BM2R08MV1
BM2R08MV1
    CROUZET(高诺斯)
    RELAYTIMERMULTIFUNCDPDT8A
BM2R08MV1 数据手册
BM2R Timers Syrline 17.5 mm - 2 Relay 8A ›› Multi-function or mono-function ›› Multi-range (12 function) ›› Multi-voltage 12 →240 V AC/DC ›› LED status indicator (relay version) ›› Possibility of external load connection in parallel to the control input ›› 3-wire PNP sensor compatible Specifications Functions Delay Output Nominal rating Connections Supply voltage Code A - Ac - At - B - C - D - Di H - Ht -N - TL - Tt 0,5 s →10 days 2 changeover relays 2x8A Screw terminals 12 →240 V ∿/⎓ BM2R08MV1 Output relay Contact arrangement 2 CO (SPDT) (ChangeOver -Simple Pole Double Throw-) R1: Follow timing function R2: Follow timing function / Instantaneous Maximum switching voltage 250 VAC/ 8 A resistive / 250 VDC / 0.3 A resistive Switching current rate (resistive) NO / NC : 8A 250 V AC / 8 A 30 VDC @ 25°C NO / NC : 5A 250 V AC / 5 A 30 VDC @ 60°C Minimum switching contact 10 mA / 5 VDC Maximum switching power (resistive) 2000 VA / 80 W @ 25°C Electrical life 105 cycles min at 250 VAC/ 8 A resistive Maximum rate (at max switching power) 360 cycles /hour Mechanical life 10 x 106 cycles Rated impulse voltage 5 kV (1.2/50µs) Dielectric strength between coil / contacts IEC 60664-1: 5 kV /1 min / 1 mA / 50 Hz Dielectric strength between open contacts 2.5 kV /1 min / 1 mA / 50 Hz Timing Timing ranges (7 ranges) 0.5→10s, 0.05→1min, 0.5→10min, 0.05→1h, 0.5→10h, 0.05→1day, 0.5→10days Minimum pulse duration typically (relay version) IEC 1812-1: 30 ms 100 ms with load Maximum reset time by de-energisation typically (relay version) IEC 1812-1: 120 ms Repeatability IEC 1812-1: ≤ ± 0,5 % Repetition accuracy with constant parameters IEC 1812-1: ≤ ± 10 % Drift Temperature ≤ ± 0.05 % / °C Voltage-dependent drift ≤ ± 0.2 % / V I Timers I 02 I www.crouzet-control.com Supply Multi-voltage power supply 12→240 V∿/⎓ Operating range 15 %, +10 % Operating frequency (Hz) 50 / 60 Hz ± 5 % Galvanic isolation No Max. absorbed power Approx. 3 VA (V∿) 1.5 W (V⎓) Immunity from micro power cuts 10 ms General characteristics Insulation voltage, IEC 60664-1 300 V Installation category (acc. to IEC/EN 60664-1) Overvoltage category III ; pollution degree 2 Impulse voltage CEI/EN 60664-1 4 kV (1,2 / 50 μs) Clearance / Creepage distances IEC 60664-1: 3 mm / 3.2 mm Breakdown voltage EN-61812-1: 2,5 kV / 1 min / 1 mA / 50 Hz Insulation resistance NFC 93 050: > 500 MΩ / 250 V⎓ / 1min Status indication Un: green LED blinks when count, continuous ON when supplied R: yellow LED continuous ON when the relay is ON Casing DIN 43880: 17,5 mm Fixing: Symmetrical DIN rail EN 50022: 35 mm Mounting position All positions Housing material Enclosure plastic type UL94 - V0 Protection (IEC/EN 60529) Housing: IP40 / Terminal block: IP20 Terminal capacity Single-wire without ferrule IEC 60947-1 1 x 0.5 →3.3 mm² (AWG 20 →AWG 12) 2 x 0.5 →1.5 mm² (AWG 20 →AWG 16) Max. tightening torque (Nm) IEC 60947-1: 0,5 N.m / 4,4 lbf.in Operating temperature range (°C) IEC 60068-2: -20 °C →+60 °C Storage temperature range (°C) IEC 60068-2: -40 °C →+70 °C Relative humidity no condensation acc. to IEC/EN 60068-2-30 93 % without condensation Vibration resistance according to IEC/EN 60068-2-6 ± 0.15 mm from 10 Hz →60 Hz 2g from 60 Hz →150 Hz Impact resistance IEC 60068-2-27 15gn - 11ms ; 3 x 6 axis (output OFF) 5gn - 11ms ; 3 x 6 axis (Output ON) Drop to concrete floor IEC 60068-2-32 High: 0.75m Weight: casing 17,5 mm 70 g 80 g with packaging Directives 2014/30/EU: EMC 2014/35/EU: low voltage Certifications CE - cULus Listed Industrial Control Equipment - CCC Conformity to standards CEI 60664-1: Insulation coordination for equipment within low-voltage systems CEI 61812-1/ Specified time relays for industrial use UL 60947-4-1/ Industrial Control Equipment (NRNT- Industrial Control Switches) Conformity with environmental directives 2015/863/UE: RoHS 1907/2006: Reach 2012/19/UE: WEEE Electromagnetic compatibility IEC 61000-6-2, IEC 61000-6-3, IEC 61000-6-4 Immunity for industrial environment Emission residential environment Emission industrial environment Electromagnetic compatibility - Immunity to electrostatic discharges acc to IEC/EN 61000-4-2 Level III Air ± 8 KV / Contact ± 6 KV I Timers I 03 I www.crouzet-control.com General characteristics Immunity to radiated, radio-frequency, electromagnetic field acc. IEC/EN 61000-4-3 Level III 10 V/m (80 M Hz to 1 G Hz) 80 % AM (1 k Hz) 3 V/m (1,4 →2 G Hz) 80 % AM (1K Hz) 1V/m (2 →2.7 G Hz) 80 % AM (1K Hz) Immunity to rapid transient bursts acc. to IEC/EN 61000-4-4 Level III direct ± 2 kV (power supply) / capacitive coupling clamp ± 1 KV (command input and outputs) Immunity to shock waves on power supply acc. to IEC/EN 61000-4-5 Level III line-to-earth ± 2 kV / line-to-line ± 1kV Immunity to radio frequency in common mode acc. to IEC/EN 61000-4-6 Level III Immunity to voltage dips and breaks acc. to IEC/EN 61000-4-11 Industrial Class II: 10 Vrms (0,15 →80 M Hz) 80 % AM (1 k Hz) 0 % residual voltage during 1cycle a.c. power ports 70 % residual voltage during 25/30 cycles a.c. power ports 0 % residual voltage, 250/300 cycles a.c. power ports Residential: 0 % residual voltage during 10 cycle a.c.power ports 40 % residual voltage during 10 cycles a.c. power ports 70 % residual voltage during 10 cycles a.c. power ports 0 % residual voltage, 250/300 cycles a.c. power ports Mains-borne and radiated emissions acc. to EN 55022 (CISPR22), EN55011 (CISPR11) EN 55022 / CISPR22 Class B (IT equipment) EN 55011 / CISPR11 Class B, Group 1 (Medical equipment) Dimensions Curves Function A Delay on energisation R1: Follow timing function R2: Follow timing function / Instantaneous Function Ac Timing after closing and opening of control contact R1: Follow timing function R2: Follow timing function / Instantaneous U R1/R2 R2 T U Y1 R1/R2 T T R2 inst. Function At Timing on energisation with memory R1: Follow timing function R2: Follow timing function / Instantaneous Function B Timing on impulse one shot R1: Follow timing function R2: Follow timing function / Instantaneous U Y1 R1/R2 t1 t2 T = t1+t2 U Y1 R1/R2 R2 ∞ Function C Timing after impulse R1: Follow timing function R2: Follow timing function / Instantaneous T U Y1 R1/R2 2R ∞ T I Timers I 04 I www.crouzet-control.com Curves R2: Follow timing function / Instantaneous Function Di Flip-flop Pulse start R1: Follow timing function R2: Follow timing function / Instantaneous U R1/R2 R2 U Y1 R1/R2 R2 Function H Timing on energisation R1: Follow timing function R2: Follow timing function / Instantaneous Function Ht Delay on energisation with memory R1: Follow timing function R2: Follow timing function / Instantaneous T T T T U R1/R2 R2 T U Y1 R1/R2 R2 Function N Watchdog R1: Follow timing function R2: Follow timing function / Instantaneous Function TL Impulse relay t1 t2 T = t1+t2 U Y1 R1/R2 R2 ∞ T T U Y1 R2: Follow timing function R1/R2 8 R1: Follow timing function 8 R1: Follow timing function 8 Function D Flip-flop Pause start Connections 2 changeover relay output U + A1 A2 Y1 15 R1 16 18 25 R2 26 28
BM2R08MV1 价格&库存
很抱歉,暂时无法提供与“BM2R08MV1”相匹配的价格&库存,您可以联系我们找货
BM2R08MV1
  • 1+1112.926801+139.20165
库存:48
BM2R08MV1
  • 1+845.32240
库存:55
