LED Current Meter 50A(SKU:DFR0245)
From Robot Wiki
Introduction
This is a standard LED Current Meter 50A.The biggest featrue is that the LED Current Meter
have reversed connection protection to prevent from being burnted out. It measures 0-50A with
2% accuracy. Best suitable for current display in the circuit.Just apply four wires without any
extra circuit or components, it gives the reading straight away. Easy to use, and good company
with robot application.It has three color to select, green/red.
Warnings: Please carefully follow the instructions for wiring. The power supply terminal and
measurement terminal of this LED Current Meter are used common-ground connect. So,the
measurement terminal of current meter must be cascaded after load. It's better that power supply
of the current meter is isolated. And before using the current meter ,you must be connect the
shunt firstly for fear that the current meter is burnted out by high voltage.
Specification
Measure Current: 0‐50A DC
Power supply voltage: 4‐30V DC
Display mode: 3‐bit 0.56 Led digital tube
Accuracy:2%
Opening dimension: 45.5mm*26.5mm
Dimension: 48mm*29mm*21mm
weight: 23g(current meter)+60g(shunt)
Connection Diagram
Connection Diagram 1:
Connection Diagram 3
Connection Diagram 2:
Connection Diagram 4
LED Current Meter 50A(Green)(SKU:DFR0245-G)
LED Current Meter 50A(Red)(SKU:DFR0245-R)
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0245-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+64.805641+8.42453
