EDM2ELF
EDM2ELF
    TECHNEXION
    BOARDCARRIER3.5FORMTYPE2
EDM2ELF 数据手册
Page 1 of 4 EDM2-ELF - Carrier Board for EDM Type 2 Compact Module Key Features Develop your mobile embedded device quickly with the Elf EDM Carrier Board which features a variety of sensors and interconnects. HDMI, TTL and LVDS display interfaces. Communication by dual PCI Express (with SIM cardslots). Dual CAN Bus, Dual UART, USB and 8 GPIO’s for Industrial control. Interface Overview Block Diagram Page 2 of 4 Specifications System on Module EDM Type 2 compact form factor Expansion Expansion Slots 2x mini-PCIe + SIM cardslot (for 3G communication) I/O Interfaces Connector Header 1x SATA 1x micro SD cardslot (SDIO) 1x Gigabit LAN 2x USB 3.0 Host 1x micro USB 3.0 / 2.0 OTG 1x UART (RS-232/422/485) 2x CAN Bus 1x UART (RS-232) 2x SPI 8x GPIO 2x I2C Manafacturing pins Video Connector 1x HMDI 2 channel LVDS 18/24 bit Audio Codec Connector Speaker Jumper selectable: Freescale SGTL5000 (I2S), TI TLV320AIC23B (I2S) 1x 3.5 mm jack Stereo Audio in 1x 3.5 mm jack Stereo Audio out 1x 3.5 mm jack Microphone S/PDIF 2W amplified speaker connectors Touch Controller Connector TSC2046 (4 wire by SPI) 4 wire touch panel Sensors 3-axis Movement Light Sensor Compass Real Time Clock ST Microelectronics LIS331DLH Intersil ISL29023IROZ-T7 Freescale MAG3110FCR1 Maxim integrated DS1337+ Power Specifications Input Power Requirements 12 VDC +/- 5% Page 3 of 4 Battery Smart battery connector Environmental and Mechanical Temperature Humidity Module Connector Form Factor Dimensions MTBF Weight Shock Vibration Certification Dimensional Drawing All dimensions are in mm Commercial : 0° to 60° C Extended : -20° to 70° C Industrial : -40° to 85° C 10 - 90% 314 pins MXM3 3.5" Form Factor 147 x 102 mm 5¾ x 4 inch >100,000 hours 115 grams 50G / 25ms 20G / 0-600 Hz Compliant with CE, FCC, RoHS, REACh directives Page 4 of 4 Ordering Information EDM2-ELF 3.5 inch form factor Elf carrier board for EDM type 2 system-on-modules EDM2-ELF-START Elf EDM type 2 evaluation board including cablekit and adaptor http://www.technexion.com/products/edm/edm-carrier-boards/edm2-elf 5/13/2015
EDM2ELF 价格&库存
很抱歉,暂时无法提供与“EDM2ELF”相匹配的价格&库存,您可以联系我们找货
