PBR50BG
PBR50BG
    HAMMONDMANUFACTURING
    GASKET REPLACEMENT FOR IP65
PBR50BG 数据手册
10/4/22, 8:30 AM Stack Lights (PBR Series) - Hammond Mfg. Quality Products. Service Excellence. Stack Lights PBR Series Modular design for all indoor and outdoor applications. Provides warning signals and diplays machine status. High level of protection against electric shock with IP 54 rating. Separate components for easy ordering to suit every installation application. Gallery           Base and Tubes Part No. Description L1 L2 PBR50BC Base & End Module - - PBR50S100 Tubular Stand/Plinth 3.46 - PBR50S250 Tubular Stand/Plinth 9.37 - PBR50T100 Threaded tubular stand/bracket - 3.07 https://www.hammfg.com/electrical/products/accessories/sl 1/3 10/4/22, 8:30 AM Stack Lights (PBR Series) - Hammond Mfg. L1 L2 PBR50T250 Part No. Threaded tubular stand/bracket Description - 8.98 PBR50T400 Threaded tubular stand/bracket - 14.13 Modules Part No. Description PBR50CLCL Continuous beam module, transparent PBR50CLYE Continuous beam module, yellow PBR50CLAM Continuous beam module, amber PBR50CLRE Continuous beam module, red PBR50CLGR Continuousbeam module, green PBR50CLBL Continuous beam module, blue PBR50BLYE24V Blinking module, yellow PBR50BLRE24V Blinking module, red PBR50BLGR24V Blinking module, green Gaskets, Bulbs and Accessories Part No. Description PBR50MG Replacement gasket for light module & base module PBR50TG Replacement gasket for mounting tube with plinth PBR50BG Replacement gasket for direct mounting IP 65 PBR50LED24 LED light bulb 24V/BA 15d PBR50LED115 LED light bulb 115V/BA 15d PBR50L24 Light bulb 24V DC/BA 15d 7W PBR50L115 Light bulb 115V CD/BA 15d 7W PBR50LS Bulb Remover/Installer Modular Data Continuous Beam Blinking Light Modular Colors Yellow, Red, Green, Amber, Blue, Transparent Yellow, Red, Green Modular Stages Max. 5 Max. 5 ) Angle of Beam 360 degrees 360 degrees Percentage Duty Cycle 1 1 Rated Power, max. 7W 7W Rated Power with 5 stages 5W 5W Lamp Socket BA 15d BA 15d Service life of light bulb/tube approx. 1500h approx. 1500h AC Voltage Rating 230 V, 50/60 Hz, -15% to + 10% 230 V, 50/60 Hz, -15% to +10% Current Capacity Rating 0.035 A 0.08 A DC Voltage Rating 24 V, -15% to +20% 24 V, -15% to +20% Current Capacity Rating 0.3 A 0.25 A Other Data Protection Rating IP 54 Operating Temperature -25 o C to +45 o C Relative Humidity 0.9 Installation Vertical or Horizontal Mounting Stand, tube mounting or direct mounting Accessories Gasket for light module + basic module IP 65 Gasket for tubular stand on plinth IP 65 Gasket for direct mounting IP 65 Wall bracket with hood Weight of Plinth Stand mounting (w/o module): approx. 220g Tube mounting (w/o module): 200g Direct mounting (w/o module): 180g https://www.hammfg.com/electrical/products/accessories/sl 2/3 10/4/22, 8:30 AM Stack Lights (PBR Series) - Hammond Mfg. Other Data Materials Tags: Pole Light, Light Indicator Modular: polycarbonate, Plinth: ABS, Tube: stainless steel Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electrical/products/accessories/sl 3/3
PBR50BG 价格&库存
很抱歉,暂时无法提供与“PBR50BG”相匹配的价格&库存,您可以联系我们找货
