10/4/22, 8:30 AM
Stack Lights (PBR Series) - Hammond Mfg.
Quality Products. Service Excellence.
Stack Lights PBR Series
Modular design for all indoor and outdoor applications.
Provides warning signals and diplays machine status.
High level of protection against electric shock with IP 54 rating.
Separate components for easy ordering to suit every installation application.
Gallery
Base and Tubes
Part No.
Description
L1
L2
PBR50BC
Base & End Module
PBR50S100
Tubular Stand/Plinth
3.46
PBR50S250
9.37
PBR50T100
Threaded tubular stand/bracket
3.07
https://www.hammfg.com/electrical/products/accessories/sl
1/3
10/4/22, 8:30 AM
L1
L2
PBR50T250
Part No.
Description
8.98
PBR50T400
14.13
Modules
Part No.
Description
PBR50CLCL
Continuous beam module, transparent
PBR50CLYE
Continuous beam module, yellow
PBR50CLAM
Continuous beam module, amber
PBR50CLRE
Continuous beam module, red
PBR50CLGR
Continuousbeam module, green
PBR50CLBL
Continuous beam module, blue
PBR50BLYE24V
Blinking module, yellow
PBR50BLRE24V
Blinking module, red
PBR50BLGR24V
Blinking module, green
Gaskets, Bulbs and Accessories
Part No.
Description
PBR50MG
Replacement gasket for light module & base module
PBR50TG
Replacement gasket for mounting tube with plinth
PBR50BG
Replacement gasket for direct mounting IP 65
PBR50LED24
LED light bulb 24V/BA 15d
PBR50LED115
LED light bulb 115V/BA 15d
PBR50L24
Light bulb 24V DC/BA 15d 7W
PBR50L115
Light bulb 115V CD/BA 15d 7W
PBR50LS
Bulb Remover/Installer
Modular Data
Continuous Beam
Blinking Light
Modular Colors
Yellow, Red, Green, Amber, Blue, Transparent
Yellow, Red, Green
Modular Stages
Max. 5
Max. 5 )
Angle of Beam
360 degrees
360 degrees
Percentage Duty Cycle
1
1
Rated Power, max.
7W
7W
Rated Power with 5 stages
5W
5W
Lamp Socket
BA 15d
BA 15d
Service life of light bulb/tube
approx. 1500h
approx. 1500h
AC Voltage Rating
230 V, 50/60 Hz, -15% to + 10%
230 V, 50/60 Hz, -15% to +10%
Current Capacity Rating
0.035 A
0.08 A
DC Voltage Rating
24 V, -15% to +20%
24 V, -15% to +20%
0.3 A
0.25 A
Other Data
Protection Rating
IP 54
Operating Temperature
-25 o C to +45 o C
Relative Humidity
0.9
Installation
Vertical or Horizontal
Mounting Stand, tube mounting or direct mounting
Accessories
Gasket for light module + basic module IP 65
Gasket for tubular stand on plinth IP 65
Gasket for direct mounting IP 65
Wall bracket with hood
Weight of Plinth
Stand mounting (w/o module): approx. 220g
Tube mounting (w/o module): 200g
Direct mounting (w/o module): 180g
2/3
10/4/22, 8:30 AM
Other Data
Materials
Tags:
Pole Light, Light Indicator
Modular: polycarbonate, Plinth: ABS, Tube: stainless steel
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
3/3
很抱歉,暂时无法提供与“PBR50T250”相匹配的价格&库存,您可以联系我们找货
