SASP120M110AD
SASP120M110AD
    CROUZET(高诺斯)
    SS TIMR ON DLY, 120M ADJ, 110VAC
SASP120M110AD 数据手册
TIMERS TIMERS GENERAL DETAILS OF TYPE S TIMERS S series are compact, low cost, precision devices designed to the most demanding specifications. The small size, epoxy filled case is highly resistant against dust, vibrations, shock or humidity. Creep and strike distance according to VDE 0110 Group C 250V. Case protection IP66. Case material - Polymid. 1.96 (50) 0.47 (12) 0.8 2.46 (62.5) 0.77 (45) 0.16 (42) 0.69 (17.5) 6.35 2.76 (70) 2.36 (60) 2 SAS SERIES DELAY ON MAKE Function A: Delay on Make Input Power S1 TIMER WITH SOLID STATE OUTPUT UL listed Output 0 T CSA recognized SPECIFICATIONS: Input Power . . . . . . . . . . . . . . . . . . 24 VAC/DC, 110 VAC/DC 220 VAC/DC, ±15%, 50/60 Hz Output Rating . . . . . . . . . . . . . . . . max.: 1.0 A at 20°C . . . . . . . . . . . . . . . . . . . . . . . . . . . . min.: 10 mA Repetition accuracy . . . . . . . . . . . ±0.5% at a constant ambient Temp rise derating . . . . . . . . . . . . 5 mA / °C Reset time SAS-L & SAS-DL . . . . . . . 25 ms after timing 100 ms during timing SAS-PL. . . . . . . . . . . . . 100 ms during timing Leakage current during timing . . . 5 mA max Peak surge current . . . . . . . . . . . . 20 A < 10 ms Peak surge voltage . . . . . . . . . . . . 1400 V, 10 µs Terminals . . . . . . . . . . . . . . . . . . . . 1/4˝ (6.35mm) quick connect Opertating temperature . . . . . . . . . -22°F to +140°F (-30°C to +60°C) Weight . . . . . . . . . . . . . . . . . . . . . . 1.9 oz. (55g) Function A: When input power is applied, timing (t) begins. At the end of the preselected time, the solid state SCR output turns on. The output turns off when the input power is removed, resetting the timer for the next cycle. WIRING DIAGRAM: +- SAS ˜ SAS-D S1 SAS-P S1 S1 470K POTENTIOMETER A1 A2 Peak Surge Current A1 A2 Z1 Z2 A1 A2 100A 50A 20A 15A 10A Peak Surge Current vs Surge Current Duration LOAD 5A LOAD LOAD 2A 1A 10ms 20ms 50ms 100ms 200ms 500ms 1s 2s 5s +- Surge Current Duration ORDERING INFORMATION: (100 pcs. minimum order) ˜ S AS-D 100S 220 AD MOUNTING SERIES TIME RANGE INPUT POWER S=Encapsulated requiring DIN-Rail, Panel Adapter or use Base Mounting Holes AS = standard relay AS-D = remote potentiometer AS-P = internal potentiometer AS = Fixed .1 sec - 1 min AS-D = .1 sec - 60 min Ex = 10-100 sec maintain 10:1 ratio AS-P = .1 sec - 10 sec 1-100 sec maintain 100:1 ratio 24AD = 24 VAC/DC 110AD = 110 VAC/DC 220AD = 220 VAC/DC L UL 1 AMP Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 2/43 TIMERS TIMERS SDS SERIES REPEAT CYCLE TIMER UL listed CSA recognized • Shock Resistant • SCR Solid State Output • Optional Remote Potentiometer • DIN-Rail or Base Mounting When input power S1 is applied, the solid state output turns on immediately for the timer period specified. It then turns OFF for that same time period and repeats continuously while power is applied. Recycling Input Power S1 Output 0 T T t SPECIFICATIONS: WIRING DIAGRAM: Input . . . . . . . . . . . . . . . . . . . . . . 24 VAC, 48 VAC, 110 VAC 220 VAC, ±15%, 50/60 Hz Maximum power consumption . . 24 VAC: 0.2 VA 48 VAC: 0.3 VA 110 VAC: 0.6 VA 220 VAC: 1.2 VA Output . . . . . . . . . . . . . . . . . . . . . SCR Output Rating . . . . . . . . . . . . . . . max.: 1.0 A at 20°C min.: 10 mA Repetition accuracy . . . . . . . . . . ±0.5% at a constant ambient Temp. rise derating . . . . . . . . . . . 5 mA / °C Reset time . . . . . . . . . . . . . . . . . . 100 ms after timing 150 ms during timing Leakage current during timing . . 2 mA max. Peak surge current . . . . . . . . . . . 20 A < 10ms Peak surge voltage . . . . . . . . . . . 1400 V, 100 µs Terminals . . . . . . . . . . . . . . . . . . . Faston 1/4˝ (6.35mm) Operating temperature . . . . . . . . -22°F to +140°F -30°C to +60°C Weight . . . . . . . . . . . . . . . . . . . . . 1.9 oz. (55g) SDS S1 SDSD SDSP S1 470 K S1 POTENTIOMETER A2 18 A1 A2 18 A1 Z1 Z2 LOAD A2 18 A1 LOAD LOAD DIMENSIONS See page 3-34 ORDERING INFORMATION: (100 pcs. minimum order) P.S.: Specify maximum time for “D” and “P” versions. S DS 10 min 24 MOUNTING SERIES TIME RANGE INPUT POWER S = Encapsulated, requiring DIN-Rail, Panel Adapter or use Base Mounting Holes DS = Fixed time DS-D = remote potentiometer DS-P = internal potentiometer DS = Fixed .1s. - 120 min DS-D = .1 sec. - 120 min. Maintain 10:1 ratio DS-P = 1 -10 sec. or min., 10 - 100 sec. or min. Maintain 100:1 ratio 24A = 24 VAC 48A= 48 VAC 110A = 110 VAC 220A = 220 VAC Products and specifications subject to change without notice. 2/44 Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com L UL 1 AMP TIMERS TIMERS SHS SERIES INTERVAL TIMER WITH SOLID STATE OUTPUT UL listed CSA recognized • Epoxy Encapsulated • DIN-Rail or Base Mounting • Internal or External Time Set • Fixed Time 2 The solid state output turns on when the input power (S1) is applied. The output turns off at the end of time (T). The timer is reset when the input power is removed. Function H: Internal Timer Input Power S1 Output T 0 t SPECIFICATIONS: WIRING DIAGRAM: Input . . . . . . . . . . . . . . . . . . . . . . 24 VAC, 48 VAC, 110 VAC 220 VAC, ±15%, 50/60 Hz Maximum power consumption . . 24 VAC: 0.2 VA 48 VAC: 0.3 VA 110 VAC: 0.6 VA 220 VAC: 1.2 VA Output . . . . . . . . . . . . . . . . . . . . . SCR Output Rating . . . . . . . . . . . . . . . max.: 1.0 A at 20°C min.: 10 mA Repetition accuracy . . . . . . . . . . ±0.5% at a constant ambient Temp. rise derating . . . . . . . . . . . 5 mA / °C Reset time . . . . . . . . . . . . . . . . . . 100 ms after timing 150 ms during timing Leakage current during timing . 2 mA max. Peak surge current . . . . . . . . . . . 20 A < 10 ms Peak surge voltage . . . . . . . . . . . 1400 V, 100 µs Terminals . . . . . . . . . . . . . . . . . . Faston 1/4˝ (6.35mm) Operating temperature . . . . . . . . -22°F to +140°F -30°C to +60°C Weight . . . . . . . . . . . . . . . . . . . . . 1.9 oz. (55g) SHS S1 SHS-D SHS-P S1 470 K S1 POTENTIOMETER A2 18 A1 A2 18 A1 Z1 Z2 LOAD A2 18 A1 LOAD LOAD Note: Available with internal potentiometer in HS-P Series. ORDERING INFORMATION: (100 pcs. minimum order) DIMENSIONS See page 3-34 P.S.: Specify maximum time for “D” and “P” versions. S HS-D MOUNTING SERIES S = Encapsulated, requiring DIN-Rail, Panel Adapter or Base Mounting Holes HS = Fixed time HS-D = remote potentiometer HS-P = internal potentiometer 300S TIME RANGE HS = Fixed .1s. - 120 min HS-D =.1 sec. - 120 min. Maintain 10:1 ratio HS-P =1-10 sec. or min., 10 - 100 sec. or min. Maintain 100:1 ratio 220A INPUT POWER 24A = 24 VAC 48A = 48 VAC 110A = 110 VAC 220A = 220 VAC L UL 1 AMP Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 2/45 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Crouzet: SAS10M220AD SASP100M110AD SASP10M220AD SASP10S110AD SDS5S220A SHSP10M24A SHSP20M24A SHSP30S24A SHS5S110A SHS15S110A SHSP20M220A SHS200S110A SHSP10S24A SHSP100S110A SHSP15S110A SHS1S24A SHS180S24A SHS10M220A SHS3S110A SHS120S110A SHS13M220A SHS4S110A SHSP20M110A SHS21M110A SHS1S110A SHSP10M110A SHSP100M220A SHSP50S24A SHSP15M24A SHS100S110A SHSP100M110A SHS10S110A SHS5M110A SHS20S110A SHSP5S24A SHSP60S24A SHSP6S110A SHSP10S220A SHSP300S24A SHS20S220A SHSP6M220A SHSP10S110A SHS3S24A SHS15M110A SHSP1S110A SHSP20S24A SHSP60S110A SHSP4M24A SHSP15M110A SHS1M24A SHS2.5S24A SHS60M110A SHS15S24A SHS2S110A SHSP600S110A SHSP8M110A SHS21M220A SHSP2M24A SHSP10M220A SHS2.5S110A SHSP2S220A SHSP60M110A SHSP5S220A SHS180S110A SHS90S110A SHS16M220A SHS20M220A SHSP100S24A SDS.5S220A SAS20S110AD SAS250S110AD SAS2S110AD SAS2S220AD SAS2S24AD SAS300S110AD SAS300S24AD SAS30S110AD SAS30S24AD SAS380S110A SAS3S110AD SAS3S12AD SAS3S220AD SAS45S24AD SAS4S110AD SAS4S220AD SAS4S24AD SAS5S110AD SAS5S12AD SAS5S220AD SAS5S24AD SAS60S110A SAS60S24AD SAS6S110AD SAS6S220A SAS7S110AD SAS7S220AD SAS8S220AD SAS90S110AD SASP1000S110A SASP1000S220AD
SASP120M110AD
物料型号:文档中提到了多个型号,例如SAS10M220AD、SAS20S110AD等,这些型号可能代表不同的定时器产品。
器件简介:S系列定时器是紧凑、低成本、精密的设备,设计满足最严格的规格要求。小型尺寸,环氧填充的外壳对灰尘、震动、冲击或湿度具有很高的抵抗力。
引脚分配:文档中提到了不同的引脚分配,例如SAS系列的引脚分配包括输入电源S1、输出、以及用于调节时间的电位器470K。
参数特性:包括输入电源范围、输出额定值、重复精度、温度上升降额、复位时间、漏电流、峰值浪涌电流、峰值浪涌电压等。
功能详解:文档详细描述了不同系列定时器的功能,例如SAS系列的“Delay on Make Function A”功能,当输入电源S1被应用时,计时开始,预选时间结束后,固态SCR输出将被激活。
应用信息:文档提供了订购信息,包括最小订购量、型号选择、输入电源类型等,以及技术支持的联系方式。
封装信息:文档中提到了封装材料为Polymid,具有IP66的防护等级。
SASP120M110AD 价格&库存
很抱歉,暂时无法提供与“SASP120M110AD”相匹配的价格&库存,您可以联系我们找货
