88950302
88950302
    CROUZET(高诺斯)
    POWER SUP MOD 100-240VAC 24VDC
88950302 数据手册
02/11/2015 www.crouzet.com Modular power supplies PS Part number 88950302 Switch mode power supply regulated and protected against overloads and short-circuits, easy to integrate into switchboards and enclosures The potentiometer can be used to set the output voltage between 100 and 120 % (24 VDC versions) to compensate for any voltage drops on the line The LED continuously signals the presence of voltage at the output and, when flashing, triggering of the self-protection Broad range of supply voltage Double insulation Part numbers 88950302 Type Nominal output voltage Nominal power Nominal output current PS 24 V DC (22,8 V →28,8 V) 60 W 2,5 A Specifications Environmental characteristics Conformity to standards Certifications Emission Operating temperature Storage temperature (°C) Protection class IEC/EN 60950-1 IEC/EN 61000-6-2 IEC/EN 61000-6-3 IEC/EN 61204-3 IEC/EN 60364-4-41 SELV : Safety Extra Low Voltage EN 55022 (CISPR22) CE, UL, CSA, TüV Harmonic : IEC / EN 61000-3-2 -25 →+55 °C -40 →+70 °C Class 2 (Double insulation) Electrical characteristics Input voltage Supply frequency range Output voltage Peak current on energisation Regulation of line and load Immunity from micro power cuts Thermal protection Technology Short-circuit protection Overload protection Primary protection Reset after overload Dielectric strength Status indication 100 →240 V AC single-phase (-15 %/+10 %) 50/60 Hz (+4 % / -6 %) or 47→53 Hz/57 →63 Hz Adjustable from 100 →120 % < 20 A (Except for 88950302 : < 90A during 1 ms) ±3% < 10 ms (100 V AC) < 150 ms (230 V AC) Yes Primary switch mode electronic power supplies Yes Yes Fuse gG 2 A or circuit breaker 2 A curve D for 88950303, 88950304, 88950305, 88950306, 88950307 Fuse gG 3 A or circuit breaker 3 A curve D for 88950302 Automatic Input / output 3000 VAC / 50 Hz / 1mn LED at the output Mechanical characteristics Mounting Screw terminals connection capacity On section, 35 x 7, 5 mm and 35 x 15 mm or on panel (2 x Ø4 mm) Input connection 2 x 0,14 →2,5 mm2 (AWG 26...AWG 14) Output connection 1 x 0,14 →2,5 mm2 (AWG 26...AWG 14) Dimensions (mm) PS Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Curves Derating The ambient operating temperature of the Millenium power supplies is 55 °C. Above this, a derating is needed upto a maximum operating temperature of 70 °C. The chart below shows the power (compared to the nominal power) that can be permanently supplied by the power supply, depending on the operating temperature. No Legend 88950302 8895030x Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
88950302 价格&库存
很抱歉,暂时无法提供与“88950302”相匹配的价格&库存,您可以联系我们找货
