997
997
    ADAFRUIT
    PLASTICWATERSOLENOIDVALVE-1
997 数据手册
Plastic Water Solenoid Valve - 12V - 1/2" Nominal PRODUCT ID: 997  Description Control the flow of fluid using the flow of electrons! This liquid valve would make a great addition to your robotic gardening project. There are two 1/2" (Nominal non-taped National Pipe) outlets. Normally, the valve is closed. When 12VDC is applied to the two terminals, the valve opens and water can push through. The valve has a gasket arrangement inside, so there is a minimum pressure requirement of 0.02 Mpa (3 PSI). Also, liquid can only flow one direction. We tried this solenoid at various DC voltages and found we could actuate it down at 6VDC (although it was a little slower to open). Here is the current draw table for various voltages. We suggest a TIP120 or NChannel power FET with a 1N4001 kickback diode to drive this from a microcontroller pin. For a power supply, our 9V 1A or 12V 1A power adapters will do the job. If you want a beefier water valve, we also carry a brass version which does not have a minimum pressure requirement and can be used with liquid flow in either direction. Voltage Current 6V 160 mA 7V 190 mA 8V 220 mA 9V 240 mA 10V 270 mA 11V 300 mA 12V 320 mA These solenoids are not rated for food safety or use with anything but water.  Technical Details o o o o o o o o o 1/2" Nominal NPS Working Pressure: 0.02 Mpa - 0.8 Mpa Working Temperature: 1 Ԩ - 75 Ԩ Response time (open): ≤ 0.15 sec Response time (close): ≤ 0.3 sec Actuating voltage: 12VDC (but we found it would work down to 6V) Actuating life: ≥ 50 million cycles Weight: 4.3 oz Dimensions: 3.3" x 1.69" x 2.24"        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“997”相匹配的价格&库存,您可以联系我们找货
