ROB-10456
ROB-10456
    SPARKFUNELECTRONICS
    One-Way Solenoid Valve Free Hanging (In-Line)
ROB-10456 数据手册
12V Solenoid Valve - 3/4" - ROB-10456 - SparkFun Electronics 12V Solenoid Valve - 3/4" ROB - 10456  images are CC BY-NC-SA 3.0 Description: Have you ever wanted to control the flow of a liquid using your computer or microcontroller, but didn’t know how? Well, here’s how: The 12V solenoid controlled fluid valve. Simply connect a fluid source to the ¾" threaded inlet and it will interrupt the flow until 12V is applied to the fast-on connectors on the solenoid. Note: This is not a gravity-feed solenoid. This means that you will need enough water pressure to fully open the valve. Check the datasheet below for exact details. It operates at a minimum of around 3 PSI, allowing around 3 L/min of flow. Although the datasheet shows the valve working at 220 VAC, it’s actually 12 VDC. Our 350 GPH pump does not have enough pressure for this valve. A garden hose or other pressurized system should work just fine. https://www.sparkfun.com/products/10456 8/17/2016
ROB-10456 价格&库存
很抱歉,暂时无法提供与“ROB-10456”相匹配的价格&库存,您可以联系我们找货
