VL-MM8-1EBN
VL-MM8-1EBN
    VERSALOGIC
    1GB, DDR2 EX TEMP ROHS
VL-MM8-1EBN 数据手册
Product Specifications PART NO.: VL470T2863A-E6S-I REV: 1.0 General Information 1GB 128Mx64 DDR2 SDRAM NON-ECC UNBUFFERED SODIMM 200-PIN Description The VL470T2863A is a 128Mx64 DDR2 SDRAM high density SODIMM. This single rank memory module consists of eight CMOS 128Mx8 bits with 8 banks DDR2 synchronous DRAMs in BGA packages and a 2K EEPROM in an 8-pin TSSOP package. This module is a 200-pin small-outline dual in-line memory module and is intended for mounting into an edge connector socket. Decoupling capacitors are mounted on the printed circuit board for each DDR2 SDRAM. Features • • • • • • • • • • • • • • • • • • • • • • Pin Description 200-pin, small-outline dual in-line memory module (SODIMM) JEDEC pin out Fast data transfer rate: PC2-5300 VDD = VDDQ = 1.8V +/-0.1V JEDEC standard 1.8V (SSTL_18 compatible) VDDSPD = 1.7V to 3.6V Differential data strobe (DQS, DQS# ) option Differential clock inputs (CK, CK#) Four-bit pre-fetch architecture DLL aligns DQ and DQS transition with CK Nominal and dynamic on-die termination (ODT) Programmable CAS# latency: 5 (DDR2-667) Write latency = Read latency - 1 tCK Eight internal component banks for concurrent operation Programmable burst; length (4, 8) Adjustable data-output drive strength Auto & self refresh, (8K/64ms refresh) Serial presence detect (SPD) with EEPROM Gold edge contacts Lead-free, RoHS compliant PCB: Height 30.00mm (1.181”), double sided component o o Industrial temperature (TOPER): -40 C to +95 C (module screening using commercial DRAM) o Pin Name Function A0~A13 Address Inputs A10/AP Address Input/ Autoprecharge BA0~BA2 Bank Address Inputs DQ0~DQ63 Data Input/Output DQS0~DQS7 Data Strobes DQS0#~DQS7# Data Strobes Complement DM0~DM7 Data Masks CK0, CK0#, CK1, CK1# Clock Inputs ODT0 On-die Termination Control CKE0 Clock Enables CS0# Chip Selects RAS# Row Address Strobes CAS# Column Address Strobes WE# Write Enable VDD Voltage Supply VSS Ground SA0~SA1 SPD Address SDA SPD Data Input/Output SCL SPD Clock Input VDDSPD SPD Voltage Supply VREF SSTL_18 Reference Voltage NC No Connect o Notes: Double refresh rate is required when 85 C < TOPER
VL-MM8-1EBN 价格&库存
很抱歉,暂时无法提供与“VL-MM8-1EBN”相匹配的价格&库存,您可以联系我们找货
