V32-08T
V32-08T
    VERSALOGIC
    STD32 8-SLOT TABLE TOP CAGE
V32-08T 数据手册
Reference Manual V32 Series STD Bus Industrial Card Cages V32-Series STD Bus Industrial Card Cages REFERENCE MANUAL Copyright  2000 All Rights Reserved VersaLogic Corporation 3888 Stewart Rd. Eugene, OR 97402 (503) 485-8575 FAX (503) 485-5712 Doc. Rev. 04/12/95 Note Although every effort has been made to ensure this documentation is error-free, VersaLogic makes no representations or warranties with respect to this product and specifically disclaims any implied warranties of merchantability or fitness for any particular purpose. VersaLogic reserves the right to revise this product and associated documentation at any time without obligation to notify anyone of such changes. MV32 Table of Contents Introduction ....................................................................................................... 3 Installation ......................................................................................................... 4 Card Orientation.....................................................................................................4 Mounting Options ..................................................................................................5 Dimensions.............................................................................................................6 High Speed Backplane ...................................................................................... 9 Termination ............................................................................................................9 Compatibility .........................................................................................................9 Slot X .....................................................................................................................9 Priority Chain Signal..............................................................................................9 Ground Lines..........................................................................................................9 Power Supply Options..........................................................................................10 External Connections .....................................................................................10, 11 Appendix .......................................................................................................... 12 STD 32 Connector Pinouts...................................................................................12 Schematics............................................................................................................13 Specifications .......................................................................................................15 V32-Series Reference Manual Introduction – 2 Introduction 1 The V32 Series card cages are high quality STD Bus card cages especially suitable for industrial applications. They feature heavy-duty cold-rolled steel construction with a sealed black oxide finish, 5/8" card spacing, card restraint bar, and the V32 five layer backplane with high reliability STD 32 bus connectors. The V32 Series card cages are available in several sizes and configurations. Cages can be purchased in 4, 6, 8, and 12-slot versions, and are available with table or rack/panelmount end plates. Other mounting positions are possible by rotating the left and right end plates 180 degrees. Additionally, the mounting flanges can be oriented inwards or outwards. The V32 Series backplanes are compatible with STD 32 (8, 16, or 32 data bits) and STD 80 (8 data bits) cards. Cards with different data bus sizes can be mixed in a system. The high speed backplane features a .093" multilayer circuit board which provides controlled impedance, reduced capacitance signal lines. STD 32 slot specific functions are provided through slot X (leftmost slot) per the STD 32 specifications. Therefore, slot X is not bused as the other card slots are. V32-Series Reference Manual Introduction – 3 Installation 2 Card Orientation STD Bus cards must be oriented correctly when inserted in the card cage. Most board manufacturers provide a card ejector at the top corner of their cards. Be certain to position these card ejectors toward the top of the card cage. For upside down or unusual mounting positions the card ejectors are positioned next to the card retainer bar. Card Retainer Bar Figure 1. Card Orientation Caution Cards should be inserted or removed from the STD Bus card cage only when the system power is off. V32-Series Reference Manual Installation – 4 Mounting Options Mounting Options The V32 Series cages can be mounted in a variety of ways by changing the orientation of the end plates. The figures below show the various combinations for the table and rack/panel-mount versions of the cage. The four threaded mounting holes in the table-mount flanges accept #8-32 screws. The four clearance holes are suitable for mounting the cage using #6 bolts. The four 0.281" slots in the rack/panel flanges will clear #12 or smaller diameter bolts. Table In Table Out Ceiling In Ceiling Out Figure 2. Mounting Configurations (Table Mount) Rack Panel Out Panel In Figure 3. Mounting Configurations (Rack/Panel Mount) V32-Series Reference Manual Installation – 5 Dimensions Dimensions Model V32-04R V32-06R V32-08R V32-12R Slots 4 6 8 12 A 5.25” 6.50” 7.75” 10.25” B 4.56” 5.81” 7.06” 9.56” C 3.46” 4.71” 5.96” 8.46” Tolerance = ±0.02” Figure 4. Overall Dimensions (Panel-Mount Configuration) Model V32-04T V32-06T V32-08T V32-12T Slots 4 6 8 12 A 3.46” 4.71” 5.96” 8.46” B 2.70” 3.95” 5.20” 7.70” C 4.04” 5.29” 6.54” 9.04” D 4.54” 5.79” 7.04” 9.54” Tolerance = ±0.02” Figure 5. Overall Dimensions (Table-Mount Configuration) V32-Series Reference Manual Installation – 6 Dimensions Dimensions with Bolt-On Power Supply Model V32-04R V32-06R V32-08R V32-12R Slots 4 6 8 12 A 7.50” 8.75” 10.00” 12.50” B 6.81” 8.06” 9.31” 11.81” C 5.71” 6.96” 8.21” 10.71” Tolerance = ±0.03” Figure 6. Overall Dimensions (Panel-Mount Configuration) Model V32-04R V32-06R V32-08R V32-12R Slots 4 6 8 12 A 7.50” 8.75” 10.00” 12.50” B 6.81” 8.06” 9.31” 11.81” C 5.71” 6.96” 8.21” 10.71” Tolerance = ±0.03” Figure 7. Overall Dimensions (Rack-Mount Configuration) V32-Series Reference Manual Installation – 7 Dimensions Dimensions with Bolt-On Power Supply Model V32-04T V32-06T V32-08T V32-12T Slots 4 6 8 12 A 5.71” 6.96” 8.21” 10.71” B 4.95” 6.20” 7.45” 9.95” C 6.29” 7.54” 8.79” 11.29” D 6.79” 8.04” 9.29” 11.79” Tolerance = ±0.030” Figure 8. Overall Dimensions (Table-Mount Configuration) Tolerance = ±0.030” Figure 9. Overall Dimensions (12-Slot, EIA 19" Rack Configuration) V32-Series Reference Manual Installation – 8 High Speed Backplane 3 Termination The V32 series backplanes feature a multilayer circuit board with controlled impedance signal lines. Selected signal lines are terminated on 12 slot backplanes to provide excellent, high speed performance. The termination is applied on both ends of the circuit board with schottky diode clamps to +5V and GND rails. V32 backplanes are designed to operate at bus speeds to 16 MHz. Compatibility Full compatibility with STD 80 cards and STD 32 cards is maintained with the V32 backplanes. A variety of STD 80 (8 data bit) and STD 32 (8, 16, or 32 data bit) cards may be mixed in a card cage. STD 32 dynamic bus sizing signals determine which size of data bus is in use at any given time. Slot X The leftmost card slot in all STD 32 (V32-Series) cages is designated as Slot X and is not bussed to the other slots. This slot is available to control slot specific signal lines of the STD 32 bus and usually works in conjunction with the permanent master in Slot 0. Slot specific functions include multimaster control, interrupt control, DMA control, and slot addressing. Slot X can accommodate an in-rack power supply if desired. Priority Chain Signal On 4, 6, and 8 slot cages, the Priority Chain In (PCI) and a Priority Chain Out (PCO) signal lines can be used as a daisy chain (i.e., card slot dependent) interrupt structure. Each PCO line is connected to the PCI line of the card slot on its left. This results in the card slot in the far right position being the highest priority slot. Slot 0 is the lowest priority slot. Slot X is not included in the priority chain. On 12 slot cages, the PCI and PCO signals are connected together and bussed across all connectors to distribute +3.3V power. Ground Lines The two power supply ground lines, GND (+5V ground) and AUX GND (±12V ground), are not tied together on the backplane. Normally these two grounds must be connected together. The ideal location for this connection is at the power supply or at the STD card that requires the common ground. All VersaLogic power supplies connect both grounds together. V32-Series Reference Manual High Speed Backplane – 9 Power Supply Options Power Supply Options The STD Bus system can be powered with an in-slot power supply such as VersaLogic's VL-PSC card in Slot X, a VL-PS35/50/80/100 series bolt on power supply, or an external stand alone power supply. Connection points are supplied on the backplane for power supply and push button reset switch connections. External Connections In addition to the STD Bus boards which plug into the bus, a number of external connections may be made to the motherboard. Pads for these connections are provided along the left and right edges of the backplane. The available connection points are: Signal +5V Description Connection to the +5 volt power supply line. GND Ground connection for the +5 volt power supply. AUX+ (+12V) Connection to +12 volt power supply line. AUX GND Ground connection for the ±12 volt power supply. AUX GND should be tied to GND at the power supply for systems which need these two grounds to be common. AUX− (−12V) Connection to the −12 volt power supply line. PBRESET Connection to a system reset push button switch (normally open). Short to GND to initiate a system reset. +3.3V Connection to the +3.3 volt power supply line. (12 slot cage only). V32-Series Reference Manual High Speed Backplane – 10 External Connections External Connections Figure 10. External Connections (4, 6, and 8-Slot Backplanes) Figure 11. External Connections (12-Slot Backplane) Optional Disk Drive Power Connector V32-Series Reference Manual High Speed Backplane – 11 Appendix A STD 32 Connector Pinouts Figure 12. STD 32 Connector Pinouts V32-Series Reference Manual Appendix – 12 Schematics Schematics Figure 13. Schematic Diagram (4, 6, 8-Slot Backplane) V32-Series Reference Manual Appendix – 13 Schematics Figure 14. Schematic Diagram (12-Slot Backplane) V32-Series Reference Manual Appendix – 14 Specifications Specifications MOTHERBOARD CONSTRUCTION: • Controlled impedance, high speed, low capacitance signal lines • Multilayer .093" PCB • Gold-plated, hemispherical knuckle card connector contacts CARD CAGE CONSTRUCTION: • Sturdy cold rolled steel with sealed black finish • Fully ventilated card slots • Anti-vibration/latch bar with slot numbers OPERATING TEMPERATURE: • −40°C to +85°C POWER BUS RATING: • +5V @ 20 Amps (4 Amps per slot) maximum • +12V @ 5 Amps (2.5 Amps per slot) maximum • +3.3 @ 5 Amps (2.5 Amps per slot) maximum V32-Series Reference Manual Appendix – 15
V32-08T 价格&库存
很抱歉,暂时无法提供与“V32-08T”相匹配的价格&库存,您可以联系我们找货
