Page 1 of 2
TOOLS / TEST EQUIPMENT
Panel Volt Meter - 4.5V to 30VDC
PRODUCT ID: 575
Page 2 of 2
DESCRIPTION
Put a voltage meter anywhere with this very handy display. This panel meter simply
connects to whatever DC supply you are trying to track, easy to wire up!
Simply connect the red wire to the positive supply, and black to negative ground.
The display has a microcontroller that will read the voltage, compare it to a stable
reference and display the voltage with 0.1V precision on a 3-digit 0.56" tall
7-segment display. It works from 4.5V up to 30V and is reverse-polarity protected
so it will be good for nearly any electronic project! The meter draws 3-4mA to
power the microcontroller and display. This particular LED display is a nice vivid
green, which we found very readable. To mount to your enclosure, simply cut a
45.5mm × 26.5mm rectangle and snap it in.
http://www.adafruit.com/products/575
7/22/2015
很抱歉,暂时无法提供与“575”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+71.409011+9.24997
