VL-MM9-4EBN
VL-MM9-4EBN
    VERSALOGIC
    DRAM SODIMM DDR3L 4GB PC3-12800
VL-MM9-4EBN 数据手册
Product Specifications PART NO.: VL47D5263A-K0SD-S1 REV: 1.0 General Information 4GB 512Mx64 DDR3 SDRAM LOW VOLTAGE NON-ECC UNBUFFERED SODIMM 204-PIN Description The VL47D5263A is a 512Mx64 DDR3 SDRAM high density SODIMM. This dual rank memory module consists of sixteen CMOS 256Mx8 bits with 8 banks DDR3 synchronous DRAMs in BGA packages and a 2K EEPROM with thermal sensor in an 8-pin MLF package. This module is a 204-pin small-outline dual in-line memory module and is intended for mounting into an edge connector socket. Decoupling capacitors are mounted on the printed circuit board for each DDR3 SDRAM. Features • • • • • • • • • • • • • • • • • • • • • • Pin Description 204-pin, small-outline dual in-line memory module (SODIMM) Fast data transfer rate: PC3-12800 VDD = VDDQ = 1.35V (1.28V~1.45V) & 1.5V (1.425V~1.575V) JEDEC standard 1.35V (1.28V~1.45V) & 1.5V (1.425V~1.575V) VDDSPD = 3.0V to 3.6V Eight internal component banks for concurrent operation 8-bit pre-fetch architecture Bi-directional differential data-strobe Nominal and dynamic on-die termination (ODT) ZQ calibration support Programmable CAS# latency: 11 (DDR3-1600) Programmable burst; length (8) Average refresh period 7.8 us Asynchronous reset Fly-by topology On board terminated command, address, and control bus Serial presence detect (SPD) EEPROM with thermal sensor o o o Thermal sensor range: -40 C to +125 C (Max +/-3 C accuracy) Lead-free, RoHS compliant Gold edge contacts PCB: Height 30.00mm (1.181”), double sided component o o Operating temperature (TOPER): -40 C to +95 C (module screening using commercial DRAM) o Function A0~A14 Address Inputs A10/AP Address Input/ Autoprecharge A12/BC# Address Input/ Burst Chop BA0~BA2 Bank Address Inputs DQ0~DQ63 Data Input/Output DQS0~DQS7 Data Strobes DQS0#~DQS7# Data Strobes Complement DM0~DM7 Data Masks CK0,CK0#, CK1,CK1# Clock Input ODT0, ODT1 On-die Termination Control CKE0, CKE1 Clock Enables CS0#, CS1# Chip Selects RAS# Row Address Strobes CAS# Column Address Strobes WE# Write Enable VDD Voltage Supply VSS Ground SA0~SA1 SPD Address SDA SPD Data Input/Output SCL SPD Clock Input EVENT# Temperature Event Output VREFCA Reference Voltage for CA VREFDQ Reference Voltage for DQ VDDSPD SPD Voltage Supply VTT Termination Voltage RESET# Register and SDRAM Control NC No Connect o Notes: Double refresh rate is required when 85 C < TOPER
VL-MM9-4EBN 价格&库存
很抱歉,暂时无法提供与“VL-MM9-4EBN”相匹配的价格&库存,您可以联系我们找货
VL-MM9-4EBN
  • 1+782.913751+101.28185
库存:94
