81513516
    CROUZET(高诺斯)
    PNEUM PRESSURE SWTCH 2-8BAR BASE
81513516 数据手册
| | WWW.CROUZET-CONTROL.COM | | 34 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM | | 35 | | PNEUMATICS PRODUCTS Amplifier with intégral régulator, positive output › Setting Flow › Fixing rail 35mm wide PRESSURE SWITCHES VACUUM Part numbers 81 510 001 Positive output Amplifiers with integral regulator Version Symbol Characteristics Pressure to make mb Reduced pressure supplied at port 8 bar Flow through port 8 Nm3/h Consumption of amplifier only NI/h Permissible overload for 1 hour mb Operating temperature °C Mechanical life operations Weight g Detectors (see page 28) Nominal range Min. total consumption for detection (0.5 b regulated pressure) Max. total consumption for short response time (2.5 b regulated pressure) Min. detectable dimensions nominal sensing distance Max. frequency of use 2 Force exerted by the jet on the parts to be detected 0.5 → 1.5 0.5 → 2.5 0.1 → 2.5 100 → 200 300 -5 ➞ +50 3 x 10 6 380 Proximity Ø 12 81 371 401 8 -5 ➞ +50 6 3 x 10 Gap Ø 18 81 372 201 18 NI/h 880 140 NI/h 2750 400 920 mm mm Hz Ø3 2 5 Ø 2 - Ø 1.5 5 Ø 7 - Ø 6.5 5 N 0.02 → 0.7 0.01 → 0.03 0.1 mm -5 ➞ +50 6 3 x 10 Proximity Ø 12 81 372 401 100 - Connection To use with detectors page 32 Principle of operation pilot pressure Dimensions This amplifier is suitable for providing a supply to associated sensors. Push-in connection for semi-rigid tubing Ø 4 mm (NFE 49100) Viewed from B Regulated pressure (bar) Viewed from A Adjustable regulator | | WWW.CROUZET-CONTROL.COM | | 36 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM | | 37 | | PNEUMATICS PRODUCTS Pressure switches - vacuum (electrical output) › Conform to the Low Voltage Directive › Can be used without enclosure according to IEC 664-1 pollution group III Part numbers Pressure and vacuum switches Mounting 81 513 552 DIN rail 81 513 502 DIN rail 81 513 501 DIN rail 81 513 522 DIN rail Actuators Manual override Pressure with­ Pressure without Low pressure without Vacuum without Ø 4 ext. Ø 4 ext. Ø 4 ext. Ø 4 ext. Symbol 81 513 516 Base mounted page 4/14 Pressure without 81 513 510 Base mounted page 4/14 Pressure with 81 513 527 Base mounted page 4/14 Vacuum without Ø 4 ext. - Ø 4 ext. - Ø 4 ext. - IP 54 IP 54 IP 54 81 513 533 81 513 523 2 screws M4 2 screws M4 Pressure without Vacuum without 81 509 080 Base mounted page 4/14 Pressure without 81 509 085 Base mounted page 4/14 Pressure with - - Characteristics Pneumatic Push-in connection for semi-rigid mm connection tubing (NFE 49100) Tapped BSP via connector Protection IEC 529 Permissible fluid: air, inert gases and liquids Adjustment of switching pressure (* adjusted to 0.3) bar Hysteresis at 1 bar bar at 2 bars bar at 4 bars bar at 6 bars bar max. 200 mb max. 250 mb Pressure to break Mechanical life (operations) Contact rating (V resistive) Wire cross-section mm2 Operating temperature °C Weight g Standard electrical contact UL and cUL approval IP 20 - IP 20 - ● ● 2➞8 0.5 0.6 0.8 1 106 5A - 220-230 V 0.75 -10 ➞ +70 48 V4 83 170 4 I W2 MH15213 (R) 2➞8 0.5 0.6 0.8 1 106 5A - 220-230 V 0.75 -10 ➞ +70 46 V4 83 170 4 I W2 MH15213 (R) Operation Pressure operated Vacuum operated IP 20 - IP 20 ● 0.3 ➞ 1.2 * ● 106 5A - 220-230 V 0.75 -10 ➞ +70 46 V4 83 170 4 I W2 MH15213 (R) ● -0.3 ➞ -0.8 ● 106 5A - 220-230 V 0.75 -10 ➞ +70 46 V4 83 170 4 I W2 MH15213 (R) Electrical life (Crouzet microswitch "V4" ref 83 170 4-1-W2) Number of cycles Resistive circuit Inductive circuit Electrical output - common - normally closed contact - normally open contact Adjustment of switching pressure 1 to 8 bars - { L c __ = 5 ms R a cos q = 0.8 Mechanical life 1/8 BSP IP 54 ‑1/8 BSP IP 54 Via sub-base Via sub-base IP 54 IP 54 ● ● ● ● ● ● ● 2➞8 0.5 0.6 0.8 1 106 5A - 220-230 V 0.75 -10 ➞ +70 56 V4 83 170 4 I W2 MH15213 (R) 2➞8 0.5 0.6 0.8 1 106 5A - 220-230 V 0.75 -10 ➞ +70 58 V4 83 170 4 I W2 MH15213 (R) -0.3 ➞ -0.9 - 2➞8 0.5 0.6 0.8 1 106 5A - 220-230 V 0.75 -10 ➞ +70 65 V4 83 170 4 I W2 MH15213 (R) -0.3 ➞ -0.8 - 1.4 ± 0.5 0.6 ± 0.2 106 5A - 220-230 V 1.5 -10 ➞ +70 80 83 133 004 1.4 ± 0.5 0.6 ± 0.2 106 5A - 220-230 V 1.5 -10 ➞ +70 80 83 133 004 Electrical connections 81 513 501 - 81 513 502 81 513 522 - 81 513 552 ● - 106 5A - 220-230 V 0.75 -10 ➞ +70 56 V4 83 170 4 I W2 MH15213 (R) Dimensions 81 513 552 - 81 513 502 81 513 501 - 81 513 522 ● 106 5A - 220-230 V 0.75 -10 ➞ +70 65 V4 83 170 4 I W2 MH15213 (R) Pressure switch with connector 81 513 516 - 81 513 510 81 513 527 81 516 082 81 513 533 81 513 523 1 - Common 4 - NO contact 2 - NC contact 81 513 510 81 513 516 - 81 513 527 Standard microswitch 5 A / 220 V Manual override For M4 screws Marking tag Current in Amps For continuous vacuum applications, please consult us. On request : - Microswitch V4 ref. 83 170 0 i W2 high current - Microswitch V4 ref. 83 170 9 i W2 low current Pilot signal Pilot signal 81 509 080 - 81 509 085 Pneumatic signal Other information length 24 mm 81 513 533 81 513 523 - 81 513 533 Pneumatic indicator | | WWW.CROUZET-CONTROL.COM | | 38 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM | | 39 | | PNEUMATICS PRODUCTS Adjustable pressure switches (manostats) (pneumatic output) Adjustable vacuum switches (vacuostat) › 100 % pneumatic › 100 % pneumatic › For vacuum -0,1 ➞ -0,9 Bar Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive Part numbers (and adjustment ranges) Adjustment range 50 → 500 mb 0.1 → 2.5 b 2 → 8 b Version Accuracy 50 → 500 mb 0.1 → 2.5 b 2 → 8 b Part numbers 81 505 140 81 505 150 81 505 160 Positive output 10 % 4% 4% 81 502 140 81 502 150 81 502 160 Negative output 10 % 4% 4% 81 505 110 Positive output 81 502 110 Negative output 81 508 110 Electrical output - 0.1 ➞ -0.9 170 80 - 0.1 ➞ -0.9 170 80 - 0.1 ➞ -0.9 170 80 Symbol Symbol Characteristics Adjustment range b Flow at 6 bars Nl/min Hysteresis mb Connection - sub-base pages 54/55 Operating temperature °C Mechanical life operations Weight g Connections Characteristics Orifice diameter mm Flow at 4 bars Nl/min Hysteresis 50 → 500 mb 0.1 → 2.5 b 2 → 8 b Connection - sub-base pages 54/55 Operating temperature °C Mechanical life operations Weight g Connections 2.5 170 60 mb 100 mb 320 mb 2.5 170 60 mb 100 mb 320 mb ● ● -5 ➞ +50 3 x 10 6 160 -5 ➞ +50 3 x 10 6 160 ● ● -5 ➞ +50 3 x 10 6 160 -5 ➞ +50 3 x 10 6 160 ● -5 ➞ +50 3 x 10 6 180 Example of use: Vacuum handling (vacuum generator, vacuum pad, vacuostats). Example of pressure threshold adjustment (mini-regulator - manostat) Principle of operation Vacuostats provide an on or off output signal when the input signal reaches a predetermined pressure threshold. Positive output Principle of operation The manostats provide an on or off output signal when the input signal reaches a predetermined pressure threshold. Positive output Output signal Negative output Output signal Output signal Negative output Output signal Pilot Hysteresis Pilot Switching off Hysteresis Switching on Switching on Switching on Switching off Switching off Hysteresis Vacuum Dimensions Dimensions 81 502 140 - 81 502 150 - 81 502 160 81 505 140 - 81 505 150 - 81 505 160 Other information Pressure switches with electrical output on request. ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com Switching off Switching on 81 502 110 - 81 505 110 Hysteresis Vacuum Vacuum 81 508 110 Vacuum | | WWW.CROUZET-CONTROL.COM | | 40 | | PNEUMATICS PRODUCTS | | WWW.CROUZET-CONTROL.COM | | 41 | | PNEUMATICS PRODUCTS Vacuum handling components › Sur le principe du Venturi › Facilement raccordable Also available in ATEX version for use in potentially explosive atmospheres in accordance with 94/9/EC Directive PNEUMATIC LOGIC COMPONENTS Part numbers 81 535 301 Sub-base mounting Vacuum generators 81 545 001 Plug-in 81 545 005 Plug-in Characteristics Push-in connectors for Male/Female/Female (MFF) semi-rigid tubing Female/Female/ (NFE 49100) Female (FFF) Operating pressure bar Vacuum pad material Weight g - - 2→8 80 - Ø 4 mm 2→8 - 13 Ø 6 mm 2→8 - 25 - Detection of the pressure decrease can be achieved by the use of manostats (see pages 38/39) Vacuum (mb) Suction flow Vacuum (mb) Vacuum (mb) Suction flow Vacuum (mb) Suction flow Vacuum (mb) Vacuum (mb) Flow Flow Flow Supply pressure (bar) Dimensions 81 535 301 Supply pressure (bar) Supply pressure (bar) 81 545 001 Sub-base mounting 81 531… and 81 532… Plug-in ferrule for push-in connector Ø 4 mm 24 2 push-in connectors Ø 4 mm 29 11 40 81 545 005 30,7 Ø 4,5 15,5 40 29 ±0,1 11 10,7 3 push-in connectors Ø 6 mm 14,5 ±0,1 ATEX version products are available in the following catologues: Pneumatic products for explosive atmospheres or on our website www.crouzet.com
81513516 价格&库存
很抱歉,暂时无法提供与“81513516”相匹配的价格&库存,您可以联系我们找货
    • 1+1034.11917
    • 4+981.08742
    库存:13
    81513516
    • 1+1174.07451
    • 3+987.77125
    • 6+928.83080
    • 10+829.64640
    库存:10
    81513516
    • 1+732.397971+87.93660
    • 4+693.246404+83.23580
    库存:13
