22/11/2013
www.crouzet.com
MBA Ø 22 panel mounted timers MBA2F Part number 88901308
Solid state output
Panel-mounted pushbutton-type timer
Function A delay on energisation
10 timing ranges : 0.05 s to 60 min
Supply 24 V DC and 110 →240 V DCAC 50 →60 Hz
Fast adjustment of timing period on PLCs (compatible with IEC1131)
IP 65
Part numbers
88 901 308
Type
Functions
Time ranges
Output
Nominal rating
Supply voltage
MBA2F
A
0,1 s →1 s
solid state
400 mA
100 →240 V AC/DC
Specifications
Repetition accuracy (with constant parameters)
Display precision
Maximum reset time by de-energisation MBA3F during
timed delay
Maximum reset time by de-energisation MBA3F after
timing
Maximum reset time by de-energisation MBA2F after
timing
timing
Solid state open collector PNP output
Voltage drop at terminals
Nominal rating
Leakage current
Electrical life (number of operations)
+/-0,2 %
±5%
7 ms
5 ms
60 ms
30 ms
MBA2F : ≤ 5 V AC
MBA3F : ≤ 3 V DC
MBA2F : 400 mA at 200C (derating 5 mA/ °C)
MBA3F : 200 mA at 20 °C (derating 1.5 mA/ °C)
MBA2F : ≤ 5 mA AC
MBA3F : ≤ 0,1 mA DC
> 108
Protection against polarity inversions
Protection against load short circuits
Display of output state by LED : output in operation
Display of output state by LED : Power on
Dielectric strength (V rms)
Ripple
Temperature limits use (°C)
Temperature limits stored (°C)
Varistor protection against overvoltage
Drift Temperature
Drift Voltage
Conformity to standards VDE 0435 / ICE 255 / ICE 1131 /
ICE 801 4
Protection class according to NFC C 20010-IEC 529-DIN
40050 Panel-mounted
Protection class according to NFC C 20010 - IEC 529 - DIN
40050 Terminal
Housing material
Terminal capacity Single-wire
Terminal capacity Multi-wire with ferrule
Terminal screws
Tightening torque (Nm)
Weight (g)
1500 V / 50 Hz / 1 min
± 10 %
-20 →+60
-20 →+80
+/- 0,05 %/ °C
+/- 0,2 %/V
IP65
IP10
Self-extinguishing
1 x 4 mm2
1 x 2,5 mm2
M3
0,5 Nm
27
Dimensions (mm)
Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
22/11/2013
No
www.crouzet.com
Legend
Panel
Nut
Sealing ring
Dimensions (mm)
Panel cut-out
Curves
22/11/2013
www.crouzet.com
Function A
Delay on energisation
Connections
Version 110
240 V DCAC 50 - 60 Hz
240 V DCAC 50 - 60 Hz" class="link_produits thickbox"> Zoom
No
Legend
*** TRADUCTION MANQUANTE ***
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Crouzet:
88901308
很抱歉,暂时无法提供与“88901308”相匹配的价格&库存,您可以联系我们找货
