VL-HDW-201
VL-HDW-201
    VERSALOGIC
    EXTRACTION TOOL FOR PC/104
VL-HDW-201 数据手册
Page 1 of 1 VL-HDW-201 PC/104 Extraction Tool Separates (unplugs) PC/104 and PC/104-Plus modules from each other. Also removes PC/104 and PC/104-Plus modules from expansion sites on Single Board Computers. Description VersaLogic's PC/104 extraction tool speeds development and production of PC/104 systems by greatly simplifying the task of separating PC/104 modules. Up to now, detaching the modules from each other was a difficult and timeconsuming chore which often resulted in bent connector pins. Unplugging the newer PC/104-Plus modules was especially difficult, due to the hundreds of interconnected pins on both ends of the module. Now PC/104 users can simply place the extraction tool between the boards, squeeze, and the boards easily detach from the stack. The extraction tool can be used in both development and production environments for separating PC/104 modules from each other, and for separating PC/104 modules from SBC expansion sites. Using the extraction tool is as simple as placing it at the edge of the boards to be separated and squeezing the handle. It features a lifetime warranty and can be safely used with electrostatic sensitive devices. The extractor is a joint offering of two major PC/104 vendors, VersaLogic Corp. and parvus Corp. It is available in single unit quantities, or at no charge with evaluation orders for any of VersaLogic's PC/104-Plus compatible products. Instructions To use the extraction tool with PC/104 modules, turn the tab marked "Single Board Computers" away from the stack. To use the tool with an SBC, position the tab against the bus connector. Specifications General Size 4.5" x 2.5" Mechanical Compatibility PC/104 PC/104-Plus Single Board Computers Data represented is subject to change. http://versalogic.com/products/DS.asp?ProductID=37 1/23/2013
VL-HDW-201 价格&库存
很抱歉,暂时无法提供与“VL-HDW-201”相匹配的价格&库存,您可以联系我们找货
