Chronos 2 timers
➜ 17.5 mm DIN rail mounting
Relay or solid state output
Multi-function or mono-function
Multi-range
Multi-voltage
Screw or spring terminals
LED status indicator (relay version)
Option of connecting an external power supply to the
control input
■ 3-wire sensor control option
Part numbers
Type
Functions
Timing
Output
MUR1
A - At - B - C - H - Ht Di - D - Ac - Bw
A - At
B
C
H - Ht
Li - L
Li - L
Ad - Ah - N - O - P Pt - TL - Tt - W
A
H
Li - L
0.1 s➞ 100h
MAR1
MBR1
MCR1
MHR1
MLR4
MLR1
MUR4
MUR3
MURc3
MXR1
MUS2
MAS5
MHS2
MLS2
Supply voltage
Code
1 changeover relay
Nominal Connections
rating
8A
Screw terminals
24 V c / 24 ➞ 240 V a
88 827 105
0.1s➞ 100h
0.1s➞ 100h
0.1s➞ 100h
0.1s➞ 100h
0.1s➞ 100h
0.1s➞ 100h
0.1s➞ 100h
1 changeover relay
1 changeover relay
1 changeover relay
1 changeover relay
1 changeover relay
1 changeover relay
1 changeover relay
8A
8A
8A
8A
8A
8A
8A
Screw terminals
Screw terminals
Screw terminals
Screw terminals
Screw terminals
Screw terminals
Screw terminals
24 V c
24 V c
24 V c
24 V c
12 V a
24 V c
12 V a
88 827 115
88 827 125
88 827 135
88 827 145
88 827 150
88 827 155
88 827 100
0.1s➞ 100h
1 changeover relay
8A
Screw terminals
12➞ 240 V a / c
88 827 103
0.1s➞ 100h
1 changeover relay
8A
Spring terminals
12 ➞ 240 V a / c
88 827 503
0.1s➞ 100h
1 changeover relay
8A
Screw terminals
88 827 185
0.1s➞ 100h
Solid state
0.7 A
Screw terminals
24 ➞ 240 V a
88 827 004
0.1s➞ 100h
0.1s➞ 100h
0.1s➞ 100h
Solid state
Solid state
Solid state
0.7 A
0.7 A
0.7 A
Screw terminals
Screw terminals
Screw terminals
24 ➞ 240 V a / c
24 ➞ 240 V a
24 ➞ 240 V a
88 827 014
88 827 044
88 827 054
Dimensions (mm)
60
44
17,5
23,2
90
2,6
45
67,5
3,5
5,5
1
/ 24 ➞ 240 V a
/ 24 ➞ 240 V a
/ 24 ➞ 240 V a
/ 24 ➞ 240 V a
/c
/ 24 ➞ 240 V a
/c
Connections
1 changeover relay output
Solid state output
U
U
U
A1
Y1
15
R
A1
A1
A2
15
R
Y1
18
R
Y1
16 15
A1
Solid state output
Y1
MULTI
A2
16 18
A-At / H-Ht / B / C / Di-D / Ac / BW
Ad - Ah - N - O - P - Pt - Tl - Tt - W
A2
Y1
Li - L
Solid state output
U
U
A1
A1
A2
Y1
A2
18
R
R
A2
A/H
Y1
L / Li
Curves
Function A
Function Ac
Function At
U
U
U
R
C
C
T
R
R
Delay on energisation
Function B
T
T
Timing after closing and opening of control
contact
Function Bw
t1
Timing on energisation with memory
Function C - 1 changeover relay
U
U
U
C
C
C
R
R
R
T
T
Timing on impulse one short
Function D
Pulse output (adjustable)
Function Di
T
U
R
R
T
Timing after impulse
U
R
T
T T
T T
Flip-flop Pulse start
Function Ht
Function H
U
Flip-flop Pause start
t2
T = t1+t2
Function L
Function Li
U
U
C
R
U
R
T1 T2
T1 T2
R
t1
t2
T = t1+t2
Delay on energisation with memory
Double temporisation
Asymmetrical recycler
Pulse start
2
Function Ad
Function Ah
Function N
U
U
U
C
C
C
R1/R2
R
R
T
T
R2 Inst.
T
T
Delay on energisation by switch
(non resettable)
Function O
U
C
R
T
T
C
P
Delayed fixed-length pulse
Function Tl
R
P = 500 ms
Delayed safe-guard
Safe-guard
U
T
Function Tt
U
C
C
R
R
8
U
8
P
Function W
C
8
t2
t1
T= t1+t2
Impulse counter (delay on)
U
Impulse relay
T
Function Pt
U
T
T
Flashing single cycle by switch
(non resettable)
Function P
R
3
T
R
T
Timed impulse relay
t
T
Timing after pulse on control contact
Chronos 2 timers
Timing
Timing ranges (7 ranges)
Repetition accuracy with
constant parameters
Drift Temperature
Drift Voltage
Display accuracy according to
IEC/EN 61812-1
Minimum pulse duration typically
(relay version)
(solid state version)
(relay version under load)
Maximum reset time by deenergisation typically (relay
version)
Maximum reset time by deenergisation typically (solid state
version)
Immunity from micro power
cuts : typical
1
Input type
1 s - 10 s - 1 min - 10 min - 1 h 10 h - 100 h
± 0.5 % (IEC/EN 61812-1)
± 0.05 % / °C
± 0.2 % / V
± 10 % / 25 °C
100 ms
120 ms
350 ms
< 10 ms
Supply
Multi-voltage power supply
Frequency (Hz)
Operating range
Operator factor
Max. absorbed power
Depending on version
50 / 60
85 ➞ 110 % Un
85 ➞ 120 % Un for 12 V a / c
100 %
32 VA (240 Va )
1.5 W (240 Vc )
0.6 W (24 Vc )
0.7 VA (12 Va )
0.7 W (12 Vc )
Output specification
1 or 2 changeover relays, AgNi
(cadmium-free)
Rated power
Maximum breaking current
Minimum breaking current
Voltage breaking capacity
Electrical life (operations)
Mechanical life (operations)
Breakdown voltage acc. to
IEC/EN 61812-1
Impulse voltage acc. to
IEC/EN 60664-1, IEC/EN 61812-1
1 C/O
2000 VA/80 W
8 Aa 250 Va resistive
8 Ac 30 Vc resistive
10 mA / 5 Vc
250 Va / 8 Aa resistive
250 Vc / 0.3 A resistive
105
8 A 250 Va resistive
10 x 106
2.5 kV / 1 min / 1 mA / 50 Hz
Derating
Maximum admissible current
Leakage current
Maximum voltage drop at
terminals
IEC/EN 60664-1, IEC 60255-5
1
Certifications
Temperature limits use (°C)
Temperature limits stored (°C)
Installation category
(acc. to IEC/EN 60664-1) )
Creepage distance and clearance
Protection (IEC/EN 60529)
Degree of protection acc. to
IEC/EN 60529 Front face
Vibration resistance
acc. to IEC/EN 60068-2-6
Relative humidity no
condensation acc. to
IEC/EN 60068-2-30
Electromagnetic compatibility Immunity to electrostatic
discharges acc to
IEC/EN 61000-4-2
Immunity to radiated, radiofrequency, electromagnetic field
acc. CEI/EN 61000-4-3
Immunity to rapid transient
bursts acc. to IEC/EN 61000-4-4
Immunity to shock waves on
power supply acc. to
IEC/EN 61000-4-5
Immunity to radio frequency in
common mode acc. to
IEC/EN 61000-4-6
Immunity to voltage dips and
breaks acc. to IEC/EN 61000-4-11
Mains-borne and radiated
emissions acc. to EN 55022
(CISPR22), EN55011 (CISPR11)
Fixing : Symmetrical DIN rail
Terminal capacity Single-wire
without ferrule
5 kV
wave 1.2 / 50 µs
Terminal capacity Multi-wire with
ferrule
Solid state output
Rated power
General characteristics
Conformity to standards
30 ms
50 ms
0.7 A a / c
20 °C (0.5 A UL)
5 mA/ °C
20 A ≤ 10 ms
10 mA
< 5 mA
250 Va / c
3 wire 4V
2 wire 8V
108
2.5 kV to 1 mA / 1 min
Volt-free contact
3-wire PNP output control option
residual voltage : 0.4V whatever
the timer power supply
Spring terminals, 2 terminals per
connection point - flexible wire
connection point - rigid wire
Housing material
IEC/EN 61812-1
IEC/EN 61000-6-1
IEC/EN 61000-6-2
IEC/EN 61000-6-3
IEC/EN 61000-6-4
CE, UL, cUL,CSA, GL
-20 ➞ +60
-30 ➞ +60
Voltage surge category III
4 kV / 3 mm
IP20
IP50
20 m/s2 10 Hz ➞ 150 Hz
93 % non-condensing
Level III (Air 8 kV / Contact 6 kV)
Level I
(1 V/m : 2.0 G Hz ➞ 2.7 G Hz)
Level II
(3 V/m : 1.4 G Hz ➞ 2.0 G Hz)
Level III
(10 V/m : 80 M Hz ➞ 1 G Hz)
Level III (direct 2 kV / Capacitive
coupling clamp 1 kV)
Level III (2 kV / common mode
2 kV/ residual current mode 1 kV)
Level III (10V rms : 0.15 M Hz to
80 M Hz)
0 % residual voltage, 1 cycle
70 % residual voltage, 25/30
cycles
Class B
35 mm
1 x 0.5 ➞ 3.3 mm2
(AWG 20 ➞ AWG 12)
2 x 0.5 ➞ 2.5 mm2
(AWG 20 ➞ AWG 14)
1 x 0.2 ➞ 2.5 mm2
(AWG 24 ➞ AWG 14)
2 x 0.2 ➞ 1.5 mm2
(AWG 24 ➞ AWG 16)
2 x 0.2 ➞ 1.5 mm2
(AWG 24 ➞ AWG 16)
2 x 0.2 ➞ 1.5 mm2
(AWG 24 ➞ AWG 16)
Self-extinguishing
Weight : casing 17.5 mm
Shock test IEC/EN 60068-2-27
Short interruption on power line
acc to IEC61000-4-11
Insulation resistance according
to IEC/EN 60664-1
88827105 (MUR1) : 63 g
88827115 (MAR1) : 63 g
88827125 (MBR1) : 63 g
88827135 (MCR1) : 62 g
88827145 (MHR1) : 63 g
88827150 (MLR4) : 63 g
88827155 (MLR1) : 64 g
88827100 (MUR4) : 62 g
88827103 (MUR3) : 66 g
88827503 (MURc3) : 59 g
88827185 (MXR1) : 63 g
88827004 (MUS2) : 55 g
88827014 (MAS5) : 53 g
88827044 (MHS2) : 53 g
88827054 (MLS2) : 56 g
15 g - 11 ms
250/300 cycles
100 MΩ (500 Vc )
1
2
很抱歉,暂时无法提供与“88827185”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+833.89842
- 25+819.29822
- 50+804.06278
- 国内价格 香港价格
- 1+875.936451+113.77970
- 10+805.6457910+104.64930
- 50+760.4962250+98.78460
