88866215
    CROUZET(高诺斯)
    RA2R1 TMR ON DLY 24VDC/24-240VAC
88866215 数据手册
02 / 26 / 2014 LAUNCH NOTE CHRONOS 2 22.5 MM SUMMARY • Introduction • New Chronos 2 Timers - New Models Cross-reference New Chronos 2 Part Numbers Reminder: Other Obsolete 22.5 mm Timers Products dimensions Agency Approvals Good to know • Applications • Launch Details Launch Note - Chronos 2 22.5 mm 2 Introduction: A 22.5mm modular design Chronos 2 Timers - 22.5mm • The new 22.5mm is close to identical to the profile of the 17.5mm Chronos 2: – Same position of terminal blocks for a perfect alignment between the 17.5mm and 22.5mm timer versions. – Same appearance in design than the 17.5mm versions. – A 45mm “nose height” on the front of the product to allow the mounting of the 22.5mm versions in modular panels. – Slightly longer than the 17.5mm versions to allow the 2 relays SPDT 8A / 250VAC. Launch Note - Chronos 2 22.5 mm 3 New Models’ Cross-reference Obsolete Models New Models 22.5 mm 22.5 mm Old P/N Type New P/N Type 88 865 175 TQR1 88 866 175 RQR1 88 865 176 TQR6 88 866 176 RQR6 88 865 215 TA2R1 88 866 215 RA2R1 88 865 300 TU2R4 88 866 300 RU2R4 88 865 303 TU2R3 88 866 303 RU2R3 88 865 305 TU2R1 88 866 305 RU2R1 88 865 385 TX2R1 88 866 385 RX2R1 • 7 new part numbers directly replace 7 old Chronos 2 22.5 mm models • The nomenclature is now 88 866 instead of 88 865 Launch Note - Chronos 2 22.5 mm 4 New Chronos 2 Part Numbers • A total of 7 redesigned timers (22.5 mm) with: – Same rated supply voltage as old versions – Same electrical specifications as old versions • 88 865 265 (function K) will not suffer any change in nomenclature and will remain available Launch Note - Chronos 2 22.5 mm 5 Generic Functions Function A: Delay on energization Function At: Timing on energization with memory Function B: Timing on impulse (one shot) – Shaping (cannot be reset) Function C: Timing after impulse. True delay off (with auxiliary power supply) Function D: Symmetrical flashing Function Di: Symmetrical flashing Function H: Timing on energization – Pulse output (adjustable) Function Ht: Delay on energization with memory Function Q: “Star-delta” starting Launch Note - Chronos 2 22.5 mm 6 Reminder: Other Obsolete 22.5 mm Models Obsolete Models New Chronos 2 Timers 22.5 mm 17.5 mm Old P/N Type New P/N Type Power supply Function 88 865 105 TUR1 88 827 105 MUR1 24 VDC / 24 to 240 VAC A, At, H, Ht, B, C, Di, D, Ac, Bw 88 865 115 TAR1 88 827 115 MAR1 24 VDC / 24 to 240 VAC A, At 88 865 125 TBR1 88 827 125 MBR1 24 VDC / 24 to 240 VAC B 88 865 135 TCR1 88 827 135 MCR1 24 VDC / 24 to 240 VAC C 88 865 145 THR1 88 827 145 MHR1 24 VDC / 24 to 240 VAC H, Ht 88 865 155 TLR1 88 827 155 MLR1 24 VDC / 24 to 240 VAC L, Li 88 865 100 TUR4 88 865 103 TUR3 88 865 503 TURc3 A, At, H, Ht, B, C, Di, D, Ac, Bw 88 827 103 MUR3 12 to 240 VAC / VDC A, At, H, Ht, B, C, Di, D, Ac, Bw 88 827 503 MURc3 12 to 240 VAC / VDC A, At, H, Ht, B, C, Di, D, Ac, Bw • These other obsolete 22.5 mm models have already been replaced with more compact Chronos 2 17.5 mm Timers since April 2013. Launch Note - Chronos 2 22.5 mm 7 Mechanical Dimensions • The new 22.5 mm Chronos 2 timers offer a compact and enhanced design with same width (22.5 mm), but 27 mm less depth than the previous version. Previous Chronos 2 Launch Note - Chronos 2 22.5 mm New Chronos 2 8 Mechanical Dimensions (cont.) • Designed for modular use, the new 22.5 mm Chronos 2 timers have a similar profile as the already redesigned 17.5 mm Chronos 2 Timers 88827. New 17.5 mm Chronos 2 Launch Note - Chronos 2 22.5 mm New 22.5 mm Chronos 2 9 Agency Approvals • New 22.5 mm Chronos 2 Timers New Timer Commercial Reference 88 866 175 • • 88 866 176 • • 88 866 215 • 88 866 300 • • • • • • • • • 88 866 303 • • 88 866 305 • • 88 866 385 • • Launch Note - Chronos 2 22.5 mm • • • • 10 Good to know • Input & output terminals are the same for Q function. Old P/N 88 865 175 Launch Note - Chronos 2 22.5 mm New P/N 88 866 175 Old P/N 88 865 176 New P/N 88 866 176 11 Good to know (cont.) • For other functions, Input & output terminals have a slight change in position, but remain on the same side of the timer. Old P/N 88 865 215 /300/303/305/385 Launch Note - Chronos 2 22.5 mm New P/N 88 866 215 /300/303/305/385 12 Good to know (cont.) • Instantaneous switch is now on the front face instead of the side Current slide switch on the side Launch Note - Chronos 2 22.5 mm New rotary switch on front face (same function as the slide switch) 13 Applications Typical applications for Timers are with:  OEM Industrial  Industrial ovens  Ice makers  HVAC systems  Compressors  Plastic machinery  Packaging equipment  Trains  Trucks and Buses  Oil and Gas Launch Note - Chronos 2 22.5 mm 14 Two Stage Launch 1 NPI First Glance, February 26th Several marketing materials are made available only to distributors and sales people to support their preparation for the day of the New Product Premiere. 2 New Product Premiere, March 31st The new Chronos 2 Timers (22.5 mm) will be announced outside of the company. Product information will be available at the Crouzet website. Launch Note - Chronos 2 22.5 mm 15 On-line Catalog • Product information will be available in the Crouzet on-line catalog Micro-control> DIN Rail Mounted Timers> New Chronos 2 Timers> 22.5 mm DIN Rail Mounting > Launch Note - Chronos 2 22.5 mm 16 Datasheets • New datasheets will be available on the website in English, German, Spanish & French • Previous Chronos 2 datasheets will remain available on the website in a new « Legacy & Obsolete » section in the on-line catalog. • A cross-reference between previous and new part numbers will also be available. Launch Note - Chronos 2 22.5 mm 17 For more information… Europe, Middle East Africa Belgium Tel.: +32 (0) 2 462 07 30 Fax: +32 (0) 2 461 00 23 com-be@crouzet.com Italy Tel.: +39 (02) 66 599 220 Fax: +39 (02) 66 599 228 crz-it-microcontrol@crouzet.com Spain / Portugal Tel.: +34 (93) 484 39 70 Fax: +34 (93) 484 39 73 es-consultas@crouzet.es France Tel.: +33 (0) 4 75 80 21 01 Fax: +33 (0) 4 75 82 89 00 com-fr@crouzet.com Netherlands Tel.: +31 (0) 71-581 20 30 Fax: +31 (0) 71-541 35 74 com-nl@crouzet.com Switzerland Tel.: +41(0) 62 887 30 30 Fax: +41(0) 62 887 30 40 info-direkt@crouzet.com Germany / Austria Tel.: +49 (0) 21 03 9 80-108 Fax: +49 (0) 21 03 9 80-250 info-direkt@crouzet.com United Kingdom Tel.: +44 (0)1256 318 900 Fax: +44 (0)1256 318 901 info@crouzet.co.uk Other Countries Tel.: +33 (0) 475 802 102 Fax: +33 (0) 475 448 126 com-ex@crouzet.com Launch Note - Chronos 2 22.5 mm 18 For more information… Americas Asia Brazil Tel.: +55 (11) 2505 7500 Fax: +55 (11) 2505 7507 China & Hong Kong Tel.: +86 (21) 6065 6699 Fax: +86 (21) 6065 7749 china@cstsensors.com USA/Canada Tel.: +1 (877) 502 5500 Fax: +1 (619) 210 1590 customer.service@us.crouzet.com Mexico Tel.: +1 (222) 409 7000 Fax: +1 (222) 409 7810 mexico@cstsensors.com Other Countries Tel.: +55 (11) 4195 1834 Fax: +55 (11) 4191 9136 Launch Note - Chronos 2 22.5 mm India Tel.: +91 (0) 80 4113 2204/05 Fax: +91 (0) 80 4113 2206 india@cstsensors.com Korea Tel.: +82 (0)2 2629 8312 Fax: +82 (0)2 2629 8310 korea@cstsensors.com South East Asia & Pacific Tel.: +886 (0)2 8751 6388 Fax: +886 (0)2 2657 8725 eap@cstsensors.com taiwan@cstsensors.com 19 THANK YOU WWW.CROUZET.COM
88866215 价格&库存
很抱歉,暂时无法提供与“88866215”相匹配的价格&库存,您可以联系我们找货
