EDMANTP150A138045D2450BK
    TECHNEXION
    KITEDMANTENNAU.FLTOSMA
EDMANTP150A138045D2450BK 数据手册
EDM1-CF-IMX6 Main Features ARM Cortex-A9 Freescale i.MX6 scalable single/dual/ quad core EDM type 1 compact System-on-Module Gigabit LAN, WiFi 802.11 b/g/n and Bluetooth v. 4.0 communication interface Targeting multimedia applications with LVDS, TTL, HDMI, S/PDIF, I2S, MIPI camera and display 1 GPMC TTL Power 5 VDC I2S 2nd SPDIF USB Host I2S 1st LAN LVDS HDMI PCIe x1 SATA 1st USB OTG CANBus x2 SD SPI x2 UART x2 I2C x2 RSVD Buttons + GPIO RTC Specifications Core System Signalling CPU System Memory Storage Debug Interface FPC Connector Video EDM Type 1 compliant Freescale i.MX6Quad @ 1Ghz Freescale i.MX6Dual @ 1Ghz Freescale i.MX6DualLite @ 1Ghz Freescale i.MX6Solo @ 1Ghz up to 2GB DDR3 eMMC (default 4GB) optional NAND Flash (MOQ apply) JTAG Interface by thruhole MIPI Interface Camera MIPI Interface Display Connectivity Network WiFi Bluetooth Atheros AR8031 Gigabit LAN Broadcom BCM4330 802.11bgn Broadcom BCM4330 BT 4.0 Solo / Duallite Vivante GC880 35Mtri/s 266Mpxl/s Open GL ES 2.0 Dual / Quad Vivante GC2000 200Mtri/s 1000Mpxl/s OpenGL ES 2.0 & Halti, CL EP GPU 2D (Vector Graphics) emulated on GPU 3D Vivante GC355 300Mpxl/s OpenVG 1.1 GPU 2D (Composition) Vivante GC320 600Mpxl/s, BLIT Vivante GC320 600Mpxl/s, BLIT Video Decode Video Encode 1080p30 + D1 1080p30 H.264 BP / Dual 720p 1080p60 H.264 1080p30 H.264 BP / Dual 720p GPU 3D I/O Interfaces Storage Expansion Display USB CAN Bus Serial Port Other 1x SATA 2.0 (Dual /Quad only) 1x SDIO / MMC 1x PCIe 2.0 HDMI v1.4 1 channel LVDS 18/24 bit 24 bit RGB TTL USB Host 2.0 USB OTG 2.0 2x Flex CAN version 2.0B compliant 2x UART SPI, I2C, I2S, GPIO, Local Bus (GPMC) EDM Standard SOM’s and Carrier Boards Audio Interface Audio Codec I2S (2 channel), S/PDIF on EDM Carrier Board Power Specifications Input power 5 VDC +/- 5% Operation Systems Standard Support Extended Support Linux Android Commercial Linux Windows Embedded Compact Real Time OS EDM1-CF-IMX6 Block Diagram NAND Flash Up to 2GB DDR3 MIPI Camera & Display eMMC OR u.FL Freescale i.MX6 Cortex A9 314 Pin EDM Connector Environmental and Mechanical Temperature Humidity Module Connector Form Factor Dimensions MTBF Weight Shock Vibration 82 GPIO MMC 1 Ordering Information Commercial : 0° to 60° C Extended : -20° to 70° C Industrial : -40° to 85° C (no WiFi ) 10 to 90% 314 pins MXM3 EDM Compact Form Factor 82 x 60 mm (3⅝ x 2⅜ inch) >100,000 hours 20 grams 50G / 25ms 20G / 0-600 Hz Dimensions (units in mm) SPI SPI I2C 2 IC UART I2S USB Host USB OTG SPDIF Gigabit LAN SATA PCIE HDMI LVDS TTL GPMC WiFi Bluetooth UART CAN PHY LAN PHY 5 VDC in SDIO CANBus IS Power M3 EDM1-CF-IMX6S10-R512-NI4G-L-2C EDM Compact Type 1 Freescale i.MX6 Solo 1Ghz + 512MB RAM + 4GB eMMC+ Gigabit LAN + 2 CAN EDM1-CF-IMX6U10-R1GB-NI4G-L-2C EDM Compact Type 1 Freescale i.MX6 Duallite 1Ghz + 1GB RAM + 4GB eMMC + Gigabit LAN + 2 CAN EDM1-CF-IMX6D10-R1GB-NI4G-L-S-2C EDM Compact Type 1 Freescale i.MX6 Dual 1Ghz + 1GB RAM + 4GB eMMC + Gigabit LAN + 2 CAN + SATA EDM1-CF-IMX6Q10-R2GB-NI4G-L-S-2C EDM Compact Type 1 Freescale i.MX6 Quad 1Ghz + 2GB RAM + 4GB eMMC + Gigabit LAN + 2 CAN + SATA EDM1-CF-IMX6S10-R512-NI4G-BW-L-2C EDM Compact Type 1 Freescale i.MX6 Solo 1Ghz + 512MB RAM + 4GB eMMC + Gigabit LAN + 2 CAN + 802.11bgn + Bluetooth 4.0 EDM1-CF-IMX6U10-R1GB-NI4G-BW-L-2C EDM Compact Type 1 Freescale i.MX6 Duallite 1Ghz + 1GB RAM + 4GB eMMC + Gigabit LAN + 2 CAN + 802.11bgn + Bluetooth 4.0 EDM1-CF-IMX6D10-R1GB-NI4G-BW-L-S-2C EDM Compact Type 1 Freescale i.MX6 Dual 1Ghz + 1GB RAM + 4GB eMMC + Gigabit LAN + 2 CAN + SATA + 802.11bgn + Bluetooth 4.0 EDM1-CF-IMX6Q10-R2GB-NI4G-BW-L-S-2C EDM Compact Type 1 Freescale i.MX6 Quad 1Ghz + 2GB RAM + 4GB eMMC + Gigabit LAN + 2 CAN + SATA + 802.11bgn + Bluetooth 4.0 11.5 60 45 * Feel free to contact us for custom tailored Carrier Board request for your projects. 75 2015-05. All specifications are subject to change without notice. EDM Standard SOM’s and Carrier Boards Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: TechNexion: EDM1CFIMX6U10R1GBNI4GL2C EDM1CFIMX6D10START EDM1CFIMX6S10R512NI4GL2C EDM1CFIMX6S10R512NI4GBWL2C EDM1CFIMX6Q10R2GBNI4GBWLS2C EDM1CFIMX6D10R1GBNI4GLS2C EDM1CFIMX6U10START EDM1CFIMX6S10START EDM1CFIMX6U10BWSTART EDM1CFIMX6S10BWSTART EDM1CFIMX6U10R1GBNI4GBWL2C EDMANTP150A138045D2450BK EDM1CFIMX6D10BWSTART EDM1CFIMX6Q10R2GBNI4GLS2C EDM1CFIMX6D10R1GBNI4GBWLS2C EDM1CFIMX6Q10BWSTART EDM1CFIMX6Q10START EDM1CFIMX6S10R512NI4GL2CTE EDM1CFIMX6Q10R2GBNI4GBWLS2CTE EDM1CFIMX6D10R1GBNI4GLS2CTE EDM1CFIMX6Q10R2GBNI4GLS2CTE EDM1CFIMX6D10R1GBNI4GBWLS2CTE EDM1CFIMX6U10R1GBNI4GBWL2CTE EDM1CFIMX6U10R1GBNI4GL2CTE Other: EDM1-CF-iMX6S10-BW-START EDM1-CF-iMX6U10-START EDM1-CF-iMX6Q10-BW-START EDM1-CF-iMX6U10BW-START EDM-ANT-P150-A138-045D-2450-BK EDM1-CF-iMX6Q10-START EDM1-CF-iMX6S10-START EDM1CF-iMX6D10-R1GB-Ni4G-BW-L-S-2C EDM1-CF-iMX6D10-BW-START EDM1-CF-iMX6Q10-R2GB-Ni4G-BW-L-S-2C EDM1-CF-iMX6D10-R1GB-Ni4G-L-S-2C EDM1-CF-iMX6Q10-R2GB-Ni4G-L-S-2C EDM1-CF-iMX6U10-R1GB-Ni4G-L2C EDM1-CF-iMX6D10-START EDM1-CF-iMX6U10-R1GB-Ni4G-BW-L-2C EDM1-CF-iMX6S10-R512-Ni4G-BW-L-2C EDM1-CF-iMX6S10-R512-Ni4G-L-2C
物料型号:EDM1-CF-IMX6
器件简介:该模块是TechNexion公司生产的基于Freescale i.MX6处理器的系统级模块(SOM),适用于多媒体应用。
它支持多种显示接口,包括LVDS、TTL、HDMI、S/PDIF、I2S、MIPI相机和显示器。
引脚分配:模块具有314个引脚的MXM3接口,包括电源、LAN、GPMC、SPDIF、CANBus、SD、SPI、UART、按钮+GPIO、LVDS、HDMI、PCIe、SATA、USB OTG、USB Host等。
参数特性: - 处理器:Freescale i.MX6,有Solo、Dual、DualLite和Quad版本,核心频率为1GHz。
- GPU:Vivante GC880(3D)和GC320(2D),支持OpenGL ES 2.0和OpenVG 1.1。
- 内存:系统内存可达2GB DDR3,存储包括eMMC(默认4GB)和可选NAND Flash。
- 显示接口:支持HDMI 1.4、LVDS 18/24位、RGB TTL。
- 通信接口:Gigabit LAN、WiFi 802.11 b/g/n、蓝牙4.0。
- 扩展接口:SATA 2.0、SDIO/MMC、PCIe 2.0。
- I/O接口:包括2x UART、2x SPI、GPIO等。
功能详解:该模块支持多种操作系统,如Linux、Android和Windows Embedded Compact,适用于商业、扩展和工业温度范围。
它还支持多种音频和视频编解码功能。
应用信息:适用于多媒体应用,包括但不限于工业自动化、医疗设备、数字标牌和车载系统。
封装信息:EDM Compact Form Factor,尺寸为82x60mm,重量约20克,支持-40°至85°C(无WiFi)的工业温度范围。
订购信息:提供多种配置选项,包括不同的处理器版本、内存大小和存储容量。
EDMANTP150A138045D2450BK 价格&库存
很抱歉,暂时无法提供与“EDMANTP150A138045D2450BK”相匹配的价格&库存,您可以联系我们找货
