VL-MM5D-1GBET
VL-MM5D-1GBET
    VERSALOGIC
    1GB 200PIN PC2700 DDR DRAM - ET
VL-MM5D-1GBET 数据手册
Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 General Information 1GB 128Mx64 DDR SDRAM NON-ECC UNBUFFERED SODIMM 200-PIN Description The VL470L2925 is a 128Mx64 Double Data Rate SDRAM high density SODIMM. This dual rank memory module consists of sixteen CMOS 64Mx8 bits with 4 banks Synchronous DRAMs in BGA packages and a 2K EEPROM in an 8-pin TSSOP package. This module is a 200-pin small-outline dual in-line memory module and is intended for mounting into an edge connector socket. Decoupling capacitors are mounted on the printed circuit board for each DDR SDRAM. Features • • • • • • • • • • • • • • • • • • Pin Description 200-pin, small-outline dual in-line memory module (SODIMM) Two data transfers per clock cycle VDD = VDDQ = 2.5V +/-0.2V for DDR333 JEDEC standard 2.5V I/O (SSTL_2 compatible) VDDSPD = 2.3V to 3.6V Bi-directional data-strobe (DQS) Differential clock inputs (CK and CK#) DLL aligns DQ and DQS transition with CK transition Programmable read latency: DDR333 (2.5 clock) Programmable burst; length (2, 4, 8) Programmable burst (sequential & interleave) Auto & Self refresh, 7.8us refresh interval (8K/64ms refresh) Serial presence detect (SPD) with EEPROM Lead-free, RoHS compliant JEDEC pinout Gold edge contacts PCB: Height 31.75mm (1.250”), double sided component o Operating temperature (TA): -40 to +85 C (module screening using commercial DRAM) Order Information: VL470L2925 - R3 S G DRAM DIE G-DIE Pin Name Function A0~A12 Row Address Inputs A0~A9, A11 Column Address Inputs BA0~BA1 Bank Address Inputs DQ0~DQ63 Data Input/Output DQS0~DQS7 Data Strobes Input/Output DM0~DM7 Data Mask CK0, CK0# CK1, CK1# Clock Input CKE0, CKE1 Clock Enables Input CS0#, CS1# Chip Selects Input RAS# Row Address Strobes CAS# Column Address Strobes WE# Write Enable VDD Voltage Supply VDDQ Voltage Supply for DQS VSS Ground VREF Power Supply Reference VDDSPD SPD Voltage Supply SA1~SA2 SPD Address SDA SPD Data Input/Output SCL SPD Clock Input NC No Connect DRAM MANUFACTURER S - SAMSUNG MODULE SPEED R3: PC2700 @CL2.5 (R: Screening grade) VL: Lead-free/RoHS DRAM component: Samsung K4H510838G-HCB3 Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com 1 Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 Pin Configuration 200-PIN DDR SODIMM FRONT 200-PIN DDR SODIMM BACK Pin Name Pin Name Pin Name Pin Name Pin Name Pin Name Pin Name Pin Name 1 VREF 51 VSS 101 A9 151 DQ42 2 VREF 52 VSS 102 A8 152 DQ46 3 VSS 53 DQ19 103 VSS 153 DQ43 4 VSS 54 DQ23 104 VSS 154 DQ47 5 DQ0 55 DQ24 105 A7 155 VDD 6 DQ4 56 DQ28 106 A6 156 VDD 7 DQ1 57 VDD 107 A5 157 VDD 8 DQ5 58 VDD 108 A4 158 CK1# 9 VDD 59 DQ25 109 A3 159 VSS 10 VDD 60 DQ29 110 A2 160 CK1 11 DQS0 61 DQS3 111 A1 161 VSS 12 DM0 62 DM3 112 A0 162 VSS 13 DQ2 63 VSS 113 VDD 163 DQ48 14 DQ6 64 VSS 114 VDD 164 DQ52 15 VSS 65 DQ26 115 A10 165 DQ49 16 VSS 66 DQ30 116 BA1 166 DQ53 17 DQ3 67 DQ27 117 BA0 167 VDD 18 DQ7 68 DQ31 118 RAS# 168 VDD 19 DQ8 69 VDD 119 WE# 169 DQS6 20 DQ12 70 VDD 120 CAS# 170 DM6 21 VDD 71 CB0* 121 CS0# 171 DQ50 22 VDD 72 CB4* 122 CS1# 172 DQ54 23 DQ9 73 CB1* 123 NC 173 VSS 24 DQ13 74 CB5* 124 CS2#* 174 VSS 25 DQS1 75 VSS 125 VSS 175 DQ51 26 DM1 76 VSS 126 VSS 176 DQ55 27 VSS 77 DQS8* 127 DQ32 177 DQ56 28 VSS 78 DM8* 128 DQ36 178 DQ60 29 DQ10 79 CB2* 129 DQ33 179 VDD 30 DQ14 80 CB6* 130 DQ37 180 VDD 31 DQ11 81 VDD 131 VDD 181 DQ57 32 DQ15 82 VDD 132 VDD 182 DQ61 33 VDD 83 CB3* 133 DQS4 183 DQS7 34 VDD 84 CB7* 134 DM4 184 DM7 35 CK0 85 CS3#* 135 DQ34 185 VSS 36 VDD 86 NC 136 DQ38 186 VSS 37 CK0# 87 VSS 137 VSS 187 DQ58 38 VSS 88 VSS 138 VSS 188 DQ62 39 VSS 89 CK2* 139 DQ35 189 DQ59 40 VSS 90 VSS 140 DQ39 190 DQ63 41 DQ16 91 CK2#* 141 DQ40 191 VDD 42 DQ20 92 VDD 142 DQ44 192 VDD 43 DQ17 93 VDD 143 VDD 193 SDA 44 DQ21 94 VDD 144 VDD 194 SA0 45 VDD 95 CKE1 145 DQ41 195 SCL 46 VDD 96 CKE0 146 DQ45 196 SA1 47 DQS2 97 NC 147 DQS5 197 VDDSPD 48 DM2 98 NC 148 DM5 198 SA2 49 DQ18 99 A12 149 VSS 199 NC 50 DQ22 100 A11 150 VSS 200 NC Note: *: These pins are not used in this module. Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com 2 Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 Function Block Diagram CS1# CS0# DQS0 DQS4 DM0 DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 DM4 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS D0 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS DQ32 DQ33 DQ34 DQ35 DQ36 DQ37 DQ38 DQ39 D8 DQS1 CS# DQS D1 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS DQ40 DQ41 DQ42 DQ43 DQ44 DQ45 DQ46 DQ47 D9 CS# DQS D2 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS DQ48 DQ49 DQ50 DQ51 DQ52 DQ53 DQ54 DQ55 D10 CS# DQS DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS CS# DQS D5 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS D13 D6 D14 DQS7 DM3 A0~A12 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 D12 DM6 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 DQS3 BA0~BA1 CS# DQS CS# DQS DQS6 DM2 DQ24 DQ25 DQ26 DQ27 DQ28 DQ29 DQ30 DQ31 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 D4 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 DM5 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 DQS2 DQ16 DQ17 DQ18 DQ19 DQ20 DQ21 DQ22 DQ23 CS# DQS DQS5 DM1 DQ8 DQ9 DQ10 DQ11 DQ12 DQ13 DQ14 DQ15 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 DM7 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS D3 DM DQ0 DQ1 DQ2 DQ3 DQ4 DQ5 DQ6 DQ7 CS# DQS DQ56 DQ57 DQ58 DQ59 DQ60 DQ61 DQ62 DQ63 D11 Serial PD BA0~BA1: DDR SDRAMs D0~D15 A0~A12: DDR SDRAMs D0~D15 RAS# RAS#: DDR SDRAMs D0~D15 CAS# CAS#: DDR SDRAMs D0~D15 WE# WE#: DDR SDRAMs D0~D15 CKE0 CKE0: DDR SDRAMs D0~D7 CKE1 CKE0: DDR SDRAMs D8~D15 SDA Vss A0 A1 A2 SA0 SA1 SA2 Clock Input CK0, CK0# CK1, CK1# DDR SDRAMs 8 SDRAMs 8 SDRAMs VDDSPD VDD/ VDDQ Notes: 1. Unless otherw ise noted, resistor values are 22 ohms +/-5% D15 Clock Wiring SCL WP D7 Serial PD D0-D15 VREF D0-D15 VSS D0-D15 Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com 3 Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 Absolute Maximum Ratings Symbol Parameter Value Unit VIN, VOUT Voltage on any pin relative to VSS -0.5 ~ 3.6 V VDD, VDDQ Voltage on VDD & VDDQ supply relative to VSS -1.0 ~ 3.6 V Storage temperature -55 ~ +150 0 -40 ~ +85 0 TSTG C TA Operating temperature C PD Power dissipation 16 W IOS Short circuit current 50 mA Notes: Permanent device damage may occur if ABSOLUTE MAXIMUM RATINGS are exceeded. Functional operation should be restricted to recommended operating condition. Exposure to higher than recommended voltage for extended periods of time could affect device reliability. DC Operating Conditions Alls voltages referenced to VSS TA = -400C to +850C Symbol VDD Parameter Supply voltage VDDQ I/O Supply voltage VREF I/O Reference voltage Min Max Unit 2.3 2.7 V 2.3 2.7 V 0.49 * VDDQ 0.51 * VDDQ V 1 2 VTT I/O Termination voltage VREF-0.04 VREF+0.04 V VIH(DC) Input logic high voltage VREF+0.15 VDDQ+0.30 V VIL(DC) Input logic low voltage -0.3 VREF-0.15 V VIN(DC) Input voltage level, CK and CK# -0.3 VDDQ+0.30 V VID(DC) Input differential voltage, CK and CK# 0.3 VDDQ+0.60 V VIX(DC) Input crossing point voltage, CK and CK# 0.3 VDDQ+0.60 V Address, CAS#,RAS#,WE# -32 32 uA CS#,CKE -16 16 uA CK, CK# -16 16 uA II Input leakage current DM -4 4 uA -10 10 uA Output high current(normal strength) VOUT = v + 0.84V -16.8 - mA IOZ Output leakage current IOH Note IOL Output high current(normal strength) VOUT = VTT - 0.84V 16.8 - mA IOH Output high current(half strength) VOUT = VTT + 0.45V -9 - mA IOL Output high current(half strength) VOUT = VTT - 0.45V 9 - mA 3 Notes: 1. VREF is expected to be equal to 0.5*VDDQ of the transmitting device, and to track variations in the DC level of the same. Peak to peak noise on VREF may not exceed +/- 2% of the DC value. 2. VTT is not applied directly to the device. VTT is a system supply for signal termination resistors, is expected to be set equal to VREF, and must track variations in the DC level of VREF. 3. VID is the magnitude of the difference between the input level on CK and the input level of CK#. Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com 4 Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 AC Operating Conditions All voltages referenced to VSS TA = -400C to +850C Symbol Parameter Min Max Unit VIH(AC) Input High (Logic 1) Voltage VREF + 0.31 - V VIL(AC) Input Low (Logic 0) Voltage - VREF - 0.31 V VID(AC) Input Differential Voltage, CK and CK# inputs 0.70 VDDQ + 0.60 V VIX(AC) Input Crossing Point Voltage, CK and CK# inputs 0.5*VDDQ - 0.2 0.5*VDDQ + 0.2 V Input/Output Capacitance 0 TA=25 C, f=100MHz Parameter Symbol Min Max Unit Input capacitance (A0~A12, BA0~BA1, RAS#, CAS#, WE#) CIN1 28 44 pF Input capacitance (CKE0, CKE1) CIN2 16 24 pF Input capacitance (CS0#, CS1#) CIN3 16 24 pF Input capacitance (CK0, CK0#, CK1, CK1#) CIN4 16 24 pF Input/Output capacitance (DQ, DQS, DQS#, DM) CIO 11 13 pF Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com 5 Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 IDD Specification Condition Symbol B3 (DDR333) Unit OPERATING CURRENT: One device bank active; Active-Precharge; tRC=tRC(MIN); tCK=tCK(MIN); DQ,DM and DQS inputs change once per clock cycle; Address and control inputs change once every two clock cycles IDD0* 560 mA OPERATING CURRENT: One device bank; Active-Read-Precharge; BL=4; tRC=tRC(MIN); tCK=tCK(MIN); IOUT =0mA; Address and control inputs change once per clock cycle IDD1* 680 mA PRECHARGE POWER-DOWN STANDBY CURRENT: All device banks are idle; Power-down mode; tCK=tCK(MIN); CKE=LOW IDD2P** 80 mA IDLE STANDBY CURRENT: CS#=HIGH; All device banks are idle; tCK=tCK(MIN); CKE=HIGH; Address and other control inputs changing once per clock cycle. VIN =VREF for DQ,DQS and DM IDD2F** 368 mA IDD3P** 240 mA ACTIVE STANDBY CURRENT: CS#=HIGH; CKE=HIGH; One device bank active; tRC =tRAS(MAX); tCK=tCK(MIN); DQ, DM and DQS inputs change twice per clock cycle; Address and other control inputs changing once per clock cycle IDD3N** 640 mA OPERATING CURRENT: Burst = 2; Reads; Continnuous burst; One device bank active; Address and other control inputs changing once per clock cycle; tCK=tCK(MIN); IOUT=0mA IDD4R* 800 mA OPERATING CURRENT: Burst = 2; Writes; Continnuous burst; One device bank active; Address and other control inputs changing once per clock cycle; tCK=tCK(MIN); DQ, DM and DQS inputs change twice per clock cycle IDD4W* 840 mA AUTO REFRESH CURRENT: tRC=tRFC(MIN) IDD5** 1760 mA SELF-REFRESH CURRENT: CKE< 0.2V IDD6** 80 mA OPERATING CURRENT: Four device bank interleaving Reads Burst=4 with auto precharge; tRC=tRC(MIN); tCK=tCK(MIN); Address and control inputs change only during Active READ, or WRITE commands IDD7* 1800 mA ACITVE POWER-DOWN STANDBY CURRENT: One device bank active; Powerdown mode; tCK=tCK(MIN); CKE=LOW Notes: IDD specification is based on Samsung G-die components. Other manufacturers' DRAMs may have different values. *: Value calculated as one module rank in this operation condition, and other module rank in IDD2P (CKE LOW) mode. **: Value calculated as all module ranks in this operation condition. Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com 6 Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 AC TIMING PARAMETERS & SPECIFICATIONS Parameter Symbol Row cycle time Refresh row cycle time Row active time RAS to CAS delay Row precharge time Row active to Row active delay Write recovery time Last data in to Read command tRC tRFC tRAS tRCD tRP tRRD tWR tWTR Clock cycle time CL=2.0 CL=2.5 CL=3.0 Clock high level width Clock low level width DQS-out access time from CK/CK Output data access time from CK/CK Data strobe edge to ouput data edge Read Preamble Read Postamble CK to valid DQS-in DQS-in setup time DQS-in hold time DQS falling edge to CK rising-setup time DQS falling edge from CK rising-hold time DQS-in high level width DQS-in low level width Address and Control Input setup time(fast) Address and Control Input hold time(fast) Address and Control Input setup time(slow) Address and Control Input hold time(slow) Data-out high impedence time from CK/CK Data-out low impedence time from CK/CK Mode register set cycle time DQ & DM setup time to DQS DQ & DM hold time to DQS Control & Address input pulse width DQ & DM input pulse width Exit self refresh to non-Read command Exit self refresh to read command Refresh interval time Output DQS valid window Clock half period Data hold skew factor DQS write postamble time Active to Read with Auto precharge command Autoprecharge write recovery + Precharge time Power Down Exit Time tCK tCH tCL tDQSCK tAC tDQSQ tRPRE tRPST tDQSS tWPRES tWPRE tDSS tDSH tDQSH tDQSL tIS tIH tIS tIH tHZ tLZ tMRD tDS tDH tIPW tDIPW tXSNR tXSRD tREFI tQH tHP tQHS tWPST tRAP tDAL tPDEX CC (DDR400) Min Max 55 70 40 70K 15 15 10 15 2 6 12 5 10 0.45 0.55 0.45 0.55 -0.55 +0.55 -0.65 +0.65 0.4 0.9 1.1 0.4 0.6 0.72 1.28 0 0.25 0.2 0.2 0.35 0.35 0.6 0.6 0.7 0.7 -0.65 +0.65 -0.65 +0.65 10 0.4 0.4 2.2 1.75 75 200 7.8 tHP -tQHS tCLmin or tCHmin 0.5 0.4 0.6 B3 (DDR333) Min Max 60 72 42 70K 18 18 12 15 1 7.5 12 6 12 0.45 0.55 0.45 0.55 -0.6 +0.6 -0.7 +0.7 0.4 0.9 1.1 0.4 0.6 0.75 1.25 0 0.25 0.2 0.2 0.35 0.35 0.75 0.75 0.8 0.8 -0.7 +0.7 -0.7 +0.7 12 0.45 0.45 2.2 1.75 75 200 7.8 tHP -tQHS tCLmin or tCHmin 0.55 0.4 0.6 B0 (DDR266) Min Max 65 75 45 120K 20 20 15 15 1 10 12 7.5 12 0.45 0.55 0.45 0.55 -0.75 +0.75 -0.75 +0.75 0.5 0.9 1.1 0.4 0.6 0.75 1.25 0 0.25 0.2 0.2 0.35 0.35 0.9 0.9 1.0 1.0 -0.75 +0.75 -0.75 +0.75 15 0.5 0.5 2.2 1.75 75 200 7.8 tHP -tQHS tCLmin or tCHmin 0.75 0.4 0.6 15 18 20 (tWR/tCK) + (tRP/tCK) 1 (tWR/tCK) + (tRP/tCK) 1 (tWR/tCK) + (tRP/tCK) 1 Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com Unit ns ns ns ns ns ns ns tCK ns tCK tCK ns ns ns tCK tCK tCK ns tCK tCK tCK tCK tCK ns ns ns ns ns ns ns ns ns ns ns ns tCK us ns ns ns tCK tCK tCK 7 Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 Package Dimensions FRONT VIEW 3.40 MAX 67.60 4.0 +/- 0.10 (2X) 31.75 1.80 (2X) TYP 20.00 6.00 TYP 0.5 R PIN 1 2.15 TYP 1.00 +/- 0.10 0.60 TYP 1.0 +/- 0.10 PIN 199 0.45 TYP 63.60 TYP BACK VIEW 3.50 TYP 2.55 TYP 4.20 TYP PIN 200 47.40 TYP 11.40 TYP 15.35 TYP PIN 2 Note: 1. All dimensions are in millimeters with tolerance +/- 0.15mm unless otherwise specified. 2. The dimensional diagram is for reference only. Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com 8 Product Specifications PART NO.: VL470L2925-R3SG REV: 1.0 Revision History: Date 10/24/2014 Rev. Page 1.0 All Changes Spec release Tel 949.888.2444 – 30052 Tomas, Rancho Santa Margarita, CA 92688 USA – www.virtium.com 9
VL-MM5D-1GBET 价格&库存
很抱歉,暂时无法提供与“VL-MM5D-1GBET”相匹配的价格&库存,您可以联系我们找货
VL-MM5D-1GBET
  • 1+1914.626491+247.70805
