DFR0245-G
DFR0245-G
    DFROBOT
    AMMETER0-50ALEDPANELMOUNT
DFR0245-G 数据手册
      LED Current Meter 50A(SKU:DFR0245) From Robot Wiki      Introduction   LED Current Meter 50A  This is a standard LED Current Meter 50A.The biggest featrue is that the LED Current Meter have reversed connection protection to prevent from being burnted out. It measures 0-50A with 2% accuracy. Best suitable for current display in the circuit.Just apply four wires without any extra circuit or components, it gives the reading straight away. Easy to use, and good company with robot application.It has three color to select, green/red. Warnings: Please carefully follow the instructions for wiring. The power supply terminal and measurement terminal of this LED Current Meter are used common-ground connect. So,the measurement terminal of current meter must be cascaded after load. It's better that power supply of the current meter is isolated. And before using the current meter ,you must be connect the shunt firstly for fear that the current meter is burnted out by high voltage. Specification        Measure Current: 0‐50A DC  Power supply voltage: 4‐30V DC   Display mode: 3‐bit 0.56 Led digital tube  Accuracy:2%  Opening dimension: 45.5mm*26.5mm  Dimension: 48mm*29mm*21mm  weight: 23g(current meter)+60g(shunt)  Connection Diagram Connection Diagram 1:         Connection Diagram 3    Connection Diagram 2:    Connection Diagram 4      LED Current Meter 50A(Green)(SKU:DFR0245-G) LED Current Meter 50A(Red)(SKU:DFR0245-R)       Powered By DFRobot © 2008-2017
DFR0245-G 价格&库存
很抱歉,暂时无法提供与“DFR0245-G”相匹配的价格&库存,您可以联系我们找货
DFR0245-G
    库存:70
