VEEK-MT-SOCKIT
1
WWW.TERASIC.COM
MARCH 21, 2014
TABLE OF CONTENTS
1.
INTRODUCTION………………………………………………………………………………………………………………...3
1.1.
1.2.
1.3.
2.
PURPOSE ................................................................................................................................................................................................. 3
ACCESSORIES FROM THE PACKAGE...................................................................................................................................................... 3
REQUIREMENT OF ITEMS SELF-SUPPLIED............................................................................................................................................. 4
DISASSEMBLE ORIGINAL SOCKIT………………………………………………………………………………………….4
2.1.
2.2.
2.3.
2.4.
3.
UNLOAD ACRYLICS AND SCREWS OF SOCKIT ..................................................................................................................................... 4
UNLOAD STANDOFFS .............................................................................................................................................................................. 5
STANDOFFS/SCREWS/ACRYLICS UNLOADED ................................................................................................................................ 6
MSEL SETTING ON SOCKIT .................................................................................................................................................................. 6
ASSEMBLE SOCKIT……………………………………………………………………………………………………………7
3.1.
3.2.
3.3.
4.
INSTALL STANDOFFS ............................................................................................................................................................................... 7
INSTALL BRACKET ................................................................................................................................................................................... 8
INSTALL HSMC CABLE......................................................................................................................................................................... 12
INSTALLATION OF MTLC DISPLAY MODULE.............................................................................................................. 14
4.1.
INSTALL STANDOFFS ............................................................................................................................................................................. 14
5.
ASSEMBLE MTLC DISPLAY MODULE AND SOCKIT……………………………………………………………………15
6.
ASSEMBLE ACRYLICS FOR VEEK-MT-SOCKIT UPGRADE KIT………………………………………………………16
7.
COMPLETION………………………………………………………………………………………………………………….19
VEEK-MT-SOCKIT
2
WWW.TERASIC.COM
MARCH 21, 2014
1. Introduction
1.1.
Pur pose
This document shows how to assemble SoCKit and VEEK-MT-SoCKit Upgrade Kit into
VEEK-MT-SoCKit.
It covers the assembly procedures and lists the accessories required to complete the
task.
1.2. Accessories from the Package
Item
Name
Quantity
Item
Name
Quantity
A
MTLC
Display
Module
1
F
26mm
Standoff
5
B
VEEK-MT-S
oCKit
Acrylics
1
G
5mm
Standoff
2
C
SoCKit
Bracket
1
H
8mm Screw
10
D
HSMC
Cable
1
I
4mm Screw
6
E
19mm
Standoff
4
J
4-40 Thread
Hex Nut
4
VEEK-MT-SOCKIT
3
WWW.TERASIC.COM
MARCH 21, 2014
1.3. Requirement of Items Self-supplied
Item
Name
A
SoCKit
B
Phillips
Screwdriver
Quantity
Item
1
Recommend
Spec.:PH#2(6mm)
C
Name
Hex
Socket
Wrench
Quantity
(Recommend Spec.:
5.0mm)
1
1
2. Disassemble Original SoCKit
2.1. Unload Acr ylics and Screws of SoCKit
Use a Phillips screwdriver to unload the four screws on the corners of SoCKit in
anticlockwise direction and take off the acrylics of SoCKit.
VEEK-MT-SOCKIT
4
WWW.TERASIC.COM
MARCH 21, 2014
2.2. Unload Standoffs
Use a hex socket wrench to unload the four standoffs in anticlockwise direction from
the SoCKit. Do NOT take off the bracket if it’s been installed.
VEEK-MT-SOCKIT
5
WWW.TERASIC.COM
MARCH 21, 2014
2.3. Standoffs/Screws/Acr ylics Unloaded
They are not required for further use. Please put them away.
2.4. MSEL Setting on SoCKit
Set MSEL[0:4] = 00000 to boot Linux from the microSD card
VEEK-MT-SOCKIT
6
WWW.TERASIC.COM
MARCH 21, 2014
Set MSEL[0:4] = 01001 to configure the FPGA with data stored in the EPCQ device.
3. Assemble SoCKit
3.1. Install Standof fs
Install Item E*2+Item J*2 and Item G*2+Item I*2 onto the SoCKit with a hex socket
wrench and Phillips screwdriver, respectively.
VEEK-MT-SOCKIT
7
WWW.TERASIC.COM
MARCH 21, 2014
3.2. Install Bracket
The following section applies to SoCKit boards with micro USB connector only, as
shown in the left figure below. If your SoKit board comes with mini USB connectors
shown in the right figure below, please skip to the last part of this section on page 10.
VEEK-MT-SOCKIT
8
WWW.TERASIC.COM
MARCH 21, 2014
mirco USB connector
mini USB connector
Please be aware of the micro USB connectors during the installation. Improper
installation could result in damage beyond repair by ripping the micro USB connectors off
the board. Please follow the steps below strictly and re-adjust the angle of installation
whenever any of the standoffs cannot not be screwed easily or tightly.
Should you experience any difficulty, please stop the installation immediately and contact
us via
Email: support@terasic.com Tel: +886-3-5750-880
Install the bracket to the SoCKit approximately 15° to the micro USB connectors
onboard.
Please make sure both sides of the micro USB connectors (red dotted lines) stay
within the bracket without exceeding the surface of the bracket. DO NOT force the
installation to rip the connectors off the board.
VEEK-MT-SOCKIT
9
WWW.TERASIC.COM
MARCH 21, 2014
Push down the bracket to complete the installation.
Please confirm the SoCKit and the bracket are perpendicular to each other, as shown
below.
Install Item E*2+Item J*2 to the SoCKit tightly with a hex socket wrench.
VEEK-MT-SOCKIT
10
WWW.TERASIC.COM
MARCH 21, 2014
For a SoCKit with mini USB connectors populated, please install Item E*2+Item J*2
to the SoCKit tightly with a hex socket wrench, as shown below.
VEEK-MT-SOCKIT
11
WWW.TERASIC.COM
MARCH 21, 2014
3.3. Install HSMC Cable
The HSMC cable has two HSMC connectors. One is male type (J1) and the other one
is female type (J2). Please connect J1 to the HSMC connector (J14) on the SoCKit and
force the installation with both thumbs pressing down the HSMC cable. Install Item I*2
with a Phillips screwdriver to further secure the connection.
VEEK-MT-SOCKIT
12
WWW.TERASIC.COM
MARCH 21, 2014
VEEK-MT-SOCKIT
13
WWW.TERASIC.COM
MARCH 21, 2014
4. Installation of MTLC Display Module
4.1. Install Standof fs
Install Item F*5/Item H*1 to the MTLC display module with a Philips screwdriver
and a hex socket wrench in clockwise direction. Please pay extra attention to the
installation to avoid permanent damage to the screw holes, which are made of plastic.
VEEK-MT-SOCKIT
14
WWW.TERASIC.COM
MARCH 21, 2014
5. Assemble MTLC Display Module and SoCKit
Connect the assembled SoCKit to the MTLC display module with a HSMC cable.
Press the joints circled in red with both thumbs to secure the installation. Install Item I*2
with a Philips screwdriver on top of the joints to further enhance the installation.
VEEK-MT-SOCKIT
15
WWW.TERASIC.COM
MARCH 21, 2014
Turn the SoCKit over on top of the MTLC display module, as shown below.
6. Assemble Acrylics for VEEK-MT-SoCKit Upgrade Kit
Put the acrylics on the SoCKit and MTLC display module, as shown below.
VEEK-MT-SOCKIT
16
WWW.TERASIC.COM
MARCH 21, 2014
Install Item H*4 to the positions shown below to secure the acrylics and the SoCKit.
VEEK-MT-SOCKIT
17
WWW.TERASIC.COM
MARCH 21, 2014
Install Item H*5 to fix the acrylics with the MTLC display module, as shown below.
VEEK-MT-SOCKIT
18
WWW.TERASIC.COM
MARCH 21, 2014
7. Completion
VEEK-MT-SOCKIT
19
WWW.TERASIC.COM
MARCH 21, 2014
很抱歉,暂时无法提供与“P0171”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3167.340161+409.69556
