DK197P
DK197P
    C-TON
    PROCESS METER/VOLTMETER 0-10VDC
DK197P 数据手册
Voltage Powered LCD Digital Panel Meters Adjustable Voltage 3½ Digit EPIC SERIES DK190V Series Features: ◊ Optional window mount ◊ 3½ digits with high-contrast LCD ◊ 12V or 24V DC Voltage powered ◊ User selectable, displayed engineering units Ordering Information: Specifications: Display: Backlighting: Digits: Type: 3 ½ digits (±19999 counts) 0.45" (11.4 mm) 7 segment LCD Optional Red Negative (red numbers/black background) Optional Green Negative (green numbers/black background) Optional Amber Negative (amber numbers/black background) Optional Green Positive (black numbers/green background) Inputs: Performance: Environment: Power Supply: Mounting: Connection: Polarity: Annuciators: Decimal Points: Overrange: Ranges: Configuration: Impedence: Accuracy: Conversion Rate: Normal Mode Rejection: Adjustments: Warmup: Temperature Coefficient: Offset Range: Gain Range: Operating Range: Storage Range: Optional Backlight: automatic, “-” displayed °F, °C, PSI, %, user selectable, or V, A, KW, PF 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 0-10 VDC, 0-5 VDC or 0-200 mV DC single ended 390 KΩ min. ±(0.1% fs + 2 count) 3 per second >30 dB @ 60 Hz span (gain) (2) (10V and 5V) and zero (offset) 10 minutes typical ± 100 ppm per °C typical -1999 to +1999 1-2000 counts above adjusted zero 0 to 50 °C -10 to 60 °C 12 VDC or 24 VDC regulated (selectable) 24 VDC at 35 mA typical snap-in bezel mount 4 screw terminal (6 with backlight) PART NUMBER BACKLIGHT COLOR BACKLIGHT POWER SNAP-IN: DK196*......................................... NEG AMBER................................................. 24 VDC DK197*......................................... NEG GREEN................................................. 24 VDC DK198*......................................... NEG RED...................................................... 24 VDC DK199*......................................... NO BACKLIGHT...............................................NONE DK200*......................................... POS GREEN...................................................24VDC *Add (P) for Power Engineering Units V, A, KW, PF PW2-12....................................................Regulated 120V AC to 12V DC Power Supply PW2-24....................................................Regulated 120V AC to 24V DC Power Supply PW1.0........................................................................... 24V AC to adjustable DC output CPW1.5........................................................................ 24V AC to adjustable DC output CVC.................................................................................................................. Calibrator C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com Voltage Powered LCD Digital Panel Meters Adjustable Voltage 3½ Digit DK190V Series EPIC SERIES Dimensions Wiring C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com
DK197P 价格&库存
很抱歉,暂时无法提供与“DK197P”相匹配的价格&库存,您可以联系我们找货
