| | WWW.CROUZET-CONTROL.COM
| | 34
| | PNEUMATICS PRODUCTS
| | 35
| | PNEUMATICS PRODUCTS
Amplifier with intégral régulator, positive output
› Setting Flow
› Fixing rail 35mm wide
PRESSURE SWITCHES
VACUUM
Part numbers
81 510 001
Positive output
Amplifiers with integral regulator
Version
Symbol
Characteristics
Pressure to make
mb
Reduced pressure supplied at port 8
bar
Flow through port 8
Nm3/h
Consumption of amplifier only
NI/h
Permissible overload for 1 hour
mb
Operating temperature
°C
Mechanical life
operations
Weight g
Detectors (see page 28)
Nominal range
Min. total consumption for detection
(0.5 b regulated pressure)
Max. total consumption for short response
time (2.5 b regulated pressure)
Min. detectable
dimensions
nominal sensing distance
Max. frequency of use
2
Force exerted by the jet on the parts
to be detected
0.5 → 1.5
0.5 → 2.5
0.1 → 2.5
100 → 200
300
-5 ➞ +50
3 x 10 6
380
Proximity
Ø 12
81 371 401
8
-5 ➞ +50
6
3 x 10
Gap
Ø 18
81 372 201
18
NI/h
880
140
NI/h
2750
400
920
mm
mm
Hz
Ø3
2
5
Ø 2 - Ø 1.5
5
Ø 7 - Ø 6.5
5
N
0.02 → 0.7
0.01 → 0.03
0.1
mm
-5 ➞ +50
6
3 x 10
Proximity
Ø 12
81 372 401
100
Connection
To use with detectors page 32
Principle of operation
pilot pressure
Dimensions
This amplifier
is suitable for
providing a supply
to associated
sensors.
Push-in connection for semi-rigid tubing Ø 4 mm (NFE 49100)
Viewed from B
Regulated pressure (bar)
Viewed from A
Adjustable regulator
| | 36
| | PNEUMATICS PRODUCTS
| | 37
| | PNEUMATICS PRODUCTS
Pressure switches - vacuum (electrical output)
Conform to the Low Voltage Directive
› Can be used without enclosure according to
IEC 664-1 pollution group III
Part numbers
Pressure and vacuum switches
Mounting
81 513 552
DIN rail
81 513 502
DIN rail
81 513 501
DIN rail
81 513 522
DIN rail
Actuators
Manual override
Pressure
with
Pressure
without
Low pressure
without
Vacuum
without
Ø 4 ext.
Ø 4 ext.
Ø 4 ext.
Ø 4 ext.
Symbol
81 513 516
Base mounted
page 4/14
Pressure
without
81 513 510
Base mounted
page 4/14
Pressure
with
81 513 527
Base mounted
page 4/14
Vacuum
without
Ø 4 ext.
Ø 4 ext.
Ø 4 ext.
IP 54
IP 54
IP 54
81 513 533 81 513 523
2 screws M4 2 screws M4
Pressure
without
Vacuum
without
81 509 080
Base mounted
page 4/14
Pressure
without
81 509 085
Base mounted
page 4/14
Pressure
with
Characteristics
Pneumatic
mm
connection
tubing (NFE 49100)
Tapped BSP via connector
Protection
IEC 529
Permissible fluid: air, inert gases and liquids
Adjustment of switching pressure (* adjusted to 0.3) bar
Hysteresis
at 1 bar
bar
at 2 bars
bar
at 4 bars
bar
at 6 bars
bar
max. 200 mb
max. 250 mb
Pressure to break
Mechanical life (operations)
Contact rating (V resistive)
Wire cross-section
mm2
°C
Weight
g
Standard electrical contact
UL and cUL approval
IP 20
IP 20
2➞8
0.5
0.6
0.8
1
106
5A - 220-230 V
0.75
-10 ➞ +70
48
V4 83 170 4 I W2
MH15213 (R)
2➞8
0.5
0.6
0.8
1
106
5A - 220-230 V
0.75
-10 ➞ +70
46
V4 83 170 4 I W2
MH15213 (R)
Operation
Pressure operated
Vacuum operated
IP 20
IP 20
0.3 ➞ 1.2 *
106
5A - 220-230 V
0.75
-10 ➞ +70
46
V4 83 170 4 I W2
MH15213 (R)
-0.3 ➞ -0.8
106
5A - 220-230 V
0.75
-10 ➞ +70
46
V4 83 170 4 I W2
MH15213 (R)
Electrical life
(Crouzet microswitch "V4" ref 83 170 4-1-W2)
Number of cycles
Resistive circuit
Inductive circuit
Electrical output
- common
- normally closed contact
- normally open contact
Adjustment of switching pressure 1 to 8 bars
L
c __ = 5 ms
R
a cos q = 0.8
Mechanical
life
1/8 BSP
IP 54
‑1/8 BSP
IP 54
Via sub-base Via sub-base
IP 54
IP 54
2➞8
0.5
0.6
0.8
1
106
5A - 220-230 V
0.75
-10 ➞ +70
56
V4 83 170 4 I W2
MH15213 (R)
2➞8
0.5
0.6
0.8
1
106
5A - 220-230 V
0.75
-10 ➞ +70
58
V4 83 170 4 I W2
MH15213 (R)
-0.3 ➞ -0.9
2➞8
0.5
0.6
0.8
1
106
5A - 220-230 V
0.75
-10 ➞ +70
65
V4 83 170 4 I W2
MH15213 (R)
-0.3 ➞ -0.8
1.4 ± 0.5
0.6 ± 0.2
106
5A - 220-230 V
1.5
-10 ➞ +70
80
83 133 004
1.4 ± 0.5
0.6 ± 0.2
106
5A - 220-230 V
1.5
-10 ➞ +70
80
83 133 004
Electrical connections
81 513 501 - 81 513 502
81 513 522 - 81 513 552
106
5A - 220-230 V
0.75
-10 ➞ +70
56
V4 83 170 4 I W2
MH15213 (R)
Dimensions
81 513 552 - 81 513 502
81 513 501 - 81 513 522
106
5A - 220-230 V
0.75
-10 ➞ +70
65
V4 83 170 4 I W2
MH15213 (R)
Pressure switch with connector
81 513 516 - 81 513 510
81 513 527
81 516 082
81 513 533
81 513 523
1 - Common
4 - NO contact
2 - NC contact
81 513 510
81 513 516 - 81 513 527
Standard microswitch
5 A / 220 V
Manual override
For M4 screws
Marking tag
Current
in Amps
For continuous vacuum applications, please consult us.
On request :
- Microswitch V4 ref. 83 170 0 i W2 high current
- Microswitch V4 ref. 83 170 9 i W2 low current
Pilot signal
Pilot
signal
81 509 080 - 81 509 085
Pneumatic signal
Other information
length 24 mm
81 513 533
81 513 523 - 81 513 533
Pneumatic indicator
| | 38
| | PNEUMATICS PRODUCTS
| | 39
| | PNEUMATICS PRODUCTS
Adjustable pressure switches (manostats) (pneumatic output)
Adjustable vacuum switches (vacuostat)
› 100 % pneumatic
› 100 % pneumatic
› For vacuum -0,1 ➞ -0,9 Bar
Also available in ATEX version for use in potentially explosive atmospheres in accordance with
94/9/EC Directive
Part numbers (and adjustment ranges)
Adjustment range
50 → 500 mb
0.1 → 2.5 b
2 → 8 b
Version
Accuracy 50 → 500 mb
0.1 → 2.5 b
2 → 8 b
Part numbers
81 505 140
81 505 150
81 505 160
Positive output
10 %
4%
4%
81 502 140
81 502 150
81 502 160
Negative output
10 %
4%
4%
81 505 110
Positive output
81 502 110
Negative output
81 508 110
Electrical output
- 0.1 ➞ -0.9
170
80
- 0.1 ➞ -0.9
170
80
- 0.1 ➞ -0.9
170
80
Symbol
Symbol
Characteristics
Adjustment range
b
Flow at 6 bars
Nl/min
Hysteresis mb
Connection - sub-base pages 54/55
°C
Mechanical life
operations
Weight g
Connections
Characteristics
Orifice diameter
mm
Flow at 4 bars
Nl/min
Hysteresis 50 → 500 mb
0.1 → 2.5 b
2 → 8 b
°C
Mechanical life
operations
Weight g
Connections
2.5
170
60 mb
100 mb
320 mb
2.5
170
60 mb
100 mb
320 mb
-5 ➞ +50
3 x 10 6
160
-5 ➞ +50
3 x 10 6
160
-5 ➞ +50
3 x 10 6
160
-5 ➞ +50
3 x 10 6
160
-5 ➞ +50
3 x 10 6
180
Example of use:
Vacuum handling (vacuum generator,
vacuum pad, vacuostats).
Example of pressure threshold adjustment
(mini-regulator - manostat)
Vacuostats provide an on or off output signal when the input signal reaches a predetermined pressure threshold.
Positive output
The manostats provide an on or off output signal when the input signal reaches a predetermined pressure threshold.
Positive output
Output signal
Negative output
Output signal
Output signal
Negative output
Output signal
Pilot
Hysteresis
Pilot
Switching off
Hysteresis
Switching
on
Switching
on
Switching
on
Switching off
Switching off
Hysteresis
Vacuum
Dimensions
Dimensions
81 502 140 - 81 502 150 - 81 502 160
81 505 140 - 81 505 150 - 81 505 160
Other information Pressure switches with electrical output on request.
ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website
www.crouzet.com
Switching off
Switching
on
81 502 110 - 81 505 110
Hysteresis
Vacuum
Vacuum
81 508 110
Vacuum
| | 40
| | PNEUMATICS PRODUCTS
| | 41
| | PNEUMATICS PRODUCTS
Vacuum handling components
› Sur le principe du Venturi
› Facilement raccordable
94/9/EC Directive
PNEUMATIC
LOGIC COMPONENTS
Part numbers
81 535 301
Sub-base mounting
Vacuum generators
81 545 001
Plug-in
81 545 005
Plug-in
Characteristics
Push-in connectors for
Male/Female/Female (MFF)
semi-rigid tubing
Female/Female/
(NFE 49100)
Female (FFF)
Operating pressure
bar
Vacuum pad material
Weight g
2→8
80
Ø 4 mm
2→8
13
Ø 6 mm
2→8
25
Detection of the pressure decrease can be achieved by the
use of manostats (see pages 38/39)
Vacuum (mb)
Suction flow
Vacuum
(mb)
Vacuum (mb)
Suction flow
Vacuum (mb)
Suction flow
Vacuum
(mb)
Vacuum
(mb)
Flow
Flow
Flow
Supply pressure (bar)
Dimensions
81 535 301
81 545 001
Sub-base mounting 81 531… and 81 532…
Plug-in ferrule for push-in connector
Ø 4 mm
24
2 push-in connectors
Ø 4 mm
29
11
40
81 545 005
30,7
Ø 4,5
15,5
40
29 ±0,1
11
10,7
3 push-in connectors
Ø 6 mm
14,5 ±0,1
www.crouzet.com
很抱歉,暂时无法提供与“81505150”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5585.413181+722.62229
- 3+5571.378473+720.80652
- 5+5557.437905+719.00294
- 国内价格 香港价格
- 1+5312.950781+687.37200
