SHSP1S110A
SHSP1S110A
    CROUZET(高诺斯)
    SS TIMR INTERVAL, 1S ADJ, 110VAC
SHSP1S110A 数据手册
TIMERS TIMERS GENERAL DETAILS OF TYPE S TIMERS S series are compact, low cost, precision devices designed to the most demanding specifications. The small size, epoxy filled case is highly resistant against dust, vibrations, shock or humidity. Creep and strike distance according to VDE 0110 Group C 250V. Case protection IP66. Case material - Polymid. 1.96 (50) 0.47 (12) 0.8 2.46 (62.5) 0.77 (45) 0.16 (42) 0.69 (17.5) 6.35 2.76 (70) 2.36 (60) 2 SAS SERIES DELAY ON MAKE Function A: Delay on Make Input Power S1 TIMER WITH SOLID STATE OUTPUT UL listed Output 0 T CSA recognized SPECIFICATIONS: Input Power . . . . . . . . . . . . . . . . . . 24 VAC/DC, 110 VAC/DC 220 VAC/DC, ±15%, 50/60 Hz Output Rating . . . . . . . . . . . . . . . . max.: 1.0 A at 20°C . . . . . . . . . . . . . . . . . . . . . . . . . . . . min.: 10 mA Repetition accuracy . . . . . . . . . . . ±0.5% at a constant ambient Temp rise derating . . . . . . . . . . . . 5 mA / °C Reset time SAS-L & SAS-DL . . . . . . . 25 ms after timing 100 ms during timing SAS-PL. . . . . . . . . . . . . 100 ms during timing Leakage current during timing . . . 5 mA max Peak surge current . . . . . . . . . . . . 20 A < 10 ms Peak surge voltage . . . . . . . . . . . . 1400 V, 10 µs Terminals . . . . . . . . . . . . . . . . . . . . 1/4˝ (6.35mm) quick connect Opertating temperature . . . . . . . . . -22°F to +140°F (-30°C to +60°C) Weight . . . . . . . . . . . . . . . . . . . . . . 1.9 oz. (55g) Function A: When input power is applied, timing (t) begins. At the end of the preselected time, the solid state SCR output turns on. The output turns off when the input power is removed, resetting the timer for the next cycle. WIRING DIAGRAM: +- SAS ˜ SAS-D S1 SAS-P S1 S1 470K POTENTIOMETER A1 A2 Peak Surge Current A1 A2 Z1 Z2 A1 A2 100A 50A 20A 15A 10A Peak Surge Current vs Surge Current Duration LOAD 5A LOAD LOAD 2A 1A 10ms 20ms 50ms 100ms 200ms 500ms 1s 2s 5s +- Surge Current Duration ORDERING INFORMATION: (100 pcs. minimum order) ˜ S AS-D 100S 220 AD MOUNTING SERIES TIME RANGE INPUT POWER S=Encapsulated requiring DIN-Rail, Panel Adapter or use Base Mounting Holes AS = standard relay AS-D = remote potentiometer AS-P = internal potentiometer AS = Fixed .1 sec - 1 min AS-D = .1 sec - 60 min Ex = 10-100 sec maintain 10:1 ratio AS-P = .1 sec - 10 sec 1-100 sec maintain 100:1 ratio 24AD = 24 VAC/DC 110AD = 110 VAC/DC 220AD = 220 VAC/DC L UL 1 AMP Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 2/43 TIMERS TIMERS SDS SERIES REPEAT CYCLE TIMER UL listed CSA recognized • Shock Resistant • SCR Solid State Output • Optional Remote Potentiometer • DIN-Rail or Base Mounting When input power S1 is applied, the solid state output turns on immediately for the timer period specified. It then turns OFF for that same time period and repeats continuously while power is applied. Recycling Input Power S1 Output 0 T T t SPECIFICATIONS: WIRING DIAGRAM: Input . . . . . . . . . . . . . . . . . . . . . . 24 VAC, 48 VAC, 110 VAC 220 VAC, ±15%, 50/60 Hz Maximum power consumption . . 24 VAC: 0.2 VA 48 VAC: 0.3 VA 110 VAC: 0.6 VA 220 VAC: 1.2 VA Output . . . . . . . . . . . . . . . . . . . . . SCR Output Rating . . . . . . . . . . . . . . . max.: 1.0 A at 20°C min.: 10 mA Repetition accuracy . . . . . . . . . . ±0.5% at a constant ambient Temp. rise derating . . . . . . . . . . . 5 mA / °C Reset time . . . . . . . . . . . . . . . . . . 100 ms after timing 150 ms during timing Leakage current during timing . . 2 mA max. Peak surge current . . . . . . . . . . . 20 A < 10ms Peak surge voltage . . . . . . . . . . . 1400 V, 100 µs Terminals . . . . . . . . . . . . . . . . . . . Faston 1/4˝ (6.35mm) Operating temperature . . . . . . . . -22°F to +140°F -30°C to +60°C Weight . . . . . . . . . . . . . . . . . . . . . 1.9 oz. (55g) SDS S1 SDSD SDSP S1 470 K S1 POTENTIOMETER A2 18 A1 A2 18 A1 Z1 Z2 LOAD A2 18 A1 LOAD LOAD DIMENSIONS See page 3-34 ORDERING INFORMATION: (100 pcs. minimum order) P.S.: Specify maximum time for “D” and “P” versions. S DS 10 min 24 MOUNTING SERIES TIME RANGE INPUT POWER S = Encapsulated, requiring DIN-Rail, Panel Adapter or use Base Mounting Holes DS = Fixed time DS-D = remote potentiometer DS-P = internal potentiometer DS = Fixed .1s. - 120 min DS-D = .1 sec. - 120 min. Maintain 10:1 ratio DS-P = 1 -10 sec. or min., 10 - 100 sec. or min. Maintain 100:1 ratio 24A = 24 VAC 48A= 48 VAC 110A = 110 VAC 220A = 220 VAC Products and specifications subject to change without notice. 2/44 Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com L UL 1 AMP TIMERS TIMERS SHS SERIES INTERVAL TIMER WITH SOLID STATE OUTPUT UL listed CSA recognized • Epoxy Encapsulated • DIN-Rail or Base Mounting • Internal or External Time Set • Fixed Time 2 The solid state output turns on when the input power (S1) is applied. The output turns off at the end of time (T). The timer is reset when the input power is removed. Function H: Internal Timer Input Power S1 Output T 0 t SPECIFICATIONS: WIRING DIAGRAM: Input . . . . . . . . . . . . . . . . . . . . . . 24 VAC, 48 VAC, 110 VAC 220 VAC, ±15%, 50/60 Hz Maximum power consumption . . 24 VAC: 0.2 VA 48 VAC: 0.3 VA 110 VAC: 0.6 VA 220 VAC: 1.2 VA Output . . . . . . . . . . . . . . . . . . . . . SCR Output Rating . . . . . . . . . . . . . . . max.: 1.0 A at 20°C min.: 10 mA Repetition accuracy . . . . . . . . . . ±0.5% at a constant ambient Temp. rise derating . . . . . . . . . . . 5 mA / °C Reset time . . . . . . . . . . . . . . . . . . 100 ms after timing 150 ms during timing Leakage current during timing . 2 mA max. Peak surge current . . . . . . . . . . . 20 A < 10 ms Peak surge voltage . . . . . . . . . . . 1400 V, 100 µs Terminals . . . . . . . . . . . . . . . . . . Faston 1/4˝ (6.35mm) Operating temperature . . . . . . . . -22°F to +140°F -30°C to +60°C Weight . . . . . . . . . . . . . . . . . . . . . 1.9 oz. (55g) SHS S1 SHS-D SHS-P S1 470 K S1 POTENTIOMETER A2 18 A1 A2 18 A1 Z1 Z2 LOAD A2 18 A1 LOAD LOAD Note: Available with internal potentiometer in HS-P Series. ORDERING INFORMATION: (100 pcs. minimum order) DIMENSIONS See page 3-34 P.S.: Specify maximum time for “D” and “P” versions. S HS-D MOUNTING SERIES S = Encapsulated, requiring DIN-Rail, Panel Adapter or Base Mounting Holes HS = Fixed time HS-D = remote potentiometer HS-P = internal potentiometer 300S TIME RANGE HS = Fixed .1s. - 120 min HS-D =.1 sec. - 120 min. Maintain 10:1 ratio HS-P =1-10 sec. or min., 10 - 100 sec. or min. Maintain 100:1 ratio 220A INPUT POWER 24A = 24 VAC 48A = 48 VAC 110A = 110 VAC 220A = 220 VAC L UL 1 AMP Products and specifications subject to change without notice. Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com 2/45
SHSP1S110A
物料型号: - S系列:SAS B型,具有固体状态SCR输出的延迟接通定时器。 - SDS系列:重复周期定时器,具有固体状态输出。 - SHS系列:间隔定时器,具有固体状态输出。
器件简介: - S系列:紧凑、低成本、精密设备,适用于高要求规格。 - SDS系列:具有抗冲击性、固体状态SCR输出、可选的远程电位器、DIN导轨或底座安装。 - SHS系列:环氧树脂封装、DIN导轨或底座安装、内部或外部时间设置、固定时间。
引脚分配: - S系列:S1为输入电源,A1和A2为输出端子,Z1和Z2为远程电位器端子。 - SDS系列:与S系列类似,但具有不同的型号和配置。 - SHS系列:S1为输入电源,A1和A2为输出端子,Z1和Z2为远程电位器端子。
参数特性: - 输入电源:24 VAC/DC, 110 VAC/DC,输出额定值、重复精度、温度上升降额、重置时间、漏电流、峰值浪涌电流和电压等。
功能详解: - S系列:输入电源接通后开始计时,到达预选时间后,固体状态SCR输出接通。 - SDS系列:输入电源接通后,固体状态输出立即接通,然后关闭相同的时间周期,并在电源接通时持续重复。 - SHS系列:输入电源接通时,固体状态输出接通,时间结束后关闭输出,移除输入电源时重置定时器。
应用信息: - 适用于需要精确定时控制的应用场合。
封装信息: - 尺寸、重量和安装方式等信息。
SHSP1S110A 价格&库存
很抱歉,暂时无法提供与“SHSP1S110A”相匹配的价格&库存,您可以联系我们找货
SHSP1S110A
  • 10+261.4934410+33.79782
