576
576
    ADAFRUIT
    CONN RCA JACK MONO 3.2MM PNL MT
576 数据手册
Page 1 of 2 SENSORS / TEMPERATURE Panel Temperature Meter / -30 to +70 °C PRODUCT ID: 576 Page 2 of 2 DESCRIPTION - Put a temperature meter anywhere with this very handy display. This panel meter displays the temperature of the attached waterproof 1% thermistor in °C. It does require a DC voltage to run, at 4.5-30VDC. It has reverse polarity protection in case you swap the power leads by accident. To use, simply connect the thin red wire to a positive supply, and the thin black wire to ground. Then tape the black thermistor bulb to whatever you want to measure - or leave it loose to measure ambient temperature. The display has a microcontroller that will read thermistor resistance and display the corresponding temperature from -30°C to 70°C with 1 °C precision on a 3-digit 0.56" tall 7-segment display. The meter draws 3-4mA to power the microcontroller and display. This particular LED display is a nice vivid blue, which we found very readable. To mount to your enclosure, simply cut a 45.5mm × 26.5mm rectangle and snap it in. This meter can only display the temperature in Centigrade °C, it cannot be modified to °F and we do not have a version that is °F. http://www.adafruit.com/products/576 7/22/2015
576
物料型号:576 器件简介:这是一个非常实用的面板温度计,可以显示连接的防水热敏电阻的温度,温度范围为-30°C至70°C。
引脚分配:红色细线连接正电源,黑色细线连接地线。
参数特性:需要4.5-30VDC的直流电压运行,具有反极性保护,以防止电源线接反。
功能详解:通过连接热敏电阻,可以测量物体或环境的温度,温度计使用微控制器读取热敏电阻的阻值,并在3位数字的0.56英寸高的7段LED显示器上显示相应的温度,精度为1°C。
应用信息:可以用于测量物体或环境的温度,例如用于监测设备或环境的温度。
封装信息:面板尺寸为45.5mm x 26.5mm,可以切割相应尺寸的孔并将其安装到外壳中。
以上信息摘自PDF文档,提供了该温度计的详细规格和使用说明。
很抱歉,暂时无法提供与“576”相匹配的价格&库存,您可以联系我们找货
