16 GB DDR3L socket memory up to 1600 MT/s., two SO-DIMM sockets (one each on top and bottom.) 6 1 SATA Two SATA 6 Gb/s (6a) and two SATA 3 Gb/s (6b) ports support high-capacity storage (rotating media or solid-state drives). Includes hardware RAID 0/1/5/10 support 7 Device I/O Two USB 3.0 ports (7a), ten USB 2.0 ports (7b) support keyboard, mouse, and other devices. Four RS-232/422 serial ports, three 8254 timer/ counters (7c), and Intel High Definition Audio (HDA) compatible. 8 Analog + Digital I/O On-board data acquisition support. Sixteen analog inputs, eight analog outputs, and thirty-two digital I/O lines. 9 12 10b 8 13 10a 3a 3b 7c 2 14b * CPU model dependent, see specifications for more details. Mini PCIe Socket Supports Wi-Fi modems, Ethernet, Analog I/O, Serial ports, GPS, MIL-STD-1553, Ethernet, solid-state storage, and other plug-in devices. 10 Flash Memory Dedicated mSATA socket (10a) and eUSB interface (10b – on back side) provides additional solid-state drive (SSD) options. 11 Wide Input Voltage Range Accepts 9 to 15 volts (12V nominal) simplifies system power supply requirements. Copperhead is fully compatible with 12V automotive applications. Tailor Copperhead to Your Exact Requirements Customization options are available in quantities as low as 100 pieces. ƒƒ Conformal Coating ƒƒ Custom Labeling ƒƒ Custom Screening ƒƒ Custom Cabling ƒƒ BGA Underfill ƒƒ Connector & I/O Changes ƒƒ BIOS Modifications ƒƒ Application-Specific Testing ƒƒ Software and Drivers ƒƒ And more – ƒƒ Custom Testing ƒƒ Revision Locks VersaLogic Corporation, 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | www.VersaLogic.com Copperhead EBX Single Board Computer Specifications General Board Size Processor Controller Hub Input Voltage Power Requirements (@ +12V) § System Reset & Hardware Monitors Stackable Bus Manufacturing Standards RoHS Security EBX standard: 5.75” x 8” (146 mm x 203 mm) Intel 3rd Generation 64-bit CPU platform. Trusted L3 Cache AES New Execution Processor Size Instructions Technology i7-3615QE 6 MB Yes Yes i7-3517UE 4 MB Yes Yes i3-3217UE 3 MB No No Celeron 1047UE 2 MB No No Embedded Intel QM77 12V (9V–15V) Model Idle Typical Max. VL-EBXe-41SJF 16.2W 37.2W 58.1W VL-EBXe-41EJP 16.2W 37.2W 58.1W VL-EBXs-41SAK 7.6W 20.7W 33.7W VL-EBXs-41EAF 7.6W 20.7W 33.7W VL-EBXe-41EHF 7.6W 20.7W 33.7W VL-EBXe-41ELF 8.8W 14.4W 20.0W VL-EBXe-41SLK 8.8W 14.4W 20.0W VL-EBXe-41SMK 9.8W 13.3W 16.9W VL-EBXe-41EMF 9.8W 13.3W 16.9W All voltage rails monitored. Two watchdog timers with programmable timeout. CPU temperature and fan speed monitoring. Push-button sleep, reset, and power. SUMIT or PCIe/104 Type 1 expansion site Standard IPC-A-610 Class 2 modified Special Order IPC-A-610 Class 3 modified Compliant TPM (optional) Memory System RAM General VRAM Desktop Display Interface ‡ OEM Flat Panel Interface # DisplayPort Rotating Drives / Flash / Solid-State Drives Network Interface Ethernet ‡ † Heat sink (fanless) Fan + Heat sink (0.5 Linear Meters per Second) 0° to +60°C 100 Linear Feet per Minute (0.5 Linear Meters per Second) -40° to +85°C 100 Linear Feet per Minute (0.5 Linear Meters per Second) Thermal Shock Humidity Vibration, Sinusoidal Sweep ¥ Vibration, Random ¥ Mechanical Shock ¥ 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis § Represents operation at +25°C and +12V running Windows 7 with 4 GB RAM, LVDS display, SATA, GbE, COM, and USB keyboard/mouse. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power measured with 95% CPU utilization. ‡ TVS protected port (enhanced ESD protection) # Power pins are overload protected † IEEE 1588 Precision Time Protocol (PTP) compatible ◊ Derate -1.1°C per 305m (1,000 ft.) above 2,300m (7,500 ft.) * For extended altitude information contact VersaLogic Sales Dept. ¥ MIL-STD-202G shock and vibe levels were used to illustrate the overall ruggedness of this product. Certification at higher levels or different types of shock or vibration methods per the specific requirements of the application is available. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. Intel and Core are trademarks of Intel Corp. EBX and PCIe/104 are trademarks of the PC/104 Consortium. SUMIT is a trademark of the SFF-SIG. PCI Express is a registered trademark of the PCI-SIG. DisplayPort is a trademark of VESA. All other trademarks are the property of their respective owners. Integrated high-performance video. Simultaneous Graphics Independent Hardware Processor Graphics Core Displays Accel. i7-3615QE Intel HD Graphics 4000 3 Yes i7-3517UE Intel HD Graphics 4000 3 Yes i3-3217UE Intel HD Graphics 4000 3 Yes Celeron 1047UE Intel HD Graphics 2 No Up to 512 MB shared DRAM Standard analog output (VGA). Up to 2048 x 1536 (75 Hz). 32-bit. LVDS interface. 18/24-bit. Up to 1280 x 800 (60 Hz). 8 bpp. CMOS-selectable TFT panel types. Support for LVDS Backlight Control and FPD power control. Two mini DisplayPort outputs. Up to 2560 x 1600 (60 Hz). 10 bpp. Mass Storage Operating Temperature ◊ Storage Temperature Altitude be kept below 90°C) Two SO-DIMM sockets. Up to 16 GB DDR3L SDRAM total. Supports 1066, 1333, and 1600 MT/s. 1.35V. Video Environmental 0° to +60°C and -40° to +85°C See Ordering Information for Specific Models -40° to +85°C Operating * To 4,570m (15,000 ft.) Storage To 12,000m (40,000 ft.) Airflow Requirements Thermal Solution Temp. Range Airflow Heat plate 0° to +60°C Zero airflow (Heat plate must -40° to +85°C 100 Linear Feet per Minute Support for Intel Trusted Platform Module 1.2 devices Network Boot Option - Two SATA 6 Gb/s ports (latching connectors) - Two SATA 3 Gb/s ports (latching connectors) Supports RAID 0, 1, 5, and 10. mSATA socket (SATA signaling, bootable) eUSB site (USB signaling, bootable) Two autodetect 10BaseT/100BaseTX/1000BaseT ports Standard RJ45 connectors Special Order Ruggedized connectors Via BIOS extension built into Ethernet controller flash Device I/O USB # ‡ COM 1 / 2 / 3 / 4 ‡ Analog Input Analog Output Digital I/O Audio Counter/Timers Ten USB 2.0 host ports. Two USB 3.0 host ports. RS-232/422 selectable. 16C550 compatible. Sixteen channels. 12-bit single-ended. 100 Ksps. 16-bit by special order. Eight channels. 12-bit single-ended. 100 Ksps. Thirty-two TTL I/O lines (3.3V). Independently configurable. Intel High-Definition Audio (HDA) Three general-purpose 16-bit timers Other I/O Mini PCIe / Socket VersaLogic SPX Interface Full-size Mini PCIe socket. Supports Wi-Fi modems, GPS receivers, non-volatile flash data storage with auto-detect mSATA support, and other plug-in modules. Supports low cost analog, digital, and CANbus SPX modules Software BIOS VersaAPI Sleep Mode Operating Systems American Megatrends (AMI) Aptio UEFI BIOS with OEM enhancements. Field reprogrammable. Support for USB keyboard/mouse and USB boot. User-configurable CMOS defaults. VersaLogic Application Programming Interface to support on-board I/O devices. ACPI 4.0a. Support for S3 and S4 suspend states Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, and VxWorks C O R P O R A T I O N Copperhead Product Data Sheet EBX Single Board Computer Ordering Information Model VL-EBXe-41SJF VL-EBXe-41EJP VL-EBXs-41SAK* VL-EBXs-41EAF* VL-EBXe-41EHF* VL-EBXe-41ELF VL-EBXe-41SLK* VL-EBXe-41SMK VL-EBXe-41EMF* Processor i7-3615QE i7-3615QE i7-3517UE i7-3517UE I7-3517UE i3-3217UE i3-3217UE Celeron 1047UE Celeron 1047UE Cores Quad Quad Dual Dual Dual Dual Dual Dual Dual Nominal Speed 2.3 GHz 2.3 GHz 1.7 GHz 1.7 GHz 1.7 GHz 1.6 GHz 1.6 GHz 1.4 GHz 1.4 GHz Other configurations are possible. Please contact VersaLogic Sales at (503) 747-2261 to discuss requirements! Max Turbo Speed 3.3 GHz 3.3 GHz 2.8 GHz 2.8 GHz 2.8 GHz N/A N/A N/A N/A HyperThreading Yes Yes Yes Yes Yes Yes Yes No No vPro Technology Yes Yes Yes Yes Yes No No No No AVX Instructions Yes Yes Yes Yes Yes Yes Yes No No Expansion PCIe/104 PCIe/104 SUMIT SUMIT PCIe/104 PCIe/104 PCIe/104 PCIe/104 PCIe/104 Operating Temp. 0° to +60°C -40° to +85°C 0° to +60°C -40° to +85°C -40° to +85°C -40° to +85°C 0° to +60°C 0° to +60°C -40° to +85°C Cooling Fan + heat sink Heat plate (fanless) Heat sink (fanless) Fan + heat sink Fan + heat sink Fan + heat sink Heat sink (fanless) Heat sink (fanless) Fan + heat sink * Special Order Product – Contact VersaLogic Sales for minimum order quantities and lead time. Accessories Part Number Cable Kit VL-CKR-COPPR VL-CBR-5013 VL-CBR-1201 VL-CBR-0702 VL-CBR-0808 VL-CBR-4004 VL-HDW-105 (x2) Cables VL-CBR-0401 VL-CBR-1401 VL-CBR-1402 VL-CBR-2010 VL-CBR-2011 VL-CBR-2012 VL-CBR-2031 Memory VL-MM9-xxxx Drives VL-HDS35-xxx VL-F15-xxxx Hardware VL-PS-ATX12-300A VL-HDW-106 VL-HDW-108 VL-HDW-109 Miscellaneous VL-HDW-111 VL-HDW-203 VL-HDW-401 VL-EPH-V6 Description Copperhead cable kit. Includes VL-CBR-0702, 0808, 1201, 4004, 5013, and VL-HDW-105 (x2). Primary breakout cable (4 USB, 4 RS-232/422, programmable LED, speaker, audio, reset push button, power push button) 12-pin 2 mm (latching) / 15-pin VGA adapter 20" SATA cable. Latching. 12” power adapter cable. ATX12 to Copperhead. Cable & paddleboard for the A/D, D/A, DIO, CTC 15.24 mm standoffs, metric thread (four per kit) 6.25" ATX to SATA power cable 6" 14-pin cable assembly for (2) SPX modules 12" 14-pin cable assembly for (4) SPX modules 20” 18-bit LVDS flat panel cable (Hirose) 20” 18-bit LVDS flat panel cable (JAE) 20” 24-bit LVDS flat panel cable (Hirose) 36” miniDisplayPort to MiniDisplayPort DDR3 PC3-12800 SO-DIMM memory module (1.35v) Expansion Modules Part Number Description Network VL-MPEe-W2E Wi-Fi 802.11 a/b/g/n VL-SPX-3 CANbus Module single-channel V2.0B VL-MPEe-E3E Gigabit Ethernet adapter Serial I/O VL-MPEe-U2E Quad serial plus twelve GPIOs Analog & Digital I/O VL-MPEe-A1E Analog input (12-bit resolution) VL-MPEe-A2E Analog input (16-bit resolution) VL-SPX-1 Analog Input Module 8-Channels VL-SPX-2 Digital I/O Module 16-lines VL-SPX-4 Analog Output Module 4-channels 12-bit VL-SPX-5 Solid State Switch Module 8-channel GPS VL-MPEu-G2E GPS receiver Solid-State Storage (flash memory) VL-MPEs-F1Exx mSATA module (4/16/32 GB) (SATA) Adapters VL-MPEs-S3E SATA adapter Form Factor Mini PCIe SPX Mini PCIe Mini PCIe Mini PCIe Mini PCIe SPX SPX SPX SPX Mini PCIe Mini PCIe Mini PCIe 3.5” hard drive (SATA) eUSB flash module ATX12 development power supply 0.6” standoffs, English thread (four per kit) Mini PCIe / mSATA hardware kit (metric thread) 2.5 mm eUSB hardware kit Half to Full Size MiniPCIe Adapter kit. Metal adapter and screws (2). PC/104 extractor tool (metal) Thermal compound paste (1.75g) Display Port to Dual Channel LVDS converter Mini PCIe Modules 07/29/16 12100 SW Tualatin Rd., Tualatin, OR 97062 | (503) 747-2261 | Info@VersaLogic.com | www.VersaLogic.com C O R P O R A T I O N
VL-EBXE-41SLK 价格&库存
很抱歉,暂时无法提供与“VL-EBXE-41SLK”相匹配的价格&库存,您可以联系我们找货
