460
460
    ADAFRUIT
    RND STANDOFF 8-32 PHENOLIC 1/4"
460 数据手册
Page 1 of 2 TOOLS / TEST EQUIPMENT Mini 2-wire Volt Meter (3.2 - 30 VDC) PRODUCT ID: 460 Page 2 of 2 DESCRIPTION - Put a voltage meter anywhere with this very handy display. These are often used by RC hobbyists for keeping track of batteries but we thought it would be great on a breadboard or enclosure. This is the 2-wire version of the volt meter, two wires are used to power it and measure at the same time. We also have a 3-wire version that measure a wider range of voltages. Simply connect the red wire to the positive supply, and black to negative ground. The display has a microcontroller that will read the voltage, compare it to a stable reference and display the voltage with 0.1V precision on a 3-digit 7-segment display. It works from 3.2V up to 30V so it will be good for nearly any electronic project! The meter draws 3-4mA to power the microcontroller and display. This particular LED display is a nice vivid green, which we found very readable. Mounting tabs make this module easy to attach to any box or plate. http://www.adafruit.com/products/460 7/21/2015
很抱歉,暂时无法提供与“460”相匹配的价格&库存,您可以联系我们找货
