81519832
81519832
    CROUZET(高诺斯)
    SOLENOID VALVE 3/2 NO SUBBASE MT
81519832 数据手册
Electro-pneumatic control valves www.crouzet.com 57 Miniature solenoid valves for alternating current ■ Conform to the Low Voltage Directive mounting on sub-base or footprint in accordance with CNOMO recommendation E‑06-36-120N ■ For Part numbers (and voltages) Voltage 24 V a 50-60 Hz 48 V a 50-60 Hz* 110 V a 50-60 Hz 220 V- 230 V a 50-60 Hz Consumption 2.5 VA 2.5 VA 2.5 VA 2.5 VA Function Version 81 519 080 - 81 81 81 81 519 519 519 519 380 381 378 379 81 81 81 81 519 519 519 519 680 681 678 679 3/2 NC Without manual override 3/2 NC With manual override by impulse 3/2 NC With manual override by latching (1/4 turn) 1➞ 8 0.5 12 0.12 5 ➞ 15 5 107 -10 ➞ +50 1➞ 8 0.5 12 0.12 5 ➞ 15 5 107 -10 ➞ +50 1➞8 0.5 12 0.12 5 ➞ 15 5 107 -10 ➞ +50 Characteristics Operating pressure Orifice diameter Flow at 6 bars kV Switching time Mechanical life (operations) Operating temperature Compressed air or inert gas - oil-free air filtered to 50 µ Duty factor Insulation class Weight Rotatable connector 4 positions in 90° steps Degree of with sub-base (page 62) protection with connector 81 516 082 (page 65) UL and cUL approval 15x15 mm footprint according to CNOMO E 06-36-120N 6 min. °C ● IEC 85 3 9,7 100 % ED F 35 ● IEC 529 IEC 529 IP 20 IP 65 MH 15085 Dimensions 81 519 0 26 7,5 min. 2 1 1,4 3,8 ● 100 % ED F 35 ● IP 20 IP 65 MH 15085 ● 100 % ED F 35 ● IP 20 IP 65 MH 15085 81 519 3 81 519 6 9,4±0,1 Manual override 42 max. 17 min. 5 ms 9 min. 2 x M3 - 6 H depth 6 Solenoid valve projecting on this side bar mm Nl/min 3,8 7,5 min. 2 or 3 Ø 1.6 min 2 max 16 15 Adjacent side of footprint when valves mounted in bank 1 - Supply 2 - Output 3 - Exhaust 58 www.crouzet.com Miniature solenoid valves for direct current ■ Conform to the Low Voltage Directive mounting on sub-base or footprint in accordance with CNOMO recommendation E‑06-36-120N ■ For Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive Part numbers (and voltages) Consumption 1W Function Version Voltage 24 V c 81 519 032 3/2 NC Without manual override 81 519 332 3/2 NC With manual override by impulse 81 519 632 3/2 NC With maintained manual override 81 519 340 3/2 NF With maintained manual override 1➞ 8 0.8 25 0.3 5 ➞ 15 5 107 -10 ➞ +50 1➞ 8 0.8 25 0.3 5 ➞ 15 5 107 -10 ➞ +50 1➞ 8 0.8 25 0.3 5 ➞ 15 5 107 -10 ➞ +50 1➞ 8 0,8 25 0,3 5 ➞ 15 5 107 -10 ➞ +50 Characteristics bar mm Nl/min Operating pressure Orifice diameter Flow at 6 bars kV Switching time Mechanical life (operations) Operating temperature Compressed air or inert gas - oil-free air filtered to 50 µ Duty factor Insulation class Weight Rotatable connector 4 positions in 90° steps Degree of with M12 5-pin connector protection with connector 81 516 082 UL and cUL approval 15x15 mm footprint ms °C ● IEC 85 IEC 529 IEC 529 ● 100 % ED F 35 100 % ED F 35 ● 100 % ED F 35 ● 100 % ED F 35 ● ● ● ● – – – – IP 65 MH 15085 IP 65 MH 15085 IP 65 MH 15085 IP 65 MH 15085 according to CNOMO E 06-36-120N 6 min. 2 x M3 - 6 H depth 6 7,5 min. 3 17 min. 9,7 Solenoid valve projecting on this side 1 - Supply 2 - Output 3 - Exhaust 9 min. 2 1 1,4 3,8 3,8 7,5 min. 5 2 or 3 Ø 1.6 min 2 max Adjacent side of footprint when valves mounted in bank Encombrement 81 519 0 Manual override 42 max. 16 15 Manual override 9,4±0,1 42 max. 26 9,4±0,1 42 max. 26 81 519 3 81 519 3 81 519 6 21 15 21 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com www.crouzet.com 59 Sub-bases for miniature solenoid valves Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive Part numbers 81 514 101 - Pair of end bases Intermediate sub-base Adaptor sub-base for CNOMO 06-05-80 / NFE 49066 footprint 81 514 161 - 79 453 569 Characteristics Pneumatic indicator on output Common supply Common exhaust Torque capacity Push-in connection for semi-rigid tubing Ø 4 mm (NFE 49100) Mounting ● ● ● ● ● mm2 3 mm ● g UL and cUL approval Weight Connection Pneumatic ● 3 ● DIN rail 35 mm DIN rail 35 mm MH 15085 65 MH 15085 30 2 screws M4 x 10 50 - Electrical A2 1 - Supply 2 - Output 3 - Exhaust A1 A1 - Pilot signal A2 - Common - Earth t Dimensions with miniature solenoid valve (page 58) 81 514 101 - 81 514 161 66 Miniature solenoid valve 81 519 ... see page 58 8 CNOMO footprint E 06-36-120N for mounting miniature solenoid valve 81 519 7 max. 34,7 15 Mounting on CNOMO 06-05-80/ NFE 49066 footprint Fixing on CNOMO 06-05-80/ NFE 49-066 footprint by 2 cap screws M4x10 (NFE 25-127) 21 52 max. 32 9 0 52 max. Connector ref 81 516 082 (rotatable in 90° steps) see page 65 51 37,8 5 16 79 453 569 14 25 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com 60 www.crouzet.com Electro-pneumatic miniature control valves Mounting Miniature solenoid valves Indicators - LED seals - LED 003229P51 Valve modules - Poppet 3/2 monostable (17.5 mm) 4/2 monostable (17.5 mm) - Slide valve 4/2 bistable (35 mm) 4/2 monostable spring-return (35 mm) Sub-bases 003241 P51 For miniature solenoid valves For valve modules 5 Double Single 003234P5 Complete product 003233P5 www.crouzet.com 61 Valve modules ■ Monostable, ■ 3/2, bistable 4/2 Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive 81 513 100 Function 81 513 600 81 513 200 3/2 NC monostable 3/2 NO monostable 4/2 monostable 81 516 200 4/2 bistable 81 516 100 4/2 monostable Symbol 14 3 1 2 Characteristics Width Working pressure Orifice diameter Flow at 6 bars with Ø 4 mm with Ø 6 mm Flow Rate with Ø 4 mm with Ø 6 mm Operating temperature Switching time for the valve only Mechanical life Weight sub-base sub-base sub-base sub-base (page (page (page (page 63) 63) 63) 63) mm bars mm 17.5 3➞8 3 200 Nl/min 300 kV 2.2 2.5 ° C -10 ➞ +50 ms 15 operations 1.5 x 107 38 g 17.5 3➞8 3 200 300 2.2 2.5 -10 ➞ +50 15 1.5 x 107 38 17.5 3➞8 3 200 300 2.2 4 -10 ➞ +50 15 1.5 x 107 38 35 2➞8 4 300 400 4 5 -10 ➞ +50 50 107 106 35 3.5➞8 4 300 400 4 5 -10 ➞ +50 50 107 106 Dimensions 81 513 81 516 5 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com 62 www.crouzet.com Sub-bases and end bases for miniature control valves Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive Part numbers Mounting Version Push-in connection for semirigid tubing (NFE 49100) Sub-bases End bases (pair) Intermediate supply module Characteristics Torque capacity UL and cUL approval Cabinet 17.5 mm 81 513 060 81 513 065 - Ø 4 mm Ø 6 mm Ø 6 mm Cabinet 81 513 001 - - mm2 3 MM15085 DIN rail 35 mm 3 MM15085 DIN rail 35 mm DIN rail 35 mm DIN rail 35 mm g 55 110 86 44 Pneumatic 81 513 011 - 81 513 001 2 - Pneumatic output 4/2 (NO) 4 - Pneumatic output 3/2 or 4/2 (NC) 2 2 4 4 Output at rest (NO) Output at rest * Output at rest * Output operating (NC) Note : Each sub-base can accept - sub-base 81 513 060-065 : 1 relay 3/2 or 4/2, width 17.5 mm - sub-base 81 517 101-201 : 1 bistable relay 4/2 (width 35 mm) or 2 relays 3/2 or 4/2 (width 17.5 mm) Cabinet 81 513 011 - Ø 6 mm Mounting Weight Connections Cabinet 35 mm 81 517 101 81 517 201 - Electrical 02 2 Supply ports 03 2 Exhaust ports Integral push-in connections Ø 6 mm Degree of protection : IP20 when assembled. A1 - Pilot signal A2 - Common t Earth A1 - Operating control signal (14) A2 - Common A1 - Rest control signal (12) A2 - Common t 5 Earth Dimensions with miniature control valves (page 62) + miniature solenoid valves (page 58) + indicators (page 65) End bases Intermediate base LED indicator 80 Module 3 1 2 1 17,5 3 1 4 3 17,5 3 6 5 35 17,5 17,5 35 x (n module + 1) Ø4 12,5 1 77 max. Ø6 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com www.crouzet.com 63 Valves and solenoids valves assembled Contact us for Other versions Part numbers Function Sub-base with push-in connection for semi-rigid tubing (NFE 49100) Version 3/2 NC 4/2 monostable Ø 4 ext. Ø 4 ext. Solenoid valve with manual override by impulse 81 513 103 Solenoid valve with manual override by impulse 81 513 203 Operating pressure bar Orifice diameter mm Flow at sub-base 81 513 060 NL/min 6 bars sub-base 81 517 101 NL/min with sub-base 81 513 060 KV with sub-base 81 517 101 Operating temperature °C Switching time of the assembly ms Mechanical life (operations) at 4 bars Valve position will be maintained in the event of pressure loss and/or electrical current loss Mounting 3➞8 3 200 3➞8 3 200 DIN rail 35 mm DIN rail 35 mm g Weight UL and cUL approval Principle of operation 130 MH15085 130 MH15085 Dimensions Voltage 24 VDC (+10% -15%) Symbol Characteristics -10 ➞ +50 20 1.5 x 107 - 2.2 -10 ➞ +50 20 1.5 x 107 - 3/2 monostable module (NC) Anti-return valve to prevent back pressures - Electrical signal - Common A2 - Pilot signal A1 - Earth End bases - one pair LED indicator Module Intermediate module LED indicator Plug-in solenoid valve Common exhaust Poppet valve 80 Manual override Common air supply 1 3 1 2 Marking tag 1 3 1 4 5 Pneumatic indicator Pneumatic output 17,5 17,5 35 17,5 17,5 35 x (n module + 1) 4/2 monostable module 3 6 3 4/2 bistable module Ø4 12,5 5 - 2.2 77 max. Ø6 End bases not supplied (page 63) Intermediate bases not supplied (page 63) Indicators not supplied (page 65) 64 www.crouzet.com Accessories Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive Part numbers 24 V - 50-60 Hz c 48 V - 50-60 Hz c 110 V - 50-60 Hz c 230 V - 50-60 Hz (-10% +6 %) Visual indicators with anti- surge 81 513 052 81 513 055 81 513 058 - - - - - 81 513 059 - - - - - - - - - 81 513 064 (by 10) LED seal 12 to 24 V - DC - AC Packaging (by 5) Exhaust Plug-in Ø 6 silencer Plug-in Ø 8 Connector for solenoid valve Without manual override Pneumatic With manual override pilots by impulse Push-in connection for semi-rigid tubing Ø 4 mm (NFE 49100) Blanking plate - - - - - - - - - - ● - - - - - - - - 81 537 001 81 537 201 - 81 516 082 - 81 516 081 - 81 516 091 81 516 085 Symbol 81 513 052 81 513 055 81 513 058 81 513 059 Characteristics Consumption W Temperature °C Connection mm Mounted between the pilot solenoid valve and the body of the module Supplied in multiples of 5 Supplied in multiples of 10 Packet of 10 pieces g Weight 6 - 0.24 - 10 ➞ +50 - Instantané Ø 4 ext. - ● ● - - - - ● - - ● ● - - - ● 2 - 30 10 1 2 Connection t 5 ● 5 ● 3 Pilot signal Earth (4) Dimensions 81 513 052 - 81 513 055 Mounted by plugging into push-in connector for semirigid tubing (NFE 49100) 81 513 058 - 81 513 059 81 516 082 15,5 - 0 15,5 - 0 + 0,1 M3 15 29 Ø 15 + 0,1 26 35 81 537 001 - 81 537 201 50 28 15 Pg 7 Ø 14 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com www.crouzet.com 65 Solenoid valves ■ Reduced "dimensions" ■ Mounted on sub-base Part numbers and voltages Function Mounting Solenoid valves with manual override by impulse 24 V (+10% -15%) 24 V - 50/60 Hz (+10% -15%) 48V - 50/60 Hz (+10% -15%) 110 V - 50/60 Hz (+10% -15%) 220 - 230 V - 50/60 Hz (+10% -15%) 3/2 NC On sub-base (54) 81 519 732 81 519 774 81 519 775 81 519 776 81 519 777 Symbol Characteristics Operating pressure Orifice diameter Flow at 6 bars Rotatable coil 4 positions in 90° steps Degree of protection (with connector 81 516 082 not supplied) (see page 65) Mechanical life c Consumption ~ Operating temperature Weight UL and cUL approval Principle of operation 1-2 5 2→8 2.7 170 bar mm Nl/min ● IEC 529 operations W VA °C g IP 65 1.5 x 107 1 2.5 -5 ➞ +50 70 MH15085 Connections Pneumatic { Electrical { t Earth 1 - Supply 2 - Output Dimensions 81 519 On separate sub-base 1 - 2 - Pilot signal Electrical connection by connector 81 516 062 (see page 65) 66 www.crouzet.com Specific islands "for integrators" (supplied in packs of 20) Versions with interfaces 300 NL / mm Configuration 1 - Specify the number and type of interfaces (3 / 2 mono 4 / 2 mono - 4 / 2 bistable) see page 62. 2 - Specify the voltage, the type and method of the control valve connections, see page: 58-59 (Example: 24 V DC with manual switch maintained, exit leads). 3 - Please send us your application specifying your requirements and quantities per year, and we will respond as soon as possible. Versions with interfaces 30 NL / mm Configuration 1 - Specify the voltage, the type and method of the control valve connections, see page: 58-59 (Example: 24 V DC with manual switch maintained, exit leads). 2 - Please send us your application specifying your requirements and quantities per year, and we will respond as soon as possible. Develop customised versions to specifications 5 Crouzet analyses your needs and offers a customised solution. www.crouzet.com 67 5 68 www.crouzet.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Crouzet: 81513100 81513200 81513600 81513203 81513052 81519380 81516093 81519348 81513058 81519332 81513064 81519774 81516200 79453569 81519777 81519048 81519034 81519632 81519678 81516107 81519335 81519379 81519776 81519331 81517106 81519732 81519132 81516208 81519832 81512401 81513065 81519035 81514161 81519738 81519635 81519680 81519648 81517201 81513055 81516082 81513001 81513059 81516081 81517101 81519378 81514101 81513011 81519347 81519037 81516085 81519032 81513060 81519334
81519832 价格&库存
很抱歉,暂时无法提供与“81519832”相匹配的价格&库存,您可以联系我们找货
