VL-F20-8SBN
VL-F20-8SBN
    VERSALOGIC
    8GB DISKONMODULE STD TEMP
VL-F20-8SBN 数据手册
Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ RoHS Compliant Value Added ATA Disk Module Ⅲ Specification for Mini ADM III (44P/270D) January 19, 2009 Revision 1.0 Apacer Technology Inc. 9/F, No. 100, Hsin Tai Wu Rd., Hsichih, Taipei Hsien 221, Taiwan Tel: +886-2-2696-1666 Fax: +886-2-2696-1668 www.apacer.com 1 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ Features:  Standard ATA/IDE bus interface – ATA command set compatible – ATA operating mode supports up to: PIO Mode-4 Multiword DMA Mode-2 Ultra DMA Mode-4  Connector type – 44-pin female connector  Low power consumption (typical) – Supply voltage: 3.3V & 5V – Active mode: 85mA/95mA (3.3V/5V) – Sleep mode: 500µA /600µA (3.3V/5V)  Performance – Sustained read: Up to 35 MB/sec – Sustained write: Standard: Up to 15 MB/sec High Speed: Up to 25 MB/sec   Temperature ranges – Operation: Standard: 0°C to 70°C 1 ET : -40°C to 85°C – Storage: -40°C to 100°C  Flash management – Intelligent endurance design Advanced wear-leveling algorithms S.M.A.R.T. Technology Built-in Hardware ECC Enhanced Data Integrity – Intelligent power failure recovery – Enhanced security level Secure Protection Zone Quick Erase  RoHS compliant Capacity – Standard: 128, 256, 512 MB 1, 2, 16 GB – High Speed: 256, 512 MB 1, 2, 4, 8 GB *Extended Temperature 2 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 4 1.1 PERFORMANCE-OPTIMIZED CONTROLLER ............................................................................................................4 1.1.1 Power Management Unit (PMU)..................................................................................................................4 1.1.2 SRAM Buffer .................................................................................................................................................4 2. FUNCTIONAL BLOCK .......................................................................................................... 5 3. PIN ASSIGNMENTS ............................................................................................................... 6 4. CAPACITY SPECIFICATION............................................................................................... 7 4.1 PERFORMANCE SPECIFICATION .............................................................................................................................7 4.2 ENVIRONMENTAL SPECIFICATION.........................................................................................................................8 5. FLASH MANAGEMENT ........................................................................................................ 9 5.1 INTELLIGENT ENDURANCE DESIGN.......................................................................................................................9 5.1.1 Advanced wear-leveling algorithms .............................................................................................................9 5.1.2 S.M.A.R.T. Technology .................................................................................................................................9 5.1.3 Built-in Hardware ECC ................................................................................................................................9 5.1.4 Enhanced Data Integrity...............................................................................................................................9 5.2 INTELLIGENT POWER FAILURE RECOVERY .........................................................................................................10 5.3 ENHANCED SECURITY LEVEL .............................................................................................................................10 5.3.1 Secure Protection Zone...............................................................................................................................10 5.3.2 Quick Erase ................................................................................................................................................10 6. SOFTWARE INTERFACE .................................................................................................. 11 6.1 COMMAND SET ...................................................................................................................................................11 7. ELECTRICAL SPECIFICATION ...................................................................................... 13 8. PHYSICAL CHARACTERISTICS ..................................................................................... 14 8.1 DIMENSION – MINI ADM ...................................................................................................................................14 8.1.1 44 pin/ 270 degree .....................................................................................................................................14 9. PRODUCT ORDERING INFORMATION ........................................................................ 15 9.1 PRODUCT CODE DESIGNATIONS .........................................................................................................................15 9.2 VALID COMBINATIONS .......................................................................................................................................16 3 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 1. General Description Apacer’s ATA-Disk Module (ADM) is a high-performance, embedded flash drive designed to replace the conventional IDE hard disk drive. The ADMs can be plugged into a standard IDE connector commonly found in desktops, IT-STB, industrial PCs and thin client systems. Apacer’s ADM SSD has a built-in microcontroller with file management firmware that communicates with the ATA standard interfaces. No additional or proprietary host software is required. Well suited for embedded flash storage applications by offering new and expanded functionalities as well as more cost-effective designs, better performance and increased reliability, ADM is designed to work at either 5 or 3.3 Volts, supports the standard ATA/IDE protocol for up to PIO Mode-4, Multiword DMA Mode-2 and Ultra DMA Mode-4 interfaces, and uses the standard ATA driver complying with all major operating systems such as Microsoft’s Windows series, Mac OS, and Unix variants. Featuring technologies as Advanced Wear-leveling algorithms, S.M.A.R.T, Enhanced Data Integrity, Intelligent Power Failure Recovery, Secure Protection Zone and Quick Erase, Apacer’s ADM assures users of a versatile device on data storage. 1.1 Performance-Optimized Controller The kernel of an ATA-Disk Module is the ATA controller, which translates standard ATA signals into the data and controls of the flash media. This proprietary ATA controller is specifically designed to attain high data throughput from the host to the flash. 1.1.1 Power Management Unit (PMU) The power management unit (PMU) controls the power consumption of the ATA-Disk Module. It reduces the power consumption of the ATA-Disk Module Controller by putting circuitry not in operation into sleep mode. The PMU has zero wake-up latency. 1.1.2 SRAM Buffer The ATA-Disk Module Controller performs as an SRAM buffer to optimize the host’s data transfer to and from the flash media. 4 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 2. Functional Block The ATA-Disk Module (ADM) includes the ATA controller and flash media, as well as the ATA standard interface. Figure 2-1 shows the functional block diagram. Flash Array Flash Media HOST ATA/IDE Bus Flash Media ATA Controller Flash Media Flash Media Figure 2-1: Functional block diagram 5 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 3. Pin Assignments Table 3-1 lists the pin assignments with respective signal names for the 44-pin configuration. A “#” suffix indicates the active low signal. The pin type can be input, output or input/output. Table 3-1: Pin assignments for the 44-pin configuration Pin No. Signal Name Pin Type I/O Type1 Pin No. Signal Name Pin Type 1 RESET# I I2U 2 GND - Ground 3 D7 I/O I1Z, O2 4 D8 I/O I1Z, O2 5 D6 I/O I1Z, O2 6 D9 I/O I1Z, O2 7 D5 I/O I1Z, O2 8 D10 I/O I1Z, O2 9 D4 I/O I1Z, O2 10 D11 I/O I1Z, O2 11 D3 I/O I1Z, O2 12 D12 I/O I1Z, O2 13 D2 I/O I1Z, O2 14 D13 I/O I1Z, O2 15 D1 I/O I1Z, O2 16 D14 I/O I1Z, O2 17 D0 I/O I1Z, O2 18 D15 I/O I1Z, O2 19 GND - Ground 20 NC - - 21 DMARQ# O O1 22 GND I I2Z 24 GND - Ground I I2Z 26 GND - Ground O O1 28 NC/CSEL I I1U 23 IOWR# STOP I/O Type Ground IORD# 25 HDMARDY# HSTROBE# IORDY 27 DDMARDY# DSTROBE 29 DMACK# I I2U 30 NC - - 31 INTRQ O O1 32 IOCS16# O O2 33 A1 I I1Z 34 PDIAG# I/O I1U, O1 35 A0 I I1Z 36 A2 I I1Z 37 CS1FX# I I2Z 38 CS3FX# I I2Z 39 DASP# I/O I1U, O6 40 GND - Ground 41 VDD - Power 42 VDD - Power 43 GND - Ground 44 NC - - 6 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 4. Capacity Specification Capacity specification of the ATA-Disk Module (ADM) product family is available as shown in Table 4-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 4-1: Capacity specifications Capacity Total bytes Cylinders Heads Sectors Max LBA 128 MB 128,057,344 977 8 32 250,112 256 MB 256,901,120 980 16 32 501,760 512 MB 512,483,328 993 16 63 1,000,944 1GB 1,024,966,656 1986 16 63 2,001,888 2GB 2,048,385,024 3969 16 63 4,000,752 4GB 4,096,253,952 7937 16 63 8,000,496 8GB 8,001,552,384 15504 16 63 15,628,032 16GB 16,001,040,384 16383 16 63 31,252,032* *CYLINDERS, HEADS OR SECTORS ARE NOT APPLICABLE FOR THESE CAPACITIES. ONLY LBA ADDRESSING APPLIES 4.1 Performance Specification Performances of the Standard and High Speed ATA-Disk Module are listed in Table 4-2 and Table 4-3. Table 4-2: Standard Performance specifications Capacity Performance 128 MB / 256 MB 2 GB 16 GB 512 MB / 1 GB Sustained read (MB/s) 19 35 22 Sustained write (MB/s) 7 15 15 Table 4-3: High Speed Performance specifications Capacity 256 MB / 512 MB 1GB / 2 GB / 4 GB / 8 GB Sustained read (MB/s) 30 35 Sustained write (MB/s) 13 25 Performance 7 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 4.2 Environmental Specification Environmental specification of the ATA-Disk Module (ADM) product family follows the MIL-STD-810F standard which is shown in Table 4-4. Table 4-4: Environmental specifications Environment Temperature Specification * Operation 0°C to 70°C; -40°C to 85°C (ET ) Storage -40°C to 100°C Humidity Vibration (Non-Operation) Shock (Non-Operation) 5% to 95% RH (Non-condensing) Sine wave: 10~2000Hz, 15G (X, Y, Z axes) Half sine wave, Peak acceleration 50 G, 11 ms (X, Y, Z ; All 6 axes) *Extended Temperature 8 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 5. Flash Management 5.1 Intelligent Endurance Design 5.1.1 Advanced wear-leveling algorithms The NAND flash devices are limited by a certain number of write cycles. When using a file system, frequent file table updates is mandatory. If some area on the flash wears out faster than others, it would significantly reduce the lifetime of the whole device, even if the erase counts of others are far from the write cycle limit. Thus, if the write cycles can be distributed evenly across the media, the lifetime of the media can be prolonged significantly. The scheme is achieved both via buffer management and Apacerspecific advanced wear leveling to ensure that the lifetime of the flash media can be increased, and the disk access performance is optimized as well. 5.1.2 S.M.A.R.T. Technology S.M.A.R.T. is an acronym for Self-Monitoring, Analysis and Reporting Technology, an open standard allowing disk drives to automatically monitor their own health and report potential problems. It protects the user from unscheduled downtime by monitoring and storing critical drive performance and calibration parameters. Ideally, this should allow taking proactive actions to prevent impending drive failure. Apacer SMART feature adopts the standard SMART command B0h to read data from the drive. When the Apacer SMART Utility running on the host, it analyzes and reports the disk status to the host before the device is in critical condition. 5.1.3 Built-in Hardware ECC The ATA-Disk Module uses BCH Error Detection Code (EDC) and Error Correction Code (ECC) algorithms which correct up to eight random single-bit errors for each 512-byte block of data. High performance is fulfilled through hardware-based error detection and correction. 5.1.4 Enhanced Data Integrity The properties of NAND flash memory make it ideal for applications that require high integrity while operating in challenging environments. The integrity of data to NAND flash memory is generally maintained through ECC algorithms and bad block management. Flash controllers can support up to 8 bits ECC capability for accuracy of data transactions, and bad block management is a preventive mechanism from loss of data by retiring unusable media blocks and relocating the data to the other blocks, along with the integration of advanced wear leveling algorithms, so that the lifespan of device can be expanded. 9 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 5.2 Intelligent Power Failure Recovery The Low Power Detection on the controller initiates cached data saving before the power supply to the device is too low. This feature prevents the device from crash and ensures data integrity during an unexpected blackout. Once power was failure before cached data writing back into flash, data in the cache will lost. The next time the power is on, the controller will check these fragmented data segment, and, if necessary, replace them with old data kept in flash until programmed successfully. 5.3 Enhanced Security Level 5.3.1 Secure Protection Zone Partitioning with static commands to logically secure data, protection zones are the solid frameworks of file vaults. 3 different types of zones, unprotected, read-only, and restricted, are offered for effortless administration. When the product is shipped out of Apacer, all sectors are in the unprotected zone, which means there is no control on any data transaction. For further management control, the read-only zone can be set to be accessed exclusively for grantees, and the restricted zone, to be as the maximum security stockade with full administration privilege required. A maximum of 4 zones can be configured as either restricted or read-only zone presenting concurrently. The space outside these 4 zones is automatically in the unprotected zone if available. After the zone has been configured, the protection zone can be de-activated or re-activated by either software methods or hardware components. Protection zone configuration is non-volatile and it will be in effect until the next set of configuration overwrites it. 5.3.2 Quick Erase Accomplished by the Secure Erase (SE) command, which added to the open ANSI standards that control disk drives, “Quick Erase” is built into the disk drive itself and thus far less susceptible to malicious software attacks than external software utilities. It is a positive easy-to-use data destroy command, amounting to electronic data shredding. Executing the command causes a drive to internally completely erase all possible user data. This command is carried out within disk drives, so no additional software is required. Once executed, neither data nor the erase counter on the device would be recoverable, which blurs the accuracy of device lifespan. The process to erase will not be stopped until finished while encountering power failure, and will be continued when power is back on. 10 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 6. Software Interface 6.1 Command Set This section defines the software requirements and the format of the commands the host sends to the ATA-Disk Module (ADM). Commands are issued to the ADM by loading the required registers in the command block with the supplied parameters, and then writing the command code to the command register. The manner in which a command is accepted varies. Table 6-1: Command set (1 of 2) Code FR1 SC2 SN3 CY4 DH5 E5H or 98H - - - - D 8 - Execute-Drive-Diagnostic 90H - - - - D - Erase Sector(s) C0H - Y Y Y Y Y Flush-Cache E7H - - - - D - 8 Command Check-Power-Mode 7 LBA6 Format Track 50H - Y - Y Y Y Identify-Drive ECH - - - - D - Idle E3H or 97H - Y - - D - Idle-Immediate E1H or 95H - - - - D - Initialize-Drive-Parameters 91H - Y - - Y - NOP 00H - - - - D - Read-Buffer E4H - - - - D - Read-DMA C8H or C9H - Y Y Y Y Y C4H - Y Y Y Y Y Read-Sector(s) 20H or 21H - Y Y Y Y Y Read-Verify-Sector(s) 40H or 41H - Y Y Y Y Y Recalibrate 1XH - - - - D - Request-Sense 03H - - - - D - Security-Disable-Password F6H - - - - D - Security-Erase-Prepare F3H - - - - D - Security-Erase-Unit F4H - - - - D - Security-Freeze-Lock F5H - - - - D - Security-Set-Password F1H - - - - D - Security-Unlock F2H - - - - D - Seek 7XH - - Y Y Y Y - - - D - Read-Multiple Set-Features 7 EFH Y 11 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ Table 6-1: Command set (2 of 2) Code FR1 SC2 SN3 CY4 DH5 SMART B0H Y Y Y Y D Set-Multiple-Mode C6H - Y - - D - Set-Sleep-Mode E6H or 99H - - - - D - Standby E2H or 96H - - - - D - Standby-lmmediate E0H or 94H - - - - D - Translate-Sector 87H - Y Y Y Y Y Write-Buffer E8H - - - - D - Write-DMA CAH or CBH - Y Y Y Y Y Write-Multiple C5H - Y Y Y Y Y Write-Multiple-Without-Erase CDH - Y Y Y Y Y 30H or 31H - Y Y Y Y Y Write-Sector-Without-Erase 38H - Y Y Y Y Y Write-Verify 3CH - Y Y Y Y Y Command Write-Sector(s) LBA6 1. FR - Features register 2. SC - Sector Count register 3. SN - Sector Number register 4. CY - Cylinder registers 5. DH - Drive/Head register 6. LBA - Logical Block Address mode supported (see command descriptions for use) 7. Y - The register contains a valid parameter for this command 8. For the Drive/Head register: Y means both the ATA-Disk Module and Head parameters are used D means only the ATA-Disk Module parameter is valid and not the Head parameter 12 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 7. Electrical Specification Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 7-1: Operating range Range Standard Extended Temperature Ambient Temperature 0°C to +70°C -40°C to +85°C 3.3V 5V 3.135-3.465V 4.75-5.25V Table 7-2: Absolute maximum power pin stress ratings Parameter Input Power Voltage on any pin except VDD with respect to GND Symbol VDD V Conditions -0.3V min. to 6.5V max. -0.5V min. to VDD + 0.5V max. Table 7-3: Recommended system power-up timing Symbol 1 TPU-READY 1 TPU-WRITE Parameter Power-up to Ready Operation Power-up to Write Operation Typical 200 200 Maximum 1000 1000 Units ms ms 1. This parameter is measured only for initial qualification and after a design or process change that could affect this parameter. 13 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 8. Physical Characteristics 8.1 Dimension – Mini ADM 8.1.1 44 pin/ 270 degree Pin 1 Pin 1 Unit: mm Tolerance: ±0.2mm 14 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 9. Product Ordering Information 9.1 Product Code Designations AP – FM xxxx E A X X X S - XXJ Model: J: Value AddedⅠ ET: Extended Temperature Green: S: Halogen-free R: RoHS Voltage: 3: 3.3V 5: 5.0V Speed: S: Standard D: High Speed PCB Version Package Modifier: 44 pin / 270D Controller Version Capacity: 128M: 256M: 512M: 001G: 002G: 004G: 008G: 016G: 128MB 256MB 512MB 1GB 2GB 4GB 8GB 16GB Model Name Apacer Product Code 15 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ 9.2 Valid Combinations Standard Single (Standard Speed) Dual (High Speed) Capacity P/N (5V) Capacity P/N (5V) 128MB 256MB 2GB AP-FM0128EA4S5S-J AP-FM0256EA4S5S-J AP-FM0512EA4S5S-J AP-FM001GEA4S5S-J AP-FM002GEA4S5S-J 4GB AP-FM0256EA4D5S-J AP-FM0512EA4D5S-J AP-FM001GEA4D5S-J AP-FM002GEA4D5S-J AP-FM004GEA4D5S-J 16GB AP-FM016GEA4S5S-J 8GB AP-FM008GEA4D5S-J Capacity P/N (3.3V) Capacity P/N (3.3V) 128MB 256MB 2GB AP-FM0128EA4S3S-J AP-FM0256EA4S3S-J AP-FM0512EA4S3S-J AP-FM001GEA4S3S-J AP-FM002GEA4S3S-J 4GB AP-FM0256EA4D3S-J AP-FM0512EA4D3S-J AP-FM001GEA4D3S-J AP-FM002GEA4D3S-J AP-FM004GEA4D3S-J 16GB AP-FM016GEA4S3S-J 8GB AP-FM008GEA4D3S-J 256MB 512MB 1GB 256MB 512MB 1GB 512MB 1GB 2GB 512MB 1GB 2GB Ext. Temp. Single (Standard Speed) Dual (High Speed) Capacity P/N (5V) Capacity P/N (5V) 128MB 256MB 2GB AP-FM0128EA4S5S-ETJ AP-FM0256EA4S5S-ETJ AP-FM0512EA4S5S-ETJ AP-FM001GEA4S5S-ETJ AP-FM002GEA4S5S-ETJ 4GB AP-FM0256EA4D5S-ETJ AP-FM0512EA4D5S-ETJ AP-FM001GEA4D5S-ETJ AP-FM002GEA4D5S-ETJ AP-FM004GEA4D5S-ETJ 16GB AP-FM016GEA4S5S-ETJ 8GB AP-FM008GEA4D5S-ETJ Capacity P/N (3.3V) Capacity P/N (3.3V) 128MB AP-FM0128EA4S3S-ETJ 256MB AP-FM0256EA4D3S-ETJ 256MB AP-FM0256EA4S3S-ETJ AP-FM0512EA4S3S-ETJ 512MB AP-FM0512EA4D3S-ETJ AP-FM001GEA4D3S-ETJ 2GB 2GB AP-FM001GEA4S3S-ETJ AP-FM002GEA4S3S-ETJ 4GB AP-FM002GEA4D3S-ETJ AP-FM004GEA4D3S-ETJ 16GB AP-FM016GEA4S3S-ETJ 8GB AP-FM008GEA4D3S-ETJ 256MB 512MB 1GB 512MB 1GB 512MB 1GB 2GB 1GB 16 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ Revision History Revision 1.0 Date 01/19/2009 Description Remark Official release 17 © 2009 Apacer Technology Inc. Rev. 1.0 Value Added ATA-Disk Module Ⅲ AP-FMxxxxEAXXXS-XXJ Global Presence Taiwan (Headquarters) Apacer Technology Inc. 9F, 100, Sec. 1, Hsin Tai Wu Rd., Hsichih, 221 Taipei Hsien Taiwan, R.O.C. Tel: +886-2-2696-1666 Fax: +886-2-2696-1668 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-586-1291 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Europalaan 89 5232 BC 'S-Hertogenbosch The Netherlands Tel: 31-73-645-9620 Fax: 31-73-645-9629 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt. Ltd. #143, 1st Floor, Raheja Arcade, 5th Block Kormangala Industrial Layout, Bangalore - 560095, India Tel: 91-80-4152-9061 sales_india@apacer.com 18 © 2009 Apacer Technology Inc. Rev. 1.0
VL-F20-8SBN 价格&库存
很抱歉,暂时无法提供与“VL-F20-8SBN”相匹配的价格&库存,您可以联系我们找货
VL-F20-8SBN
  • 1+768.424311+99.75397
库存:222
