23/06/2014
www.crouzet.com
Top 2000 6 min 12 h Part number 88226507
Relay output
Mono-voltage
1 timed changeover and 1 instantaneous contact
Elapsed time can be saved mechanically in the event of a break in supply
Progress of cycle displayed
Housing 48 x 48 mm
Connection by screw-terminal base or 8-pin base
Part numbers
88 226 507
Type
Functions
Relay outputs
Delay
Voltages
6 min 12 h
110 →127 VAC- 50 Hz
Specifications
Precision limit error
Repetition accuracy
Selection precision
Reset time
± 2 % (± 5 %/6 s)
± 1.5 % (± 4 %/6 s)
See "timing ranges" table for scale graduation
0.20 s
Timed two-pole
Instantaneous single pole
Thermal rating
1
1
6,3 A
Rating (cos φ = 0.41) 104 operations
5 A - 230 V
Absorbed power-motor
3 VA cos φ 0,8
24 V +10 % - 42 V -15 %
48 V +10 % - 110 V -20 %
127 V 0 % - 220 V -20 %
240 V 0 %
100 %
-10→+55
-20→70
Voltage variation at maximum temperature of 55 oC
according to IEC 255 100
Operating factor
Temperature limits use (°C)
Temperature limits stored (°C)
Environmental protection Tropicalised to IEC 68-2-10
Vibration withstand on 3 axes (Veritas standard)
4 G - 55 Hz
Dielectric test voltage according to IEC 255 5 or VDE 0435 1000 V - Un ≤ 60 V
2000 V - Un > 60 V
Insulation according to standard VDE 0110 group C
380 V AC - 440 V DC
Protection Housing
IP 40
Degree of terminal protection
IP 10
Conformity to standards NFC 45250 - VDE 0110 - 0435 0660 or ICE 529
Connection : Screw/saddle
Terminal capacity Single-wire 1 or 2 leads Multi-wire
0,75 - 2,5 mm2
Terminal capacity Multi-wire 1 or 2 leads
0,5 - 1 mm 2
Mounting : Base mounting on 8-pin socket
Weight (g)
185
Accessories
Accessories
Code
Solder tag connector 8-pin
25 622 301
8-pin connector base
25 622 128
Invertor for DC supply 24-48 V DC
84 861 501
Invertor for DC supply 110-127 V DC
84 861 503
Dimensions (mm)
88 226 0
Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
23/06/2014
No
www.crouzet.com
Legend
Panel depth 10 mm max
M3 screw
Dimensions (mm)
88 226 5
No
Legend
Dimensions (mm)
Panel cut-out
Dimensions (mm)
25 622 301 - 8-pin
23/06/2014
www.crouzet.com
Dimensions (mm)
Inverter for DC supply
84 861 501 : 24 48 V DC
84 861 503 : 110 127 V DC
Weight 150 g
48 V DC
Weight 150 g" class="link_produits thickbox"> Zoom
No
Legend
Fixing holes ø 5
Dimensions (mm)
Screw terminal or connector socket
26 622 128 - 8-pin
Curves
CO F2_TOP2000_N01
23/06/2014
Function
*** TRADUCTION MANQUANTE ***
Curves
CO F3_TOP2000_N01
Function
Curves
CO F4_TOP2000_N01
Function
Connections
Function 2
Connections
Function 3
www.crouzet.com
23/06/2014
www.crouzet.com
Connections
Function 4
Function 4 : On energisation, chance of contact bounce on instantaneous contact for 250 ms
Connections
88 226 0
No
Legend
Supply
Timed contact
Instantaneous contact
Connections
88 226 0
23/06/2014
www.crouzet.com
No 2-3
Legend
Supply
Timed contact
Connections
88 226 5
No
Legend
Supply
Timed contact
Connections
88 226 5
No
Legend
Supply
23/06/2014
www.crouzet.com
Timed contact
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Crouzet:
88226507
很抱歉,暂时无法提供与“88226507”相匹配的价格&库存,您可以联系我们找货
