DK191P
DK191P
    C-TON
    PROCESS METER 4-20MA LCD PNL MT
DK191P 数据手册
Loop Powered LCD Digital Panel Meters 3½ Digit LCD with Loop Power Board EPIC SERIES DK191 Series Features: ◊ Low-cost, high-performance replacement for many OEM DPMs ◊ 3½ digits with high-contrast LCD ◊ Optional RED, GREEN or AMBER backlighting ◊ 4-20 mA loop powered input ◊ Snap-in bezel mount eliminates mounting hardware ◊ User selectable, displayed engineering units ◊ Resistant to RF and EMI Ordering Information: Specifications: Display: Backlighting: Inputs: Performance: Environment: Power Supply: Mounting: Connection: Digits: Type: Polarity: Annuciators: Decimal Points: Overrange: Ranges: Configuration: Impedance: Accuracy: Conversion Rate: Normal Mode Rejection: Common Mode Range: Common Mode Rej.: Adjustments: Warmup: Temperature Coefficient: Operating Range: Storage Range: Optional Backlight: 3 ½ digits (±1999 counts) 0.45" (11.4 mm) 7 segment LCD Optional Red Negative (red numbers/black background) Optional Green Negative (green numbers/black background) Optional Amber Negative (amber numbers/black background) Optional Green Positve (black numbers/green background) automatic, “-” displayed °F, °C, PSI, % , user selectable, or V, A, KW, PF 3 position, user selectable three lower order digits blank for inputs >1999 & < -1999 4-20 mA  DC bipolar differential 300Ω nominal ±(0.1% fs + 2 count) 3 per second >30 db @ 60 Hz ±1 VDC max >86 dB span (gain) and zero (offset) 10 minutes typical ± 100 ppm per °C typical 0 to 50 °C -20 to 70 °C powered by the milliamp control loop 24 VDC at 35 mA typical snap-in bezel mount 2 screw terminal (4 with backlight) PART NUMBER BACKLIGHT COLOR BACKLIGHT POWER DK191*......................................... NO BACKLIGHT.............................................. NONE DK192*......................................... NEG AMBER.................................................. 24VDC DK193*......................................... NEG GREEN.................................................. 24VDC DK194*......................................... NEG RED....................................................... 24VDC DK195*......................................... POS GREEN.................................................. 24VDC *Add (P) for Power Engineering Units V, A, KW, PF PW2-24....................................................Regulated 120V AC to 24V DC Power Supply PW1.0............................................................ 24V AC to adjustable DC output CPW1.5......................................................... 24V AC to adjustable DC output CVC...................................................................................................Calibrator C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com Loop Powered LCD Digital Panel Meters 3½ Digit LCD with Loop Power Board DK191 Series EPIC SERIES Dimensions Jumper Selection & Wiring 1. DECIMAL SELECTION: 1999 199.9 19.99 1.999 J7 J6 J5 J4 2. J1, J2, J3 SELECTION: IF: OFFSET (ZERO) IS 0 or OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO)≥ 5 J3 J2 J1 A B IF: OFFSET (ZERO) > 0 and GAIN (SPAN) ÷ OFFSET (ZERO) < 5 A B J3 J2 J1 C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 • email: info@ctonindustries.com
DK191P 价格&库存
很抱歉,暂时无法提供与“DK191P”相匹配的价格&库存,您可以联系我们找货
