VL-F15-4EBN
VL-F15-4EBN
    VERSALOGIC
    SSD 4 GB EUSB IT
VL-F15-4EBN 数据手册
SMART eUSB Drive October 14, 2008 Revision History Rev A Date October 14, 2008 Details New release of Short and Legacy eUSB Spec with SM325AC controller Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 1 SMART eUSB Drive October 14, 2008 SMART eUSB Drive 1.0 General Description 1.1 Overview The SMART INDUSTRIAL GRADE eUSB Drive is a robust “SLC” flash based hard drive designed for use as the main boot and storage device for embedded systems. The small form factor, low power consumption and fast access time are important advantages a SMART eUSB Drive has over traditional hard drives. The drive uses a USB 2.0 High Speed serial link providing a simple two wire signaling interface to the host. The SMART eUSB Drive is available in sizes up to 16GB, Commercial or Industrial temperature, and 5V or 3.3V power. The drive is capable of sustained read speeds up to 35MB/s and write speeds up to 24MB/ s. The time to access a random location is typically less than 1 ms for the drive. 1.2 Features • Universal Serial Bus 2.0 (Hi-Speed USB) compatible • 2 wire small form factor USB interface to host • Industry standard header, or low profile stacking header for connecting to the host • Read Speed up to 35 MB/s and write Speed up to 24 MB/s • Capacity range from 256GB to 16GB • BCH Error Correction Code - corrects up to 8 bit errors per 512 byte sector • Low power Dissipation- less than .45W active (.68W for 5V version) and less than 1mW standby • Dynamic and Static Wear Leveling • Commercial Temp range 0º C to 70º • Industrial Temp range -40º C to 85º • Firmware upgradeable via USB bus • Support USB Mass Storage Class requirements for Bootability • Remote Write Protect and drive Reset Control options available • Life Monitoring (Vendor Commands) • Descriptors programmed into 256 Bytes of Attribute Memory Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 2 SMART eUSB Drive October 14, 2008 1.3 Ordering Information SMART Legacy Standard Connector (.385in high) Part Number Supply Voltage Connector Physical Capacity Chip Density Chip Quantity Read Speed (MB/s) Write Speed (MB/s) Random Access Time Typ. Write Current SG9ED52L256G1 5 Legacy 256MB 1Gb 2 31 12 .4 80 SG9ED52L512G2 5 Legacy 512MB 2Gb 2 31 17 .4 90 SG9ED52L1GG4 5 Legacy 1GB 4Gb 2 30 17 .5 100 SG9ED52L2GGD 5 Legacy 2GB 8Gb, 4K 2 33 17 .5 100 SG9ED52L2GG9 5 Legacy 2GB 8Gb 2 33 17 .6 100 SG9ED52L4GGC 5 Legacy 4GB 16Gb, 4K 2 32 17 .6 110 SG9ED52L4GGA 5 Legacy 4GB 16Gb 2 32 24 .6 110 SG9ED52L8GGB 5 Legacy 8GB 32Gb, 4K 2 35 15 .6 110 SG9ED52L16GGB 5 Legacy 16GB 32Gb, 4K Stacked 2 28.6 15 .8 110 SMART Legacy Low Profile Connector (.290in high) Part Number Supply Voltage Connector Physical Capacity Chip Density Chip Quantity Read Speed (MB/s) Write Speed (MB/s) Random Access Time Typ. Write Current SG9ED52U256G1 5 Legacy Low Profile 256MB 1Gb 2 31 12 .4 80 SG9ED52U512G2 5 Legacy Low Profile 512MB 2Gb 2 31 17 .4 90 SG9ED52U1GG4 5 Legacy Low Profile 1GB 4Gb 2 30 17 .5 100 SG9ED52U2GGD 5 Legacy Low Profile 2GB 8Gb, 4K 2 33 17 .5 100 SG9ED52U2GG9 5 Legacy Low Profile 2GB 8Gb 2 33 17 .6 100 SG9ED52U4GGA 5 Legacy Low Profile 4GB 16Gb 2 32 24 .6 110 SG9ED52U4GGC 5 Legacy Low Profile 4GB 16Gb, 4K 2 32 17 .6 110 SG9ED52U8GGB 5 Legacy Low Profile 8GB 32Gb, 4K 2 35 15 .6 110 SG9ED52U16GGB 5 Legacy Low Profile 16GB 32Gb, 4K Stacked 2 28.6 15 .8 110 Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 3 SMART eUSB Drive October 14, 2008 1.3 Ordering Information Continued SMART Legacy 2mm Connector (.144in high) Part Number Supply Voltage Connector Physical Capacity Chip Density Chip Quantity Read Speed (MB/s) Write Speed (MB/ s) Random Access Time Typ. Write Current SG9ED52M256G1 5 Legacy 2mm 256MB 1Gb 2 31 12 .4 80 SG9ED52M512G2 5 Legacy 2mm 512MB 2Gb 2 31 17 .4 90 SG9ED52M1GG4 5 Legacy 2mm 1GB 4Gb 2 30 17 .5 100 SG9ED52M2GGD 5 Legacy 2mm 2GB 8Gb, 4K 2 33 17 .5 100 SG9ED52M2GG9 5 Legacy 2mm 2GB 8Gb 2 33 17 .6 100 SG9ED52M4GGC 5 Legacy 2mm 4GB 16Gb, 4K 2 32 17 .6 110 SG9ED52M4GGA 5 Legacy 2mm 4GB 16Gb 2 32 24 .6 110 SG9ED52M8GGB 5 Legacy 2mm 8GB 32Gb, 4K 2 35 15 .6 110 SG9ED52M16GGB 5 Legacy 2mm 16GB 32Gb, 4K Stacked 2 28.6 15 .8 110 Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 4 SMART eUSB Drive October 14, 2008 1.3 Ordering Information Continued SMART Stacking Top 9-Pin Locking Connector Part Number Supply Voltage Connector Physical Capacity Chip Density Chip Quantity Read Speed (MB/s) Write Speed (MB/s) Random Access Time Typ. Write Current SG9ED32T256G1 3.3 Stacking-Top 256MB 1Gb 2 31 12 .4 80 SG9ED32T512G2 3.3 Stacking-Top 512MB 2Gb 2 31 17 .4 90 SG9ED32T1GG4 3.3 Stacking-Top 1GB 4Gb 2 30 17 .5 100 SG9ED32T2GGD 3.3 Stacking-Top 2GB 8Gb, 4K 2 33 17 .5 100 SG9ED32T2GG9 3.3 Stacking-Top 2GB 8Gb 2 33 17 .6 100 SG9ED32T4GGC 3.3 Stacking-Top 4GB 16Gb, 4K 2 32 17 .6 110 SG9ED32T4GGA 3.3 Stacking-Top 4GB 16Gb 2 32 24 .6 110 SG9ED32T8GGB 3.3 Stacking-Top 8GB 32Gb, 4K 2 35 15 .6 110 SG9ED32T16GGB 3.3 Stacking-Top 16GB 32Gb, 4K Stacked 2 28.6 15 .8 110 SMART Stacking Bottom 9-pin Locking Connector Part Number Supply Voltage Connector Physical Capacity Chip Density Chip Quantity Read Speed (MB/s) Write Speed (MB/s) Random Access Time Typ. Write Current SG9ED32B256G1 3.3 Stacking-Bot 256MB 1Gb 2 31 12 .4 80 SG9ED32B512G2 3.3 Stacking-Bot 512MB 2Gb 2 31 17 .4 90 SG9ED32B1GG4 3.3 Stacking-Bot 1GB 4Gb 2 30 17 .5 100 SG9ED32B2GGD 3.3 Stacking-Bot 2GB 8Gb, 4K 2 33 17 .5 100 SG9ED32B2GG9 3.3 Stacking-Bot 2GB 8Gb 2 33 17 .6 100 SG9ED32B4GGC 3.3 Stacking-Bot 4GB 16Gb, 4K 2 32 17 .6 110 SG9ED32B4GGA 3.3 Stacking-Bot 4GB 16Gb 2 32 24 .6 110 SG9ED32B8GGB 3.3 Stacking-Bot 8GB 32Gb, 4K 2 33 15 .6 110 SG9ED32B16GGB 3.3 Stacking-Bot 16GB 32Gb, 4K Stacked 2 28.6 15 .8 110 Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 5 SMART eUSB Drive October 14, 2008 1.3 Ordering Information Continued SMART Short eUSB With Standoff Connector Part Number Supply Voltage Connector Physical Capacity Chip Density Chip Quantity Read Speed (MB/s) Write Speed (MB/s) Random Access Time Typ. Write Current SG9ED31E256G1 3.3 Standoff eUSB 256MB 1Gb 2 31 12 .4 80 SG9ED31E512G4 3.3 Standoff eUSB 512MB 4Gb 1 18 10 .6 90 SG9ED32E512G2 3.3 Standoff eUSB 512MB 2Gb 2 31 17 .4 90 SG9ED32E1GG4 3.3 Standoff eUSB 1GB 4Gb 2 30 17 .5 100 SG9ED32E2GGD 3.3 Standoff eUSB 2GB 8Gb, 4K 2 33 17 .5 100 SG9ED32E2GG9 3.3 Standoff eUSB 2GB 8Gb 2 33 17 .6 100 SG9ED32E4GGC 3.3 Standoff eUSB 4GB 16Gb, 4K 2 35 15 .6 110 SG9ED32E4GGA 3.3 Standoff eUSB 4GB 16Gb 2 32 24 .6 110 SG9ED32E8GGB 3.3 Standoff eUSB 8GB 32Gb 2 32 15 .6 110 SG9ED32E16GGB 3.3 Standoff eUSB 16GB 32Gb, 4K Stacked 2 28.6 15 .8 110 Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 6 SMART eUSB Drive October 14, 2008 1.3.1 Part Number Geometry Page Size 2K/PG Flash 4K/PG Flash Part Number Drive Capacity Unformatted Capacity Cylinders Heads Sectors Track Maximum LBA SG9EDxxx256G1 256MB 256,900,608 978 16 32 5017759 SG9EDxxx512G2 512MB 513,801,728 995 16 63 1003519 SG9EDxxx1GG4 1GB 1,027,603,968 1991 16 63 2007039 SG9EDxxx2GG9 2GB 2,055,208,448 4072 16 63 4014079 SG9EDxxx4GGA 4GB 4,110,417,408 7964 16 63 8028159 SG9EDxxx2GGD 2GB 2,013,265,408 3900 16 63 3932159 SG9EDxxx4GGC 4GB 4,026,531,328 7801 16 63 7864319 SG9EDxxx8GGB 4GB 8,052,129,792 15602 16 63 15728639 Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 7 SMART eUSB Drive October 14, 2008 Part Number Decoder SG 9 Smart Modular Memory Cards ED Product Code 52L 256 Configuration Disk Density G USB Controller 1 Device Density I Operating Temperature SG: ROHS G: SM325 Static Wear Leveling ED: Enbedded Drive 5:5 Volt 1: 1 Chip C: Short Version 3:3.3 Volt 2: 2 Chip E: Standoff Version L: Legacy Connector M: Legacy Mini Connector U: Legacy: Low Profile B: Stacking Connector Bottom T: Stacking Connector Top 256: 256MB 512: 512MB 1G: 1GB 2G: 2GB 4G: 4GB 8G: 8GB 16G: 16GB 1: 1Gb 2: Gb 4: 4Gb 9: 8Gb A: 16Gb/2K B: 32Gb, 4K C: 16Gb, 4K D: 8Gb. 4K Blank : Commercial 0C to 70C I: Industrial -40C to 85C Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 8 SMART eUSB Drive October 14, 2008 1.4 Device Operational Characteristics 1.4.1 Transfer Rates . 2 Chip Solution • Write Data Transfer Rate • Read Data Transfer Rate • Host Interface Speed 24MB/s (2kp 4GB drive) 35MB/s (2kp 4GB drive) 60MB/s ( Refer to chart on page 3 for performance of other capacities) 1.4.2 Reliability • • MTBF Write/Erase >6,000,000 Hours >2M Cycles 1.4.3 Power Requirements (All listed values are typical based on highest power drive configuration . Refer to chart on page 3 for active current requirements of other capacities) 2 Chip Solution • VCC • Idle Current • Write Current • Standby Current 1.4.4 5.0V±5%; 3.3V±10% 50mA 130mA 2mA Environmental Characteristics • Operating temperature 0ºC to +70ºC (Commercial) -40ºC to +85ºC (Industrial) • Storage temperature -55ºC to +150ºC • • • • Humidity Shock Vibration Altitude 70% to 85% 80G max 1.12 grms (3 to 500 Hz) 3000 m Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 9 SMART eUSB Drive October 14, 2008 1.4 Device Operational Characteristics Continued 1.4.5 Physical Dimensions Legacy Connector 1.36 in. (34.54mm) • Length PCB 0.99 in. (25.15mm) • Width PCB • Mounted Height 0.591 in (15.02mm) (Standard) 0.381 in (9.68mm) (Low Profile) Stacking Connector 1.65 in. (41.91mm) .906 in. (23.00mm) 0.277in. (7.04mm) (Single) 0.468in. (11.8mm) (Double) Legacy 2mm 1.45 in. (36.9mm) 1.05 in. (26.6mm) 0.24in (6.0mm) 1.4.6 Physical Dimensions Short eUSB Short eUSB W/Standoff • • • Length Width Mounted Height 1.496 in. (38mm) 0.906 in. (23mm) 0.211in. (5.39mm) Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 10 SMART eUSB Drive October 14, 2008 1.5 MTBF Information SMART Modular Reliability Modeling Product reliability is based upon several key factors. Every semiconductor component manufacturer publishes a “reliability report” associated with each component. There are several means of reporting and representing these reliability statistics within the industry standard formats. The two major formats of “product reliability” are the abbreviated terms of MTBF (Mean Time Between Failure, in hours) and the FIT Rate (Failures Per Billion hours). These two terms of reliability factors are the most commonly used within the Electronics Semiconductor Industry. Reliability Models are based upon internal components specific to each product and will vary widely based upon the internal components technology family, and internal operating conditions for a given application. Reliability Modeling will extrapolate approximate product life-span calculations by utilizing known reliability factors from each component manufacturer, over a given temperature range and operating parameters. There are several industry standard software packages available for product reliability modeling. Smart Modular utilizes Item Software’s reliability model, the RDF2000 UTE C 80-810 Telecom Standard. Smart Modular Technology has derived the following reliability statistics based upon numerous specifics related to and including; internal component packaging, pin configurations, component density, and internal component substrate architecture. Product reliability modeling for Smart Modular Technology is based upon continual usage of the product, within accepted normal operating parameters. Compromise of the published normal operating parameters will adversely effect the product life-span reliability model. For a more detailed breakdown analysis, contact Smart Modular Customer Support. E-USB 2GB @25ºC FPBH (Failures Per Billion Hours) 112 MTBF (Hours) 8,863,894 Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 11 SMART eUSB Drive October 14, 2008 2.0 General Description The Smart eUSB Drive contains a USB/NAND controller and one or two flash memory devices. The controller interfaces with a host system allowing data to be written and read from the flash memory device. 2.1 Functional Block Diagram 5V RAM Buffer 3.3V USB Endpoint Controller D+ D- Host Conn Local Microprocessor Flash Memory Data Buffer WP# Reset# USB/NAND Controller GND Flash Memory Interface ECC 12MHz Osc Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 12 SMART eUSB Drive October 14, 2008 2.2 Physical Specifications All dimensions in Inches 2.2.1 Board Dimensions- Legacy Connector Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 13 SMART eUSB Drive October 14, 2008 2.2.2 Board Dimensions- Stacking Connector Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 14 SMART eUSB Drive October 14, 2008 2.2.3 Horizontal Mounting Legacy Connector: Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 15 SMART eUSB Drive October 14, 2008 Low Profile Legacy connector: Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 16 SMART eUSB Drive October 14, 2008 Stacking Connector: Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 17 SMART eUSB Drive October 14, 2008 2mm Low Profile Legacy connector: Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 18 SMART eUSB Drive October 14, 2008 2.2.4 Connector Pinout Legacy Connector, 5V: Standoff (Bottom View) 10 8 6 4 2 X 97531 1 2 3 4 5 6 7 8 9 1 : : : : : : : : : 0 + 5 V N o C o D a ta – N o C o D a ta + N o C o G N D N o C o K ey : N o C n n ect n n ect n n ect n n ect o n n ect Legacy Connector, 3.3V: Standoff (Bottom View) 10 8 6 4 2 X 97531 1 2 3 4 5 6 7 8 9 1 : : : : : : : : : 0 K ey N o C on D a ta – N o C on D a ta + N o C on G N D N o C on + 3 .3 V : N o C o nect nect nect nect nnect Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 19 SMART eUSB Drive October 14, 2008 Standoff Connector: Stacking Connector: Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 20 SMART eUSB Drive October 14, 2008 2.2.5 Host Connector and Pinout Legacy Connector The embedded USB drive uses a .1” pitch 2x5 pin header that is keyed to the voltage of the board. The 3.3V board will have position 1 blocked and the 5V board will have position 9 blocked. The connector on the host must be keyed correctly to avoid damage to the board. The header on the host may be any .1” pitch 2x5 header with .025sqin posts with the appropriate position removed for keying. For example a Samtec P/N TSW-105-23-F-D-009 is the appropriate part number to for the 5V board. P/N TSW-105-1-23-F-D-001 is the appropriate part number for the 3.3V board. For the Legacy Short Connector, the header on the host shoudl be TMM-105-S-D-009 Standoff The Legacy Connector Drive uses a standoff that can be screwed or locked onto the host board. The mounting hole on the host board should be 0.125 inches in diameter to accommodate a screw or locking pins and should be spaced as indicated on the diagram in section 2.2.1. The low profile versions do not come with a standoff. Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 21 SMART eUSB Drive October 14, 2008 Stacking Connector The SMART eUSB Drive with the stacking connectors is designed for applications where low mounted height is important or where a second drive is needed. The stacking drive comes in two configurations: Top or Bottom. If only a single drive will be used on a system, use the Top configuration. In this configuration, J1 is used to connect the power and USB signals between the host and the drive. J2 is used only for board support in this configuration and will not use any signals on this connector. If board stacking is to be used, a Bottom drive and a Top drive can be used together. Each will have its own independent USB bus and appear as a seperate drive. The Bottom drive is the same as the top drive, except that it has additional headers mounted on top of it to connect with a second drive. On the Bottom drive, J2 and J3 are used to pass the second USB bus up to the Top board. J4 is a dummy header used for supporting the Top board and does not contain any signals. The Stacking Connector drives contains two Hirose DF9, 9Pin, 1mm pitch, friction locking, SMT receptacles for connecting to the host. The part number for this part from Hirose is: DF9B-9S-1V The mating part for use on the host may be any of the following Hirose Part numbers: DF9-9P-1V (with metal fitting, with boss) DF9B-9P-1V (with metal fitting, without boss) DF9A-9P-1V (without metal fitting, with boss) DF9C-9P-1V (without metal fitting, without boss) Both 5V and 3.3V are shown on the connector but only one is necessary. If the 3.3V drive is being used only 3.3V needs to be connected on the host. If the 5V drive is being used only 5V needs to be connected on the host. To be able to use either drive connect both power lines on the host. Two optional signals are brought out to pins 1 and 2 of the connector. If these signals are not used by the host, these pins must be left unconnected. Pin 1, Reset#, may be used by the host to apply a hardware reset to the drive. This reset signal is a 3.3V active low signal. The host may pull this signal low to force a reset to the drive controller. At all other times (including during power up) the host must present a high impedance to this signal. Reset# is pulled up to 3.3V on the drive Pin 2, WP#, may be used by the host to write protect the drive. This signal is a 3.3V active low signal that is shared between the host and the switch (if present) on the USB drive. The host may pull this signal low to write protect the drive. At all other times the host must present a high impedance to this signal. WP# is pulled up to 3.3V on the drive. The switch and this pin are logicallay OR’d- if either are set, the drive will be write protected. Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 22 SMART eUSB Drive October 14, 2008 Stacking Connector cont. Pin 3, LED, is a 3.3V status signal that indicates when the drive is busy. This signal may be used to drive a low current LED or other logic on the host to indicate drive status to the user or system. This signal is active low ? has a 4mA drive strenght Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 23 SMART eUSB Drive October 14, 2008 2.3.2 Board Dimensions- Short eUSB Drive W/Standoff Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 24 SMART eUSB Drive October 14, 2008 2.3.4 Horizontal Mounting - Short eUSB Drive W/Standoff Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 25 SMART eUSB Drive October 14, 2008 2.3.5 Connector Pinout - Short eUSB Drive Connector Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 26 SMART eUSB Drive October 14, 2008 2.3.6 Host Connector and Pinout The short eUSB Drive is designed for applications where low mounted height and a small fooptrint is needed. The same connector is used on this drive as on the stacking version of the EUSB. J1 is used to bring the USB and control signals to the drive and J2 is a dummy connector used for mechanical support. The Short EUSB drive contains two Hirose DF9, 9Pin, 1mm pitch, friction locking, SMT receptacles for connecting to the host. The part number for this part from Hirose is: DF9-9S-1V (61) The mating part for use on the host may be any of the following Hirose Part numbers: DF9-9P-1V (with metal fitting, with boss) (61) DF9B-9P-1V (with metal fitting, without boss) (61) Both 5V and 3.3V are shown on the connector but only one is necessary. If the 3.3V drive is being used only 3.3V needs to be connected on the host. If the 5V drive is being used only 5V needs to be connected on the host. To be able to use either drive connect both power lines on the host. Three optional signals are brought out to pins 1, 2 and 3 of the connector. If these signals are not used by the host, these pins must be left unconnected. Pin 1, Reset#, may be used by the host to apply a hardware reset to the drive. This reset signal is a 3.3V active low signal. The host may pull this signal low to force a reset to the drive controller. At all other times (including during power up) the host must present a high impedance to this signal. Reset# is pulled up to 3.3V on the drive Pin 2, WP#, may be used by the host to write protect the drive. This signal is a 3.3V active low signal that is shared between the host and the switch (if present) on the USB drive. The host may pull this signal low to write protect the drive. At all other times the host must present a high impedance to this signal. WP# is pulled up to 3.3V on the drive. The switch and this pin are logicallay OR’d- if either are set, the drive will be write protected Pin 3, Activity#, is a 3.3V status signal that indicates when the drive is busy. This signal may be used to drive a low current LED or other logic on the host to indicate drive status to the user or system. This signal is active low and has a 4mA drive strength. Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 27 SMART eUSB Drive October 14, 2008 3.0 Electrical Interface 3.1. Electrical Description This interface standard is electrically compatible with the USB 2.0 specification. Bus Timing and Electrical Characteristics are described in the Universal Serial Bus Specification Revision 2.0 Section 7.3.2 3.2 Absolute Maximum Ratings Symbol Parameter Ratings Unit 5V Supply Voltage -0.3 min to 6.0 max V 3.3V Supply Voltage -0.3 min to 4.0 max V VIN Input Voltage GND - 0.5 to VCC + 0.5 V IIN* DC Input Current TBD mA TSTG Storage Temperature -25 to 75 (Commercial) -40 to 85 (Industrial) oC *Total current from all supplies 3.3 Recommended Operating Conditions Symbol 5V* Parameter Supply Voltage Ratings Unit 5.0V 4.75 to 5.25 V 3.3V** Supply Voltage 3.3V 3.0 to 3.6 V TA Operating Temperature Commercial Industrial 0 to 70 -40 to 85 oC *This supply is not used on the 3V only drive. **This supply is not used on the 5V only drive. Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 28 SMART eUSB Drive October 14, 2008 3.4 Electrical Characteristics Parameters Min Typ Max Unit 1 Chip 55 71 90 mA 2 Chips 55 71 120 mA 1 Chip 75 95 90 mA 2 Chips 85 105 150 mA Idle Current All 50 65 75 mA Suspend Current All 230 300 500 uA Read Current Write Current Configuration DC Characteristics (Ta = 0 to +70 oC, Vcc = 3.3V, unless otherwise specified Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 29 SMART eUSB Drive October 14, 2008 4.0 RBC Command Description for USB Bulk-Only Transport This section documents the Host Interface Commands supported by the USB Memory Controller. The standard class interface specification is currently implemented. SMART Modular’s device does not support Interrupt or Isynchronous transport protocol. For the purpose of data integrity only Bulk and Control Transport modes are implemented. 4.1.0 Conventions For the purpose of this addendum the following naming conventions are used: • Smart Modular’s Device - SMART Modular’s Embedded USB Drive • 1Fh - Hexadecimal numbers are followed by an “h” • 011b- Binary numbers are followed by a “b” • bRequest - words in italics indate terms defined by USB or by this specification 4.1.1 Definitions • • • • • • • • • • • • • • • • Bulk Only Interface - Communication method used for data storage needing good data integrity. This interface uses bulk endpoints. Command block Wrapper (CBW) - A packet containing a command block and associated inforamtion. Command Status Wrapper (CSW) - A packet containing the status of a command block. Configuration Descriptor - A string of data that describes the functionality and operation of the device. Data-In - Indicates a transfer of data IN form the device to the host. Data-Out - Indicates a transfer of data OUT from the host to the device. Device Descriptor - is a string of data that describes a USB device. Examples of data within this descriptor are: Class, Subclass, Product ID, and Version. Device Request - Low level communication from the host for querying the device using the control pipe. Endpoint - A uniquely addressable portion of a USB device that is the source or sink of information in a communication flow between the host and device. Interface Descriptor - Binds a driver to a USB software interface. USB devices may have one or multiple software interfaces. A PC views a USB device as a collection of software interfaces. Processed - Data received and controlled internally by the device to the point that the host need no longer be concerned about it. Relevant - The amount of the data sent to the host by the device that is significant. Reset Recovery - An error recovery procedure by which the host prepares the device for further CBWs. This is done below RBC level through a special low level control packet Thin Diagonal - Cases where the host and device are in complete agreement about the data transfer. SPC-2 - SCSI Primary Command-2 RBC - Reduced Block Command Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 30 SMART eUSB Drive October 14, 2008 5.0 Related Documents • • • • • USB Mass Storage Overview Version 1.1, available at http://www.usb.org/developers/data/devclass/usbmassover_11.pdf USB Mass Storage Bulk-Only Version 1.0 available at http://www.usb.org/developers/data/devclass/usbmassbulk_10.pdf Reduced Block Commands (RBC), T10/1240-D, available at http://www.t10.org/drafts.htm Universal Serial Bus Specification Version 1.1, available at http://www.usb.org/developers/data/usbspec.zip Universal Serial Bus Specification version 2.0, available at http://www.usb.org/developers/data/usb_20.zip Note: Please do not confuse the command or transport document versions with the USB specification SMART Modular’s device is USB 2.0 compliant Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 31 SMART eUSB Drive October 14, 2008 6.0 Standard Descriptor SMART Modular’s device supports the following standard USB descriptors: • • • • • Device Descriptor - SMART Modular’s device has one device descriptor. Configuration - SMART Modular’s device has one default configuration descriptor, which supports the Bulk-Only Data Interface. Interface - SMART Modular’s device supports the Bulk-Only Data Interface. Endpoint - SMART Modular’s device supports the following endpoints: (a) Control (b) Bulk-In endpoint (c) Bulk-Out endpoint. The host shall use the first reported Bulk-In and Bulk-Out endpoints for the selected interface. String - SMART Modular’s device provides the string field that has Vendor Name, product ID as well as containing a unique serial number 6.1- Device Descriptor SMART Modular’s device has one device descriptor. The device shall specify the device class and subclass codes in the interface descriptor, and not in the device descriptor. Table 6.1- Device Descriptor Offset Field Size Value Description 0 bLenght Byte 12h Size of this descriptor in bytes. 1 bDescriptorType Byte 01h DEVICE descriptor type. 2 bcdUSB Word 0200h 4 bDeviceClass Byte 00h Class is specified in the interface descriptor. 5 bDeviceSubClass Byte 00h Subclass is specified in the interface descriptor. 6 bDeviceProtocol Byte 00h 00h Protocol is specified in the interface descriptor. 7 bMaxPacketSize0 Byte 40h Maximum packet size for end point zero. (only 8, 16, 32, or 64 are valid (08h, 10h, 20h, 40h)) 8 idVendor Word 0E39h Vendor ID (assigned by the USB-IF). 10 idProduct Word 2B00h Product ID (assigned by the manufacturer) 12 bcdDevice Word Varies Device release number in binary-code decimal 14 iManufactures Byte 01h Index of string descriptor describing the manufacturer. 15 iProduct Byte 02h Index of string descriptor describing this product 16 iSerial Number Byte 03h Index of string descriptor describing the device’s serial number 17 bNumConfiguration Byte 01h Number of possible configurations USB Specification Release Number in Binary Coded Decimal Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 32 SMART eUSB Drive October 14, 2008 6.2 Configuration Descriptor SMART Modular’s Embedded USB Drive device has one default configuration descriptor, which supports the Bulk-Only Data Interface. The configuration descriptor describes information about a specific device configuration. The descriptor contains a bConfiguration Value field with a value that, when used as a parameter to the setConfigguration() request, causes the device to assume the described. Table 6.2 Configuration Descriptor Offset Field Size Value Description 0 bLength Byte 09h Size of this descriptor in bytes. 1 bDescriptorType Byte 02h Configuration Descriptor type. 2 wTotalLength Word 0020h Total length of data returned for this configuration, Includes combined length of all descriptors (configuration, interface, endpoint, and class-or vendor-specific) returned for this configuration. 4 bNumIterfaces Byte 01h Number of interfaces supported by this configuration. The device shall support at least the Bulk-Only Data Interface. 5 bConfigurationValue Byte 01h Value to use as an argument to the SetConfuguration() request to select this configuration. 6 iConfiguration Byte 00h Index of string descriptor describing this configuration 7 bmAttributes Byte 80h Configuration characteristics: Bit Description 7 Reserved (set to one) 6 Self-powered 5 Remote 4..0 Reserved (reset to zero) Bit 7 is reserved and must be set to one for historical reasons. For a full description of this bmAttributes bitmap, see the USB 2.0 Specification. 8 maxPower Byte 32h Maximum power consumption of the USB device from the bus in this specific configuration when the device is fully operational. Expressed in 2mA units (i.e.50=100mA). Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 33 SMART eUSB Drive October 14, 2008 6.3 Interface Description SMART Modular’s device supports the Bulk-Only Data Interface. This descriptor describes a specific interface within a configuration. A configuration provides one or more interfaces, each with zero or more endpoint descriptors describing a unique set of endpoints within the configuration. Table 6.3 -Bulk-Only Data Interface Descriptor Offset Field Size Value Description 0 bLength Byte 09h Size of this descriptor in bytes. 1 bDescriptorType Byte 04h INTERFACE Descriptor type. 2 bInterfaceNuber Byte 00h Number of interface. Zero-based value identifying the index in the array of concurrent interfaces supported by this configuration. 3 bAlternateSetting Byte 00h Value used to select alternate setting for the interface identified in the prior field. 4 bNumEndpoints Byte 02h Number of endpoints used by this interface (excluding endpoint zero) 5 bInterfaceClass Byte 08h MASS STORAGE Class 6 bInterfaceSubClass Byte 06h Subclass code (assigned by the USB-IF). Indicates which industry standard command block definition to use. Does not specify a type of storage such as a floppy disk or CD-ROM drive. (06h means USB Flash Disc is using SCSI transparent Command set as of USB Mass Storage Overview Specification) 7 bInterfaced Protocol Byte 50h BULK-ONLY TRANSPORT. (See USB Mass Storage Overview Specification) 8 iInterface 00h Index to string descriptor describing this interface Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 34 SMART eUSB Drive October 14, 2008 6.4 Endpoints Descriptors Smart Modular’s device supports three endpoints: Control, Bulk-In and Bulk-Out. 0 (zero) is the default Control endpoint and does not require a descriptor. 6.4.1 Bulk-In Endpoint Table 6.4.1 - Bulk-In Endpoint Descriptor Offset Field Size Value Description 0 bLength Byte 07h Size of this descriptor in bytes. 1 bDescriptorType Byte 05h ENDPOINTS Descriptor type. 2 bEnpointAddress Byte 81h The address of this endpoint on the USB device. The address is encoded as follows. Bit Description 3..0 The endpoint number 6..4 Reversed. set to 0 7 1 = In 3 bAttributes Byte 02h This is a Bulk endpoints. 4 wMaxPacketSize Word 0200h 6 bInterval Byte FFh Maximum packet size. Does not apply to Bulk endpoints 6.4.2 Bulk-Out endpoint The Bulk-Out Endpoint is used to transfer command and data from host to device. Table 6.4.2 - Bulk-Out Endpoint Descriptor Offset Field Size Value Description 0 bLength Byte 07h Size of this descriptor in bytes. 1 bDescriptorType Byte 05h ENDPOINTS Descriptor type. 2 bEnpointAddress Byte 02h The address of this endpoint on the USb device. The address is encoded as follows. Bit Description 3..0 The endpoint number 6..4 Reversed. set to 0 7 0 = Out 3 bAttributes Byte 02h This is a Bulk endpoints. 4 wMaxPacketSize Word 0200h 6 bInterval Byte FFh Maximum packet size. Does not apply to Bulk endpoints Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 35 SMART eUSB Drive October 14, 2008 7.0 Reduce Block Command (RBC) Descriptors The Reduced Block Commands are a simplified set of the SCSI Primary Commands - 2 (SPC-2) used for block devices. The SPC-2 specification contains the second-generation definition of the basic commands for all SCSI devices. 7.0 Reduce Block Command (RBC) Descriptors OpCode Command Support Supported by SMART Modular’s device Reference FORMAT UNIT 04h O NO * RBC INQUIRY 12h M Yes SPC-2 MODE SELECT (6) 15h M Yes SPC-2 MODE SENSE (6) 1Ah M Yes SPC-2 PERSISTENT RESERVE IN 5Eh O No * SPC-2 PERSISTENT RESERVE OUT 5Eh O No * SPC-2 PREVENT.ALLOW MEDIUM REMOVAL 1Eh M Yes RBC READ (10) 28h M Yes RBC READ CAPACITY 25h M Yes SPC-2 RELEASE (6) 17h O No * SPC-2 REQUEST SENSE 03h O Yes SPC-2 RESERVE (6) 16h O No * RBC START STOP UNIT 1Bh M Yes RBC SYNCHRONIZE CACHE 35h O No * SPC-2 TEST UNIT READY 00h M Yes RBC VERIFY (10) 2Fh M Yes RBC WRITE (10) 2Ah M Yes SPC-2 WRITE BUFFER 3Bh O Yes SPC-2 MODE SENSE 5Ah B Yes USB-Boot Command Notes: • Command Support Key: M = support is mandatory; N/A = not applicable, O = support is optional, B = support if for Bootability • The CONTROL byte (the last byte of CDB) shall be set to zero • *When the host issue command that t is not supported by SMART Modular’s device, the device returns “STALL” and waits for the host to send a “Clear Feature” command to reset. Corporate Headquarters: P. O. Box 1757, Fremont, CA 94538, USA • Tel:(510) 623-1231 • Fax:(510) 623-1434 • E-mail: info@smartm.com Flash Design Center: 3 Highwood Drive, Suite 103E, Tewksbury , MA 01876 USA • Tel:(978) 805-2100 • Fax:(978) 805-2357 Asia: Plot 18, Lrg Jelawat 4, Kawasan Perindustrian Seberang Jaya 13700, Prai, Penang, Malaysia • Tel: +604-3992909 • Fax: +604-3992903 36
VL-F15-4EBN 价格&库存
很抱歉,暂时无法提供与“VL-F15-4EBN”相匹配的价格&库存,您可以联系我们找货
