81519032
81519032
    CROUZET(高诺斯)
    PNEUM VLV SOLENOID 24VDC 3/2 NC
81519032 数据手册
| | WWW.CROUZET-CONTROL.COM | | 56 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM | | 57 | | PNEUMATICS PRODUCTS Mounting accessories Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive 81 533 501 Hole domino Mounting equipment Supply manifold 13 outputs 81 533 001 Clip domino - - 8 For mounting on the end of a zinc-coated mild steel rod Ø 8 mm on an asymmetrical DIN rail -5 ➞ +50 4 For adjustable mounting on a zinc-coated mild steel rod Ø 8 mm on an asymmetrical DIN rail -5 ➞ +50 79 450 609 Bar clips Ø8 - 81 536 801 Characteristics Weight (g) Operating temperature °C 80 Packet of 100 pieces 80 -5 ➞ +50 -5 ➞ +50 Dimensions 81 536 804 Mounted on steel rod Ø 8 mm 35 8Ø Input port 8Ø mm push-in fitting 35 25 67 Ø8 Ø4 13 outputs push-in fittings 4 mm Ø 67 80 80 Ø4 25 Push-in connection for semi-rigid tubing Ø 4 mm (NFE 49100) Other information Use Weidmuller plastic labels for marking components part number FW 4734-6. ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com ELECTRO-PNEUMATIC CONTROL VALVES | | WWW.CROUZET-CONTROL.COM | | 58 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM Miniature solenoid valves for alternating current | | 59 | | PNEUMATICS PRODUCTS Miniature solenoid valves for direct current › Conform to the Low Voltage Directive › For mounting on sub-base or footprint in accordance with CNOMO recommendation E‑06-36-120N Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive › Conform to the Low Voltage Directive › For mounting on sub-base or footprint in accordance with CNOMO recommendation E‑06-36-120N Part numbers (and voltages) Part numbers (and voltages) 81 81 81 81 519 519 519 519 380 381 378 379 81 81 81 81 519 519 519 519 680 681 678 679 3/2 NC Without manual override 3/2 NC With manual override by impulse 3/2 NC With manual override by latching (1/4 turn) 1➞ 8 0.5 12 0.12 5 ➞ 15 5 107 -10 ➞ +50 1➞8 0.5 12 0.12 5 ➞ 15 5 107 -10 ➞ +50 Characteristics bar Operating pressure 1➞ 8 mm Orifice diameter 0.5 Nl/min Flow at 6 bars 12 kV 0.12 ms Switching time 5 ➞ 15 Mechanical life (operations) 5 107 °C -10 ➞ +50 Operating temperature Compressed air or inert gas - oil-free ● air filtered to 50 µ 100 % ED Duty factor F Insulation class IEC 85 35 Weight ● Rotatable connector 4 positions in 90° steps IP 20 Degree of with sub-base (page 62) IEC 529 IP 65 protection with connector 81 516 082 (page 65) IEC 529 MH 15085 UL and cUL approval 15x15 mm footprint Dimensions 81 519 0 according to CNOMO E 06-36-120N 6 min. 26 ● IP 20 IP 65 MH 15085 9,4±0,1 Adjacent side of footprint when valves mounted in bank 2 or 3 Ø 1.6 min 2 max 81 519 632 3/2 NC With maintained manual override 81 519 340 3/2 NF With maintained manual override 1➞ 8 0.8 25 0.3 5 ➞ 15 5 107 -10 ➞ +50 1➞ 8 0.8 25 0.3 5 ➞ 15 5 107 -10 ➞ +50 1➞ 8 0,8 25 0,3 5 ➞ 15 5 107 -10 ➞ +50 ● 100 % ED F 35 ● 100 % ED F 35 ● 100 % ED F 35 ● ● ● – – – IP 65 MH 15085 IP 65 MH 15085 IP 65 MH 15085 2 x M3 - 6 H depth 6 Solenoid valve projecting on this side 1 - Supply 2 - Output 3 - Exhaust 9 min. 7,5 min. 3 2 1 1,4 3,8 7,5 min. 3,8 2 or 3 Ø 1.6 min 2 max Adjacent side of footprint when valves mounted in bank 7,5 min. 3,8 81 519 332 3/2 NC With manual override by impulse according to CNOMO E 06-36-120N 17 min. 2 1 81 519 032 3/2 NC Without manual override bar Operating pressure 1➞ 8 mm Orifice diameter 0.8 Nl/min Flow at 6 bars 25 kV 0.3 ms Switching time 5 ➞ 15 Mechanical life (operations) 5 107 °C -10 ➞ +50 Operating temperature Compressed air or inert gas - oil-free ● air filtered to 50 µ 100 % ED Duty factor F Insulation class IEC 85 35 Weight ● Rotatable connector 4 positions in 90° steps – Degree of with M12 5-pin connector IEC 529 IP 65 protection with connector 81 516 082 IEC 529 MH 15085 UL and cUL approval 15x15 mm footprint 6 min. Manual override Voltage 24 V c Characteristics 81 519 3 81 519 6 42 max. 9,7 17 min. 3 ● 100 % ED F 35 Function Version 7,5 min. 1,4 3,8 ● IP 20 IP 65 MH 15085 9 min. 2 x M3 - 6 H depth 6 Solenoid valve projecting on this side ● 100 % ED F 35 Consumption 1W 16 15 Encombrement 81 519 0 1 - Supply 2 - Output 3 - Exhaust Manual override 26 9,4±0,1 42 max. 16 15 Manual override 9,4±0,1 42 max. 26 81 519 3 81 519 3 81 519 6 42 max. Function Version 81 519 080 - 9,7 Voltage 24 V a 50-60 Hz 48 V a 50-60 Hz* 110 V a 50-60 Hz 220 V- 230 V a 50-60 Hz Consumption 2.5 VA 2.5 VA 2.5 VA 2.5 VA 21 15 21 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com | | WWW.CROUZET-CONTROL.COM | | 60 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM | | 61 | | PNEUMATICS PRODUCTS Electro-pneumatic miniature control valves Mounting Miniature solenoid valves Indicators - LED seals - LED 003229P51 Valve modules - Poppet 3/2 monostable (17.5 mm) 4/2 monostable (17.5 mm) - Slide valve 4/2 bistable (35 mm) 4/2 monostable spring-return (35 mm) Sub-bases 003241 P51 For miniature solenoid valves For valve modules Double Single 003234P5 Complete product 003233P5 | | WWW.CROUZET-CONTROL.COM | | 62 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM Valve modules | | 63 | | PNEUMATICS PRODUCTS Sub-bases and end bases for miniature control valves › Monostable, bistable › 3/2, 4/2 Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive 81 513 100 81 513 600 81 513 200 81 516 200 81 516 100 Part numbers Function 3/2 NC monostable 3/2 NO monostable 4/2 monostable 4/2 bistable 4/2 monostable Symbol Mounting Version Push-in connection for semirigid tubing (NFE 49100) Sub-bases End bases (pair) Intermediate supply module 14 Characteristics 3 1 Torque capacity UL and cUL approval 2 17.5 3➞8 3 200 300 2.2 2.5 -10 ➞ +50 15 1.5 x 107 38 17.5 3➞8 3 200 300 2.2 2.5 -10 ➞ +50 15 1.5 x 107 38 17.5 3➞8 3 200 300 2.2 4 -10 ➞ +50 15 1.5 x 107 38 35 2➞8 4 300 400 4 5 -10 ➞ +50 50 107 106 35 3.5➞8 4 300 400 4 5 -10 ➞ +50 50 107 106 Weight Connections Pneumatic Cabinet 81 513 011 Cabinet 81 513 001 - - mm2 3 MM15085 DIN rail 35 mm 3 MM15085 DIN rail 35 mm DIN rail 35 mm DIN rail 35 mm g 55 110 86 44 81 513 011 - 81 513 001 2 - Pneumatic output 4/2 (NO) 4 - Pneumatic output 3/2 or 4/2 (NC) 2 2 4 4 Output at rest (NO) Output at rest * Output at rest * Output operating (NC) Note : Each sub-base can accept - sub-base 81 513 060-065 : 1 relay 3/2 or 4/2, width 17.5 mm - sub-base 81 517 101-201 : 1 bistable relay 4/2 (width 35 mm) or 2 relays 3/2 or 4/2 (width 17.5 mm) Dimensions 81 513 Cabinet 35 mm 81 517 101 81 517 201 - - Ø 6 mm Mounting Characteristics Width mm Working pressure bars Orifice diameter mm Flow at 6 bars with Ø 4 mm sub-base (page 63) with Ø 6 mm sub-base (page 63) Nl/min Flow Rate with Ø 4 mm sub-base (page 63) kV with Ø 6 mm sub-base (page 63) Operating temperature ° C Switching time for the valve only ms Mechanical life operations Weight g Ø 4 mm Ø 6 mm Ø 6 mm Cabinet 17.5 mm 81 513 060 81 513 065 - 81 516 Electrical 02 2 Supply ports 03 2 Exhaust ports Integral push-in connections Ø 6 mm Degree of protection : IP20 when assembled. A1 - Pilot signal A2 - Common t Earth A1 - Operating control signal (14) A2 - Common A1 - Rest control signal (12) A2 - Common t Earth Dimensions with miniature control valves (page 62) + miniature solenoid valves (page 58) + indicators (page 65) End bases Intermediate base LED indicator 80 Module 3 1 2 1 17,5 3 www.crouzet.com 1 17,5 3 6 5 35 x (n module 17,5 + 1) 35 Ø4 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website 3 4 17,5 12,5 1 77 max. Ø6 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com | | WWW.CROUZET-CONTROL.COM | | 64 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM Valves and solenoids valves assembled | | 65 | | PNEUMATICS PRODUCTS Accessories Contact us for Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive Other versions Part numbers Part numbers Ø 4 ext. Ø 4 ext. Solenoid valve with manual override by impulse 81 513 103 Solenoid valve with manual override by impulse 81 513 203 Symbol Characteristics 3➞8 3 200 Operating pressure bar Orifice diameter mm Flow at sub-base 81 513 060 NL/min 6 bars sub-base 81 517 101 NL/min with sub-base 81 513 060 KV with sub-base 81 517 101 Operating temperature °C Switching time of the assembly ms Mechanical life (operations) at 4 bars Valve position will be maintained in the event of pressure loss and/or electrical current loss Mounting 3➞8 3 200 DIN rail 35 mm DIN rail 35 mm g Weight UL and cUL approval Principle of operation 130 MH15085 130 MH15085 Dimensions - -10 ➞ +50 20 - - - - - - - - - 81 513 064 (by 10) (by 5) Exhaust Plug-in Ø 6 silencer Plug-in Ø 8 Connector for solenoid valve Without manual override Pneumatic With manual override pilots by impulse Push-in connection for semi-rigid tubing Ø 4 mm (NFE 49100) Blanking plate - - - - - - - - - - ● - - - - - - - Instantané Ø 4 ext. - 81 513 052 81 513 055 81 537 001 81 537 201 - 81 516 082 - 81 516 081 - 81 516 091 81 516 085 End bases - one pair Intermediate module Module LED indicator Consumption W Temperature °C Connection mm Mounted between the pilot solenoid valve and the body of the module Supplied in multiples of 5 Supplied in multiples of 10 Packet of 10 pieces g Weight 6 - 0.24 - 10 ➞ +50 - ● ● - - - ● - - ● ● - - - ● 2 - 30 10 1 2 Connection t 80 Poppet valve 3 1 2 1 Pneumatic indicator 17,5 3 1 4 3 17,5 Ø4 3 6 17,5 + 1) 3535 x (n module ● 3 Pilot signal Earth (4) Dimensions 5 17,5 Ø6 End bases not supplied (page 63) Intermediate bases not supplied (page 63) Indicators not supplied (page 65) 12,5 1 Marking tag 5 ● 77 max. 81 537 001 - 81 537 201 81 513 052 - 81 513 055 Mounted by plugging into push-in connector for semirigid tubing (NFE 49100) 81 513 058 - 81 513 059 81 516 082 + 0,1 26 15,5 - 0 35 Electrical signal - Common A2 - Pilot signal A1 - Earth 81 513 058 81 513 059 Characteristics Manual override 4/2 bistable module 81 513 059 LED seal 12 to 24 V - DC - AC Packaging - Plug-in solenoid valve 4/2 monostable module - 1.5 x 107 Common exhaust Pneumatic output - Symbol LED indicator Common air supply - + 0,1 Anti-return valve to prevent back pressures - -10 ➞ +50 20 - 3/2 monostable module (NC) - 15,5 - 0 1.5 x 107 - 2.2 81 513 052 81 513 055 81 513 058 M3 2.2 24 V - 50-60 Hz c 48 V - 50-60 Hz c 110 V - 50-60 Hz c 230 V - 50-60 Hz (-10% +6 %) Visual indicators with anti- surge 15 24 VDC (+10% -15%) 4/2 monostable 29 Voltage 3/2 NC Ø 15 Function Sub-base with push-in connection for semi-rigid tubing (NFE 49100) Version 50 28 15 Pg 7 Ø 14 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com | | WWW.CROUZET-CONTROL.COM | | 66 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM Solenoid valves | | PNEUMATICS PRODUCTS Miniature control valves, 17.5 mm ➜ Electro-pneumatic interface block › Reduced "dimensions" › Mounted on sub-base Complete block, ready to install, consisting of: ■ Preconfigured 8-position sub-base ■ 6 4/2 monostable valve modules with 24 Vc pilot holes ■ 2 blanking plates (for extension if necessary) ■ 1 connection cable Part numbers and voltages Function Mounting Solenoid valves with manual override by impulse | | 67 24 V (+10% -15%) 24 V - 50/60 Hz (+10% -15%) 48V - 50/60 Hz (+10% -15%) 110 V - 50/60 Hz (+10% -15%) 220 - 230 V - 50/60 Hz (+10% -15%) 3/2 NC On sub-base (54) 81 519 732 81 519 774 81 519 775 81 519 776 81 519 777 Part numbers Symbol Part numbers IP 65 Electrical characteristics Supply voltage Courant max. absorbé sur le 24 V de SUBD (mA) Courant absorbé par chaque électrovanne Response time (ms) LED display Protection against voltage surges Electrical connections Type of cable Cable length Pneumatic characteristics Function 1.5 x 107 1 2.5 -5 ➞ +50 70 MH15085 Operating pressure bars Flow at 6 bars NL/mim Mechanical life (operations) Working medium Characteristics Operating pressure bar Orifice diameter mm Flow at 6 bars Nl/min Rotatable coil 4 positions in 90° steps Degree of protection (with connector 81 516 082 not supplied) (see page 65) IEC 529 Mechanical life operations c W Consumption ~ VA Operating temperature °C Weight g UL and cUL approval Principle of operation Connections ● Pneumatic { Electrical { t Earth 1 - Supply 2 - Output Dimensions 81 519 Pneumatic connections Power supply connection Output connections Connection of common exhaust General characteristics Operating temperature range IEC 68214 (oC) Storage temperature IEC 68-2-14 (°C) Protection (IEC/EN 60529) Mounting On separate sub-base 1 - 2 - Pilot signal Weight (g) Comments Other configurations on request Electrical connection by connector 81 516 062 (see page 65) Dimensions (mm) 16 outputs 81513241 81513238 24 Vc ± -10% 500 60 15 Yes (integrated in the sub-base) Yes 24 Vc ± -10% 500 60 15 Yes (integrated in the sub-base) Yes Sub D9 AWG 24 wires 2m Sub D9 AWG 24 wires 2m 6 4/2 monostable valve modules (81513200) + 2 free positions 3 ➞8 b 300 1.5 x 107 Compressed air or inert gas, 50 µm filtered non-lubricated air Whitout 3 ➞8 b 300 1.5 x 107 Compressed aire or inet gaés, 50 µm filtered non-lubricated air Push-in connection Ø 8 mm Push-in connection Ø 6 mm Push-in connection Ø 8 mm Push-in connection Ø 8 mm Push-in connection Ø 6 mm Push-in connection Ø 8 mm -5 ➞ +50 -15 ➞ +50 IP 20 On DIN rail or via two M5 screws (according to mounting plan) 1350 -5 ➞ +50 -15 ➞ +50 IP20 On DIN rail or via two M5 screws (according to mounting plan) Connections 81513241 Connector wiring 1 2 3 4 2 3 4 5 5 88,5 1 88,5 1-2 2→8 2.7 170 16 outputs A 2 A 4 2 2 2 2 2 4 4 2 2 2 2 4 2 2 2 2 4 2 4 4 213213 EV1 EV1 ...... … 2 E 6 E 4 7 8 6 9 93 EV6 EV6 1 1 EV EV 1 Commun 0 V 2 Clips femelle Cl 1 2 1 Gemeinsam 0 V 2 Clips für Schienen Cl 7 8 9 1 1 93 2 960 | | WWW.CROUZET-CONTROL.COM | | 68 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM | | 69 | | PNEUMATICS PRODUCTS Specific islands "for integrators" (supplied in packs of 20) Versions with interfaces 300 NL / mm Configuration 1 - Specify the number and type of interfaces (3 / 2 mono 4 / 2 mono - 4 / 2 bistable) see page 62. 2 - Specify the voltage, the type and method of the control valve connections, see page: 58-59 (Example: 24 V DC with manual switch maintained, exit leads). 3 - Please send us your application specifying your requirements and quantities per year, and we will respond as soon as possible. Versions with interfaces 30 NL / mm Configuration 1 - Specify the voltage, the type and method of the control valve connections, see page: 58-59 (Example: 24 V DC with manual switch maintained, exit leads). 2 - Please send us your application specifying your requirements and quantities per year, and we will respond as soon as possible. Develop customised versions to specifications Crouzet analyses your needs and offers a customised solution. MULTI-FLUID SOLENOID VALVES
81519032 价格&库存
很抱歉,暂时无法提供与“81519032”相匹配的价格&库存,您可以联系我们找货
    • 1+197.90001
    库存:1
    81519032
    • 1+416.43893
    库存:48
