DFR0244-R
DFR0244-R
    DFROBOT
    AMMETER0-9.99ALEDPANELMOUNT
DFR0244-R 数据手册
    LED Current Meter 10A(SKU:DFR0244) From Robot Wiki  LED Current 10A  Introduction  This is a standard LED Current Meter 10A. It measures 0-9.99A with 2% accuracy. Best suitable for current display in the circuit.Just apply four wires without any extra circuit or components, it gives the reading straight away. Easy to use, and good company with robot application.It has three color to select, green/blue/red. Warnings: Please carefully follow the instructions for wiring. The power supply terminal and measurement terminal of this LED Current Meter are used common-ground connection. So,the measurement terminal of current meter must be cascaded after loads. It's better that power supply of the current meter is isolated. Specification         Measure Current: 0‐9.99A DC  Power supply voltage: 4‐30V DC   Display mode: 3‐bit 0.56 Led digital tube  Accuracy:2%  Opening dimension: 45.5mm*26.5mm  Dimension: 48mm*29mm*21mm  weight: 23g    Connection Diagram Connection Diagram 1:   Connection Diagram 1  Connection Diagram 2: Connection Diagram 2    LED Current Meter 10A(Blue)(SKU:DFR0244‐B)  LED Current Meter 10A(Green)(SKU:DFR0244-G) LED Current Meter 10A(Red)(SKU:DFR0244-R)        Powered By DFRobot © 2008-2017
DFR0244-R 价格&库存
很抱歉,暂时无法提供与“DFR0244-R”相匹配的价格&库存,您可以联系我们找货
DFR0244-R
    库存:53
