LC-F-3-C
LC-F-3-C
    CURTISINDUSTRIES
    CONTROL LIQUID LEV 24VAC CHASSIS
LC-F-3-C 数据手册
3 Selection Chart Page Series Number Supply Voltage Load Capacity Description and Special Notes Curtis liquid level controls ® ELS 3 120, 240VAC 1/4 HP, 10 amp non-inductive 120VAC, 1/3 HP, 240 VAC Economical liquid level control sensitivity range to 100,000 ohms ELC 4 120, 240VAC 1/4 HP, 10 amp non-inductive 120VAC, 1/3 HP, 240 VAC Low-cost liquid level control with sensitivity up to 50,000 ohms LCT 5 24, 120, 240VAC 1/4 HP, 10 amp non-inductive 120VAC, 1/3 HP, 240 VAC Liquid level control with built-in time delay feature for standard applications up to 100,000 ohms LCS 6 24, 120, 240VAC 1/4 HP, 10 amp non-inductive 120VAC, 1/3 HP, 240 VAC Liquid level control with adjustable sensitivity ranges for detection up to 100,000 ohms LHS 6 24, 120, 240VAC 1/6 HP, 10 amp non-inductive 120VAC, 1/3 HP, 240 VAC Liquid level control with adjustable sensitivity ranges for detection up to 3,00,000 ohms LC 7 24, 120, 240VAC 1/4 HP, 10 amp non-inductive 120VAC, 1/3 HP, 240 VAC Liquid level control with forward and reverse operating modes, adjustable sensitivity to 100,000 ohms DLC 8 24, 120, 240VAC 1/6 HP, 10 amp non-inductive 120VAC, 1/3 HP, 240 VAC Dual liquid level control with heater/pump lockout feature, sensitivity range to 100,000 ohms Accessories Rugged, compact contractors and enclosures meeting NEMA 1, 3, 4, and 12 specifications 9 Liquid level probe assemblies A variety of pressure, temperature and fitting options available 9 RSA 10 Low-cost amplifier module for liquid level applications 24, 120, 240VAC Curtis industrial controls ® ELS 11 24, 120, 240VAC 1/6 HP, 10 amp non-inductive 120VAC, 1/3 HP, 230 VAC For precision photoelectric or temperature applications Curtis liquid level control principle of operation ® Operating on the principle of conductivity (the ability of a liquid to conduct electricity), Curtis Liquid Level controls sense and control the level of almost any fluid or moist solid. These units are available with fixed or adjustable setpoints to control levels in fluids having an external circuit resistance up to 3,000,000 ohms. Typical solution resistivity is shown below. Typical Liquid Resistivity Liquid Nominal Resistivity Range (ohms/CC) acids, bases and salts ................................................ 0-20 dilute acids .............................................................. 20-200 milk, beer ........................................................... 200-2,000 non-distilled water ......................................... 2,000-20,000 distilled water ............................................ 20,000-200,000 In operation, two or more submerged liquid level probes pass a minute electrical current through the liquid to be controlled. This 4 current, typically 500 microamperes, is introduced to a solid-state resistance-sending amplifier which provides sufficient gate signal to trigger a silicon-controlled rectifier (SCR). The firing threshold is accurate to within 2% of operating differential and is adjustable by means of a potentiometer. The output of the SCR is used to operate the plug-in control relay. When anticipated loads exceed that of the standard relay, an auxiliary contactor is utilized. Control Models ELS, LCS/LHS, LCF and RSA are designed for forward mode operation. They interpret a decrease of external circuit resistance from setpoint as an “ON” signal. Model LCR is designed for reverse mode operation. It energizes when external circuit resistance increases above setpoint. Model DLC is intended primarily for pump and heater level/lockout applications. See the appropriate catalog sections for specific application information. When selecting a liquid level control, several factors must be taken into consideration. Questions arise as to what mode of operation is required, what is the resistivity range of the fluid to be controlled, is a fixed or variable setpoint called for, are special functions required such as a pump or heater lockout, etc. Use the connection diagrams to select the ideal control for your specific application. Curtis liquid level controls ® Model ELS Economical unit with sensitivity up to 100,000 ohms Features ■ Solid State Amplifier with SCR and Control Relay ■ Low AC Signal Voltage ■ Compact Printed Circuit Design ■ 1/4” Quick-Connect Terminals ■ Insensitive to Transients ■ Built-in Holding Circuit for Differential Levels or Manual Reset ■ Plug-in Dust-Tight Relay ■ Recognized Under the Components Program of Underwriters Laboratories, Inc. Listed with Canadian Standards Association. Specifications Model ELS-1-A,B,C ELS-1-A,B,C Maximum Allowable Supply Voltage Variation: ± 10% Maximum Power Consumption: 3 Watts Detectable Range: ELS-1,2-A ELS-1,2-B ELS-1,2-C Input Supply: Input Supply 120VAC, 50/60 Hz 240VAC, 50/60 Hz 100,000 ohms 50,000 ohms 25,000 ohms Maximum Signal or Probe Voltage: 24VAC Maximum Signal or Probe Current: 10MA Control Relay: Single Pole Double Throw, Plug-in Type with Dust-Tight Cover Load Contacts: SPST Rated – 1/4 HP, 10 Amps, 120VAC 1/3 HP, 10 Amps, 240VAC Ambient Operating Temperature: 32° F to 140° F Standard Termination: .250” Quick-Connects Outline and Mounting Dimensions Connection Diagrams This is a fixed-sensitivity, forward mode control. The control relay is energized when liquid rises to contact the “H” probe. The control relay is pulled in and remains energized until liquid drops below the “L” probe. Ordering Information Typical Curtis Model Number ELS-1 -A- Model (Also refer to “Specifications” above) Detectable Range (A-100 k ohms, B-50 k ohms, C-25 k ohms) Enclosure – specify only if necessary – N3-NEMA 3, N4–NEMA 4 JIC The composite number above reads as “an ELS amplifier for 120VAC supply, without enclosure, and with 100 K ohms sensitivity.” For further information on catalog listed controls contact your area Curtis representative or Curtis distributor. For custom design or modification contact your area Curtis Representative or the factory direct. 5 Curtis liquid level controls ® Model ELC Economical unit with sensitivity up to 50,000 ohms Features ■ Compact, Solid-State Design ■ Single Level, Forward Mode Operation ■ Holding Circuit for Differential Levels, or Manual Reset ■ Low AC Signal Voltage ■ Transient-Protected Circuit, Positive ON/OFF Eliminates Relay Chatter ■ Circuit Design Limits Short Circuit Probe Current to 10MA/24VAC Specifications Model ELC-1-S,D ELC-1-S,D Maximum Allowable Supply Voltage Variation: ± 10% Maximum Power Consumption: 3 Watts Detectable Range: Up to 50,000 ohms Operating Point Differential: 3% (Typical) Maximum Signal or Probe Voltage: 24VAC Maximum Signal or Probe Current: 10MA Input Supply: Input Supply 120VAC, 50/60 Hz 240VAC, 50/60 Hz Control Relay: Plug-in Type with Dust-Tight Cover Probe Contacts: SPDT internally connected Load Contacts: SPDT (ELC-1,2-S) or DPDT (ELC-1,2-D) Rated 10 amp Non-inductive, 120VAC, 1/4 HP 1/3 HP at 240VAC Ambient Operating Temperature: +32° F to +140° F Standard Termination: .250” Quick-Connect Mounting Style: 4 Standoffs Outline and Mounting Dimensions Connection Diagrams This is a fixed-sensitivity, forward mode control. The control relay is energized when liquid rises to contact the “H” probe. The control relay is pulled in and remains energized until liquid drops below the “L” probe. Ordering Information Typical Curtis Model Number ELC-1 -S- Model (Also refer to “Specifications” above) Detectable Range (A-100 k ohms, B-50 k ohms, C-25 k ohms) Enclosure – specify only if necessary – N3-NEMA 3, N4–NEMA 4 JIC The composite number above reads as “an ELC amplifier for 120VAC supply SPDT Output and without Enclosure.” For further information on catalog listed controls contact your area Curtis representative or Curtis distributor. For custom design or modification contact your area Curtis representative or the factory direct. 6 Curtis liquid level control with time delay ® Model LCT Features ■ ■ ■ ■ ■ ■ ■ ■ Low Cost Control for Standard Applications up to 100,000 ohms Built-in Delay-on-Make Interchangeable with Curtis Model LCS Liquid Level Controls Solid-State Amplifier with Potentiometer for Signal Sensitivity Adjustment Positive ON/OFF Operation Eliminates Relay Chatter Circuit Limits Short-Circuit Probe Current to 10MA/24VAC Holding Circuit for Differential Levels, or Manual Reset Pre-wired Auxiliary Contactor Available for Handling Heavy Loads and Motor Ratings Exceeding Capacity of Plug-in Relay Specifications Model Input Supply LCT-10 120VAC ±10%, 50/60 Hz LCT-20 240VAC ±10%, 50/60 Hz LCT-30 24VAC ±10%, 50/60 Hz. Maximum Allowable Supply Voltage Variation: ± 10% Maximum Power Consumption: 3 Watts Sensitivity Range: 1,000 to 100,000 ohms Detectable Range: Up to 100,000 ohms Operating Point Differential: 3% (Typical) Time Delay: Delay on Operate: 3 sec: ±50% (Other values between 0.5 and 10 sec. available on request.) Input Supply: Outline and Mounting Dimensions Delay on Release: 0.5 sec. ±50% Open Circuit Probe Voltage: 24VAC Short Circuit Probe Current: 10MA Control Relay: Plug-in type with dust cover Contact Rating: 10 amp non-inductive, 1/4 HP at 120VAC, 1/3 HP at 240VAC Auxiliary Contactor: DPST-NO-DB, rated 1 HP at 120VAC, 2 HP at 240VAC Ambient Operating Temperature: 0° C to +60° C Standard Termination: Barrier-type terminal blocks accepting wire up to No. 12AWG. Auxiliary contactor has combination screw/double .250” quick-connects Mounting Style: Flange Outside Dimensions: 5-1/2” long x 4-1/8” wide x 2-13/16” high Connection Diagrams Model LCT is a forward mode control. The control relay is energized when liquid rises to contact the “H” probe. The time delay on operate is 3 seconds nominal and 0.5 seconds on release. Other values between 0.5 and 10 seconds are available on request. The control relay is pulled in and remains energized until liquid drops below the “L” probe. Sensitivity is adjustable. Ordering Information Typical Curtis Model Number LCT-20 - - Model (Also refer to “Specifications” above) Contactor (add “C” if desired) Enclosure – specify only if necessary – N3-NEMA 3, N3C–NEMA 3/ Contactor, N4 – NEMA 4 JIC The composite number above reads as an LCT amplifier for 240VAC supply, without enclosure and without contactor. For further information on catalog listed controls contact your area Curtis Representative or Curtis distributor. For custom design or modification contact your area Curtis Representative or the factory direct. 7 Curtis liquid level controls with ® Models LCS/LHS Two sensitivity ranges for detection up to 3,000,000 ohms Features ■ Low cost Model LCS for Standard Applications up to 100,000 ohms ■ High-Sensitivity Model LHS for Special Applications from 100,000 to 3,000,000 ohms ■ Solid-State Amplifier with Potentiometer for Signal Sensitivity Adjustment ■ Positive ON/OFF Operation Eliminates Relay Chatter ■ Circuit Limits Short Circuit Probe Current to 10MA/24VAC ■ Holding Circuit for Differential Levels, or Manual Reset ■ Pre-Wired Auxiliary Contactor Available for Handling Heavy Loads and Motor Ratings Exceeding Capacity of Plug-In Relay Specifications Model Input Supply Input Supply: LCS-10/LHS-1 120VAC, 50/60 Hz LCS-20/LHS-2 240VAC, 50/60 Hz LCS-30 24VAC, 50/60 Hz. Maximum Allowable Supply Voltage Variation: ± 10% Maximum Power Consumption: 3 Watts Detectable Range: Up to 100,000 ohms (LCS); Up to 3,000,000 ohms (LHS) Adjustable Range: 1,000 to 100,000 ohms (LCS); 1,000 to 3,000,000 ohms (LHS) Operating Point Differential: 3% (Typical) Signal or Probe Voltage: 24VAC Maximum Signal or Probe Current: 10MA Outline and Mounting Short Circuit Probe Current: 10MA Control Relay: Plug-in type with dust cover Probe Contacts: Internally Connected for Holding Circuit Load Contacts: LCS – SPDT, 1/4 HP, 10 amp Non-inductive, 120VAC 1/3 HP at 240 VAC LHS – SPDT, 1/6 HP, 10 amp Non-inductive, 120VAC 1/3 HP at 240VAC Auxiliary Contactor: DPST-NO-DB, rated 1 HP at 120VAC, 2 HP at 240VAC Ambient Operating Temperature: +32° F to +140° F Standard Termination: Barrier-type terminal blocks accepting wire up to No. 12AWG. Auxiliary contactor has combination screw/double .250” quick-connects Mounting Style: Flange Connection Diagrams Models LCS/LHS is a forward mode control. The control relay is energized when liquid rises to contact the “H” probe. The control relay is pulled in and remains energized until liquid drops below the “L” probe. Sensitivity is adjustable. Ordering Information Typical Curtis Model Number LCS-20 - - Model (Also refer to “Specifications” above) Contactor (add “C” if desired) Enclosure – specify only if necessary – N3-NEMA 3, N3C–NEMA 3/ Contactor, N4 – NEMA 4 JIC The composite number above reads as an LCS amplifier for 240VAC supply, without enclosure and without contactor. For further information on catalog listed controls contact your area Curtis representative or Curtis distributor. For custom design or modification contact your area Curtis representative or the factory direct. 8 adjustable setpoints Model LC Forward or reverse, mode with single or differential level operation Features Specifications ■ ■ ■ ■ Model Input Supply Model Input Supply Input Supply: LC-F-1 120VAC, 50/60 Hz LC-R-1 120VAC, 50/60 Hz LC-F-2 240VAC, 50/60 Hz LC-R-2 240VAC, 50/60 Hz LC-F-3 24VAC, 50/60 Hz LC-R-3 24VAC, 50/60 Hz Maximum Allowable Supply Voltage Variation: ± 10% Maximum Power Consumption: 3 Watts Detectable Range: Up to 100,000 ohms Adjustable Range: 1,000 to 100,000 ohms Operating Point Differential: 3% (Typical) Signal or Probe Voltage: 24VAC Maximum Signal or Probe Current: 10MA Control Relay: Plug-in type with dust cover Probe Contacts: Internally connected for holding circuit Load Contacts: DPDT rated 10 amp, Non-inductive/120VAC, 1/4 HP at 240VAC Auxiliary Contactor: DPST-NO-DB, rated 1 HP at 120VAC, 2 HP at 240VAC Ambient Operating Temperature: +32° F to +140° F Standard Termination: Barrier-type terminal blocks for wire up to No. 12AWG. Auxiliary contactor has combination screw/double .250” quick-connects. Optional SPDT contacts have .250” quick-connects Options: Alarm and indicator lamp for enclosure-mounted controls, high impedance relays available for extended control dropout time.= Mounting Style: Standoffs ■ ■ ■ ■ Adjustable Sensitivity up to 100,000 ohms Solid State Amplifier with SCR and Control Relay Circuit Limits Short Circuit Probe Current 10MA/24VAC Recommended for Applications Having Longer Than Average Probe Runs. (Resultant Line Capacitance can be Compensated for by Adding a Capacitor (CX) of Equivalent Value to Available Terminals or the Control) Temperature-Stabilized from +32° F to +140° F Shielded, Grounded Isolation Transformer Low Power Consumption Auxiliary Contactor Available Outline and Mounting Dimensions Connection Diagrams Model LC – Forward Mode Control energizes when liquid reaches “H”. Control de-energizes when liquid falls below “L” and remains in an off state until liquid again reaches “H”. This control maintains a liquid level between “H” and “L” and will not chatter due to surface ripple. Single Level Operation (Not Illustrated) both the LC-F and LC-R may be used without the “L” Probe. Operation without the “L” Probe gives a very small differential between the energize and de-energize levels. This may result in chattering of the control if splashing or ripple is present at the liquid surface. Model LC – Reverse Mode Control Energizes when liquid falls below “L. Control remains energized until liquid rises past “L” and contacts “H”. Control de-energizes when liquid reaches “H” and remains in an off state until liquid again falls below “L. This control maintains a liquid level between “L” and “H” and will not chatter due to surface ripple. Ordering Information Typical Curtis Model Number LC-R-1 - - Model (Also refer to “Specifications” above) Operational Mode (F – Forward, R – Reverse) Contactor (add “C” if desired) Enclosure – specify only if necessary – N3-NEMA 3, N3C–NEMA 3/ Contactor, N4 – NEMA 4 JIC The composite number above reads as an LC amplifier with reverse mode, for 120VAC supply, without enclosure and without contactor.” For further information on catalog listed controls contact your area Curtis representative or Curtis distributor. For custom design or modification contact your area Curtis representative or the factory direct. 9 Curtis liquid level controls ® Models DLC Dual-level control with lockout feature Features ■ Ideal for Pump and Heater Applications Requiring Lockout in the Event of Loss of Water or Product Being Controlled ■ Circuit Design Limits Short Circuit Probe Current to 10MA/24VAC ■ Three-Probe Circuit Eliminates “Hunting” or Relay Chatter ■ Built-in Holding Circuit for Differential Levels or Manual Reset ■ Has Provision for Priming Switch for Applications Requiring Manual Priming of System ■ Solid-State Amplifier with SCR and Control Relay ■ Sensitivity to 100,000 ohms Specifications Model Input Supply DLC-1 120VAC, 50/60 Hz DLC-2 240VAC, 50/60 Hz DLC-3 24VAC, 50/60 Hz. Maximum Allowable Supply Voltage Variation: ± 10% Maximum Power Consumption: 3 Watts Sensitivity Range: External circuit sensitivity fixed at 100,000 ohms; Lockout circuit sensitivity fixed at 15,000 ohms Operating Point Differential: 3% (Typical) Maximum Signal or Probe Voltage: 24VAC Input Supply: Outline and Mounting Dimensions Maximum Signal or Probe Current: 10MA Control Relay: Plug-in types with dust cover Probe Contacts: Internally connected for holding circuit Load Contacts: 1/6 HP, 10 amp, Non-inductive/120VAC, 1/3 HP at 240VAC One side of No. 1 relay actuates fill water solenoid valve, a second set of contacts function as an internally connected holding circuit. One side of No. 2 relay is used to operate a heater load contactor. Ambient Operating Temperature: +32° F to +140° F Standard Termination: .250” quick-connects Description and Special Notes The DLC control maintains liquids between a low and a high level. Activating the main switch on this dualrelay unit pulls in control relay No. 1 and starts filling boiler tank through the solenoid valve. When liquid rises to “XL”, minimum level, lockout control relay No. 2 energizes to operate the pump, heater core or contactor. The solenoid valve continues to fill the tank until liquid reaches the “H” probe. When the liquid drops below the “L” probe, the solenoid fill valve is again activated. Relay No. 2, he lockout control, remains energized as long as liquid level remains above “XL” minimum level. Ordering Information Typical Curtis Model Number DLC-1 - - Model (Also refer to “Specifications” above) Contactor (add “C” if desired) Enclosure – specify only if necessary – N3-NEMA 3, N3C–NEMA 3/ Contactor, N4 – NEMA 4 JIC The composite number above reads as a “DLC amplifier for 120VAC supply, without enclosure and without contactor. Unless otherwise noted, when a contactor is ordered for the DLC unit, it is wired into the output of the No. 2 (heater control) relay. Contactors may be wired into the output of the No. 1 (solenoid valve control) relay or both No. 1 and No. 2 relays, as application may require. Specify with order. Refer to “Control Accessories,” page 7, for additional information. For further information on catalog listed controls contact your area Curtis representative or Curtis distributor. For custom design or modification contact your area Curtis representative or the factory direct. 10 Curtis liquid level probe assemblies ® P Series Probes for almost any pressure/temperature requirement Five basic probe types and 14 model variations provide design versatility matched to your specific application. Choose from single, dual or multi-probe designs in PVC or nylon fittings. All probes feature 316 stainless steel electrodes with standard lengths ranging up to six feet, in one-foot increments. Pressure/temperature limits range as high as 2500 lbs./700° F. Covered probes are offered for applications subject to unusually adverse environments or stringent safety codes. Model EP Economy probe designed for budget systems. Available in NPT sizes 3/4” (Single probe), 1” (Dual probe), 1-1/2” (Triple probe) with Nylon Hex fittings. Model SP Simple probe designed with adjustable probe length feature. Must be used with conductive container only. Available in probe size diameters of 1/8”, 3/16” or 1/4” (i.e. SP125, SP187, SP250). Models HTPP - HTPGP High temperature, high pressure 3/8” NPT probe designed to withstand hydrostatic pressures to 2500 psi and temperatures to 700° F. Standard Model HTPP does not contain added threaded stud for common ground connection, when required specify HTPGP Model. Constructed from 18-8 non-magnetic stainless steel with alumina insulation. Model CP Covered Probe designed for high humidity environments. Probe headers are splash-proof and moisture-tight. Available in NPT fitting sizes 1-1/2” for dual probe systems and 2” for triple or quadruple probe systems. Accessories Control enclosures for hostile environments NEMA 3 Enclosures – Weather-Resistant for Outdoor Applications Designed to exclude rain, snow and sleet, thee durable enclosures may also be used indoors wherever dripping water presents a problem. Construction features heavygauge steel finished in satin gray enamel. Enclosures accepting standard control models are designated N3, while those accepting the larger contactor mounting panels are designated N3C. Enclosures also meet NEMA I specifications for general purpose dust resistance. Standard Control Models ELS, LCS/LHS, LC, RSA, DLC, and PCT are open-style. Models with contactors are attached to a 6-7/8” x 8-3/4” panel. NEMA 3 and MEA 4JIC enclosures are offered to fit above models with or without contactor mounting panels. Alarm and indicator lamp options are also available. Contact factory or your local representative for additional information. NEMA 4-JIC Enclosures – Water Tight and Oil Tight Intended for use in areas which are regularly hosed down. They are suitable for outdoor, shipdeck, dairy or brewery applications. Enclosures are fabricated of extra-heavy 14gauge steel with welded seams. Construction also features external mounting feet and solid neoprene cover gasket. These grey hammertone enamel-finished units accept standard and contactor mounting panel controls. Enclosures also meet NEMA 12 for dust, dirt and oil protection. Any standoff or flange-mounted control may be ordered with the auxiliary contactor. Track-mounted controls are available with auxiliary contactors on special order only. Contact factory for additional info. Auxiliary Contactors – For Loads Exceeding That of Standard Relays When anticipated loads exceed the 10 amp/120VAC rating of relays furnished with our standard controls, use of a contactor is necessary. These small, ruggedly built units are available in 24, 120 and 240VAC coil voltages to match the control input supply voltage. Contactors feature heavyduty DPST-NO-DB contacts rated 1HP/120VAC or 2HP/ 240VAC. Terminals are No. 10 pressure screws with .250” double quick-connect tabs. Contactor/control assembles are prewired for customer convenience. Any standoff or flange-mounted control may be ordered with the auxiliary contactor. Track-mounted controls are available with auxiliary contactors on special order only. Contact factory for additional information. 11 Curtis® low cost amplifier module for liquid level applications Model RSA Control-Trak component ® Features Specifications ■ Inexpensive, Compact Circuitry is Compatible with any Transducer Exhibiting 100,000 ohms Resistance or Less ■ Designed to Fit Curtis TR1 or TR3 Snap-In Track Intended for Use with Curtis RS2, RS4, RS6, RS12, RS15 or RS16 Relay Socket Assemblies (See Curtis Relay Socket Catalog) ■ Ideal for Custom, Modified or Experimental Circuits – Control/ Relay Socket Combination Provides Access to the Several Hundred Relay Styles Available from Most Relay Manufacturers ■ Devices Other Than Relays, such as Solenoids or Valve Actuators may be Operated Directly Off the Module Providing that They are Rated 24VDC with Impedance Greater than 250 ohms ■ Includes Fully Adjustable Setpoint and Circuit Designed to Limit Maximum Direct-Short Transducer Current to 10MA/24VAC Model Input Supply Input Supply: RSA-1 120VAC, 50/60 Hz RSA-2 240VAC/ 50/60 Hz RSA-3 24VAC, 50/60 Hz Maximum Allowable Supply Voltage Variation: ± 10% Maximum Power Consumption: 1 W without relay Detectable Range: Up to 100,000 ohms Adjustable Range: 1,000 to 100,000 ohms Operating Point Differential: 3% (Typical) Maximum Signal or Probe Voltage: 24VAC Maximum Signal or Probe Current: 10MA Control Relay: Customer furnished – See Curtis Relay Socket Catalog for complete list of various snap-in assemblies Control Output: 90MA @ 24VDC Ambient Operating Temperature: 0° C to +60° C or ±32° F Standard Termination: .110” quick-connects Outline and Mounting Dimensions Operation Model RSA Amplifier Module accepts any liquid level transducer displaying less than 100,000 ohms resistance. As an example of its operation as a liquid level control, the control remains de-energized until liquid rises to contact the “H” probe. The resultant decrease in external circuit resistance from setpoint will energize output. Output remains energized until liquid again drops below the “H” probe. Sensitivity of the external circuit resistance setpoint is fully adjustable up to 100,000 ohms. Model RSA is designed to work in conjunction with track-mounted, customer supplied relays. However, the 90MA/24VDC output is sufficient to operate many solenoid and valve devices directly when minimum impedance exceeds 250 ohms. Ordering Information Typical Curtis Model Number RSA-1 -TR - Basic Amplifier Type (Also refer to “Specifications” above) Mounting (TR-Track, S-Standoff) The composite number above reads as a “RSA amplifier for 120VAC supply.” Model is track mounted (track ordered separately – see page 11.) An auxiliary contactor offered as a track-mounted accessory is available on special request only. Track-type units cannot be enclosure-mounted. Contact factory for additional information. For further information on catalog listed controls contact your area Curtis representative or Curtis distributor. For custom design or modification contact your area Curtis representative or the factory direct. 12 ® Curtis resistance sensing amplifier for photoelectric, temperature and process control Model PCT Features ■ Zener Diode-Regulated Power Supply Limits Operating Point Variations to Less than 0.5% ■ Standard Adjustable Resistance Sensing Range is Sensitive to 100,000 ohms but can be extended to 250,000 ohms ■ Has Provision for Remote Potentiometer Adjustment of Operating Setpoint as well as Built-In Time Delay which can be Modified to Meet Individual Customer Specifications ■ May be Wired for Light or Dark Energizing Operation ■ Circuit Design Limits Short Circuit Transducer Current to a Maximum 4MA/9VDC ■ Auxiliary Contactor Available for Loads Exceeding Capacity of Plug-in Relay ■ Differential Adjustment Provided ■ Auxiliary Contactor Available for Loads Exceeding Capacity of Plug-in Relay Outline and Mounting Dimensions Operation Ordering Information Specifications Model Input Supply PCT-1 120VAC, 50/60 Hz PCT-2 240VAC/ 50/60 Hz PCT-3 24VAC, 50/60 Hz Maximum Allowable Supply Voltage Variation: ± 10% Maximum Power Consumption: 3.5 Watts Detectable Range: Up to 100,000 ohms Standard; may be extended to 250,000 ohms Adjustable Range: 1,000 to 100,000 ohms Standard; 1,000 to 250,000 ohms for extended sensitivity circuits Operating Point Differential: 1% (With Sensing Element Resistance Above 15k ohms) Typical Maximum Signal or Probe Voltage (Element Exhibiting Infinite Resistance): 9VDC Maximum Signal or Probe Current: 4MA Control Relay: DPDT Plug-In Type with Cover Load Contacts: 1/6 HP, 10 amp, Non-inductive/120VAC; 1/3 HP at 230VAC Ambient Operating Temperature: -25° F to +140° F Standard Termination: Barrier-Type Terminal Blocks. Accepting Wire up to No. 12AWG Mounting Style: Flange Input Supply: Model PCT control may be wired to energize the control relay following either an increase or a decrease in external circuit resistance. Unit provides a .25MA/9VDC signal to a variable resistance sensing element. A control-mounted potentiometer allows adjustment of pull-in or drop-out point. The unit has provision for extension of the operating point as well as remote potentiometer adjustment. A built-in time delay eliminates false riggering due to minor sensing element impulses. Standard response time, typically 100 milliseconds, can be altered by changing the value of capacitor C2. Provides a response time of 10 to 15 milliseconds. Typical Curtis Model Number PCT-1 - - Basic Amplifier Type (Also refer to “Specifications” above) Contactor (if desired add “C”) Enclosure – specify only if necessary (N3 – NEMA 3, N3C – NEMA 3/ Contactor, N4 – NEMA 4 JIC The composite number above reads as a “PCT amplifier for 120VAC supply without contactor and less enclosure.” Contact factory for additional information. For further information on catalog listed controls contact your area Curtis representative or Curtis distributor. For custom design or modification contact your area Curtis representative or the factory direct. 13
LC-F-3-C 价格&库存
很抱歉,暂时无法提供与“LC-F-3-C”相匹配的价格&库存,您可以联系我们找货
