T1610010
T1610010
    REDLIONCONTROLS(美国红狮)
    CONTROL TEMP REL OUT 24V 18-36V
T1610010 数据手册
Bulletin No. T/P16-M Drawing No. LP0486 Released 11/16 Tel +1 (717) 767-6511 Fax +1 (717) 764-0839 www.redlion.net MODELS T16 & P16 - TEMPERATURE/PROCESS CONTROLLERS  PID CONTROL WITH REDUCED OVERSHOOT  T16 ACCEPTS TC AND RTD  P16 ACCEPTS 0-10 V AND 0/4-20 mA SIGNALS  ON DEMAND AUTO-TUNING OF PID SETTINGS  DC ANALOG OUTPUT (OPTIONAL)  USER PROGRAMMABLE FUNCTION BUTTON  PC OR FRONT PANEL PROGRAMMING  PC CONFIGURABLE WITH TP16KIT UL Recognized Component, File #E179259 GENERAL DESCRIPTION PC PROGRAMMING KIT The optional TP16KIT contains a programming module with a 9 pin RS232 connector, cable and Crimson, a Windows® based configuration software. The software allows downloading, uploading and storage of T16 and P16 program files. All controllers have a communications port that allows configuration by PC even without controller power connected. Controller calibration is also possible using the software when the proper calibration equipment and controller power is connected. The Model T16 Controller accepts signals from a variety of temperature sensors (thermocouple or RTD), while the Model P16 Controller accepts either a 0 to 10 VDC or 0/4 to 20 mA DC input signal. Both controllers can provide an accurate output control signal (time proportional or DC Analog Output) to maintain a process at a setpoint value. Dual 4-digit displays allow viewing of the process/temperature and setpoint simultaneously. Front panel indicators inform the operator of the controller and output status. The comprehensive programming allows these controllers to meet a wide variety of application requirements. CONSTRUCTION The controller is constructed of a lightweight, high impact, black plastic textured case and bezel with a clear display window. The front panel meets NEMA 4X/IP65 specifications when properly installed. In applications that do not require protection to NEMA 4X, multiple controllers can be stacked horizontally or vertically. Modern surface-mount technology, extensive testing, plus high immunity to noise interference makes the controller extremely reliable in industrial environments. MAIN CONTROL The controller operates in the PID Control Mode for both heating and cooling, with on-demand auto-tune, that establishes the tuning constants. The PID tuning constants may be fine-tuned through the front panel and then locked out from further modification. The controller employs a unique overshoot suppression feature, that allows the quickest response without excessive overshoot. Switching to Manual Mode provides the operator direct control of the output. The controller may also be programmed to operate in On/Off mode with adjustable hysteresis. SAFETY SUMMARY All safety related regulations, local codes and instructions that appear in the manual or on equipment must be observed to ensure personal safety and to prevent damage to either the instrument or equipment connected to it. If equipment is used in a manner not specified by the manufacturer, the protection provided by the equipment may be impaired. Do not use the controller to directly command motors, valves, or other actuators not equipped with safeguards. To do so can be potentially harmful to persons or equipment in the event of a fault to the controller. An independent and redundant temperature limit indicator with alarm outputs is strongly recommended. ALARMS Optional alarm(s) can be configured independently for absolute high or low acting with balanced or unbalanced hysteresis. They can also be configured for deviation and band alarm. In these modes, the alarm trigger values track the setpoint value. Adjustable alarm hysteresis can be used for delaying output response. The alarms can be programmed for Automatic or Latching operation. A selectable standby feature suppresses the alarm during power-up until the temperature stabilizes outside the alarm region. ANALOG OUTPUT OPTION The optional DC Analog Output (10 V or 20 mA) can be configured and scaled for control or re-transmission purposes. The programmable output update time reduces valve or actuator activity. CAUTION: Risk of Danger. Read complete instructions prior to installation and operation of the unit. CAUTION: Risk of electric shock. DIMENSIONS In inches (mm) PANEL CUT-OUT 1 R A1 A2 O1 O2 % MA N %PW 1.95 (49.5) 1.76 (44.7) 0.37 (9.4) 4.17 (105.9) 14 7 3 8 4 9 11 12 1.76 (44.7) 1 6 2 5 1.95 (49.5) 13 1.772 +0.024 -0.000 (45 +0.6 ) -0.0 10 +0.024 1.772 -0.000 (45 +0.6 ) -0.0 5. MEMORY: Nonvolatile E2PROM retains all programmable parameters. 6. ISOLATION LEVEL: AC power with respect to all other I/O: 250 V working (2300 V for 1 min.) Sensor input to analog output: 50 V working (500 V for 1 minute) Relay contacts to all other I/O: 300 V working (2300 V for 1 minute) DC power with respect to sensor input and analog output: 50 V working (500 V for 1 minute) 7. CERTIFICATIONS AND COMPLIANCES: CE Approved EN 61326-1 Immunity to Industrial Locations Emission CISPR 11 Class A IEC/EN 61010-1 RoHS Compliant UL Recognized Component: File #E179259 Type 4X Enclosure rating (Face only) IP65 Enclosure rating (Face only) IP20 Enclosure rating (Rear of unit) Refer to EMC Installation Guidelines section of the bulletin for additional information. 8. ENVIRONMENTAL CONDITIONS: Operating Temperature Range: 0 to 50°C Storage Temperature Range: -40 to 80°C Operating and Storage Humidity: 85% max relative humidity (noncondensing) from 0°C to 50°C Vibration to IEC 68-2-6: Operational 5 to 150 Hz, 2 g. Shock to IEC 68-2-27: Operational 20 g (10 g relay). Altitude: Up to 2000 meters 9. CONNECTION: Wire-clamping screw terminals 10. CONSTRUCTION: Black plastic alloy case and collar style panel latch. Panel latch can be installed for vertical or horizontal instrument stacking. Black plastic textured bezel with transparent display window. Controller meets NEMA 4X/IP65 requirements for indoor use when properly installed. Installation Category II, Pollution Degree 2. 11. WEIGHT: 6.3 oz (179 g) GENERAL SPECIFICATIONS 1. DISPLAY: 2 Line by 4-digit, LCD negative image transmissive with backlighting. Top (Process) Display: 0.3" (7.6 mm) high digits with red backlighting. Bottom (Parameter) Display: 0.2" (5.1 mm) high digits with green backlighting. 2. ANNUNCIATORS: Status Annunciators: O1 - Main control output is active. O2 - Cooling output is active (when Alarm 2 is used for cooling). A1 - Alarm 1 output is active. A2 - Alarm 2 output is active. °F, °C - Temperature units. %PW - Output power percentage is shown in Bottom display. MAN - Controller is in Manual Mode. R - Ramping Setpoint indicator. % - Percent indicator (P16 models only). Display Messages:  - Measurement exceeds + sensor range  - Measurement exceeds - sensor range  - Open sensor is detected (T16 only)  - Shorted sensor is detected (RTD only)  - Measurement exceeds controller limits (P16 only)  - Display value exceeds + display range  - Display value exceeds - display range 3. POWER: Line Voltage Models: 85 to 250 VAC, 50/60 Hz, 8 VA Low Voltage Models: DC Power: 18 to 36 VDC, 4 W AC Power: 24 VAC, ±10%, 50/60 Hz, 7 VA 4. CONTROLS: Three rubber push buttons for modification and setup of controller parameters. One additional button (F1) for user programmable function. One external user input (models with alarms) for parameter lockout or other user programmable functions. INPUT SPECIFICATIONS TYPE 1. SENSOR INPUT: Sample Period: 100 msec (10 Hz rate) Step Response Time: 300 msec typical, 400 msec max to within 99% of final value with step input. Failed Sensor Response: Main Control Output(s): Programmable preset output Display: “OPEN” Alarms: Upscale drive Analog Output: Upscale drive when assigned to retransmitted input. Normal Mode Rejection: >40 dB @ 50/60 Hz Common Mode Rejection: >120 dB, DC to 60 Hz Overvoltage Protection: 120 VAC @ 15 sec max 2. RTD INPUTS: (T16 only) Type: 2 or 3 wire Excitation: 150 µA typical Lead Resistance: 15 Ω max per input lead Resolution: 1° or 0.1° for all types TYPE INPUT TYPE RANGE 385 100 Ω platinum, Alpha = .00385 -200 to +600°C -328 to +1112°F IEC 751 100 Ω platinum, Alpha = .003919 120 Ω nickel, Alpha = .00672 -200 to +600°C -328 to +1112°F -80 to +215°C -112 to +419°F No official standard No official standard Linear Resistance 0.0 to 320.0 Ω N/A 392 672 Ohms J K R S B T E DISPLAY RANGE -200 to +400°C -328 to +752°F -200 to 750°C -328 to +1382°F WIRE COLOR BS 1843 (+) Blue (-) Red (+) Violet (-) Red (+) White (-) Blue (+) Brown (-) Blue BS 1843 -200 to +760°C -328 to +1400°F -200 to +1250°C -328 to +2282°F 0 to +1768°C +32 to +3214°F 0 to +1768°C +32 to +3214°F (+) White (-) Red (+) Yellow (-) Red No standard No standard (+) Yellow (-) Blue (+) Brown (-) Blue (+) White (-) Blue (+) White (-) Blue +149 to +1820°C +300 to +3308°F No standard No standard STANDARD -200 to +1300°C (+) Orange (+) Orange -328 to +2372°F (-) Red (-) Blue C 0 to +2315°C No No W5/W6 +32 to +4199°F standard standard -5.00 mV to mV N/A N/A 56.00mV ITS-90 ITS-90 ITS-90 ITS-90 ITS-90 ITS-90 ASTM E988-96 N/A 4. SIGNAL INPUT: (P16 only) MAX INPUT RANGE ACCURACY * IMPEDANCE CONTINUOUS RESOLUTION OVERLOAD STANDARD ANSI ANSI N 10 VDC (-1 to 11) 20 mA DC (-2 to 22) 0.30 % of reading +0.03V 0.30 % of reading +0.04V 1 MΩ 50 V 10 mV 10 Ω 100 mA 10 µA *Accuracies are expressed as ± percentages over 0 to 50 °C ambient range after 20 minute warm-up. 5. TEMPERATURE INDICATION ACCURACY: (T16 only) ± (0.3% of span, +1°C) at 23 °C ambient after 20 minute warm up. Includes NIST conformity, cold junction effect, A/D conversion errors and linearization conformity. Span Drift (maximum): 130 PPM/°C 6. USER INPUT: (Only controllers with alarms have a user input terminal.) Internally pulled up to +7 VDC (100 KΩ), VIN MAX = 35 V, VIL = 0.6 V max, VIH = 1.5 V min, IOFF = 40 µA max Response Time: 120 msec max Functions: Programmable 3. THERMOCOUPLE INPUTS: (T16 only) Types: T, E, J, K, R, S, B, N, C, and Linear mV Input Impedance: 20 MΩ for all types Lead Resistance Effect: 0.25 µV/Ω Cold Junction Compensation: Less than ±1°C typical (1.5°C max) error over ambient temperature range. Resolution: 1° for types R, S, B and 1° or 0.1° for all other types TYPE WIRE COLOR DISPLAY RANGE STANDARD ITS-90 ITS-90 2 OUTPUT SPECIFICATIONS Standby Mode: Programmable; enable or disable Hysteresis: Programmable Sensor Fail Response: Upscale Annunciator: “A1” and “A2” programmable for normal or reverse acting 4. COOLING: Software selectable (overrides Alarm 2). Control: PID or On/Off Output: Time proportioning Cycle Time: Programmable Proportional Gain Adjust: Programmable Heat/Cool Deadband Overlap: Programmable 5. ANALOG DC OUTPUT: (optional) Self-powered (Active) Action: Control or retransmission Update Rate: 0.1 to 250 sec 1. CONTROL AND ALARM OUTPUTS: Relay Output: Type: Form A Contact Rating: 3 A @ 250 VAC or 30 VDC (resistive load) Life Expectancy: 100,000 cycles at max. load rating (Decreasing load and/or increasing cycle time, increases life expectancy) Logic/SSR Output (main control output only): Rating: 45 mA max @ 4 V min., 7 V nominal 2. MAIN CONTROL: Control: PID or On/Off Output: Time proportioning or DC Analog Cycle Time: Programmable Auto-Tune: When selected, sets proportional band, integral time, derivative time, and output dampening time. Also sets input filter and (if applicable) cooling gain. Probe Break Action: Programmable 3. ALARMS: (optional) 2 relay alarm outputs. Modes: None Absolute High Acting (Balanced or Unbalanced Hysteresis) Absolute Low Acting (Balanced or Unbalanced Hysteresis) Deviation High Acting Deviation Low Acting Inside Band Acting Outside Band Acting Heat (Alarm 1 on Analog Output models only) Cool (Alarm 2) Reset Action: Programmable; automatic or latched OUTPUT RANGE ** ACCURACY * COMPLIANCE RESOLUTION 0 to 10 V 0.3% of FS + ½ LSD 10 kΩ min 1/8000 500 Ω max 1/8000 500 Ω max 1/6400 0 to 20 mA 4 to 20 mA 0.3% of FS + ½ LSD 0.3% of FS + ½ LSD * Accuracies are expressed as ± percentages over 0 to 50 °C ambient range after 20 minute warm-up. ** Outputs are independently jumper selectable for either 10 V or 20 mA. The output range may be field calibrated to yield approximately 5% overrange and a small underrange (negative) signal. ORDERING INFORMATION MODEL NO. MAIN CONTROL 2 ALARMS & USER INPUT Relay T16 P16 PART NUMBERS 18-36 VDC/24 VAC 85 to 250 VAC — T1610010 T1610000 Relay Yes T1611110 T1611100 Logic/SSR — T1620010 T1620000 T1621100 Logic/SSR Yes T1621110 Analog Out * Yes T1641110 T1641100 Relay — P1610010 P1610000 Relay Yes P1611110 P1611100 Logic/SSR — P1620010 P1620000 Logic/SSR Yes P1621110 P1621100 Analog Out * Yes P1641110 P1641100 * Analog out may be used for retransmitted signals. When using analog output for retransmitted signals, AL1 becomes main control O1, if selected for heating in the analog out models. ACCESSORIES MODEL NO. TP16 RLY DESCRIPTION PART NUMBERS Programming Kit 1 : Includes Software, Comms Module w/ 9-pin connector and cable, and 115 VAC Power Adapter TP16KIT1 Programming Kit 2 : Includes Software, Comms Module w/ 9-pin connector and cable TP16KIT2 External SSR Power Unit (for Logic/SSR models) RLY50000 25 A Single Phase Din Rail Mount Solid State Relay RLY60000 40 A Single Phase Din Rail Mount Solid State Relay RLY6A000 Three Phase Din Rail Mount Solid State Relay RLY70000 3 BLOCK DIAGRAM +7V 11 POWER SUPPLY 12 D + - +22V O + -6.2V OPTION POWER SUPPLY 25.5 ‚ +22V 20mA O 6 (+) O1 7 (-) O1 6 (+) O1 7 (-) O1 2 A1/O1 N.O. * 3 A1/O1 COMM 4 A2/O2 N.O. 5 A2/O2 COMM 100K .01µF D D 8.2 ‚ D 10 10 +7V +5V 10 ‚ +5V A +5V T16 TC+ P16 0-10V 9 9 976K 20K Process Circuitry A/D Converter +7V A INPUT COMM 8 A A D ALARM OUTPUT MODELS +7V 20M MAIN CONTROL OUTPUT 4.02K P16 0-20 mA -V/-I SSR DRIVE MODELS 2 E Memory +0.7V T16 RTD EXC 7 Keypad 100K 1 +V/+I 10V +7V 100K USER IN 6 (REAR) (FRONT) O O +7V - ANALOG OUTPUT MODELS POWER CONTROL CIRCUITRY POWER INPUT D/A CONV. D *A1 becomes main control O1, if selected for heating in the analog out models. EMC INSTALLATION GUIDELINES effective. The following EMI suppression devices (or equivalent) are recommended: Fair-Rite part number 0443167251 (Red Lion Controls #FCOR0000) Line Filters for input power cables: Schaffner # FN2010-1/07 (Red Lion Controls #LFIL0000) 6. To protect relay contacts that control inductive loads and to minimize radiated and conducted noise (EMI), some type of contact protection network is normally installed across the load, the contacts or both. The most effective location is across the load. a. Using a snubber, which is a resistor-capacitor (RC) network or metal oxide varistor (MOV) across an AC inductive load is very effective at reducing EMI and increasing relay contact life. b. If a DC inductive load (such as a DC relay coil) is controlled by a transistor switch, care must be taken not to exceed the breakdown voltage of the transistor when the load is switched. One of the most effective ways is to place a diode across the inductive load. Most Red Lion products with solid state outputs have internal zener diode protection. However external diode protection at the load is always a good design practice to limit EMI. Although the use of a snubber or varistor could be used. Red Lion part numbers: Snubber: SNUB0000 Varistor: ILS11500 or ILS23000 7. Care should be taken when connecting input and output devices to the instrument. When a separate input and output common is provided, they should not be mixed. Therefore a sensor common should NOT be connected to an output common. This would cause EMI on the sensitive input common, which could affect the instrument’s operation. Although Red Lion Controls products are designed with a high degree of immunity to Electromagnetic Interference (EMI), proper installation and wiring methods must be followed to ensure compatibility in each application. The type of the electrical noise, source or coupling method into a unit may be different for various installations. Cable length, routing, and shield termination are very important and can mean the difference between a successful or troublesome installation. Listed are some EMI guidelines for a successful installation in an industrial environment. 1. A unit should be mounted in a metal enclosure, which is properly connected to protective earth. 2. Use shielded cables for all Signal and Control inputs. The shield connection should be made as short as possible. The connection point for the shield depends somewhat upon the application. Listed below are the recommended methods of connecting the shield, in order of their effectiveness. a. Connect the shield to earth ground (protective earth) at one end where the unit is mounted. b. Connect the shield to earth ground at both ends of the cable, usually when the noise source frequency is over 1 MHz. 3. Never run Signal or Control cables in the same conduit or raceway with AC power lines, conductors, feeding motors, solenoids, SCR controls, and heaters, etc. The cables should be run through metal conduit that is properly grounded. This is especially useful in applications where cable runs are long and portable two-way radios are used in close proximity or if the installation is near a commercial radio transmitter. Also, Signal or Control cables within an enclosure should be routed as far away as possible from contactors, control relays, transformers, and other noisy components. 4. Long cable runs are more susceptible to EMI pickup than short cable runs. 5. In extremely high EMI environments, the use of external EMI suppression devices such as Ferrite Suppression Cores for signal and control cables is Visit http://www.redlion.net/emi for more information on EMI guidelines, Safety and CE issues as they relate to Red Lion products. 4 1.0 Setting the Jumpers To insure proper operation, the Analog Output jumpers must be set to the same range selected in programming Module 2-OP. The default jumper setting is for 20 mA. The default setting in Module 2-OP is 4-20 mA. To access the jumpers, insert a flat-blade screwdriver between the front panel and the side case slot. This should disengage the top and bottom front panel latches from the case grooves. Pull the front panel assembly with the controller boards out of the case. The jumpers are located inside the controller on the left board along the back top section. RDY A1 A2 01 02 F1 (Analog Output Models Only) LS RED RK, YO TRO ON N C .S.A. LIO DE MA PA. IN U 10V (Both jumpers toward the front of the unit) ° % MA N %P W 20mA (Both jumpers toward the rear of the unit) VIEW FROM TOP OF UNIT 2.0 Installing the Controller The T16 and P16 controllers meet NEMA 4X/IP65 requirements for indoor use to provide a watertight seal in steel panels with a minimum thickness of 0.09", or aluminum panels with a minimum thickness of 0.12". The controllers are designed to be PANEL GASKET mounted into an enclosed panel. The bezel assembly must be in place during installation of BEZEL the controller. PANEL 13 14 6 7 PANEL MOUNTING SCREW LATCHING TABS 8 9 10 LATCHING SLOTS PANEL LATCH Instructions: 1. Prepare the panel cutout to the proper dimensions. 2. Remove the panel latch from the controller. Discard the cardboard sleeve. 3. Carefully remove the center section of the panel gasket and discard. Slide the panel gasket over the rear of the controller, seating it against the lip at the front of the case. 4. Insert the controller into the panel cutout. While holding the controller in place, push the panel latch over the rear of the controller, engaging the tabs of the panel latch in the farthest forward slot possible. 5. To achieve a proper seal, tighten the panel latch screws evenly until the controller is snug in the panel, torquing the screws to approximately 7 in-lb (79 N-cm). Overtightening can result in 1.772 +0.024 -0.000 distortion of the controller, and reduce the (45 +0.6 ) effectiveness of the seal. -0.0 Note: The installation location of the controller is important. Be sure to keep it away from heat sources (ovens, furnaces, etc.) and away from 1.772 +0.024 direct contact with caustic vapors, oils, steam, or -0.000 any other process by-products in which exposure (45 +0.6 -0.0 ) may affect proper operation. Multiple Controller Stacking 2.39 (60.7) MAX. The controller is designed to allow for close spacing of multiple controllers in applications that do not require protection to NEMA 4X. Controllers can be stacked either horizontally or vertically. For vertical stacking, install the panel latch with the screws to the sides of the controller. For horizontal stacking, the panel latch screws should be at the top and bottom of the controller. The minimum spacing from centerline to centerline of controllers is 1.96" (49.8 mm). This spacing is the 1.96 (49.8) same for vertical or MIN horizontal stacking. Note: When stacking controllers, provide adequate panel ventilation to ensure that the maximum operating temperature range is not exceeded. 1.96 (49.8) MAX 1.96 (49.8) MAX. 2.39 (60.7) MAX STANDARD PANEL CUT-OUT IF NEMA 4 IS NOT REQUIRED, THIS PANEL MATERIAL MAY BE REMOVED. 5 3.0 Wiring the Controller WIRING CONNECTIONS codes and regulations. It is recommended that power (AC or DC) supplied to the controller be protected by a fuse or circuit breaker. Strip the wire, leaving approximately 1/4" (6 mm) bare wire exposed (stranded wires should be tinned with solder). Insert the wire under the clamping washer and tighten the screw until the wire is clamped tightly. All wiring connections are made to the rear screw terminals. When wiring the controller, use the numbers on the label and those embossed on the back of the case, to identify the position number with the proper function. All conductors should meet voltage and current ratings for each terminal. Also, cabling should conform to appropriate standards of good installation, local VDC CONTROLLER POWER CONNECTIONS For best results, the power should be relatively “clean” and within the specified limits. Drawing power from heavily loaded circuits or from circuits that also power loads that cycle on and off should be avoided. It is recommended that power supplied to the controller be protected by a fuse or circuit breaker. DC+ 11 DC12 + INPUT CONNECTIONS - Voltage and Current Thermocouple and Millivolt COMM 8 COMM 8 TC+ 9 TC+ 9 RTD 10 RTD 10 ~ AC 12 the preferred method. If a sense wire is not used, then use a jumper. A temperature offset error will exist. The error may be compensated by programming a temperature offset. For two wire RTDs, install a copper sense lead of the same gauge and length as the RTD leads. Attach one end of the wire at the probe and the other end to input common terminal. Complete lead wire compensation is obtained. This is RTD and Resistance VAC ~ AC 11 TC- COMM 8 TC+ DC- 10V 9 DC+ VOLTAGE 20mA 10 DC+ CURRENT CONTROL AND ALARM OUTPUT CONNECTIONS Alarm Models LOAD AC/DC POWER 2 Main Control Relay Models N.O. (+) O1 6 (-) O1 7 A1/O1* LOAD AC/DC POWER 3 COMM. 4 N.O. (+) O1 COMM. *A1 becomes main control O1, if selected for heating in the analog out models. 6 - V/I 7 6 (-) O1 7 + AC SSR POWER - UNIT AC AC POWER USER INPUT CONNECTIONS ANALOG DC OUTPUT CONNECTIONS + V/I AC/DC POWER Main Control Logic/SSR Models A2/O2 5 LOAD USER INPUT 1 CONTROLLER, RECORDER 6 8 COMM. 4.0 Reviewing the Front Keys DISPLAYS TEMPERATURE/PROCESS VALUE. ALSO DISPLAYS PARAMETER NAME IN CONFIGURATION LOOP. ILLUMINATES WHEN ALARM 1 OUTPUT IS ACTIVE. ILLUMINATES WHEN °F or °C IS SELECTED. (T16 ONLY) ILLUMINATES WHEN ALARM 2 OUTPUT IS ACTIVE. ILLUMINATES WHEN COOLING (SECONDARY) OUTPUT IS ACTIVE. Display TOP DISPLAY FLASHES WHEN RAMPING SETPOINT IS ACTIVE. ILLUMINATES WHEN MAIN CONTROL OUTPUT IS ACTIVE. and R A1 A2 O1 O2 % MA N %PW BOTTOM DISPLAY FRONT PANEL KEYS The F1 key is pressed to exit (or escape) directly to the start of the Display Loop. While in the Display Loop, the F1 key can be pressed to activate its programmed function. A The Loop key is pressed to advance to the next parameter, to activate a changed selection/value, and when held for three seconds, enter the Hidden Loop. ILLUMINATES WHEN CONTROLLER IS IN MANUAL MODE. ILLUMINATES WHEN OUTPUT POWER PERCENTAGE IS SHOWN. DISPLAYS SETPOINT OR % OUTPUT POWER. ALSO DISPLAYS PARAMETER NAME AND VALUE IN DISPLAY AND HIDDEN LOOPS OR PARAMETER VALUE IN CONFIGURATION LOOP. L ILLUMINATES WHEN PERCENT IS SELECTED. (P16 ONLY) BJ The Arrow keys are used to scroll through parameter selections/ values and in the Configuration Loop they are used to scroll to the appropriate Parameter Module. 5.0 Programming: Display Loop DISPLAY LOOP Note: Setpoint and Output Power are the only parameters visible in the Display Loop with Factory Settings. The remaining parameters can be selected for the Display Loop within Module 3. Parameter availability is model and programming dependent. FRONT DISPLAY TOP DISPLAY TEMP/PROCESS   BOTTOM DISPLAY PARAMETER SELECTION/VALUE F1 ENDS AND RETURNS TO START OF DISPLAY LOOP. ADVANCES TO NEXT PARAMETER.   CHANGES SELECTION/VALUE. DISPLAY LOOP When the A is pressed the controller advances to the next parameter in the Display Loop. Except for Setpoint and % Output Power, the bottom display alternates between the parameter name and its selection/value. The arrow keys are pressed to change the selection/value for the shown parameter. The new selection/value is activated when the A is pressed. Display Loop parameters may be locked out or hidden in Lockout Module 3-LC. Some parameters are model and programming dependent. At power up, all display segments light, and then the programmed input type and the controller’s software version will flash. Then the Temperature/Process Value is shown in the top display, and the Setpoint Value is shown in the bottom display. This is the Display Loop. If the Setpoint is hidden or locked, the Display Loop will default to Output Power. If Output Power is also hidden or locked out, the bottom display is blank. During programming, the F1 key can be pressed to return the controller to this point. (Only in the Display Loop will the F1 key perform the user F1In function programmed in Input Module 1-IN.) 7 The values shown for the displays are the factory settings. INTEGRAL TIME SETPOINT VALUE (SP1) *    T16      to  Integral action shifts the center point position of the proportional band to eliminate error in the steady state. The higher the integral time, the slower the response. The optimal integral time is best determined during PID Tuning. If time is set to zero, the previous Integral output power value is maintained. Offset Power can be used to provide Manual Reset. P16 SETPOINT VALUE (SP2) *  20   to  DERIVATIVE TIME T16     P16 Typically, the controller is operating with the Setpoint value in the bottom display. There is no annunciator nor parameter indication for Setpoint in the Display Loop. The parameter name alternates with the setpoint value in the Hidden Loop. The Setpoint value can be changed, activated and stored by pressing the arrow keys. This is the only parameter that can be configured as read only in the Display Loop, but read/write in the Hidden Loop. It is possible to store a second Setpoint value that can be selected in the Hidden Loop, by the F1 key or the user input. Both Setpoint values are limited by the Setpoint Low and High Limits in Input Module 1-IN. ALARM 1 VALUE       to   to  P16 ALARM 2 VALUE      OUTPUT POWER OFFSET  to  T16  to  P16 On models with alarms, the value for Alarm 2 can be entered here. The value is either absolute (absolute alarm types) or relative to the Setpoint value (deviation and band alarm types.) When Alarm 2 is programmed for  or , this parameter is not available. For more details on alarms, see the Alarm Module . When the Integral Time is set to zero and the controller is in the Automatic Mode, this parameter will appear after % Output Power. It is also shown with the %PW annunciator illuminated. The power offset is used to shift the proportional band to compensate for errors in the steady state. If Integral Action is later invoked, the controller will re-calculate the internal integral value to provide “bumpless” transfer and Output Power Offset will not be necessary. PROPORTIONAL BAND     T16 On models with alarms, the value for Alarm 1 can be entered here. The value is either absolute (absolute alarm types) or relative to the Setpoint value (deviation and band alarm types.) When Alarm 1 is programmed for  or , this parameter is not available. For more details on alarms, see Alarm Module 4-AL. The % Output Power is shown with the %PW annunciator. The parameter name alternates with the % Output Power value in the Hidden Loop. While the controller is in Automatic Mode, this value is read only. When the controller is placed in Manual Mode, the value can be changed, activated and stored by pressing the arrow keys. For more details on % Output Power, see Control Mode Explanations.      to  seconds per repeat Derivative time helps to stabilize the response, but too high of a derivative time, coupled with noisy signal processes, may cause the output to fluctuate too greatly, yielding poor control. Setting the time to zero disables derivative action. % OUTPUT POWER *    to  seconds * Alternating indication only used in the Hidden Loop.  to  (% of full input range) The proportional band should be set to obtain the best response to a process disturbance while minimizing overshoot. A proportional band of 0.0% forces the controller into On/Off Control with its characteristic cycling at Setpoint. For more information, see Control Mode and PID Tuning Explanations. 8 6.0 Programming: Hidden Loop HIDDEN LOOP To enter Hidden Loop, press A for 3 seconds. Note: Parameters shown bold are the only parameters visible in the Hidden Loop with Factory Settings. Setpoint and Output Power are factory set for the Display Loop. The remaining parameters can be selected for the Hidden Loop within Module 3. Parameter availability is model and programming dependent. FRONT DISPLAY TOP DISPLAY TEMP/PROCESS   BOTTOM DISPLAY PARAMETER SELECTION/VALUE F1   ENDS AND RETURNS TO START OF DISPLAY LOOP. ADVANCES TO NEXT PARAMETER. CHANGES SELECTION/VALUE. HIDDEN LOOP When A is pressed and held for three seconds, the controller advances to the Hidden Loop. The Temperature/Process Value is shown in the top display. The bottom display alternates between the parameter and its selection/value. B or J is pressed to change the selection/value for the shown parameter. The new selection/value is activated after A is pressed. When L is pressed, the controller returns to the Display Loop and stores changed selection/values to permanent memory. Hidden Loop parameters may be locked out in Lockout Module . Some parameters are model and programming dependent. SETPOINT RAMP RATE     The setpoint ramp rate can reduce sudden shock to the process and reduce overshoot on startup or after setpoint changes, by ramping the setpoint at a controlled rate. R annunciator flashes while ramping. With the T16, the ramp rate is always in tenths of degrees per minute, regardless of the resolution chosen for the process display. With the P16, the ramp rate is in least-significant (display units) digits per minute. A value of 0.0 or 0 disables setpoint ramping. Once the ramping setpoint reaches the target setpoint, the setpoint ramp rate disengages until the setpoint is changed again. If the ramp value is changed during ramping, the new ramp rate takes effect. If the setpoint is ramping prior to starting AutoTune, the ramping is suspended during Auto-Tune and then resumed afterward. Deviation and band alarms are relative to the target setpoint, not the ramping setpoint. A slow process may not track the programmed setpoint rate. At power up, the ramping setpoint is initialized at the ambient temperature/process value. ACCESS CODE      to  If the Access Code is set from 1 to 125, in Lockout Module 3-LC, Access Code will appear here. By entering the proper Code, access to the Hidden Loop is permitted. With the factory setting of 0, Access Code will not appear in the Hidden Loop. A universal code of 111 can be entered to gain access, independent of the programmed code number. CONTROL MODE TRANSFER     SETPOINT SELECT      to   or    In Automatic Mode, the percentage of Output Power is automatically determined by the controller. In Manual/User  Mode, the percentage of Output Power is adjusted manually while in the Display Loop. The Control Mode can also be transferred through the F1 Key or User Input. For more information, see Control Mode Explanations. The SPSL function allows the operator to switch from or to, setpoint 1 and setpoint 2. In the Display Loop, there is no annunciator indicating the selected Setpoint, however, the selected Setpoint value is displayed and activated. 9 AUTO-TUNE START     ACCESS CODE       The Auto-Tune procedure of the controller sets the Proportional Band, Integral Time, Derivative Time, Digital Filter, Control Output Dampening Time, and Relative Gain (Heat/Cool) values appropriate to the characteristics of the process. This parameter allows front panel starting  or stopping  of Auto-Tune. For more information, see PID Tuning Explanations. If the Access Code is set from -1 to -125, in Lockout Module , Access Code will appear here. By entering the proper Code, access to the Configuration Loop is permitted (with a negative Code value, the Hidden Loop can be accessed without the use of a code). With the factory setting of 0 or with an active User Input configured for Program Lock (), Access Code will not appear here. An active user input configured for Program Lock () always locks out the Configuration Loop, regardless of Access Code. ALARMS RESET      to   With alarm models, the alarms can be manually reset. The up key resets Alarm 1 and the down key resets Alarm 2. 7.0 Programming: Configuration Loop HIDDEN LOOP   CONFIGURATION LOOP DISPLAY LOOP INPUT PARAMETERS MODULE  OUTPUT PARAMETERS MODULE  FRONT DISPLAY TOP DISPLAY TEMP/PROCESS   BOTTOM DISPLAY CNFP/MODULE LOCKOUT PARAMETERS MODULE ALARM PARAMETERS MODULE   F1 COOLING PARAMETERS MODULE  FACTORY SERVICE MODULE  ENDS AND RETURNS TO START OF DISPLAY LOOP. ENTERS MODULE OR AT CNFP/NO RETURNS TO DISPLAY LOOP.   ADVANCES TO NEXT MODULE. To access the Configuration Loop, press the up key when / is displayed in the Hidden Loop. The arrow keys are used to select the parameter module (1-9). To enter a specific module press A while the module number is displayed. In the Configuration Loop,  will alternate with the parameter number in the bottom display. The Temperature/Process Value is shown in the top display. After entering a parameter module, press A to advance through the parameter names in the module. To change a parameter’s selection/value, press the arrow keys while the parameter is displayed. In the modules, the top display shows the parameter name, and the bottom display shows the selection/value. Use A to enter any selection/values that have been changed. The change is not committed to permanent memory until the controller is returned to the Display Loop. If a power loss occurs before returning to the Display Loop, the new values must be entered again. At the end of each module, the controller returns to /. At this location, pressing A again returns the display to the the Display Loop. Pressing the Up key allows re-entrance to the Configuration Loop. Whenever L is pressed,  momentarily appears as the parameters are stored to permanent memory and the controller returns to the Display Loop. FRONT DISPLAY TOP DISPLAY PARAMETER BOTTOM DISPLAY SELECTION/VALUE F1   ENDS AND RETURNS TO START OF DISPLAY LOOP. ADVANCES TO NEXT PARAMETER OR AT  RETURNS TO DISPLAY LOOP. ADVANCES SELECTION/VALUE. 10 7.1 MODULE 1 - Input Parameters (1-IN) T16 Only PARAMETER MENU          INPUT TYPE TEMP SCALE DECIMAL RESOLUTION DIGITAL FILTERING SHIFT/ OFFSET SETPOINT LOW LIMIT SETPOINT HIGH LIMIT INPUT TYPE   SELECTION TYPE   j     T TC E TC J TC K TC R TC S TC B TC   TYPE N TC C TC RTD 385 RTD 392 SETPOINT HIGH LIMIT Linear Ohms    Fahrenheit  Celsius USER INPUT FUNCTION (OPTIONAL)   DECIMAL RESOLUTION SELECTION  to  for temperature and resistance inputs  for mV inputs     Select whole degrees, or tenths of degrees for Temperature display, Setpoint values, and related parameters. For Linear Resistance inputs , the same parameter selections apply in ohms or tenths of an ohm. For mV inputs , only hundredths of a mV resolution is available. FUNCTION No Function Program Lock Integral Action Lock SELECTION    FUNCTION Setpoint 1 or 2 Select Setpoint Ramp Disable Reset Both Alarms Auto/Manual Select The controller performs the selected User Input function (User Input available only on models with alarms), when the User terminal 1 is connected (pulled low) to Common terminal 8. No Function: No function is performed. Program Lock: The Configuration Loop is locked, as long as activated (maintained action). Integral Action Lock: The integral action of the PID computation is disabled (frozen), as long as activated (maintained action). Auto/Manual Select: This function selects (maintained action) Automatic (open) or Manual Control (activated). Setpoint 1 or 2 Select: This function selects (maintained action) Setpoint 1(open) or Setpoint 2 (activated) as the active setpoint. Setpoint Ramp Disable: The setpoint ramping feature is disabled, as long as activated (maintained action). Any time the user input is activated with a ramp in process, ramping is aborted. Reset Alarms: Active alarms are reset, as long as activated (maintained action). Active alarms are reset until the alarm condition is cleared and triggered again (momentary action). DIGITAL FILTERING  = least to  = most The filter is an adaptive digital filter that discriminates between measurement noise and actual process changes. If the signal is varying too greatly due to measurement noise, increase the filter value. If the fastest controller response is needed, decrease the filter value. SHIFT/OFFSET    to  The controller has a programmable high setpoint limit value to restrict the setting range of the setpoint. Set the limit so that the setpoint value cannot be set above the safe operating area of the process. Select either degrees Fahrenheit or Celsius. For linear mV and ohms input types, this has no effect. If changed, adjust related parameter values, as the controller does not automatically convert them.    to  RTD 672 TEMPERATURE SCALE   F1 KEY FUNCTION The controller has a programmable low setpoint limit value to restrict the setting range of the setpoint. Set the limit so that the setpoint value cannot be set below the safe operating area of the process. Linear mV Select the input type that corresponds to the input sensor.    USER INPUT SETPOINT LOW LIMIT SELECTION          to  degrees This value offsets the controller’s temperature display value by the entered amount. This is useful in applications in which the sensor cannot provide the actual temperature signal due to mounting constraints, inaccuracy, etc. 11 F1 KEY FUNCTION The controller performs the selected F1 Key Function, when L is pressed while in the Display Loop. In any other loop or module location, pressing L will perform an escape to the Display Loop. No Function: No function is performed. Auto/Manual Select: This function toggles (momentary action) the controller between Automatic and Manual Control. Setpoint 1 or 2 Select: This function toggles (momentary action) the controller between Setpoint 1 and Setpoint 2. Reset Alarms: This function can be used to reset one or both of the alarms when activated (momentary action) The alarm will remain reset until the alarm condition is cleared and triggered again.   SELECTION    FUNCTION SELECTION No Function    Auto/Manual Select Setpoint 1 or 2 Select FUNCTION Reset Alarm 1 Reset Alarm 2 Reset Both Alarms 7.1 MODULE 1 - Input Parameters (1-IN) P16 Only PARAMETER MENU  A A   INPUT TYPE PERCENT SYMBOL   DECIMAL ROUNDING RESOLUTION INCREMENT          DIGITAL FILTERING DISPLAY VALUE 1 INPUT VALUE 1 INPUT TYPE   SELECTION TYPE   Current Voltage  On  Off   SETPOINT HIGH LIMIT USER INPUT F1 KEY FUNCTION  to  Enter the first coordinate Display Value by using the arrow keys. DECIMAL RESOLUTION INPUT VALUE SCALING POINT 1       This selection affects the decimal point placement for the Process value, and related parameters.  to  mA  to  V For Key-in Method, enter the first coordinate Input Value by using the arrow keys. To allow the P16 to “learn” the signal, use the Applied Method. For Applied Method, press L. The ° annunciator is turned on to indicate the applied method. Adjust the applied signal level externally until the appropriate value appears under . Using either method, press A to store the value for . (The controller can be toggled back to the Key-in Method by pressing L before A.) ROUNDING INCREMENT  to  In steps of 1 least significant digit, regardless of decimal point. Rounding selections other than 1 cause the process value display to round to the nearest rounding increment selected. (For example, rounding of 5 causes 122 to round to 120 and 123 to round to 125.) Rounding starts at the least significant digit of the process value. Setpoint values, Setpoint limits, Alarm values, Input Scaling values, and Analog Scaling values are not affected by rounding. DISPLAY VALUE SCALING POINT 2   DIGITAL FILTERING   SETPOINT LOW LIMIT DISPLAY VALUE SCALING POINT 1 This only illuminates the % annunciator. It does not perform any type of percent function, but is useful in applications that have been scaled in percent.   INPUT VALUE 2 To scale the controller, two scaling points are necessary. Each scaling point has a coordinate pair of Display Values and Input Values. It is recommended that the two scaling points be at the low and high ends of the input signal being measured. Process value scaling will be linear between and continue past the entered points to the limits of the input range. (Factory settings example will display 0.0 at 4.00 mA input and display 100.0 at 20.00 mA input.) Reverse acting indication can be accomplished by reversing the two signal points or the Display value points, but not both. If both are reversed, forward (normal) acting indication will occur. In either case, do not reverse the input wires to change the action. PERCENT ANNUNCIATOR   DISPLAY VALUE 2 SCALING Select the input type that corresponds to the input signal.     to  Enter the second coordinate Display Value by using the arrow keys.  = least to  = most The filter is an adaptive digital filter that discriminates between measurement noise and actual process changes. If the signal is varying too greatly due to measurement noise, increase the filter value. If the fastest controller response is needed, decrease the filter value. 12 INPUT VALUE SCALING POINT 2   F1 KEY FUNCTION    to  mA  to  V SELECTION For Key-in Method, enter the second coordinate Input Value by using the arrow keys. To allow the P16 to “learn” the signal, use the Applied Method. For Applied Method, press L. The ° annunciator is turned on to indicate the applied method. Adjust the applied signal level externally until the appropriate value appears under . Using either method, press A to store the value for . (The controller can be toggled back to the Key-in Method by pressing L before A.)     to  The controller has a programmable low setpoint limit value to restrict the setting range of the setpoint. Set the limit so that the setpoint value cannot be set below the safe operating area of the process. SETPOINT HIGH LIMIT    to  The controller has a programmable high setpoint limit value to restrict the setting range of the setpoint. Set the limit so that the setpoint value cannot be set above the safe operating area of the process. USER INPUT FUNCTION (OPTIONAL)   SELECTION     FUNCTION No Function Program Lock Integral Action Lock SELECTION    Auto/Manual Select Setpoint 1 or 2 Select SELECTION    FUNCTION Reset Alarm 1 Reset Alarm 2 Reset Both Alarms The controller performs the selected F1 key function, when L is pressed while in the Display Loop. In any other loop or module location, pressing L will perform an escape to the Display Loop. No Function: No function is performed. Auto/Manual Select: This function toggles (momentary action) the controller between Automatic and Manual Control. Setpoint 1 or 2 Selection: This function toggles (momentary action) the controller between Setpoint 1 and Setpoint 2. Reset Alarms: This function can be used to reset one or both of the alarms when activated (momentary action). The alarm will remain reset until the alarm condition is cleared and triggered again. SETPOINT LOW LIMIT  0.0 FUNCTION No Function FUNCTION Setpoint 1 or 2 Select Setpoint Ramp Disable Reset Both Alarms Auto/Manual Select The controller performs the selected User Input function (User Input available only on models with alarms), when the User terminal 1 is connected (pulled low) to Common terminal 8. No Function: No function is performed. Program Lock: The Configuration Loop is locked, as long as activated (maintained action). Integral Action Lock: The integral action of the PID computation is disabled (frozen), as long as activated (maintained action). Auto/Manual Select: This function selects (maintained action) Automatic (open) or Manual Control (activated). Setpoint 1 or 2 Select: This function selects (maintained action) Setpoint 1(open) or Setpoint 2 (activated) as the active setpoint. Setpoint Ramp Disable: The setpoint ramping feature is disabled, as long as activated (maintained action). Any time the user input is activated with a ramp in process, ramping is aborted. Reset Alarms: Active alarms are reset, as long as activated (maintained action). Active alarms are reset until the alarm condition is cleared and triggered again (momentary action). 13 7.2 MODULE 2 - Output Parameters (2-OP) 2-OP CYCt CYCLE TIME PARAMETER MENU OPAC OPLO CONTROL ACTION OPHI OUTPUT POWER LOW LIMIT OUTPUT POWER HIGH LIMIT OPFL SENSOR FAIL POWER LEVEL OPdP OUTPUT POWER DAMPENING tcod CHYS ON/OFF AUTO-TUNE CODE CONTROL HYSTERESIS CNFP ANtP    to  seconds ANHI ANALOG LOW SCALING ANALOG HIGH SCALING OUTPUT POWER DAMPENING     Direct (cooling)  Reverse (heating)  to  seconds T16 P16 The Dampening Time, entered as a time constant in seconds, dampens (filters) the calculated output power. Increasing the value increases the dampening effect. Generally, dampening times in the range of one-twentieth to one-fiftieth of the controller’s integral time (or process time constant) are effective. Dampening times longer than these may cause controller instability due to the added lag effect. This determines the control action for the PID loop. Programmed for direct action (cooling), the output power will increase if the Process value is above the Setpoint value. Programmed for reverse action (heating), the output power decreases when the Process Value is above the Setpoint Value. For heat and cool applications, this is typically set to reverse. This allows O1 or A1 (models with Analog Output) to be used for heating, and A2/O2 to be used for cooling. ON/OFF CONTROL HYSTERESIS  OUTPUT POWER LOWER LIMIT    to  percent O1  to  percent O1/O2  to  T16 P16 The controller can be placed in the On/Off Control Mode by setting the Proportional Band to 0.0%. The On/Off Control Hysteresis (balanced around the setpoint) eliminates output chatter. In heat/cool applications, the control hysteresis value affects both Output O1 and Output O2 control. It is suggested to set the hysteresis band to Factory Setting prior to starting Auto-Tune. After Auto-Tune, the hysteresis band has no effect on PID Control. On/Off Control Hysteresis is illustrated in the On/Off Control Mode section. This parameter may be used to limit controller power at the lower end due to process disturbances or setpoint changes. Enter the safe output power limits for the process. If Alarm 2 is selected for cooling, the range is from -100 to +100%. At 0%, both O1 and O2 are off; at 100%, O1 is on; and at -100%, O2 is on. When the controller is in Manual Control Mode, this limit does not apply. OUTPUT POWER UPPER LIMIT   ANLO ANALOG UPDATE TIME  to  percent O1  to  percent O1/O2 CONTROL ACTION   ANUt This parameter sets the power level for the control outputs in the event of a sensor failure. If Alarm 2 is not selected for cooling, the range is from 0% (O1 output full off) to 100% (O1 output full on). If A2 is selected for cooling, the range is from -100 to +100%. At 0%, both O1 and O2 are off; at 100%, O1 is on; and at -100%, O2 is on. The alarm outputs are upscale drive with an open sensor, and downscale drive with a shorted sensor (RTD only), independent of this setting. Manual Control overrides the sensor fail preset. The Cycle Time is entered in seconds with one tenth of a second resolution. It is the total time for one on and one off period of the time proportioning control output O1. With time proportional control, the percentage of power is converted into an output on-time relative to the cycle time value set. (If the controller calculates that 65% power is required and a cycle time of 10.0 seconds is set, the output will be on for 6.5 seconds and off for 3.5 seconds.) For best control, a cycle time equal to one-tenth or less, of the natural period of oscillation of the process is recommended. When using the Analog Output signal for control, the Cycle Time setting has no effect. If the O1 output is not being used, a cycle time of 0 can be entered to prevent the output and indicator from cycling.   ANALOG OUTPUT ASSIGNMENT SENSOR FAIL POWER LEVEL CYCLE TIME   ANAS ANALOG OUTPUT RANGE AUTO-TUNE CODE  to  percent O1  to  percent O1/O2   This parameter may be used to limit controller power at the upper end due to process disturbances or setpoint changes. Enter the safe output power limits for the process. If Alarm 2 is selected for cooling, the range is from -100 to +100%. At 0%, both O1 and O2 are off; at 100%, O1 is on; and at -100%, O2 is on. When the controller is in Manual Control Mode, this limit does not apply.  fastest to  slowest Prior to starting Auto-Tune, this code should be set to achieve the necessary dampening level under PID Control. This value allows customization of the PID values that Auto-Tune will calculate. For the process to be controlled aggressively (fastest process response with possible overshoot), set the Auto-Tune Code to 0. For the process to be controlled conservatively (slowest response with the least amount of overshoot), set this value to 2. If the Auto-Tune Code is changed, Auto-Tune needs to be reinitiated for the changes to affect the PID settings. For more information, see PID Tuning Explanations Section. 14 ANALOG LOW SCALING (OPTIONAL) ANALOG OUTPUT RANGE (OPTIONAL)    V  mA  mA ANLO  Select the type of output and range. The Analog output jumpers are factory set to current. They must be changed if voltage output is desired. The Analog output can be calibrated to provide up to approximately 5% over range operation (0 mA current can only go slightly negative). The Analog Output assignment value that corresponds to 0 V, 0 mA or 4 mA output as selected. ANALOG HIGH SCALING (OPTIONAL)   ANALOG OUTPUT ASSIGNMENT (OPTIONAL)   -999 to 9999  Main Control % Output Power  Input Signal Retransmission  Active Setpoint -999 to 9999 The Analog Output assignment value that corresponds to 10 V or 20 mA output as selected. An inverse acting output can be achieved by reversing the low and high scaling points. This setting selects the parameter that the Analog Output will retransmit or track. ANALOG UPDATE TIME (OPTIONAL)    to  seconds  = update rate of 0.1 second The update time of the Analog Output can be used to reduce excess valve actuator or pen recorder activity. 7.3 MODULE 3 - Lockout Parameters (3-LC) PARAMETER MENU     SETPOINT ACCESS SELECTION          OUTPUT POWER ACCESS PID VALUES ACCESS ALARM VALUES ACCESS ACCESS CODE  SETPOINT SELECT ACCESS   Hide: accessible in Hidden Loop. Locked: not accessible in either loop. Display/read: read only in Display Loop, (SP only) but read/write in Hidden Loop.     PID VALUES ACCESS     CONTROL TRANSFER ACCESS AUTO-TUNE START ACCESS RESET ALARMS ACCESS  to 125   to  The following parameters can be configured for , , and . OUTPUT POWER ACCESS SETPOINT RAMP ACCESS  ACCESS CODE DESCRIPTION Display: accessible in Display Loop. SETPOINT ACCESS   to  Full access to Display, Hidden, and Configuration Loops Code necessary to access Configuration Loop only. Code necessary to access Hidden and Configuration Loops. The following parameters can be configured for  or  only. ALARM VALUES ACCESS SETPOINT SELECT ACCESS   SETPOINT RAMP ACCESS CONTROL TRANSFER ACCESS       AUTO-TUNE START ACCESS   15 RESET ALARMS ACCESS   7.4 MODULE 4 - Alarm Parameters (4-AL) (Optional) PARAMETER MENU 4-AL CNFP   ACt1 Lit1 rSt1 Stb1 AL-1 ACt2 Lit2 rSt2 stb2 AL-2 AHYS ALARM 1 ACTION ALARM 1 ANNUNCIATOR ALARM 1 RESET MODE ALARM 1 STANDBY ALARM 1 VALUE ALARM 2 ACTION ALARM 2 ANNUNCIATOR ALARM 2 RESET MODE ALARM 2 STANDBY ALARM 2 VALUE ALARM 1 & 2 HYSTERESIS AVAILABLE ALARM ACTIONS  Deviation High Alarm 1 and 2 value tracks the Setpoint value  Deviation Low Alarm 1 and 2 value tracks the Setpoint value  Band Acting (inside) Alarm 1 and 2 value tracks the Setpoint value  Band Acting (outside) Alarm 1 and 2 value tracks the Setpoint value Absolute High The alarm energizes when the Process (unbalanced hysteresis) Value exceeds the alarm value.  Heat (A1 Analog models only) If heating is selected, the remaining Alarm 1 parameters are not available. Absolute Low The alarm energizes when the Process (unbalanced hysteresis) Value falls below the alarm value.  Cool (A2 only) If cooling is selected, the remaining Alarm 2 parameters are not available.  None No action, the remaining Alarm parameters are not available.  Absolute High (balanced hysteresis) The alarm energizes when the Process Value exceeds the alarm value + 1/2 the hysteresis value.  Absolute Low (balanced hysteresis) The alarm energizes when the Process Value falls below the alarm value -1/2 the hysteresis value.   ALARM ACTION FIGURES AL SP AL + ½Hys Hys SP + (-AL) AL AL - Hys Hys Hys AL - ½Hys ALARM STATE OFF ON ALARM STATE OFF ALARM STATE TRIGGER POINTS OFF ON OFF ON TRIGGER POINTS TRIGGER POINTS Absolute High Acting (Unbalanced Hys) Deviation High Acting (AL< 0) Absolute Low Acting (Balanced Hys) SP + AL AL + Hys ON OFF SP + AL Hys Hys SP Hys SP AL Hys SP - AL ALARM STATE OFF OFF ON ALARM STATE OFF TRIGGER POINTS ON OFF ALARM OFF STATE SP AL ON OFF Band Outside Acting Deviation High Acting (AL > 0) AL + ½Hys OFF TRIGGER POINTS TRIGGER POINTS Absolute Low Acting (Unbalanced Hys) ON Hys SP + AL SP Hys Hys SP - AL SP - AL Hys AL - ½Hys ALARM STATE OFF ON OFF ALARM STATE TRIGGER POINTS OFF ON TRIGGER POINTS Deviation Low Acting (AL > 0) Note: Hys inAbsolute the above to the Alarm Hysteresis. Highfigures Acting refers (Balanced Hys) 16 OFF ALARM STATE ON OFF ON OFF TRIGGER POINTS Band Inside Acting ON ALARM ACTION ALARM 1   ALARM ANNUNCIATOR ALARM 2              Normal  Reverse Select the action for the alarms. See Alarm Action Figures for a visual explanation. With normal selection, the alarm annunciator indicates “on” alarm output 2. With reverse selection, the alarm annunciator indicates “off” alarm output. ALARM ANNUNCIATOR ALARM 1 ALARM RESET MODE ALARM 2 Lit1     Normal  Reverse In Automatic mode, an energized alarm turns off automatically after the Temperature/Process value leaves the alarm region. In Latched mode, an energized alarm requires an F1 key or user input alarm reset to turn off. After an alarm reset, the alarm remains reset off until the trigger point is crossed again. With normal selection, the alarm annunciator indicates “on” alarm output 1. With reverse selection, the alarm annunciator indicates “off” alarm output. ALARM RESET MODE ALARM 1    Automatic  Latched ALARM STANDBY ALARM 2   In Automatic mode, an energized alarm turns off automatically after the Temperature/Process value leaves the alarm region. In Latched mode, an energized alarm requires an F1 key or user input alarm reset to turn off. After an alarm reset, the alarm remains reset off until the trigger point is crossed again.  Standby on  Standby off ALARM VALUE ALARM 2    Standby prevents nuisance (typically low level) alarms after a power up or setpoint change. After powering up the controller or changing the setpoint, the process must leave the alarm region (enter normal non-alarm area of operation). After this has occurred, the standby is disabled and the alarm responds normally until the next controller power up or setpoint change.  P16  to  ALARM HYSTERESIS T16  P16 The alarm values are entered as process units or degrees. They can also be entered in the Display or Hidden Loops. When the alarm is configured as deviation or band acting, the associated output tracks the Setpoint as it is changed. The value entered is the offset or difference from the Setpoint.    to  T16 P16 The Hysteresis Value is either added to or subtracted from the alarm value, depending on the alarm action selected. The same value applies to both alarms. See the Alarm Action Figures for a visual explanation of how alarm actions are affected by the hysteresis. ALARM ACTION ALARM 2    to  T16 The alarm values are entered as process units or degrees. They can also be entered in the Display or Hidden Loops. When the alarm is configured as deviation or band acting, the associated output tracks the Setpoint as it is changed. The value entered is the offset or difference from the Setpoint. ALARM VALUE ALARM 1    Standby on  Standby off Standby prevents nuisance (typically low level) alarms after a power up or setpoint change. After powering up the controller or changing the setpoint, the process must leave the alarm region (enter normal non-alarm area of operation). After this has occurred, the standby is disabled and the alarm responds normally until the next controller power up or setpoint change. ALARM STANDBY ALARM 1    Automatic  Latched           Select the action for the alarms. See Alarm Action Figures for a visual explanation. 17 7.5 MODULE 5 - Cooling (Secondary) Parameters (5-O2) PARAMETER MENU 5-O2 CYC2 gAN2 COOLING CYCLE TIME COOLING RELATIVE GAIN db-2 HEAT/COOL DEADBAND/ OVERLAP To enable Cooling in Heat/Cool applications, the Alarm 2 Action must first be set for Cooling. (For P16 Controllers, the cooling output is sometimes referred to as secondary output.) When set to cooling, the output no longer operates as an alarm but operates as a cooling output. The O2 terminals are the same as A2, however a separate O2 annunciator indicates Cooling Operation. Cooling output power ranges from -100% (full cooling) to 0% (no cooling, unless a heat/cool overlap is used). The Power Limits in Output Module 2-OP also limit the cooling power. In applications requiring only a Cooling output, the main 01 output should be used. DEADBAND/OVERLAP    to  This defines the overlap area in which both heating and cooling are active (negative value) or the deadband area between the bands (positive value). If a heat/cool overlap is specified, the percent output power is the sum of the heat power (O1) and the cool power (O2). If Relative Gain is zero, the cooling output operates in the On/Off Control Mode, with the On/Off Control Hysteresis  in Output Module  becoming the cooling output hysteresis. The function of Deadband is illustrated in the Control Mode Explanations. For most applications, set this parameter to 0.0 prior to starting Auto-Tune. After the completion of Auto-Tune, this parameter may be changed. CYCLE TIME   CNFP  to  seconds This cycle time functions like the O1 Output Cycle Time but allows independent cycle time for cooling. A setting of zero will keep output O2 off. RELATIVE GAIN    to  This defines the gain of the cooling relative to the heating. It is generally set to balance the effects of cooling to that of heating. This is illustrated in the Heat/ Cool Relative Gain Figures. A value of 0.0 places the cooling output into On/ Off Control. HEAT/COOL RELATIVE GAIN FIGURES O1 +100% 2X PROPORTIONAL BAND DEADBAND NEGATIVE VALUE O2 -100% RELATIVE GAIN O1 +100% 2 1 .5 O2 -100% % % OUTPUT POWER OUTPUT POWER HEAT COOL TEMPERATURE TEMPERATURE RELATIVE GAIN = .5 COOL HEAT SETPOINT Heat/Cool Deadband = 0 O1 +100% SETPOINT Heat/Cool Deadband < 0 DEADBAND POSITIVE VALUE RELATIVE GAIN 2 1 .5 O2 -100% % OUTPUT POWER TEMPERATURE RELATIVE GAIN = .5 HEAT COOL SETPOINT Heat/Cool Deadband > 0 18 7.5 MODULE 9 Factory Service Operations (9-FS)   PARAMETER MENU   FACTORY SERVICE CODE RTD Resistance (T16) CALIBRATION RTD calibration requires a precision 277.0 ohm resistor with an accuracy of 0.1 Ω (or better). Connect a jumper between terminals 9 and 10 with a 0 ohm jumper between 9 and 8 at  and the 277.0 ohm resistor between 9 and 8 at . If using thermocouple only, the RTD calibration need not be performed.   The controller is fully calibrated from the factory. Recalibration is recommended every two years by qualified technicians using appropriate equipment. Calibration may be performed by using the front panel or with the TP16KIT. The front panel method is explained below. (Refer to the TP16KIT bulletin for calibration instructions using TP16KIT cable and software.) Calibration may be aborted by disconnecting power to the controller before exiting Factory Service Module . In this case, the existing calibration settings remain in effect. Note: Allow the controller to warm up for 30 minutes minimum and follow the manufacturer’s warm-up recommendations for the calibration source or measuring device. PROMPT       APPLY FRONT PANEL ACTION Press J until , press A. Press A. Press A. Press B for , press A. 0.0 ohm After 5 seconds (minimum), press A. 277.0 ohm After 5 seconds (minimum), press A. Input Calibration (P16) Process calibration requires a precision signal source with an accuracy of 0.03% (or better) that is capable of generating 10.0 V connected to terminals 8 (COMM) and 9 (+10V) and 20.00 mA connected to terminals 8 (COMM) and 10 (20mA). The current calibration can be skipped by pressing A at the not applicable prompts if using the controller for process voltage only. Millivolt Calibration (T16) Millivolt calibration requires a precision voltage source with an accuracy of 0.03% (or better) connected to terminals 8 (comm.) and 9 (+). When calibrating the input, the millivolt calibration must be performed first, then the Cold Junction or RTD Resistance. PROMPT        APPLY PROMPT FRONT PANEL ACTION Press J until Press B for          , press A. , press A. 0.0 ohm After 5 seconds (minimum), press A. 14.0 mV After 5 seconds (minimum), press A. 28.0 mV After 5 seconds (minimum), press A. 42.0 mV After 5 seconds (minimum), press A. 56.0 mV After 5 seconds (minimum), press A. Cold Junction (T16) Cold Junction calibration requires a thermocouple of known accuracy of types T, E, J, K, C or N (connected to terminals 8 and 9) and a calibrated external reference thermocouple probe measuring in °C with resolution to tenths. The two probes should be brought in contact with each other or in some way held at the same temperature. They should be shielded from air movement and allowed sufficient time to equalize in temperature. (As an alternative, the T16 thermocouple may be placed in a calibration bath of known temperature.) If performing the millivolt calibration prior, verify that the correct input type is configured in Input Module  before performing the following procedure. (After the millivolt calibration the controller will default to type J.) If using RTD only, the cold junction calibration need not be performed. PROMPT COMPARE FRONT PANEL ACTION Press J until    , press A. Press A. Press B for Top display to external reference , press A. Press B or J to adjust the bottom display until the top process display matches the external reference then press A. 19 APPLY FRONT PANEL ACTION Press J until Press B for , press A. , press A. 0.0 ohm After 5 seconds (minimum), press A. 2.5 V After 5 seconds (minimum), press A. 5.0 V After 5 seconds (minimum), press A. 7.5 V After 5 seconds (minimum), press A. 10.0 V After 5 seconds (minimum), press A. 0.0 mA After 5 seconds (minimum), press A. 20.0 mA After 5 seconds (minimum), press A. Analog Output Calibration (T16 and P16) RESTORE FACTORY SETTINGS Set the controller Analog jumpers to the output type being calibrated. Connect an external meter with an accuracy of 0.05% (or better) that is capable of measuring 10.00 V or 20.00 mA to terminals 6 (+V/I) and 7 (-V/I). The voltage or current calibration that is not being used must be skipped by pressing A until End appears. PROMPT        EXTERNAL METER   Press and hold B to display  . Press A. The controller will display  and then return to . Press L to return to the Display Loop. This will overwrite all user settings with Factory Settings. FRONT PANEL ACTION Press J until , press A. Press A. NOMINAL CALIBRATION SETTINGS Press A. (T16 only) Press A. (T16 only) Press B for   YES, press A. 0.00 V Press B or J until external meter matches listing, press A.   10.00 V Press B or J until external meter matches listing, press A.   0.0 mA Press B or J until external meter matches listing, press A.   20.0 mA Press B or J until external meter matches listing, press A. Press and hold B to display  . Press A. Press and hold B to display   again. Press A. The controller will then return to . Press L to return to the Display Loop. This will not overwrite any user settings but will erase the controller calibration values. This procedure does not require any calibration signals nor external meters. This can be used to clear calibration error flag . CAUTION: This procedure will result in up to ±10% reading error and the controller will no longer be within factory specifications. For this reason, this procedure should only be performed if meter error is outside of this range to temporarily restore operation until the unit can be accurately calibrated. Troubleshooting For further technical assistance, contact technical support. PROBLEM CAUSE REMEDIES NO DISPLAY 1. 2. 3. 4. Power off. Brown-out condition. Loose connection or improperly wired. Bezel assembly not fully seated into rear of controller. 1. 2. 3. 4. Check power. Verify power reading. Check connections. Check installation. CONTROLLER NOT WORKING 1. Incorrect setup parameters. E2 IN DISPLAY 1. Loss of setup parameters due to noise spike or other 1. Press F1 to escape, then check controller accuracy. EMI event. a. Recalibrate controller. (See Factory Service Module code 77.) b. Reset parameters to factory default settings.  IN DISPLAY 1. Loss of calibration parameters due to noise spike or 1. Press F1 to escape, then check controller accuracy. other EMI event. a. Recalibrate controller. (See Factory Service Module code 77.) b. Reset parameters to factory default settings.  or  IN DISPLAY 1. 2. 3. 4. Display value exceeds 4 digit display range. Defective or miscalibrated cold junction circuit. Loss of setup parameters. Internal malfunction. 1. Press F1 to escape, then check controller accuracy. a. Recalibrate controller. (See Factory Service Module code 77.) b. Reset parameters to factory default settings.  IN DISPLAY (T16) 1. 2. 3. 4. Probe disconnected. Broken or burned-out probe. Corroded or broken terminations. Excessive process temperature. 1. 2. 3. 4. Change resolution to display whole number and verify reading. Perform cold junction calibration. Check setup parameters. Perform Input calibration.  IN DISPLAY (P16) 1. 2. 3. 4. Input exceeds range of controller. Incorrect input wiring. Defective transmitter. Internal malfunction. 1. 2. 3. 4. Check input parameters. Check input wiring. Replace transmitter. Perform input calibration.  IN TOP DISPLAY 1. Input exceeds range of controller. 2. Temperature exceeds range of input probe. 3. Defective or incorrect transmitter or probe. 4. Excessive high temperature for probe. 5. Loss of setup parameters. 1. 2. 3. 4. 5. Check input parameters. Change to input sensor with a higher temperature range. Replace transmitter or probe. Reduce temperature. Perform input calibration.  IN TOP DISPLAY 1. Input is below range of controller. 2. Temperature below range of input probe. 3. Defective or incorrect transmitter or probe. 4. Excessive low temperature for probe. 5. Loss of setup parameters. 1. 2. 3. 4. 5. Check input parameters. Change to input sensor with a lower temperature range. Replace transmitter or probe. Raise temperature. Perform input calibration.  IN DISPLAY (T16) 1. RTD probe shorted. 1. Check wiring and/or replace RTD probe. CONTROLLER SLUGGISH OR NOT STABLE 1. Incorrect PID values. 2. Incorrect probe location. 1. See PID control. 2. Evaluate probe location. SSr IN DISPLAY 1. Control output is damaged. 1. Return controller to factory for repair. 1. Check setup parameters. 20 Control Mode Explanations ON/OFF CONTROL ON/OFF CONTROL - HEAT/COOL OUTPUT FIGURES The controller operates in On/Off Control when the Proportional Band is set to 0.0%. In this control mode, the process will constantly oscillate around the setpoint value. The On/Off Control Hysteresis (balanced around the setpoint) can be used to eliminate output chatter. Output O1 Control Action can be set to reverse for heating (output on when below the setpoint) or direct for cooling (output on when above the setpoint) applications. INPUT SP + 1/2 CHYS SP ON/OFF CONTROL REVERSE OR DIRECT ACTING FIGURES INPUT HEAT/COOL DEADBAND (db2) = 0 CHYS SP - 1/2 CHYS REVERSE ACTING Output 1 (O1) : OFF ON OFF Output 2 (O2) : ON OFF ON SP + 1/2 CHYS SP INPUT HEAT/COOL DEADBAND (db-2) > 0 SP - 1/2 CHYS SP + 1/2 (db-2) + 1/2 CHYS SP + 1/2 (db-2) SP + 1/2 (db-2) - 1/2 CHYS Output 1 (O1) : OFF INPUT ON OFF CHYS db-2 SP SP - 1/2 (db-2) + 1/2 CHYS SP - 1/2 (db-2) SP - 1/2 (db-2) - 1/2 CHYS DIRECT ACTING SP + 1/2 CHYS CHYS Output 1 (O1) : O1 OFF SP O1 ON Output 2 (O2) : O1 OFF O2 OFF O2 ON O2 OFF SP - 1/2 CHYS INPUT Output 1 (O1) : OFF ON OFF HEAT/COOL DEADBAND (db-2) < 0 SP + 1/2 (db-2) + 1/2 CHYS SP + 1/2 (db-2) SP + 1/2 (db-2) - 1/2 CHYS Note: CHYS in the On/Off Control Figures refers to the On/Off Control Hysteresis () in parameter Module 2. CHYS db-2 SP For heat and cool systems, O1 Control Action is set to reverse (heat) and the Alarm 2 Action is set to cooling (O2). The Proportional Band is set to 0.0 and the Relative Gain in Cooling to 0.0. The Deadband in Cooling sets the amount of operational deadband or overlap between the outputs. The setpoint and the On/Off Control Hysteresis applies to both O1 and O2 outputs. The hysteresis is balanced in relationship to the setpoint and deadband value. SP - 1/2 (db-2) + 1/2 CHYS SP - 1/2 (db-2) SP - 1/2 (db-2) - 1/2 CHYS CHYS Output 1 (O1) : Output 2 (O2) : PID CONTROL O1 ON O2 ON O2 OFF O1 OFF O1 ON O2 ON TYPICAL PID RESPONSE CURVE In PID Control, the controller processes the input and then calculates a control output power value by use of a modified Proportional Band, Integral Time, and Derivative Time control algorithm. The system is controlled with the new output power value to keep the process at the setpoint. The Control Action for PID Control can be set to reverse for heating (output on when below the setpoint) or direct for cooling (output on when above the setpoint) applications. For heat and cool systems, the heat (O1) and cool (O2) outputs are both used. The PID parameters can be established by using Auto-Tune, or they can be Manually tuned to the process. P&I P&I&D INPUT SP P&D P only TIME 21 TIME PROPORTIONAL PID CONTROL MANUAL CONTROL MODE In Time Proportional applications, the output power is converted into output On time using the Cycle Time. For example, with a four second cycle time and 75% power, the output will be on for three seconds (4 × 0.75) and off for one second. The cycle time should be no greater than 1/10 of the natural period of oscillation for the process. The natural period is the time it takes for one complete oscillation when the process is in a continuously oscillating state. In Manual Control Mode, the controller operates as an open loop system (does not use the setpoint and process feedback). The user adjusts the percentage of power through the % Power display to control the power for Output O1. When Alarm 2 is configured for Cooling (O2), Manual operation provides 0 to 100% power to O1 (heating) and -100 to 0% power to O2 (Cooling). The Low and High Output Power limits are ignored when the controller is in Manual. MODE TRANSFER LINEAR PID CONTROL When transferring the controller mode between Automatic and Manual, the controlling outputs remain constant, exercising true “bumpless” transfer. When transferring from Manual to Automatic, the power initially remains steady, but Integral Action corrects (if necessary) the closed loop power demand at a rate proportional to the Integral Time. In Linear PID Control applications, the Analog Output Assignment  is set to % Output Power, . The Analog Low Scaling,  , is set to 0.0 and the Analog High Scaling,  , is set to 100.0. The Analog Output will then be proportional to the PID calculated % output power for Heat or Cooling per the Control Action . For example, with 0 VDC to 10 VDC (scaled 0 to 100%) and 75% power, the analog output will be 7.5 VDC. AUTOMATIC CONTROL MODE In Automatic Control Mode, the percentage of output power is automatically determined by PID or On/Off calculations based on the setpoint and process feedback. For this reason, PID Control and On/Off Control always imply Automatic Control Mode. Pid Tuning Explanations AUTO-TUNE INPUT Auto-Tune is a user-initiated function that allows the controller to automatically determine the Proportional Band, Integral Time, Derivative Time, Digital Filter, Control Output Dampening Time, and Relative Gain (Heat/Cool) values based upon the process characteristics. The Auto-Tune operation cycles the controlling output(s) at a control point three-quarters of the distance between the present process value and the setpoint. The nature of these oscillations determines the settings for the controller’s parameters. Prior to initiating Auto-Tune, it is important that the controller and system be first tested. (This can be accomplished in On/Off Control or Manual Control Mode.) If there is a wiring, system or controller problem, Auto-Tune may give incorrect tuning or may never finish. Auto-Tune may be initiated at start-up, from setpoint or at any other process point. However, ensure normal process conditions (example: minimize unusual external load disturbances) as they will have an effect on the PID calculations. AUTO-TUNE CODE FIGURE SP 2 1 0 TIME Start Auto-Tune Below are the parameters and factory settings that affect Auto-Tune. If these setting are acceptable then Auto-Tune can be started just by performing two steps. If changes are needed, then they must be made before starting Auto-Tune. DISPLAY PARAMETER  Input Type  Digital Filtering  On/Off Control Hysteresis   Auto-Tune Code  Auto-Tune Access Deadband FACTORY SETTING    AUTO-TUNE OPERATION (REVERSE ACTING) INPUT MODULE j T16  P16   T16  P16   TYPICAL RESPONSE CURVES WITH AUTO-TUNE CODES 0 TO 2. SETPOINT AUTO-TUNE CONTROL POINT 1/2 CHYS * 1/2 CHYS *   AUTO-TUNE COMPLETE, PID SETTINGS ARE CALCULATED AND LOADED INTO MEMORY AUTO-TUNE START   TIME PHASE OUTPUT 1 (O1) : Aut1 Aut2 Aut3 Aut4 ON OFF ON OFF * - On/Off Control Hysteresis 1. Enter the Setpoint value in the Display Loop. 2. Initiate Auto-Tune by changing Auto-Tune Start  to  in the Hidden Loop. Auto-Tune Progress The controller will oscillate the controlling output(s) for four cycles. The bottom display will flash the cycle phase number. Parameter viewing is permitted during Auto-Tune. The time to complete the Auto-Tune cycles is process dependent. The controller should automatically stop Auto-Tune and store the calculated values when the four cycles are complete. If the controller remains in Auto-Tune unusually long, there may be a process problem. AutoTune may be stopped by entering  in Auto-Tune Start . 22 PID Adjustments In some applications, it may be necessary to fine tune the Auto-Tune calculated PID parameters. To do this, a chart recorder or data logging device is needed to provide a visual means of analyzing the process. Compare the actual process response to the PID response figures with a step change to the process. Make changes to the PID parameters in no more than 20% increments from the starting value and allow the process sufficient time to stabilize before evaluating the effects of the new parameter settings. In some unusual cases, the Auto-Tune function may not yield acceptable control results or induced oscillations may cause system problems. In these applications, Manual Tuning is an alternative. PROCESS RESPONSE EXTREMES OVERSHOOT AND OSCILLATIONS SLOW RESPONSE INPUT INPUT SP SP TIME TIME TO DAMPEN RESPONSE: - INCREASE PROPORTIONAL BAND. - INCREASE INTEGRAL TIME. - USE SETPOINT RAMPING. - USE OUTPUT POWER LIMITS. - RE-INVOKE AUTO-TUNE WITH A HIGHER AUTO-TUNE CODE. - INCREASE DERIVATIVE TIME. - CHECK CYCLE TIME. TO QUICKEN RESPONSE: - DECREASE PROPORTIONAL BAND. - DECREASE INTEGRAL TIME. - INCREASE OR DEFEAT SETPOINT RAMPING. - EXTEND OUTPUT POWER LIMITS. - RE-INVOKE AUTO-TUNE WITH A LOWER AUTO-TUNE CODE. - DECREASE DERIVATIVE TIME. MANUAL TUNING A chart recorder or data logging device is necessary to measure the time between process cycles. This procedure is an alternative to the controller’s AutoTune function. It will not provide acceptable results if system problems exist. 1. Set the Proportional Band () to 10.0% for temperature models (T16) and 100.0% for process models (P16). 2. Set both the Integral Time () and Derivative Time () to 0 seconds. 3. Set the Output Dampening Time () in Output Module  to 0 seconds. 4. Set the Output Cycle Time [CYCt] in Output Module  to no higher than one-tenth of the process time constant (when applicable). 5. Place the controller in Manual  Control Mode  in the Hidden Loop and adjust the % Power to drive the process value to the Setpoint value. Allow the process to stabilize after setting the % Power. Note:  must be set to  in Parameter Lockouts Module . 6. Place the controller in Automatic () Control Mode  in the Hidden Loop. If the process will not stabilize and starts to oscillate, set the Proportional Band two times higher and go back to Step 5. 7. If the process is stable, decrease Proportional Band setting by two times and change the Setpoint value a small amount to excite the process. Continue with this step until the process oscillates in a continuous nature. 8. Fix the Proportional Band to three times the setting that caused the oscillation in Step 7. 9. Set the Integral Time to two times the period of the oscillation. 10. Set the Derivative Time to 1/8 (0.125) of the Integral Time. 11. Set the Output Dampening Time to 1/40 (0.025) the period of the oscillation. 23 PARAMETER VALUE CHART Programmer:______________________Date:_________ Controller Number:_______ Security Code:_______ DISPLAY LOOP DISPLAY PARAMETER  SETPOINT VALUE SP1    * SETPOINT VALUE SP2  OUTPUT POWER PERCENT PROPORTIONAL BAND * INTEGRAL TIME  *  *  * DERIVATIVE TIME ALARM 1 VALUE ALARM 2 VALUE OUTPUT MODULE () FACTORY SETTING USER SETTING DISPLAY  T16  P16  T16  P16   T16  P16  T16  P16  T16  P16   * Factory Setting places these parameters in the Hidden Loop (set to Lockout Module .  in PARAMETER       CYCLE TIME        ON/OFF CONTROL HYSTERESIS CONTROL ACTION OUTPUT POWER LOWER LIMIT OUTPUT POWER UPPER LIMIT SENSOR FAIL POWER PRESET OUTPUT POWER DAMPENING AUTO-TUNE CODE ANALOG OUTPUT RANGE ANALOG OUTPUT ASSIGNMENT ANALOG UPDATE TIME ANALOG LOW SCALING ANALOG HIGH SCALING FACTORY SETTING USER SETTING       T16  P16  T16  P16 0      HIDDEN LOOP DISPLAY     PARAMETER FACTORY SETTING SETPOINT SELECT LOCKOUT MODULE () USER SETTING     SETPOINT RAMP RATE CONTROL MODE TRANSFER AUTO-TUNE START DISPLAY           INPUT MODULE ( ) T16 ONLY DISPLAY          PARAMETER FACTORY SETTING INPUT TYPE USER SETTING j         TEMPERATURE SCALE DECIMAL RESOLUTION DIGITAL FILTERING SHIFT/OFFSET SETPOINT LOW LIMIT SETPOINT HIGH LIMIT USER INPUT FUNCTION F1 KEY FUNCTION              PARAMETER INPUT TYPE PERCENT ANNUNCIATOR DECIMAL RESOLUTION ROUNDING INCREMENT DIGITAL FILTERING DISPLAY VALUE SCALING 1 INPUT VALUE SCALING 1 DISPLAY VALUE SCALING 2 INPUT VALUE SCALING 2 SETPOINT LOW LIMIT SETPOINT HIGH LIMIT USER INPUT FUNCTION F1 KEY FUNCTION FACTORY SETTING SETPOINT ACCESS OUTPUT POWER ACCESS PID VALUE ACCESS ALARM VALUE ACCESS ACCESS CODE SETPOINT SELECT ACCESS SETPOINT RAMP ACCESS TRANSFER CONTROL ACCESS AUTO-TUNE ACCESS RESET ALARMS ACCESS FACTORY SETTING USER SETTING           ALARM MODULE () DISPLAY            INPUT MODULE ( ) P16 ONLY DISPLAY PARAMETER USER SETTING            PLOC NONE PARAMETER ALARM 1 ACTION ALARM 1 ANNUNCIATOR ALARM 1 RESET MODE ALARM 1 STANDBY ALARM 1 VALUE ALARM 2 ACTION ALARM 2 ANNUNCIATOR ALARM 2 RESET MODE ALARM 2 STANDBY ALARM 2 VALUE ALARM 1 & 2 HYSTERESIS FACTORY SETTING USER SETTING         NO   T16  P16 COOLING MODULE () DISPLAY    24 PARAMETER CYCLE TIME RELATIVE GAIN DEADBAND FACTORY SETTING    USER SETTING 25 9-FS 5-O2 4-AL 3-LC 2-OP 1-IN CNFP   no HIDDEN LOOP Factory Service Code CodE Cooling Cycle Time CYC2 Alarm 1 Action ACt1 Setpoint Access Ends and returns to start of Display Loop. SCAL ANtP OP Cooling Relative Gain GAN2 Alarm 1 Annunciator Lit1 Output Power Access OPLO ANAS  OPHI ANUt rSt1 Heat/Cool Deadband/Overlap db-2 Alarm 1 Reset Mode Stb1 Alarm 1 Standby OPFL ANLO AL-1 Alarm 1 Value SPHI OPdP ANHI SPSL CHYS SPrP Stb2 Alarm 2 Standby rSt2 Alarm 2 Annunciator Lit2 Setpoint Ramp Rate Access INP1 F1In  tUNE AL-2 Alarm 2 Value AHYS Alarm 1 & 2 Hysteresis ALrS Reset Alarms Access  - T16 only  - P16 only Auto-Tune Auto/Manual Off/On Access Transfer Access trnF Auto-Tune Code tcod Input Value 1 F1 Key Function On/Off Control Hysteresis Alarm 2 Reset Mode Alarm 2 Action ACt2 Setpoint Select Access InPt Display Value 1  Advances to the next module, then changes parameter selection/value. dSP1 BJ User Input Function Output Power Dampening Analog High Scaling CodE Access Code FLtr Digital Filtering Setpoint High Limit Sensor Fail Power Preset Analog Low Scaling AL Alarm Values Access SPLO Rounding Increment rnd  Enters displayed module, then advances to the next parameter. Setpoint Low Limit Output Power High Limit Analog Output Update Time PId PID  Values Access SHFt Decimal Resolution dCPt Shift/Offset  Output Power Low Limit Analog Output Assignment OPAC Control Action Display Value 2 Input Value 2 INP2    PCt Temp Scale dSP2 A Parameter availability is model and program dependent. L Percent Symbol Analog Output Range SP Cycle Time CYCt Input Type tYPE DISPLAY LOOP T16 & P16 Programming Quick Overview This page intentionally left blank 26 This page intentionally left blank 27 LIMITED WARRANTY (a) Red Lion Controls Inc., Sixnet Inc., N-Tron Corporation, or Blue Tree Wireless Data, Inc. (the “Company”) warrants that all Products shall be free from defects in material and workmanship under normal use for the period of time provided in “Statement of Warranty Periods” (available at www.redlion.net) current at the time of shipment of the Products (the “Warranty Period”). EXCEPT FOR THE ABOVE-STATED WARRANTY, COMPANY MAKES NO WARRANTY WHATSOEVER WITH RESPECT TO THE PRODUCTS, INCLUDING ANY (A) WARRANTY OF MERCHANTABILITY; (B) WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE; OR (C) WARRANTY AGAINST INFRINGEMENT OF INTELLECTUAL PROPERTY RIGHTS OF A THIRD PARTY; WHETHER EXPRESS OR IMPLIED BY LAW, COURSE OF DEALING, COURSE OF PERFORMANCE, USAGE OF TRADE OR OTHERWISE. Customer shall be responsible for determining that a Product is suitable for Customer’s use and that such use complies with any applicable local, state or federal law. (b) The Company shall not be liable for a breach of the warranty set forth in paragraph (a) if (i) the defect is a result of Customer’s failure to store, install, commission or maintain the Product according to specifications; (ii) Customer alters or repairs such Product without the prior written consent of Company. (c) Subject to paragraph (b), with respect to any such Product during the Warranty Period, Company shall, in its sole discretion, either (i) repair or replace the Product; or (ii) credit or refund the price of Product provided that, if Company so requests, Customer shall, at Company’s expense, return such Product to Company. (d) THE REMEDIES SET FORTH IN PARAGRAPH (c) SHALL BE THE CUSTOMER’S SOLE AND EXCLUSIVE REMEDY AND COMPANY’S ENTIRE LIABILITY FOR ANY BREACH OF THE LIMITED WARRANTY SET FORTH IN PARAGRAPH (a). Red Lion Controls Headquarters 20 Willow Springs Circle York PA 17406 Tel +1 (717) 767-6511 Fax +1 (717) 764-0839 Red Lion Controls Europe Softwareweg 9 NL - 3821 BN Amersfoort Tel +31 (0) 334 723 225 Fax +31 (0) 334 893 793 Red Lion Controls India 201-B, 2nd Floor, Park Centra Opp 32 Mile Stone, Sector-30 Gurgaon-122002 Haryana, India Tel +91 984 487 0503 Red Lion Controls China Unit 1102, XinMao Plaza Building 9, No.99 Tianzhou Road ShangHai, P.R. China 200223 Tel +86 21 6113 3688 Fax +86 21 6113 3683
T1610010 价格&库存
很抱歉,暂时无法提供与“T1610010”相匹配的价格&库存,您可以联系我们找货
