VL-EPICS-36S
VL-EPICS-36S
    VERSALOGIC
    SBC CORE II DUO 2.26 GHZ MAX 4GB
VL-EPICS-36S 数据手册
KOMODO SUMIT™ on EPIC™ Single Board Computer ƒƒ Intel® Core™2 Duo processor ƒƒ SUMIT and ISA expansion ƒƒ Extended temp. version ƒƒ Gigabit Ethernet ƒƒ High-performance video ƒƒ Four serial ports ƒƒ MiniBlade™ flash socket Highlights SUMIT and PC/104™ Compatible Supports SUMIT and ISA expansion on an EPIC format. Intel Core 2 Duo Processor Up to 2.26 GHz performance. High-performance Video 3D video acceleration (Gen 5.0). Analog and LVDS flat panel outputs. Network Support Gigabit Ethernet with remote boot support. System RAM Up to 4 GB DDR3 RAM for system flexibility. USB I/O Four USB 2.0 ports support keyboard, mouse, and other devices. Device I/O Four serial ports, dual SATA interface, and HD audio. Flash Memory MiniBlade socket and eUSB interface for high-reliability flash storage. Extended Temperature Version -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock / vibration environments. SPX™ Expansion Supports expansion with versatile SPX add-on I/O modules. Overview The Komodo is a versatile single board computer (SBC) that leverages the ultra-high performance of an Intel Core 2 Duo processor. This robust SBC is the ideal solution for demanding industrial, medical, defense, and aerospace applications where performance and dependability are crucial design factors. Based upon the EPIC-sized industry standard footprint, the Komodo features the SUMIT expansion interface as defined by the Small Form Factor Special Interest Group (SFF-SIG). This provides OEMs with a stackable multi-board expansion interface that supports both high- and low-speed signals. This simplifies adding both standard and custom I/O boards to the system. The Komodo expansion interfaces include PCIe, USB, LPC, SPI, SMBus, as well as ISA bus support for PC/104 modules. Like all VersaLogic products, this SBC is designed to support OEM applications where high reliability and long-term availability are required. From application design-in to 5+ guaranteed years of production life, the Komodo provides a durable embedded computer solution with an exceptional cost of ownership. The Komodo is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in very low quantities. Details The combination of Intel’s dual core processor, along with its companion chipset, provide the majority of the Komodo’s features including high-speed video with LVDS and analog VGA output, four USB 2.0 ports, four serial ports, gigabit Ethernet, dual SATA interface, HD audio, and PS/2 keyboard and mouse support. The SUMIT interface provides three x1 PCIe lanes, LPC, SPI, SMBus, and four additional USB channels. The PC/104 connector provides ISA bus compatibility. A MiniBlade socket and eUSB interface provide high-reliability flash storage, while VersaLogic’s SPX expansion interface creates additional access to cost-effective plug-in I/O solutions. The Komodo supports up to 4 GB of DDR3 system memory and is designed and tested to MIL-STD-202G shock and vibration standards. The Komodo features an embedded BIOS with OEM enhancements from Phoenix Technologies. The field-reprogrammable BIOS supports custom defaults and the addition of firmbase applications for security processes, remote booting, and other pre-OS software functions. The Komodo is compatible with a variety of popular operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com KOMODO SUMIT on EPIC Single Board Computer S PEC I F  I CATI O N S General Board Size Processor Chipset Power Requirements EPIC standard: 115 mm x 165 mm (4.5” x 6.5”) Intel Core 2 Duo (P8400). Up to 1066 MHz FSB. 3 MB L2 cache. Temperature protected. GM45 + ICH9M +5V running Windows XP with 1 GB RAM, Ethernet, keyboard, and mouse: Idle Typical Max VL-EPICs-36S 2.5A (12.5W) 4A (20W) 5.5A (27.5W) VL-EPICs-36E 2.3A (11.5W) 3.1A (15.5W) 3.9A (19.5W) Environmental VL-EPICs-36S (Top) VL-EPICs-36S (Bottom) Ordering Information Model VL-EPICs-36S VL-EPICs-36E Processor Speed Intel Core 2 Duo 2.26 GHz Intel Core 2 Duo 1.2 GHz Operating Temp. Cooling 0° to +60°C Fan -40° to +85°C Fan Vibration, Random Mechanical Shock Accessories VL-CBR-0401*...................................... 6.25” ATX to SATA power adapter cable VL-CBR-0701*....................................................................... 19.75” SATA cable VL-CBR-0702.......................................................... 19.75” SATA cable, latching VL-CBR-0803*................................ 12” 8-pin latching / two 3.5 mm audio cable VL-CBR-1201*.........................12-pin 2 mm latching / 15-pin VGA adapter cable VL-CBR-1401.......................................... Cable assembly for two SPX modules VL-CBR-1402..........................................Cable assembly for four SPX modules VL-CBR-2010......................................20” 18-bit LVDS flat panel cable (Hirose) VL-CBR-2011..........................................20” 18-bit LVDS flat panel cable (JAE) VL-CBR-2012......................................20” 24-bit LVDS flat panel cable (Hirose) VL-CBR-2014......................................................... LVDS to VGA adapter board VL-CBR-2022*..........................................................ATX to 10-pin power cable VL-CBR-5009*....................................................I/O cable set and paddleboard VL-CBR-5009A.................................................................. 18” I/O ribbon cable VL-CKR-KOMO............................................................... Development cable kit VL-ENCL-5C.................................................................. Development enclosure VL-EPHs-B1x........................................................ SUMIT to USB adapter board VL-F15-xxxx....................................................................... eUSB module (USB) VL-F23-xxxx................................................................ MiniBlade module (USB) VL-HDS35-xxx...................................................................3.5” SATA hard drive VL-HDW-105*...................................... SUMIT standoff package (metric thread) VL-HDW-106..................................... SUMIT standoff package (English thread) VL-MM7-xxxx..................................................................DDR3 SDRAM module VL-SPX-x......................................................................SPX expansion modules Memory Video Mass Storage Network Interface Device I/O * Included in VL-CKR-KOMO cable kit SUMIT Resources Form Factor: SUMIT on EPIC SUMIT-A PCIe x1 1 PCIe x4 USB 4 ExpressCard – LPC ü SPI / µWire SPI SMBus / I 2 C SMBus +12V ü System Reset & Hardware Monitors Stackable Bus Expansion RoHS Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep SUMIT-B 2 – +5V ü ü +5Vsb ü ü +3.3V ü ü Software System RAM Major voltage rails monitored SUMIT, PC/104 (ISA) VersaLogic SPX interface RoHS (2002/95/CE) compliant -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis One SO-DIMM socket. Up to 4 GB DDR3 SDRAM. General Integrated high-performance video. Intel GMA 4500 MHD graphics core. Simultaneous independent analog and flat panel output capability. Optional video adapter card converts LVDS output to VGA for dual VGA operation. VRAM Up to 512 MB shared DRAM Desktop Display Interface* Standard analog output (VGA) OEM Flat Panel Interface 18/24-bit LVDS interface. CMOS-selectable TFT panel types. Hard Drive Dual SATA interface (Revision 2.0) Flash One MiniBlade socket (USB or SATA signaling). One eUSB interface (USB signaling). Ethernet* Autodetect 10BaseT/100BaseTX/1000BaseT port Network Boot Option Intel boot agent (downloadable) supports PXE protocol. Argon Managed Boot Agent (optional with royalty fee) supports PXE, RPL, NetWare, TCP/IP (DHCP, BOOTP) remote boot protocols. USB*‡ Four USB 2.0 / 1.1 ports COM 1 / 2 Interface* RS-232. 16C550 compatible. 115 Kbps. COM 3 / 4 Interface* RS-232/422/485 selectable. 16C550 compatible. 460 Kbps. Stereo HD audio in / out Audio Other PS/2 keyboard and mouse. Four additional USB ports available through SUMIT interface with appropriate adapter board. BIOS Phoenix Technologies Embedded BIOS with OEM enhancements. Field reprogrammable. Support for USB keyboard / mouse and USB boot. User-configurable CMOS defaults. Operating Systems Compatible with most x86 operating systems, including Windows, Windows Embedded, Linux, VxWorks, and QNX * TVS protected port (enhanced ESD protection) ‡ Power pins on this port are overload protected Data represents standard operation at +25°C with +5V supply unless otherwise noted. Specifications are subject to change without notification. Intel and Intel Core are trademarks of Intel Corp. PC/104 and EPIC are trademarks of the PC/104 Consortium. SUMIT and MiniBlade are trademarks of the SFF-SIG. SPX is a trademark of VersaLogic Corp. 02/15/13 VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EPICS-36S 价格&库存
很抱歉,暂时无法提供与“VL-EPICS-36S”相匹配的价格&库存,您可以联系我们找货
