VL-EBX-37E
VL-EBX-37E
    VERSALOGIC
    SBC CORE II DUO 1.2 GHZ MAX 8GB
VL-EBX-37E 数据手册
MAMBA EBX™ Single Board Computer ƒƒ Intel® Core™2 Duo processor (2.26 GHz) ƒƒ SATA (2 ports) ƒƒ High-performance video ƒƒ HD audio ƒƒ Dual gigabit Ethernet ƒƒ PCIe Mini Card socket ƒƒ DDR3 RAM (up to 8 GB) ƒƒ Industrial temp. version ƒƒ USB 2.0 (6 ports) ƒƒ SPX™ I/O expansion ƒƒ Analog + Digital I/O ƒƒ Serial I/O (4 ports) Highlights EBX Form Factor Industry-standard format with PC/104-Plus™ expansion. Intel Core 2 Duo Processor Very high performance. High-performance Video 3D video acceleration (Gen 5.0). Analog and LVDS flat panel outputs. Overview The Mamba is an embedded single board computer (SBC) featuring a high-performance Intel Core 2 Duo processor. Based on the EBX industry-standard form factor, the Mamba supports PC/104-Plus stackable expansion boards. With its combination of very high performance (up to 2.26 GHz), mid-range power consumption (18.5W typ.), and extensive on-board I/O capabilities, the Mamba is an ideal embedded computer solution for medical, security, defense, transportation, and industrial applications that rely on fast on-board processing of large amounts of data. System RAM Like all VersaLogic products, the Mamba is designed to support OEM applications where high reliability and long-term availability are required. From application design-in support, to its 5+ year production life guarantee, the Mamba provides a durable embedded computer solution with an excellent cost of ownership. The Mamba is manufactured and tested to the highest quality standards and is fully RoHS compliant. Customization is available, even in low OEM quantities. USB I/O Details Network Support Dual gigabit Ethernet with remote boot support. Up to 8 GB DDR3 RAM. Six USB 2.0 ports support keyboard, mouse, and other devices. Device I/O Four serial ports, two SATA ports, and HD audio. Analog + Digital I/O On-board data acquisition support. Eight analog inputs + four analog outputs + thirty-two digital I/O on standard models. Additional analog channels in custom configurations. Mini Card Socket Supports plug-in Wi-Fi modems, GPS receivers, flash data storage, and other cards. Flash Memory eUSB interface for plug-in flash storage. Other flash options available in custom configurations. Industrial Temperature Version -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock/vibration environments. SPX Expansion Add additional analog, digital, or CANbus modules. Driven by a 2nd generation Intel Core 2 Duo processor designed specifically for embedded applications, the Mamba runs at up to 2.26 GHz. Enhanced Intel SpeedStep® technology provides dynamic processor frequency scaling to meet instantaneous performance needs while minimizing power draw and heat dissipation. This allows users to fine-tune the balance between power conservation and performance to suit their application needs. Intel’s GM45 + ICH9M chipset offers graphics core speeds up to 533 MHz for high-end graphics, advanced 3D rendering, high-definition video playback, and media acceleration for video CODECs. A dual-channel LVDS flat panel interface and an analog VGA video interface support a wide range of display configurations. Mamba’s standard on-board features include dual gigabit Ethernet, two SO-DIMM sockets for up to 8 GB DDR3 RAM, six USB 2.0 ports, four serial ports, two SATA ports, HD audio, and eUSB flash storage. On-board data acquisition features include up to sixteen analog inputs, up to eight analog outputs, and thirty-two digital I/O lines. The PC/104-Plus expansion site provides plug-in access to industry-standard expansion modules. Additional system expansion and communications flexibility is available via the on-board PCI Express Mini Card socket which can accommodate plug-in Wi-Fi modems, GPS receivers, and more. VersaLogic’s SPX expansion interface creates additional access to cost-effective plug-in I/O including analog, digital, and CANbus solutions. Available in both industrial (-40° to +85°C) and commerical (0° to +60°C) temperature versions; the Mamba meets MIL-STD-202G specifications for shock and vibration. Transient voltage suppression VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com MAMBA EBX Single Board Computer Specifications (TVS) devices on critical I/O ports provide enhanced electrostatic discharge (ESD) protection for the system. General The Mamba features an embedded BIOS with OEM enhancements from Phoenix Technologies. The field-reprogrammable BIOS supports custom defaults and the addition of firmbase applications for security processes, remote booting, and other pre-OS software functions. The Mamba is compatible with a variety of popular operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX. Chipset Power Requirements * Ordering Information Model VL-EBX-37A VL-EBX-37F Processor Intel Core 2 Duo Intel Core 2 Duo Speed 2.26 GHz 1.2 GHz Operating Temp. 0° to +60°C -40° to +85°C Environmental Description Development cable kit. Includes bold items below. 6.25” ATX to SATA power adapter cable 19.75” SATA cable 12” 8-pin latching / two 3.5 mm stereo line in / out cable 12-pin 2 mm latching / 15-pin VGA adapter cable ATX to 10-pin power cable I/O cable and paddleboard Primary breakout cable and paddleboard 0.6” standoff package (metric thread) VL-CBR-0201 VL-CBR-0702 VL-CBR-1401 VL-CBR-1402 VL-CBR-2010 VL-CBR-2011 VL-CBR-2012 VL-CBR-2014 VL-CBR-ANT01 VL-CFA-2A VL-ENCL-5C VL-F15-xxxx VL-F23-xxxx VL-TBD-xxxx VL-HDS35-xxx VL-HDW-106 VL-HDW-107 VL-MM7-xxxx VL-PS200-ATX VL-SPX-x VL-WD10-CBN Wi-Fi antenna adapter cable 19.75” SATA cable, latching Cable assembly for two SPX modules Cable assembly for four SPX modules 20” 18-bit LVDS flat panel cable (Hirose) 20” 18-bit LVDS flat panel cable (JAE) 20” 24-bit LVDS flat panel cable (Hirose) LVDS to VGA adapter board Wi-Fi (802.11n) antenna CompactFlash adapter (SATA) Development enclosure eUSB module (USB) MiniBlade™ module (USB) Disk on Module (SATA) 3.5” hard drive (SATA) 0.6” standoff package (English thread) PCI Express Mini Card mounting hardware kit DDR3 SDRAM module Development power supply SPX expansion modules PCI Express Mini Card: 802.11g/n wireless Vibration, Random Mechanical Shock Memory Video Mass Storage ‡  Power pins on this port are overload protected Specifications are subject to change without notification. Intel, Intel Core, and SpeedStep are trademarks of Intel Corp. MiniBlade is a trademark of the SFF-SIG. SPX is a trademark of VersaLogic Corp. All other trademarks are the property of their respective owners. 02/15/13 System RAM EBX standard: 5.75” x 8” (146 mm x 203 mm) Intel Core 2 Duo (P8400). Up to 1066 MHz FSB. 3 MB L2 cache. Temperature protected. GM45 + ICH9M Model VL-EBX-37A  VL-EBX-37F Idle Typical Max 2.4A (12.0W) 3.7A (18.5W) 5.0A (25.0W) 2.2A (11.0W) 2.9A (14.3W) 3.5A (17.5W) Major voltage rails monitored. Watchdog timer with 20 ms resolution. PC/104-Plus: PCI, ISA PCI Express Mini Card socket. SPX interface. RoHS (2002/95/CE) compliant Model VL-EBX-37A VL-EBX-37F Operating Temperature 0° to +60°C -40° to +85°C -40° to +85°C Free air from -40° to +85°C 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 minutes per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 minutes per axis MIL-STD-202G, Method 213B, Condition G: 20g half-sine, 11 ms duration per axis Two SO-DIMM sockets. Up to 8 GB DDR3 SDRAM. General Integrated high-performance video. Intel GMA 4500 MHD graphics core. Optional video adapter card converts LVDS output to VGA for dual VGA operation. VRAM Up to 512 MB shared DRAM Desktop Display Interface † Standard analog output (VGA) OEM Flat Panel Interface Dual-channel LVDS interface. 18/24-bit. CMOSselectable TFT panel types. Up to 1920 x 1200 (24 bits). Hard Drive Two SATA (Revision 2.0) ports Standard eUSB (USB signaling) Flash Custom Network Interface Ethernet † Network Boot Option Device I/O USB † ‡ COM 1 / 2 Interface † COM 3 / 4 Interface † Analog Input MiniBlade (USB or SATA signaling) SATA DOM (SATA signaling) Two autodetect 10BaseT/100BaseTX/1000BaseT ports Intel boot agent (downloadable) supports PXE protocol. Argon Managed Boot Agent (optional with royalty fee) supports PXE, RPL, NetWare, TCP/IP (DHCP, BOOTP) remote boot protocols. Six USB 2.0/1.1 ports RS-232. 16C550 compatible. 115 Kbps. RS-232/422/485 selectable. 16C550 compatible. 460 Kbps. Standard Custom Eight channels Sixteen channels 12-bit. Single-ended.100 Ksps. Per-channel input ranges of 0 to +5V, ±5V, 0 to +10V, and ±10V. Analog Output Digital I/O Audio † Counter / Timers Other *  Power specifications represent operation at +25°C with +5V supply running Windows XP with 1 GB RAM, dual Ethernet, keyboard, and mouse. Typical power computed as the mean value of Idle and Maximum power specifications. Maximum power is measured with 95% CPU utilization. †  TVS protected port (enhanced ESD protection) System Reset & Hardware Monitors Stackable Bus Other I/O Expansion RoHS Operating Temperature Storage Temperature Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep Accessories Part Number VL-CKR-MAMBA VL-CBR-0401 VL-CBR-0701 VL-CBR-0803 VL-CBR-1201 VL-CBR-2022 VL-CBR-4004 VL-CBR-5009 VL-HDW-105 Board Size Processor Software BIOS Operating Systems Standard Custom Four channels Eight channels 12-bit. Single-ended. 100 Ksps. 0 to +4.096V. Thirty-two TTL I/O lines (3.3V). Independently configurable. Digital HD audio in/out Three general-purpose timer inputs PS/2 keyboard and mouse Phoenix Technologies Embedded BIOS with OEM enhancements. Field reprogrammable. User-configurable CMOS defaults. Compatible with most x86 operating systems including Windows, Windows Embedded, Linux, VxWorks, and QNX VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com
VL-EBX-37E 价格&库存
很抱歉,暂时无法提供与“VL-EBX-37E”相匹配的价格&库存,您可以联系我们找货
VL-EBX-37E
  • 1+21684.671881+2810.74634
