TC0700PIBW6UR1GBNI4GBK
    TECHNEXION
    HMITOUCHSCREEN7.0"COLOR
TC0700PIBW6UR1GBNI4GBK 数据手册
TechNexion - Toucan Page 1 of 3 Toucan-0700 Key Features Based around Freescale i.MX6 ARM Cortex-A9 multicore technology. Projective Multi-touch bright (500 nits) high resolution (1024*600) 7 inch panel. Galvanic isolated CAN Bus and serial ports (RS-232/422/485). USB host, USB OTG, Micro-SD cardslot, 4 GPIO's and HDMI for secondary display. Gigabit POE function or 10~36VDC power input. Available with colorful bezels. Specifications Processor Memory Storage Operation System Freescale i.MX6 Solo/Duallite (i.MX6 Dual/Quad on project base) 512MB (Solo), 1GB (Duallite) eMMC 4GB Linux 3.x, Yocto, Ubuntu Android 4.3 (jellybean), Android 4.4 (Kitkat) Connectors Network LAN External Display USB SD cardslot Serial CAN Bus GPIO Buttons Power RJ-45 Gigabit Ethernet with POE function 802.3at HDMI 1.4 1x USB Host 2.0 Connector 1x USB OTG 3.0 Connector micro SD cardslot 1x RS-232 (galvanic isolated) 1x RS-232/422/485 (galvanic isolated) 2x Flex CAN version 2.0B Compliant (galvanic isolated) 4x GPIO 1x Reset button 1x Boot select button (force SD card boot) 2 pin DC power terminal block (10~30VDC) Internal Expansion Interfaces USB Audio Display and Touch 2x Internal pinheader 1x pinheader (if touchpanel is not used) Audio speaker connectors (Left / Right) (2 Watt pre-amplified) Page 2 of 3 Internal Screen Resolution Maximum Colors Luminance Touchscreen External Display 7 inch widescreen LCD display with LED backlight 1024 x 600 pixels 16.7 million 500 cd/m² Projective Capacitive multitouch (4 points) HDMI 1.4 Connector Graphic Capabilities GPU 3D GPU 2D (Vector Graphics) GPU 2D (Composition) Video Decode Video Encode Vivante GC880 35Mtri/s 266Mpxl/s Open GL ES 2.0 emulated on GPU 3D Vivante GC320 600Mpxl/s, BLIT 1080p30 + D1 1080p30 H.264 BP / Dual 720p Network Network WiFi Bluetooth 10/100/1000 Mbps with POE function 802.3at Broadcom BCM4330 802.11bgn Broadcom BCM4330 BT 4.0 Power Input Power Requirements Power over Ethernet (POE) Power Consumption 10~30V DC +/- 5% 802.3at POE implementation (36~57VDC) 7 Watt Environmental and Mechanical Operation Temperature Storage Temperature Humidity Dimensions MTBF Weight Shock Vibration Certification 0° to 60° C -20° to 70° C 10 - 90% 184 (W) x 122 (H) x 30 (D) mm 50,000 hours 595 grams 50G / 25 ms 20G / 0-600 Hz Compliant with CE, FCC, RoHS, REACh directives Mounting Options Rear Mounting VESA Mounting 4 mounting clips required (included) 35*75 VESA MIS C. Standard (seperate purchase) Page 3 of 3 Dimensional Drawing all sizes in mm Copyright © 1999 - 2015. All Rights Reserved. http://www.technexion.com/products/panel-pc/toucan 1/26/2015
TC0700PIBW6UR1GBNI4GBK 价格&库存
很抱歉,暂时无法提供与“TC0700PIBW6UR1GBNI4GBK”相匹配的价格&库存,您可以联系我们找货
